- clutch chattering
- BACK FIRES Shifting Gears ?
- Random misfire return
- Car dies on highway any ideas?
- 4.8 cold start issue...
- Car wont start, need quick help...
- crankshaft position code ?
- Aggravating Interior Noise
- Optima Red Top
- Headlamp grinding
- volt meter prob
- drivers side wont lock
- still getting REDUCED ENGINE POWER message
- Headlight prob on 98 z28...
- 01 Trans Am, when use keyfob, lights go up and down?
- The damn thing won't start please help
- rear main seal parts & write-up?
- Oil leak?
- oil drain plug
- Loud clunk on transmission during gear shift(auto)
- starter problem????
- RPM puzzle
- code P0128
- Water in oil help please
- Weird Vibration
- What the hell did I break???
- How to repair fiberglass?
- Window
- When to change fuel filter
- OMGWTFBODY'S issues and repairs thread: Swap advice.
- oil pressure gauge gone nuts
- moisture in taillight
- Window Shudders?
- Mixed Green Coolant and DEX-COOL in my car! HELP!
- P1441 Code troubleshooting?
- Having a pinging sound under hood need help!
- How Far Can an LT1 Go?
- Security light at startup=no igniton
- WTF?? OIL blowing out at startup??
- A/C tensioner/idler pulleys
- Where to get AC Iridiums for a 1998 LS1?
- alternator clip?
- A/C clutch
- REDUCED ENGINE POWER message
- What could cause this starting issue?
- tranny mount
- Please Help. EGR Flow Malfunction P0400
- Steering wheel vibrates at 60+MPH
- odd vibration at 1900-2200 rpm
- Rough idle
- SES after plug/wire change
- SoCal, Longtubes, and Smog Check
- Electric problem! Anyone ever have this problem?
- What can it be???
- 2002 Mustang V-6 exhaust leak
- a few issues
- smoking!!
- can someone help me diagnose this problem??
- HELP- rattle!
- Sounds like popcorn?
- Noticeable vibration when car turns off
- LT1 coolant flush
- What's up with my gas tank?
- Air conditioning evaporator drain hose.....location???
- loose wires under hood?
- Ideas on my power loss
- Not running smooth when warm?
- Oil Pressure Gauge
- Replaced waterpump and thermostat and getting hotter than before!?!?!?
- Shifter vibrates when I accelerate
- Time for a tune up?
- Oil Pump taking a crap???? shaky needle help!!!
- Transmission problems: I could use some help
- Silver Stars Fog Light Bulbs
- Vacume leak?And some other questions
- big problems with the t/a
- Unknown Clunk?
- ripped up PCV system, advice needed
- Need help picking a new horn
- Installing Silverstar fog lights on Trans Am?
- Car vibrates while driving... hard idle... blue smoke
- Misfire? maybe a spark plug?
- ANNOYING SQUEAK!! Please help!!
- new problem can any one help?
- No turn signals...
- OIL seepage
- Pop up and grind. Amusing headlight antics.
- Turn signal works fine but stopped blinking (yes I changed the bulb)
- TQ arm mount????
- loud turn signal
- Car pulls to the left!
- Electrical Problem
- A/C - blows, no cold air, found green liquid, pictures inside
- Headlight adjustment screws trans am
- Checking Grounds...
- Help! Car drops voltage randomly. Its possesed!
- Driver Side DRL
- Help! Overheating Problem on Daughters V6 Camaro
- Strange fuel pump issue
- Rear passenger side exhaust rattle
- Seats arent working and im driving cross country in the morning help please
- ses light question
- Manual Vs Automatic Columns
- Replacing low beam headlights on Trans Am?
- Need some help with a/c leak.
- wont start
- bad road noise
- clunking on slow decel
- lights diming
- having problem with my taillights
- Misfire or something up past 5700rpms, help!
- so i broke my torqe arm mounts
- OEM motor mount for 98 ss!
- TERRIBLE noise!!!
- Fogs on a '97 Camaro
- is it bad to drive with the knock sensors bad?
- Weird problem when key is turned too ACC..
- Where are the knock sensors?
- Headlight Motorrrrrrrrrrrrrrr!
- Knock sensor code help.
- Gremlins?!
- A/C Delete
- gas gague
- dead o2 sensor making car run rich???
