- What is the N/A M6 record to date?
- Whats the time for me to beat
- Need advice..2000 xtreme vs. Civic Si ?
- 60' formula?
- Dash Removal / Airbag Removal
- Lightweight SS hood, stock appearing. I'm still looking.
- Wolfe 6 point bolt-in
- Member of the 10 doh! club :)
- 13's @ LACR Almost stock?? Elevation: 2700 FT
- Chris@Diamond is now Chris@AP-Engineering
- Cam or Big stall TC (help)
- New best 1/8 at Irwindale!!
- M&H Racemaster Drag Radial?
- 2 step settings
- Baton Rouge Area
- Guys running 105mph in the 1/8th
- Burnout question
- Gt-r Vs 300zx
- 1/4 mile guesses with new parts?
- San Diego Track(s)
- Drag tubes?
- Big Money at Spring Break Shootout!
- What are the lightest Drag Wheels?
- Clash of the Titan Shootout, Sponsored by Cartek
- Went to track with new Patriot 6.0 Liter 59CC Heads
- Bandit 1/8 Mile Times with Patriot Heads & New Mods
- What could I expect from these things?
- 30 more rwhp = how much more mph 1/4??
- Stock internal list?
- LS1TECH Series Sponsors & Contingency
- more 12's for me!!!
- what size rims.
- Limped car home 200 miles on 7 cylinders!!!
- New best today (stock internal)
- V6 springs?
- NEW BEST 10.60 @ 126 N/A!! Thunder Racing H/C 346ci LS1
- 26 or 28 ET Drag
- Wiring 2 step
- New Best in 100% Stock Z06 11.783@116.90
- G5X3 - New best 10.747 @ 124.96
- New cam only best!!
- New Stock Internals Best
- Removing front tag on TA to make a ram air set up? Any1 did it?
- Oil temp gauge
- 2 Questions after I removed the Air, Heat, and Airbags?
- Can you guys post some pics of your wheels
- cam only times...
- How do you guys do it?
- Whats the fastest all ls1-ls6 setup?
- Nitto 555r 305/35/18 Drag Radials
- Anyone run drag radials on Convo pros?
- With mysetup, what average best should I see? Probably asked alot by others hehe
- How to get screwed...
- fastest with stock clutch
- ET Database?
- How does the Harlan Two Step work?
- PICS!!!442 ci C5R,,gen7 DFI
- ET question for m6 stock internal guys
- ET street radial info
- How my hp and what kind of times should we get ?!?!
- How to race an A4 w/ 3600 stall form a roll?
- TR224(stock heads), what times
- It's been asked 1,000,000 times.
- someone please post pics of home depot carpet
- A possible c5r entry for ls1tech series
- Went out to LACR for Hangover on the 1st
- 1st 2004 Race Report
- Negative impact if bar above pan hard rod is removed?
- 1.30 60ft but...
- After Market Steering Wheel with Buttons?
- Possilbe 15,000 LS1 Race May 2004
- 11.99 Set-up? Will This Work?
- No Heat!!!
- Looking for pics of fuel cell and rear firewall install
- drag racing newbie
- bellhousing/blanket for t56
- LAST CALL 5 point legal to 10.0?
- C4 Ls1 Swap, wheelie picture
- Those who have !ABS--->
- Does NEBody Race @ Woodburn Dragstrip or Portland Int. Raceway??
- Stolen wheelstand pic on ebay?
- 339rwhp and 1/4 time
- How much does tire/wheel size affect dyno #s?
- Stock hood weight?
- CSI supershield vs Hughes flexplate shield and RCI Trans blanket - thoughts?
- 6.78///@100.2 in the 1/8 N/A
- Harlans car
- What is the fastest mph in the 1/4 for a A4, 346 C.I., H/C Post up?
- Will a 325-50-15 DR fit our cars?
- My 2004 Racing season starts this weekend!
- The ET thing is down.. Big Engine cars what are your times?
- 85 mph 1/8th...doesn't make sense
- Narrowing rear for zero offset wheels?
- Aluminum Guage Panel>
- M6 Cam only/stock 10bolt/DR's Who's the quickest?
- tci 3500 to much for 16in drag radials
- 8.5@91(1/8),What is wrong with this?
- what times should i get??
- noticed these LS1 cars on hot rod gossip
- A video of the Kerminator at Atco
- Weather and its effects???
- John Lingenfelter dead at age 58
- Drag tires
- MPH so low????
- 1.42 60ft on back tires (my wheelstand video)
- Spring choices with Qa1 R's
- Fastest cam only full wieght car?
- How many ppl with race cars and no air filter?
- The guys on a RX-7 forum don't believe in the Z06
- 12 bolt + 200 shot = BOOM, pics inside.
- Storing ET Streets
- 3400LB race weight with iron motor
- The best torque arm set up?
- Check it out!!!!
- Anyone try these dash's yet?
- New! LS1 Racing videos
- Spring Break Shootout Info
- New best, Barely 10.75 at 125.73
- Anyone using the Jegs Torque Arm?
- could i cut low low 10's? setup inside
- Tweaked II
- 11.07@122.2 New Best NA
- Sound Deadening Removal
- Bolt circle for Pro stars??
- mph and track times
- 11.324@117.19 Stock Internals NA
- ABS delete
- Those with Jazz Racing Seats
- Update on Mickey Thompson drag radials?
