View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
  1. Dyno #s from bolt-on A4 2001 SS
  2. Dyno Numbers
  3. Dynoed today
  4. 233/239
  5. Novi 2000@ 11 psi
  6. dynoed my car this weekend
  7. Dyno Jet with horsepower rider?
  8. 439 rwhp N/A stock heads
  9. LG Motorsports 346 VS 402 same H/C, its all in the stroke
  10. 2000 Formula dyno results
  11. C5 dynoed again with just a home made cold air
  12. How to tune on a load-bearing dyno?
  13. TR227/224 and FAST Comparison
  14. 600rwhp all motor th400
  15. New 408 dyno numbers in!
  16. discussion topic: will the rims weight affect the dyno numbers ?
  17. Carb Dyno Tuning?
  18. My first Dyno! TTP NJ Rocks
  19. 2007 Procharged C6 A6
  20. 513rwhp 510lbsft 416ci
  21. LG Motorsports 402 + Vengeance Ported 92mm FAST = 507 rwhp 500 rwtq first pull !!!
  22. Dynoed for the first time today!!! (vid)
  23. Dynoed the Formula for the first time.
  24. 402 & aps tt z06 after methanol
  25. How do you lock a 4l60E in 3rd on the dyno?
  26. New numbers
  27. 370 w/ D1SC @ 11psi
  28. SAE Cam only #'s
  29. dynoed my car yesterday
  30. TR 224 Results / video and graph
  31. RWHP on 2007 Mustang GT300
  32. Ragin Racin C6 05 LS2 Stage 3 results and video
  33. mild 402, M6, F-body
  34. new shop = different results (baltimore to delaware)
  35. MS4 graph inside
  36. MY bone stock C5 dyno(good numbers?)
  37. Dyno sheet from work done at Rapid Motorsports over the summer
  38. Va Speed 402
  39. 09 Stock CTS-V Dyno Video
  40. SlowT1 dyno results
  41. 03 SVT Cobra Dyno
  42. 2000 SS dyno results....
  43. 340/345
  44. dyno results!!!
  45. 6.0+vindicator=441hp
  46. New numbers after H/C swap
  47. 299HP/319Torq
  48. 832rwhp...
  49. Cam only with ported FAST 92
  50. New dyno numbers
  51. LQ4 with stock 243 horsepower?
  52. Stock WS6 dyno numbers
  53. 09 CTS V Dyno
  54. swapped cams and added FAST 78
  55. Air Lid vs. Full Cold Air System
  56. Any back to back testing on Eldebrock to other 1 7/8" headers
  57. Tr224 numbers
  58. The great header debate continued. 1 3/4 vs 1 7/8
  59. Ls1 240sx with a t-rex cam 390whp 360wtq
  60. Another C6 with LG G6X-3 CAM
  61. 224/224 Cam in 06 A6 Vette with Video
  62. HKE pump gas 445ci with TFS 235s lays down 574/482
  63. G-Force cam only results
  64. first dyno experience
  65. 2001 z06 dyno results
  66. 347 & d1sc @11 psi
  67. Disappointing dyno results
  68. First Dyno - look okay?
  69. First time at dyno whacha think?
  70. ASA cam 226/236, .525"/.525", 110LSA dyno results
  71. what do you think? 346 h/c 441RWHP 412ftlbs
  72. First time on the dyno.
  73. Discussion of test results for a new product
  74. 417 rwhp/425 rwtq N/A LS1 with stock cam!
  75. Cam only Dyno'd tonight
  76. 408 w/ vic jr. dyno #'s after T/B change!
  77. got my sheet
  78. My 408 Dyno #'s! Help!!
  79. Did my 3rd dyno today..
  80. trex dyno graphs
  81. Kind of an odd question regarding altitude horsepower
  82. dyno numbers are in
  83. TFS 220 As Cast Vs Dart 205 Head Swap .... Comparison Results Inside
  84. Good Numbers For MS3
  85. 2006 c6 & lg g6x-3 cam
  86. Part bolt-ons & cam!
  87. Vengeance Tuned InconTT
  88. Cam only 2007 Z06! Video!
  89. How's this for some D1SC numbers?
  90. dyno #2
  91. 402, M6 F body, (results will be posted wed evening Dec 3)
  92. How much power are you other MS4 guys making?
  93. 1st Dyno run
  94. a big newbie question
  95. Low 408 results?
  96. Fast 92mm intake change
  97. 500 RWTQ on LS2 with 243 casting????