- blinker question
- cig. lighter
- Shock problem?
- Stripped bolt. Need help
- Squeeking from the left/rear of the car.
- Crank Positioning Sensor
- Dont know where to post this so here it is...
- Rear end fluid....how often should it be changed?
- Driver side headlight cover is a biotch
- Road noise, vibration, thud noises
- Belt Noise From Hell
- is this the opti (please help)
- Squeaking and vibration
- Need Help with 97 Pontiac
- Help Grinding Noise???
- SLP lid question!
- Buzzing under dash.
- Where do I begin to look?
- EGR Removal w.o a tune?
- Scanner wont scan?
- A/C compressor runs but air does not get cold.
- oil pressure gauge at 0?!?!
- Freon?
- 01SS Fuel Issue
- Done some Reading on Main Rear Seal
- Photo request of LT1 throttle linkage please!
- dirty MAF??
- broken bolt in LS6 intake.......(pics)
- Power steering moaning, weird electrical problem, belt chirping, oh my!
- Vacuum leak? P0507 code...
- detonation???
- replaced opti but car runs rough time to time
- What type of Waterpump?
- Clunk while shifting
- Headlight question; need assistance
- Shortage ?
- Rattle upon accleration (and other problems)
- Great install guide for many apps
- Power Steering
- REALLY need some help, FAST
- water pump replacement
- Pulstar Spark Plug Vs. Conv.???
- blown head gasket
- both window motors went out
- Oil pressure 25-30PSI
- Help!!!!!
- Cooling fans
- Headlights On My Trans Am Makes A Noise When T Goes Down.
- AC knob moves freely and doesnt change?
- Air intake Oil?
- help with misfire
- Help me fix the clunk over bumps
- Flashers and Blinkers
- trunk doesnt pop when car is running?
- Motor Mount Question
- coolant flush
- Vibration question
- stumbling.. SES, but now no SES
- HELP!!! frustrated
- trans am headlight problem, and no its not the motor.
- brake lights please help
- formula ws6 or trans am ws6
- Shredded the Drive shaft in two..
- OK, I have no idea what's going on.....
- The Blinking SES light
- Changing Corner lamps / Camaro
- Cooling fan motor replacement
- Rung off bolts in the cylinder head removal!
- ttops drip, drivers window switch not workin now..
- How do you change turn signal bulbs?
- idle air control
- at a cold start car doesnt want to hold an idle
- Best aftermarket replacement for pushrods
- Coolant issue
- Good Pushrods.. and difficulty on the installation.??
- Another Overheating LS1
- Temp way to high
- window switch removal
- is my fuel pump going out...??
- Just got my Y Pipe on and....
- Should I dump the Dex-cool for the green stuff
- PCV valve elbow
- Brakes Are Squeaking
- 10 years/30k miles and stock plugs...
- Maintenance intervals, etc.
- help! missed a gear and now i hear a tick?
- bent header!!! need help
- Car stumbles, RPM'sdrop below 500, help!
- Tps
- how to take out coolant sensor?
- A/C vent problem
- Squeaking noise at start up - sounds like its coming from under the heads
- a/c problems
- Car won't start
- computer output circut?
- Blinkers Out
- Cam position sensor
- Need help diagnosing a low RPM problem
- A4 Tranny mount problem???
- Maintenance at 177,000 miles
- Headlight Control Module??
- Fog Lights
- power door locks not working, need help!
- Help no headlights!
- steering column lever (wiper, turn signals, high beam) not activating high beams
- 'Service Vehicle' light on, not SES.
- All you German Castrol guys
- Ses Codes, Help!
- car dies stumbles and runs like SHI%
- Low coolant lite
- Steering wheel swap
- NEED HELP!!! brake pads
- Help with seat cushion..my back is killing me!
- Oil on Spark Plug threads...valve seal?
- Bad Smell
- part #'s for oil pressure sensor and coolant level sensor from SDPC
- Somebody Slap Me!
- o2 question
- Low Oil Light ? help
- Why does my car drive smoother with the AC on?
- I think my thermostat went up a few ???
- Help on speedometer reading...
- cruise control... weird one.
- Rattling sound when I close the door
- how to tighten driverside door
- my car has a p1870 code, how to get it fix?
