View Full Version : Gears & Axles
  1. just a few pics of my 8.8
  2. Going to the track tomorrow morning need to know stock steel or stock aluminum
  3. moser 12
  4. How to do a solid rearend checkup (m9)
  5. 2.73 to 3.73 change in cammed camaro ?
  6. What Do you think?
  7. rearend rebuild
  8. Midwest Chassis Fabbed Rears
  9. Axles?
  10. Rear-End Noise
  11. Bolt in 8.8? or anything close?
  12. stock posi unit
  13. Whats the Right Rear End For my Setup
  14. looking for good rear show bushings
  15. different driveshaft?
  16. Need Driveline Vibration Help....
  17. where you guys buying good u-joints at?
  18. Synthetic or Normal for Eaton
  19. auburn
  20. 12bolt 4 channel
  21. rear end noise....
  22. 99 ta 456 gear swap problem
  23. Found a great deal on a Moser 12-bolt...tell me what problems I might have
  24. BMR LCA's made it worse
  25. 9" Question
  26. Going from 3.23 to 3.73. Is it enough?
  27. What gears are you guys running?
  28. Moser M9 users
  29. Gear RPM calculation?
  30. Aftermarket Driveshaft
  31. Is my driveshaft too long or not?
  32. Posi replacement instructions?
  33. Can I put in a mini spool..
  34. gear swap in C6?
  35. napa axel bearing for moser 9"
  36. Gear noise
  37. Need your opinion fellas....
  38. How narrow?
  39. 10 bolt info needed
  40. Rear End/Leaking Axles
  41. Slip Additive in Moser 9Inch???
  42. Posi unit broke, gears are fine, Can I put a spool in it for now, until I buy a 9"?
  43. diff trouble
  44. anyone know if a watts link will fit clear and fit on a moser M9?
  45. need some help
  46. What type of "posi trac" should i get for my 9" rear? locker? worn type? clutch type?
  47. 3.42s good choice for me?
  48. 12 Bolt Assembly
  49. 3:73 gears changed my speedometer.
  50. Best deal on rearend?
  51. Whats the diference between 3rd and 4th gen 9" rear housings??
  52. Will any 9" centersection fit for a 4th gen housing with stock DS??
  53. Only one wheel spinning during a burnout??
  54. How fast do rearends break with head n cam
  55. anyone need 4.11 4 series gears for 12 bolt
  56. drive shaft differences
  57. Help with a 10-bolt pattern
  58. Ordered my 9" today
  59. Torque Arm Noise
  60. Please Help Me Decide Which Gears!!!!
  61. Gear selection, M6 LT-1 Formula
  62. Good shop for rear end work in Mississippi
  63. New Mexico Midwest 9" Install
  64. Gears and ET
  65. Need help on 10 bolt
  66. 4 point wheel alignment after rear end exchange?
  67. midwest 9, how much gear oil?
  68. Dana 60 noisy or quiet
  69. Will it Fit?>
  70. C-clip eliminators?
  71. C-CLIP Eliminators?
  72. What's the general limit on an LS1 Driveshaft?
  73. Think 9" w 31 spline axles and true trac posi is strong enough?
  74. Doing a rear swap...Torsen noise?
  75. Differentials for 9in 31 spline?
  76. Installed 9in rear with Strano springs
  77. i need to buy gears
  78. My rearend is leaking........
  79. Weird vibrations???
  80. What wheel studs...?
  81. what gears should i put
  82. Moser 9"
  83. Auburn or Eaton???
  84. 06 GTO Rearend
  85. ugh im so pissed!!
  86. Any way to tell a "good" 10-bolt?
  87. pinion seal
  88. 9' help....fill spot same spot to install breather?
  89. Just Ordered Midwest Fab 9 inch!!!!
  90. 10 bolt went need something stronger
  91. Rear Noise
  92. How fast until you broke your 7.5 rearend
  93. top speed
  94. midwest 9" housings are the bomb
  95. 9" bearing order?
  96. Axle cost for a C6 corvette?
  97. Strange or Moser 12 bolt rear end?
  98. Moser axle assembly help
  99. what are the typical 1/4 ET gains from 3.42 to 4.10s in a M6 car?
  100. ls1 brakes on lt1 moser
  101. Anyone not wish they have a spoll in a daily driver??????
  102. Carrier Pin removal with Auburn Posi
  103. 9" Almost In
  104. bad driveshaft??
  105. need help
  106. bearings for a moser 12 bolt
  107. installed drive shaft, strange new noise (tried searching)
  108. 4.10's in a 94
  109. Going To Be Changing Rear End Fluid....
  110. Is this gear pattern ok?
  111. Zexel versus Auburn, anyone tried both?
  112. Whats needed for gear change?
  113. what RPM will my stock 93 z28 run with 456 gears
  114. will this rearend cover work on the s60
  115. gear help
  116. Rear Noise when in Nuetral only?
  117. correct gears for optimized performance
  118. traction control question
  119. Help with ujoints!!!!
  120. Just finished Summit Brand gear swap
  121. will my rear be okay.....
