View Full Version : Suspension & Brakes
- seized brake piston
- Suspension issues '99 F-body
- Camber Issue
- Grinding sound T-56?
- Need some part numbers
- Another alignment failure – what to do
- Strano rear springs, factory front??
- So will WS6 wheels fit with CTSV calipers or not...
- Grinding sound when turning left hard
- WS6 brake rotors, please advise!
- Lowering A-arms and heater hose
- 15 Inch Rim Fitment Problems
- Difference in LCA's
- Hydraulic Steering?
- Brakes fighting back with stock wheels and tires
- AFCO coilovers vs. AFCO/Wolfe perch kit
- INfo on front sway bar f-body
- Coilovers/Control Arms going on
- My solution for "clunks" on my WS6.
- Pic included....What is this bar?
- Need some information on suspension parts!
- what shocks do you recommend
- Steel braided line?
- My brake started to sometimes work only when depressed all the way.
- 5 Shocks, SFC, LCA/PHB questions - What a deal!
- Hydroboost - What is required?
- brakes pull hard right?
- Abs inop/trac control then everything lights up??
- Rear Suspension Question
- Brembo GT Front Brake Kit Pad/ Rotor Replacement Question
- Not feeling the hate on Monroe Sensa Tracs.
- anyone have tsp headers and eibach prokit?
- What shocks are good with 150 lb springs for drag
- Where can I buy bottom rear spring mount/perch
- Aerospace/strange brakes and alumastar front runners
- How long should an ls1 brake swap take?
- Eliminate Abs
- Stainless steel brake lines
- MWC Upper Control Arms On Sale Now!
- Which adjustable LCAs?
- Brembo's with 18x10.5 C5 DD
- Brembo Rotors Question
- Fitting style
- Which Sub Frame Connectors?
- brake dust
- Bilstein rear lower shock eye insulator
- BMR lowering a-arms just ordered
- brake line repair
- Darty handling: where to begin?
- Newly installed Founders torque arm. Couple questions.
- Would like to buy a torque arm
- chassis mounted torque arm vibration
- Coil Spring rate question
- driver rear rotor/indicator suddenly interfering
- What Shocks for my Lowered SS
- Passenger side motor mount
- Tubular front end options
- Chassis Improvement on Stock F-body
- umm need help UMI torque arm came loose.. how do they mount?
- Does the V6 and V8 4th gen use the same spring/strut?
- Going back to stock rear lca's & removing SFC's thoughts
- another i finally lowered my car thread
- powder coating options
- LT1 to C5 Brake Line Question
- 4th Gen Z28 suspension is awful. Likely culprits and fixes?
- 5th gen Brembo caliper bolt?
- Metallic Grinding/Rubbing sound coming from right rear wheel
- Rear calipers option.
- problems with SLP LEVEL II springs
- Line Lock issues
- How much of a diference in Drag brakes to factory @ the track???
- line lock pictures
- Oil Pan and UMI K Member
- Efffing BRAKES!!....
- 4th Gen Front Spindle Differences
- need e help with rear rotors please
- Strut and spring?
- torque spec's
- need help with ride height measurement.
- Viking Coilovers Installed
- Correct end links for a lowered trans am??
- Replacement rear springs - Moog/ACdelco
- what rod ends does bmr use on TA
- Adjustment issue
- SLP/Eibach springs: WAY too low in front
- wht type of grease?
- Founders SFC's pics
- poly/poly vs. rod/rod vs. poly/rod?
- High speed braking problem...
- Bilstein HD Shocks Too Soft only a year
- Qa1 guys, how do you lower the rear, what springs?
- BMR K-Member Install - Questions
- Front Sway Bar Mounting Clamp Bolt Size and Bracket - 1995 Camaro
- torque arm wheel hop
- Park Brake Help
- brakemotive
- installed and installing the energy suspension motor mounts
- Stock A Arms and mad man travel limiters
- mounthing brackets and hardware for qa1 strut tower brace
- What Bump Stops For Rear Coilovers?
- 2000 SS steering rack
- adh panhard help
- BMR lowering A-Arms PICS please
- Finally lowered.
- Torque arm fitment problem
- is this backwards?
- Z16 Brake Pads - Front and rears universal?
- problems after new pads and rotors!
- 2000 z28 rattling at 75
- shocks for lowered F bodys
- camaro brakes on mustang?
- Would I be ok with a set of Stranos?
- sjm line lock solenoid leaking
- Shocks/struts recommendation for Z
- in need of a torque arm not oem!!!
- Brake upgrade with 17" FM5 wheels??? NEED HELP!
- Koni, UMI & ChassisWorks Install
- Need Small brakes for 15" Wheel
- Adjustable phb question
- Recommended sway bars for..