  98. C6 & LPE CAM results
  99. Loss of rwhp thru Borla Plate Exhaust System?
  100. 2000 Corvette 347-Procharger F1R
  101. Thunderracing TRAK cam % Patriot LS6 64 CC
  102. 402 & APS TT in Kuwait results inside !!
  103. Car Got Dyno'd Today
  104. RWHP/TQ vs. BHP/TQ
  105. Here are all my dyno results
  106. running engine on test stand
  107. forged 383 hp guess?
  108. dyno run before cam
  109. Can dyno #'s be altered
  110. 811/785 402 sprayed
  111. FMS F14 with Patriot Stage II 243's
  112. ? for Joey@Tick Perf.
  113. 408, Pat G cam, AFR 225s, FAST90, Th350, 9''
  114. LME 402 with AFR 205's
  115. Any big turbo guys go any before and after fast 90/90 or 92/92 dynos.
  116. TEA As Cast Vs DART Cylinder Heads- Dyno Results Inside!!!!
  117. Got a great tune!!!
  118. 600rwhp/523rwtq LS7 Vette
  119. Kaltech Tuning and Performance Z06 Killer Package for the LS3..
  120. are my numbers low?
  121. Official hp output thread
  122. 2009 Z06 with Ragin Racin-Stage5
  123. Looking for cam X vs cam Y results
  124. Procharged 2006 LS7 Z06!
  125. G-Force Procharged SS 735 RWHP
  126. Avg. HP loss through Drivetrain?
  127. Should my power fall off this soon?
  128. stock lq9 dyno numbers!!!!!!!!!!
  129. Fir dyno
  130. can you dyno tune a car in the winter?
  131. RR-LETHAL CAM with NANO Nitrous
  132. retuned polluter results
  133. How A-Typical is this STOCK number?
  134. 408 - ported L92 heads -236/248 RPM L92 Cam - TH400 - 9 inch DYNO RESULTS w/ new cam!
  135. ***346ci 500+NA 700+Spray*** Videos Added Now
  136. Dynoed my LS2 Monte @ TTP today
  137. my ported FAST 90 added 44HP and 23LBS. that's about right, right?
  138. 383 dyno results
  139. Kooks, Borla, K&N, tune, LS1 GTO A4
  140. what gains should I see (graph inside)
  141. Stock LS6 Dyno Numbers
  142. texas speed 408
  143. 404 lq9 numbers w graph
  144. So close!
  145. 99 z28 m6 bolt on dyno results...
  146. 2004 GTO Cam Only Dyno Numbers
  147. im currious about my setup
  148. Anyone have ls 395 dyno #'s?
  149. Disappointing dyno, unrealistic goals?
  150. Dyno differences single plate VS twin plate clutches
  151. Little D-1SC on my 408 GTO
  152. 2007 C6 Z06 - TSP/PRC Heads & Cam Results
  153. Very low dyno numbers for MS3 m6
  154. re-tuned numbers
  155. New Bolt-On dyno #s (High)
  156. 2002 SS tuning results....
  157. LS2 Nissan 240sx @ Lethal Injection pics & vids
  158. GTO Dyno H/C Nitrous
  159. ***NEW***Fiber-Tuned Intake Manifold L92 Dyno Numbers inside
  160. More Procharged Fun! 740 RWHP C6
  161. G-Force F1-C GTO 850 RWHP Video
  162. how much usually for a dyno and tune?
  163. G-Force F1-C GTO 850 RWHP
  164. Is this worth it?
  165. Stock G8 making 330 RWHP
  166. 408 Stroker/TFS 235/Vengeance Custom Cam/A4 Dyno Results
  167. Latest head and cam package
  168. still under 400 hp ????