  122. looky at what i just picked up
  123. Replacing Dana S60 Studs
  124. 9 inch rearend parasitic losses compared to the 10 bolt
  125. Rear Gear???
  126. Installing a different Differential but not swapping gears?
  127. U-joint straps
  128. removing axles from Moser 9in
  129. Number of Splines (pinion yoke)
  130. where to buy axles
  131. Which differential
  132. What a good price
  133. Whats a good street gear?
  134. Going to order very soon - help me choose!
  135. Anyone REGRET going from 2.73 to 3.42?
  136. Rear end
  137. What Gears set to buy?
  138. Midwest 9" help.
  139. 3.73's or 3.90's?
  140. Can I reuse gear bolts?
  141. Still Vibrates......
  142. Lugs snapped off
  143. T56/9in?
  144. Few questions about swapping a Currie Ford 9'' rear into my 01 T/A
  145. Help please
  146. Blew up my 10 bolt
  147. So my bearings are going bad, need help
  148. Has anyone swapped a 98-02 4 channel rear into a 93-97 and had it work????
  149. impossible?
  150. Rear end swap FAQ?
  151. Broken Rear End ??
  152. 9" Fill Question
  153. 72 Monte 12 Bolt ?
  154. 373 gear with a 31 inch tall tire =what gear?
  155. rear end swap
  156. wheel bearings.. link to my question wrong section of this board
  157. i have a noise comming from the rear
  158. ques about servicing auburn rear end
  159. 9'' Frustration
  160. Rear axle moving in and out!
  161. Changing a broken stud on a strange 12 bolt?
  162. Mid west with true duals??
  163. Anyone running a Ford 9" Trac-Loc with or without billet cover?
  164. removing 10-bolt
  165. Will it hold?
  166. 5.67's for my M6?????
  167. Moser 9in and stock torque arm
  168. Should the breather tube on differential leak?
  169. Any auto guys with 3.42's?
  170. broken stud
  171. My Midwest Chassis Extreme Duty 9"
  172. 373 to 411...
  173. bad gears?
  174. Can someone check my patterns and offer advice?
  175. Rear end Coil spring removal?
  176. C5 Diff question
  177. Wheel Studs
  178. 9'' Still vibrating
  179. i think i need 4.11's video insinde!! what do you think?
  180. Leaking S60 axle tube
  181. blown axle seal
  182. american axle manufacturing ??
  183. Gear Help!
  184. 3.73 0r 4.10??????
  185. driveshaft too long now?
  186. Motive Stock Performance Gear or Motive High Performance Gear
  187. Pinion Bearing Noise
  188. Bolts backing out on aluminum 10 bolt cover?
  189. Midwest housing crossmember mount question
  190. u joint for my new 12 bolt
  191. Wahoo...no more vibration!!!
  192. aluminum center section or nodular iron
  193. driveshaft lenght for 9"
  194. Zexel Torsen and Auburn Differentials?
  195. 8.8
  196. Best price for a 9-Inch Moser. Sponsors welcome
  197. Ring gear spacer on a 2 series carrier?
  198. Quick Performance install A++
  199. Went from 323's to 390's in stock 10 bolt
  200. Strange 12 bolt w/ 4.10 gears question
  201. swapping ring and pinion, or swap the whole rearend?
  202. Will 4ch work in 3 ch Car?
  203. I think my differential is bad...
  204. motive 4.30s for 10 bolt RE
  205. 9" Moser Axles, Spacer Goes Where?
  206. LT1 to LS1 Backing Plates
  207. Help with noise
  208. 9", bmr full length TA, and yank th400 crossmember w/ ta mount..?
  209. anyone want to trade my 12 bolt for yours?
  210. gears??
  211. couple of 9" gearing questions
  212. 6 lug axels in f body rear end?
  213. what will work?
  214. Junkyard Axle Project?
  215. Torsen advice
  216. looking for 3.73 gears for 12 bolt moser
  217. Moser 12 bolt install how to..
  218. a dilemma
  219. LS1 brakes fit on LT1 rearend?
  220. **Pics** Work has started - Finally!!
  221. need help with gear choices
  222. Good deal on 12 bolt
  223. Moser 9 inch = Headache
  224. 9'' rear installed vibration
  225. axle dimensions
  226. how much gear oil?
  227. My 9" swap plans
  228. Performance gain?
  229. Insane gear whine 9"
  230. HP ratings of 9" third members
  231. To upgrade or not to upgrade...
  232. question about LSD or not
  233. Ls1 aftermarket driveshaft?
  234. posi still good?
  235. 3.73s on my stock 10 bolt
  236. Best price on 12 bolt or Dana 60?
  237. What gears do you think I have?
  238. drivetrain vibration opinions
  239. Quick help - Pinion Depth
  240. Alternate 9" third member
  241. about to install my midwest m9 have suspension tuning ?s
  242. what posi unit?
  243. moser 9'' and 4l80e driveshaft?
  244. Differential capacity - 2008 Chevrolet Kodiak 4500
  245. *PIC*Driveshaft after 9 Inch to short?
  246. Help Identify My Rear, lol
  247. Anyone run into this??
  248. LS1 Rear End Swap To LT1 Car?
  249. About to buy 4.10's and posi unit
  250. Moser vs. Strange
