- Thanks Madman!
- VFN Extended Hoods- Firebird & Camaro
- Suit Requirement - 3.2A/5?
- New Tires = Wheel hop (Vid inside)
- Which 10pt Cage for keeping useable T-tops?
- Moroso Oil Pan (21150)
- What stall for TH400 equiped 05 GTO
- Who can Certify my cage in Michigan, (NHRA)
- how to lower my 60ft's
- Ride hight/ To much rake with 28's for weight transfer? Vids in HD
- Question on new rear axle
- Found the limits of a stock 9 inch third member...
- pulls to left in wheel stand.........
- first time at track
- Car wont transfer wieght. How much weight needs to come off the nose?
- 26x10x15 stiff or 28x10.5x15 stiff for my setup???
- Effects of gearing vs. speed
- WTF - Engine Stayed at 2000 rpm after burnout?
- Im cert to 8.50, whats next?
- Greg Weld Bigs and Littles are ON!!
- 1998 SS Drag car or stock?
- Rear Mounted Transmission Cooler-Pics
- True Duals Mufflers Dumped Off Headers Or Y Pipe With Bullet
- Need some help
- Worth switching from 10.5 to 10.5W?
- Going rate for a 6 point chromoly roll bar & mini-tub install LS1 F-body?
- ETP C5R or ALL PRO LSW
- IPhone Owners: Drag Related - DA Calc
- 4.11 and 4000 converter guys
- Best way to launch my A4
- Check my graph, where should I shift?
- Champion Drag wheels
- Heat Shield on Brake Lines
- Torque Arm and Driveshaft Alignment??
- Got the Turbo and the A2W IC mounted
- drag bar question
- HELP With new setup
- BMR Rear Drag Sway Bar
- On fatory motor mounts does it matter which side of the clam shell is up
- Reaction time
- 4th gear nitrous
- 10bolt and A4 question
- high mileage owners.
- Anyone running sissy sticks with BMR xtreme duty anti roll bar?
- My new 10.5 Street/Strip car showed up today, Like it? PICTS!!!
- Modifying the stock steering shaft
- Am I going to need rim screws?
- Car wont hook without weight in the rear well...need some advice
- little help with crunching #
- Found out the difference between 275/60/15 and 275/50/15
- How to get my 60ft down on street tires?
- Hood flew off, crazy things at the strip . . .
- battery relocators come in!!!
- Another manual steering question for looped lines
- Heading to the track tonight!
- A4 guys with the MS3 cam
- Need some help....Commerce GA area.
- Air Bag Sensor Under The Console. How Do You Take It Out
- gamblers races?
- Loosing HpTuner Communication When Launching
- Afco Front shocks and springs?
- fastest stock displacment ls based car?
- tire height calulations
- push button ignition
- Rear shock setting... Comp Engineering users come in!
- Brace above the PHB
- Setting up the Moser M9 torque arm and more!
- Anyone running M/T wheels with Aerospace brakes?
- Biondo Line Lock, Seeping...
- "Set" Spohn drag bar, car really stiff...
- 2800 vs 3600 stall upgrade
- front limiters increase 60'?
- What tires to run on 15x3.5 front rims
- running C/SA "cheap"
- ???k-member???
- extended deck lid?
- Some PSI tuned cars on the dyno and at the track
- Sooo close! what can i do?
- 02 Ss Suspension Help
- Track on Wed
- Strange Two Way Adjustable Shocks Clearance!!!!
- carbed ls1's
- Guess my cam only times?
- RevXtreme team in the K&N filters add
- Moroso update 9-14-08
- Bolton camaro running 7.1x's in the 1/8th, need more...
- Wing for 4th gen firebird
- When is it time to get a vacume pump?
- passengerside airbag and bracket help please
- Cutting out the rear bucket seats.... anyone?
- C14 race fuel w/CATS
- turbo lt1 not so good at track need more oil
- Check this out.....
- Dash bars
- triangulated 4link good for 8 seconds?
- 17" MT ET Streets or 16" MT Slicks??
- Nine bar info needed please-Experts only, no guessing
- stock 2.73 vs 9" 4.11
- Any rear bumper cover sag????
- chassis differences 93-97 and 98-02
- 275/60/15 ET street radial
- Removing The Bumper Supports From A Ta
- 1.35 60ft on radials and stock shocks and springs
- i need help on dropping my 1/4 time
- IT'S ALIVE!!!! almost
- Front spring questions w/ QA1's & BBC
- Trans brake wiring and placement
- Question about drag racing and intakes
- Where would you shift using this graph?
- Rollcage questions (Post up pics of 10 pt cages)
- Anyone running a hood scoop besides a cowl or SS style on a Camaro?
- Wolfe low slung door bars
- DR newbie...have dumb question
- Terrible Times!
- Need launch help= M6 TA
- Why can't anything go easy? What is this? Broke fuel line?
- Batt Relocation
- rollbar removal
- gears,tires,mph?please help
- Thanks Madman, your parts are incredible....