- Lower seats on Bilstein shocks
- Rotor advice ??
- ride height issue
- LG motorsports C5 Brake Conversion with TT2's
- Suspension part fitment?
- Bushings...rubber vs. poly vs. thermoplastic
- Downgrading front brakes from c5 to stock
- Mwc anti roll bar
- Shocks for 98+ ss oem
- Front spring perches and lowering issues
- MWC long TA trans crossmember
- seized push pin!
- Economy Street/Strip Suspension Setup
- Thoughts & Opinions on QA1/Hotchkis set up?!
- How much better will I hook than stock?
- pinto rack...whats needed
- F-body: 3-channel to 4-channel ABS?
- CTSV Conversion Brake Pad Question
- how do these bolt up?
- What setting are your koni's?
- What thread for proportioning valve?
- Koni/ Strano suspension install.
- LCA relocation brackets
- Alignment parts
- 5th Gen Brake Swap Question
- Pinion/Driveline angle verification
- SJM ABS Delete great kit, but... all factory lines leaked on me.
- Driveshaft loop - dual exhaust & BMR torque arm
- Best shocks for daily driver?
- ? for those who've done Moog replacements
- Suspension Help
- Rearend Issues
- Lowered 4th gen clearence issues?
- Phb & lca ?
- Viking rear coil-over package installed at MWC
- Rear shock selection help
- Anyone run the AJE K member on their 4th gen?
- Need help rebuilding front suspension and steering
- lowered the formy
- Ride height issue with Strano/KONIS
- Wilwood DynaPro Front Brakes
- Drag suspension
- 1LE trans mount?
- Rear end shift
- changing rack and pinion
- Driver rear squeling noise
- bleeding abs block
- looking for tutorial for doing rear brakes
- UMI Control Arm Relocation Brackets Now Feature 3 Hole Design
- Lowering my car, looking for opinions
- is this safe?
- Help!
- PA racing lower A-arm adjustment
- suspension problem
- few ? about brakes
- Hit a curb and damaged engine cradle
- which spring to put on my car??
- Lowering car before PHB etc arrives?
- Front tie rods?
- Thump on hard decel/accel
- Anyone had success with BMR springs and SLP Bilstien shock combo?
- Please HELP :(
- Upper control arm removal?
- Cross reference Torque Arm Bushing for Random Technologies?
- parking brake light problem. HELP!!
- ls1 springs on v6
- HELP!! Hit the curb now wheel is not centered.
- Rhythmic Thumping Sound starts at 20 mph along with shaking??
- need help removing spindle arm!
- Suspension question
- F-Body Suspension
- Replacing inner tie Rod questions???
- speed bleeders
- Is wheel alignment required after front shocks
- Brake issue
- MOOG 21mm Rear sway bar bushings
- Viking Performance Berserker ASM Shock
- Harsh ride- parts list needed.
- Installed Strange rear shocks and it lowered car and making noises.r
- Make shift bump stops
- Ridetech Pothole Sale!
- Strange brake setup
- Best ride for the $?
- passenger side lower than drivers heater hose mod
- Just ordered Viking Coilovers for all 4 corners!
- 2002 WS6 Suspension Questions.
- "Play" from rear of car letting off first gear
- 130k suspension rebuild
- What do i need Drag/ street type setup
- Would lowering cause greater stress on the rear?
- snapped caliper bolt!
- viking performance coilovers?
- Violent vibration only SOMETIME!!! WTF
- BMR Springs or Hotchkis set? Better ride and G'S....
- panhard install help
- Mounting viking coil overs, is this ok?
- Set me straight
- BMR lowering questions.
- Speedway 9 inch bolt on disc brakes
- viking shocks on a DD?
- MWC Rear end question
- It's that time of year again...
- Koni Sale!!!! In 3, 2, 1... well ok, on 3/1!
- Ridetech 4th Gen Coilovers
- how to cut springs?
- Need help finding a bracket or part number
- HELPPP wheel hub BOLT is missing/fell off
- UMI Releases New Product- Bolt-in Rear Coil Over Kit for the 82-02 GM F-Body
- Koni Str.Ts worth waiting for?
- Qa1 vs viking Shocks
- 01 rcsb drag setup
- BMR/Koni
- k member
- SLP Spring issues
- Castle nut help!!
- inside of front tires bald
- Ls1 e braking system.
- Front shock help
- need opinions jegs jegster torque arm? anyone running one
- Brake Issue/ABS?
- 98 z28 e brake help
- Supsension set up for the street questions
- need shocks input
- Post up your brake set up...
- 00 TA suspension issue
- Lining up LCA Relocation Brackets
- Looking for thoughts on rough ride
- Made my own bad ass rubber bump stops for $10
- ? about c5 Z06 calipers on Fbody
- Suspension/chassis advise