- The Wife Goes 11.13 @ 115.71
- ? about !bumper reinforcements
- Rubber Removal Cleaner
- ****I Drove A Total Of About 700 Miles Round Trip, Ran A New Best And Drove Home****
- new best 1/4 mile so far.
- Mid 9s NA, how would YOU get there???
- Guys who go 10's....or should...take a look
- Best All Around Rear Drag Race Only Shocks And Springs????
- why not get rid of torque arm for better 60s.
- You guys drag racing using a Zo6 clutch?
- X1 vs TR230 for ets.
- CLASH OF THE TITANS "TUNER SHOOTOUT"
- Bart Racing wheels...
- Tire and Gear Size Question
- New Drag Shocks>>>
- FLP's very own Dan Bills goes 7.51 @185 mph in his Mustang...
- ET Streets or QTP
- full drag suspention guys in here
- My day at carlsbad.
- New QA1 "R" shocks vs. older version
- Gimme your stock times
- Gauge recommendations
- What would a 408ci run in the 1/4 on 17inch DR's?
- Promising results/information about new M/T drag radials....
- God was with me today...
- LS1Tech Super Stroker or Top Gun Engine Combination For Sale
- 7.1 in 1/8 with just cam and stall???
- Need advice on suspension setup
- LS1 Turbo 400 with transbrake (Need Help)
- How did your racing season go?
- two step for transbrake
- Winter storage of ET's
- OK, what should my next mod be?
- Grand opening of Outlaw Pontiac Drag Series.com
- pics of mounted and unmounted 17" ET Streets
- driveshaft loop for cars with duals?
- What is a "Two-step" used for?
- New HAL 90/10 "R" Series shock's...
- C5 Flexplate? TQ tube upgrades?
- Helmets...
- Time for new slicks: 26" Hoosiers vs. 27.3" ET Drags
- Eagle Crank GMPP Single Plane Intake
- when's the last issue come out???
- Lost a full second off my time
- just finished cam swap
- do I need larger injectors
- 724 RWHP, 8.99 @ 154, STOCK INTERNALS w/ POWER ADDER
- TR224 w 4.10s
- setting up pinion angle???
- Will 26x10.5x15 ET Streets hook?
- Need some opinions on a temp racing seat.
- halfway through cam change
- BIG MIKE, I'm knocking on your back door soon!!!!
- DA of 3800
- TR224 and Similar Cams: What Times?
- New Best Stock Internal
- Another new best!! Stock cubic inch Camaro SS 10.68 @ 124 MPH !!
- 9 sec 6 speed guys: what clutch???
- EastSide's Silver Bullit on its way to Texas
- ARE Rocks 10.761 at 125.64
- MMT H/C C5 A4 goes 10.73 @ 125.95
- Finally 11's
- 6 spd guys. Please share your launching techniques.
- Anyone Weighed Their Full Power TA Seats?
- Stealth II goes 11.20 and 121.47 MPH...
- imputs on my times pleeeaase!
- 15" vs. 16" Wheel
- 26" or 28" et streets?
- Moser 12mm wheel studs?
- new cam
- Why aren't there any low 7,high 6 second ls1's out there?
- 6spd drag racers inside please
- Anyone have info on the SSR
- Has anyone got into the 10s in a NA daily driver on Drag radials?
- Air filter at track?
- Quickest 383, N/A, M-6
- How many passes a year do you make at the track?
- C5, H & C, Stock CID, 10.77 @ 125 all motor
- Weight of BMR Boxed SFC?
- Any CAM ONLY cars in the 11's with stock weight?
- Roll Cage ruling for NHRA
- Best place to order ET Streets from?
- Where would a TNT 150 wet shot put me?
- How much can the DA effect ET/MPH?
- TRYING to join the 11 sec bolt on club...
- Cartek Stage 3X runs 10.58 @ 130.6 mph First time out.
- new times in 1/8th
- Who had narrowed their rear?
- Petition to complete the Nashville Motor Speedway Drag Strip (Nashville, TN)
- 50/50 rear shocks....HELP
- Need help picking some ET Streets please
- Whos camaro was that at the Citrius National's @ Moroso?
- The Hot Rod goes 6.99 @ 96.73 MPH in 1/8 mile
- New best @ NHRA Citris Nationals 10.79 ET 346ci LS1 N/A! GO THUNDER RACING! WOOT!!
- Passenger airbag removal help
- Harness & Fire Jacket
- people with a 3400lbs raceweight?
- Another new best today
- Here is a Bad Azz 4th Gen
- New stockhead Na Lt1 best!!!
- Launching & LCA & Gear Questions
- Update on KCM 402 motor - 9.77
- My pics from Thunder 03
- Help with right gear ratio.....
- New best 60ft. and ET,cam only
- Chrome Moly or Mild Steel Roll Bar?
- Race sway bar, Spohn or BMR?
- PICS of weight reduction in progress
- Air Bag Question?
- What E/T do you have run to.....
- Weld one piece rim
- MMT M2 Cam takes cam only Record....
- New best stock internal
- new track times w/ ls6 cam and dynotune:
- What will I run with my setup....
- People with gears in here please
- New best...
- Anyone gone 250 miles on ET streets?
- looking for in-car videos of the M6/6-speed cars at the track?
- 1st time to track with new setup...10.9@124