- What is the blk box under the drivers side trap door.
- Possibly building a drag strip...I need advice.
- Everyones Favorite Gauges
- What generator.....
- Cleaning your rear quarters after track day?
- Are these race gloves NHRA legal
- Weight reduction questions
- Drag radial vs Drag slick? could a drag slick slow you down?
- what belt size to eliminate just power steering. ls1 m6 t/a
- 108 mph in the 1/8, what ET?
- using the spare tires for skinnies ?
- Do any of you guys have pics on where you moved your fuse boxes
- question on setting up pinion/yoke on a 9''
- Mounting big Turbos
- Removed front bumper support...
- carberated E85 drag car????
- So in my garage I have...
- LS1 in a Dragster, Need more power.
- Race fuel ratio
- Difference between K&N filter versus Stock Filter...take a guess
- Do you need the window net if running slow???
- et 90degrees vs 60degrees
- VHT + Drag Radials?
- car won't hook... help
- needing 15X8 wheel info!!!! HELP
- Updates From Madman
- Front End Travel Limiters problem
- ET Streets: DR's or Slicks
- QA1 R front shock/spring assembly???
- anyone have any Pinks All Out tips????
- How deep into the 11s you think I can go?
- Weld Alumastar front runner?
- Time to start modding...
- borrowed a wideband and holy shit...
- What rear springs are these?
- Dirt track tires??
- 5 point harness
- What heads to run on a 383 solid roller???
- Strange shock help needed!
- New setup= can't hook
- Weight questions
- Bolt on hood to pin on questions
- What's the best drag radial for a 18X9.5 rim?
- Fire Suits
- wanted suspension mods
- How to set rear sway bar?
- Common Knock retard Causes???
- Racing battery...
- For Madman Customers...
- 2 step?
- narrowed 9 inch?
- Best way to cut 60ft while sparring the 10-bolt
- HELP & ADVICE Wanted
- Who has the lowest 60" on a 255-50-16 ET Street Radial? How low can you go?
- Consistant 60fts.
- new 18x12 335/30/18 all narrowed and in
- Best bang for the buck suspension mod?
- Richmond street shootout
- Anyone gutting out a body wiring harness?
- Burkhart Chassis save the shipping sale
- Noob Question...
- What is it, what does it do, can it be removed???
- Summertime boredom, how about some new wheels :)
- Coolant Overflow, Kirkey, and Momo Wheel Installed
- Anyone running 9's or better with MT drag radials Naturally Aspirated??
- new 402
- intake weight
- Narrowed 9" questions
- Flaming river wiring question
- People that plan to order from Madman! PLEASE READ!
- ???what Is The Dash Brace???
- Aluminum wings?
- Which Gears??
- M.T. 275/50R15's in STOCK - 1 pair!!!!
- help me with wheel hop!!!!!
- ???WEIGHT REDUCT...DASH REMOVAL???'s
- Out of everything that could have broke
- Kirkey seat mounting question
- Lowering 60' checklist
- tcs delete
- dash removal
- Hoosier 28.0/10.0-16 or M&H 26/12.0-16, which one would hook better?
- M/T Drag Radials
- How much can a tight converter effect your times?
- What Steering Wheel & Install Kit
- Best way to go on dual rear caliper
- What do you stalled a4 guys run??
- rear springs
- In car camera guys.. where do you mount it?
- 255/50/16 vs 315/35/17 for TRACTION?
- 17" dr question
- ???a/c Delete Panel???
- ???abs,tcs Delete???
- Aerospace Brake ???
- New Setup......
- Rear suspension for 8's??
- how much faster?
- have a question
- Covertor advice..
- Are DR's considered slicks at the track?
- Anyone run their tranny cooler out back?
- Spohn DS loop rubbing exhaust
- 28in tires whats the best?
- Big nitrous MT DR car.... single adj shocks or DA????
- need some help
- Anybody running 315 60 15 MT dr's with a stock length rear and 7.50" BS?
- where to get a bigger sized race jacket and pants?
- Got my Burkhart Chassis torque arm
- rev limiter for launching
- Bump stops and launching an M6
- Thanks Madman/Steve! You Rock!
- Kirkey Pro Drags does this look safe???
- Times to expect
- how are you procharger guys
- 6 point roll bar and 5 point harness
- Racecraft 1pc Dzus Rails
- Newly rebuilt Strange aluminum stud mount struts
- 4l60e Tuning for Drag Racing
- auto tranny question
- 16" or 17" DR's?
- Help with 60'(Shock settings, tire pressure..)
- tallest bias ply with out mini tubbing
- good god...has anyone noticed the price increase on high end drag wheels?
- HVAC Delete, but still with heat
- MS3 cam Only Predictions
- First time at the track, results, Q's, and vid
- what would happen
- Is it likely to get into 11's with bolt on's?
- Need: Strange Rear Brakes (Drag): Do They Make These?