  169. 4psi STS Trans Am dyno run
  170. Loosing power through converter?
  171. 99z28 Mac mids, ory, catback and K&N fipk results
  172. Valve float?
  173. Dyno numbers off ?
  174. Finally dynoe'd the 01 LS6 SS today. Pics, video.
  175. DynoGraph of 408 TA on 10-31
  176. Looking for 364 or 370 iron dyno numbers
  177. Trickflow, Dominator 2, FAST combo 445 rwhp though A4!
  178. The setup
  179. Ragin Racin LS7 Z06's
  180. heads/cam results
  181. More new 416 dyno numbers. 573/530rw N/A!!!
  182. Dominator 2 Cam Results
  183. Any 85mm or 90mm LS6 intake dyno graphs? (I searched)
  184. ms4 and ls6 heads dyno (where is the torque)?
  185. Anyone Have Stock LS1 Baseline Flywheel Dyno Info?
  186. elevation difference ???
  187. Advice on tuning on dyno tires break free!
  188. STOCK ls1 nitrous numbers HSW kit
  189. LS1+226/226+patriot stge II dyno results
  190. 2006 GTO dyno numbers....
  191. TTP 2005 GTO Cam Only Results A4 - 444/409 SAE
  192. 2001 SOM Camaro SS H/C Dyno
  193. tick perf. polluter cam results!!
  194. 340rwhp/364rwtq Hawk !!!
  195. Polluter, Lt's, Vararam, Z06 Results
  196. F14, 5.3 heads BBK intake numbers
  197. 408 ms4 243's dyno numbers
  198. Texas Mile teaser-- LG Motorsports Twin Turbo Z
  199. Dyno Days in Flint Michigan area Saturday 10-26-08
  200. 98 Z-28 extremely low dyno numbers
  201. Very impressed with my dyno results from my 01 Trans-Am WS6
  202. 2005 GTO dyno numbers.....
  203. Dave's 05' Vette, E85 ls2 cam only numbers
  204. Retuned by Nick Williams
  205. Track times for my dyno numbers.
  206. Speed Inc. SI6 cam only results LS2 auto and M6 C6
  207. Very happy 2004 gto dyno...
  208. ***346ci 500+NA 700+Spray***
  209. Dyno results: 2001 Z06 Patrick G custom grind + boltons
  210. New Lunati VooDoo Cam Only Numbers
  211. Dose this sound right????
  212. Procharged G8 on the dyno.
  213. Dyno Results 421 Solid Roller
  214. Low dyno numbers??
  215. Vengeance Racing 440 LS7 C5 Z06 Dyno Results/Idle Clip Inside
  216. New 416 dyno numbers. Thanks Ron and Pat G.
  217. Dynoed my TFS VRX5 FAST combo today
  218. Got on the dyno today!
  219. East Coast Dyno #s vs West Coast #s
  220. Another disappointed one on the dyno 6.0L L92/L76 Patrick G/others opinions needed
  221. More power with a tune!
  222. Analyze this torque curve
  223. depressing #'s dyno and track....
  224. Vengeance LS7X cam in a 07 Z06-530+RWHP!!!
  225. 98 Formula - LS6, ARHeaders, GMMG, TR224 = 400hp
  226. Stock LS6 with Kooks headers. Dyno #
  227. 2001 Camaro SS Dyno (video)
  228. IMPRESSIVE Camswap Gains on a MagnaCharged TrailBlazer SS!
  229. 416/406 bolt on z06
  230. FAST 92/92 swapped in
  231. Vengeance Racing 08 LS3 C6 goes 503/449 Stage II LS3 Cam/TEA Stage I LS3 Heads!!!
  232. ZR1 on the dyno
  233. Portable dynos?
  234. G Force C6
  235. 2004 C5 A4 Results!
  236. a4 dyno ?
  237. **New Dyno & Bench Racing Forum**
  238. my dyno numbers what do you think,idle issues also??
  239. 01 Z28 Ms3
  240. More ZR1 Dyno Numbers with EFILive Tune and ARH Headers!
  241. MORE F-Body Results from Tick Performance: POLLUTER/Trick Flow/FAST92 with an M6!
  242. A4 F-Body Results from Tick Performance: POLLUTER/Trick Flow/Fast 92
  243. Question about Mustang Dyno
  244. Can I get any more HP???
  245. 98 SS Vindicator cam only dyno and track results
  246. How does a stall affect dyno numbers?
  247. 415 Rwhp 2004 A4 Gto
  248. Dart 205/ F13/ FAST 90/90 - Dyno Results
  249. went to the dyno! happy with my new #'s
  250. 786 rwhp, stock bottom end!
