PDA
View Full Version : Generation IV External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29
  1. Choosing heads for Lq4 advice
  2. LS3 / L92 Water pump rotation Help!!!
  3. Intake elbow for FAST90
  4. what size and brand TB for 402
  5. ***HELP, buying a car with low oil pressure***
  6. Fast lsxr 102mm intake
  7. AC issue code PO455
  8. people who use a breather for an oil cap
  9. 4" E-Cutout Header Collector flange
  10. LQ9 alternator location problem
  11. Vengeance Racing Ported/PAINTED LSXR 102mm Intakes Inside... EYE Candy!!!
  12. Air filter????
  13. wtb 2" primaries
  14. LS3 and L92 pictures needed
  15. Can I switch a Carburater 383 stroker into an LS1?
  16. Ebay exhaust
  17. Ebay exhaust
  18. Whose running a 2'' primary LT header?
  19. Help! What size is this hex key?
  20. alternator hookup, no pcm
  21. LS3 clutch to LS1 T56
  22. LS-9 front cover
  23. LS2 Swap for 02 Z06 Questions
  24. Autox oil pan for ls2
  25. ls3 knock sensor conversion
  26. LS7 oil pan
  27. vvt cam sensor different?
  28. LS2 with L92 heads and LS3 intake/tb
  29. vvt with manual transmisson?
  30. LSX Part #s
  31. Need to find camaro trans...
  32. LS7 Engine
  33. Firecore50 Wires now available in a 45 deg boot
  34. bolt torque specs L93/ LS3
  35. l92 rocker arms
  36. Thank You Scoggin Dickey Carb intake
  37. GM carb intake for LS3/L92
  38. L92 oil pressure Please help!
  39. Another Oil Pressure Sender Question
  40. Tsp 402 short block
  41. pressing PS pump pulley on further than flush
  42. Not sure if you would call this an "elbow"
  43. What do the Chambers do on the stock intake?
  44. New part# for LS3 heads,what parts?
  45. LS 7 runner length
  46. 650 hp´s in a 416 l92 heads n/a pump gas
  47. 235TFS airflow
  48. What size of valve cover spacer do I need to run Jesel rockers?
  49. What's the difference between LS1 and LS3 starter ?
  50. ly6 or ls2 cam sensor wires
  51. LS3 intake bolts
  52. Header size for 500RWHP?
  53. ls3 heads and intake on a iron block forged 370 going into a c5 corvette questions
  54. LY6 to L76 intake/injectors
  55. My ported LS3 intake pics/info
  56. 02 sensors on new LS3 harness versus LC1 controller
  57. L92 questions
  58. is this balancer seated all the way?
  59. where to find power steering reservoir?
  60. LS3 Crate engine - where to buy?
  61. cable tb for ls3 intake
  62. Gen IV timing covers
  63. trying to find thread
  64. connector and wiring alternator
  65. Questions about ls2 engine PLEASE HELP!
  66. Unsolved mystery!!! 01 z28 problem plz help!!!!
  67. is it ok if i use this piston???
  68. Short style ~60-70# injectors
  69. vacume in intake at wot
  70. Speed Density Tune Vs MAF Tune
  71. Fast intake help
  72. Ls7 4" maf
  73. Looking for 4" lid
  74. starter bolt size
  75. Best Price on Fast 102 For LS2
  76. L92/L76 Head milling ?
  77. HELP! Car cranks but no spark
  78. drive by wire conversion
  79. PCV System with Truck Valley cover?
  80. Coilpacks/brackets interchangeability
  81. Smog in California
  82. Help w/ intake selection on a 416 w/ TFS 235s
  83. An alternative to seal your Super Victor intake to a Cathedral port head
  84. If you have a LPE 24X-58X conversion module come in
  85. head swap
  86. New Becks intake for my 440!!!
  87. Head Efficency Factor: CFM or CFM & Velocity
  88. Interchagability between the LS motors
  89. Billet valve covers/coil covers you probably haven't see before....
  90. C6 LS2 radiator removal / transmission oil cooler lines?
  91. Power diff ?
  92. deleting the vvt
  93. 4" in/out catalytic converter?
  94. L92 heads stock shortblock ls2/lq9
  95. Ls3 intake on a L92
  96. L76 vs LQ9... Why is the L76 more powerfull with less compression?
  97. L92 swap to C5: Crank pulley needed?
  98. Zero oil pressure gas anyone had a pump fail
  99. FAST 90 tb dbc problem
  100. 103 Thousand on the clock and here's the little things done..
  101. safe rev for 402
  102. Tall ebay valve covers
  103. Attn any Vendor?
  104. Has anyone used the TPIS MAF housing?
  105. FAST 102 and TB best combo?
  106. Meziere water pump question.
  107. 2008 4.8 headers
  108. Is it crazy to run cats on an LS7 swap?
  109. LS ITB's
  110. top end package for 08 escalade
  111. Ls3 manifold on a L92?
  112. How Long Should An Engine Builder Take?
  113. Best place to measure oil temp - LS7 with Dry Sump
  114. how does this sound?
  115. ptm 102tb
  116. which header is best for lsx
  117. D585 and plug wire question
  118. FAST 102 gains over ported LS3 intake in bolt-on 6.0L G8
  119. Single Plane EFI Guys Come Inside Please.
  120. L92 w/ CtSv s/c?
  121. LS2 how to make it work?
  122. Dyno'd the ZO6 today!
  123. throttle response tune?
  124. Using engine plate (front and mid)
  125. Doing something wrong measuring Pushrod length HELP PLEASE
  126. Below engine catch can mounting
  127. L92 Vic Jr help
  128. External damage
  129. What whould be your choice?
  130. LS3 wiring diagram
  131. Custom radiator needs cap..how many PSI for LS2 cooling?
  132. looking for L92 edelbrock victor JR intake
  133. Searched: Are L92 injectors the same as LS3?
  134. Bought LS7 crate engine, where to find information on all hoses?
  135. Ly6 vvt 6.0
  136. Ported L76 vs Ported Fast 102
  137. power limits
  138. power limits
  139. Rev Extreme!!!!!! Tsp time to built!
  140. injector adaptor help
  141. ls3 coolant crossover?? or isit blocked off??
  142. max lift on stock ls2 bottom with TFS heads
  143. Beck intake
  144. L76 intake plumbed for DP nitrous?
  145. 4l60e
  146. LS3 Mani + 60lb/hrs + FAST fuel Rails = custom brackets? PICS inside
  147. engine swap
  148. Cam Suggestions?
  149. Anybody running the Comp Ultra Pro Magnum LS3 rockers yet?
  150. cath or not to cath
  151. Emission equipment
  152. Do you go with an UD Pulley or the stock one when doing a cam swap?
  153. Porting your TB to 96MM
  154. will my dart ls1 heads fit a lq9 block??
  155. Tall Deck intake spacer kits
  156. Any tb porters have experience with the dbw 87mm?
  157. VENGEANCE PORTED FAST LSXR 102mm Intake Picks up 42RWHP/36RWTQ on Stock cube LS2
  158. 600hp build
  159. Best Setup for bored 408ci LQ9
  160. need help, drive by wire,pcm,and pedal ?
  161. 87mm L92 throttle body... worth upgrading to the 90mm LS3 tb?
  162. LS3 Won't Start
  163. Header Gaskets - Percy's Seal 4 Good OR Remflex?
  164. im pulling my hair out
  165. PRC 5.3 stage 2.5 heads not bad! What do you think?
  166. L76 and LS3 the same ???
  167. FAST 102mm
  168. steam line hook up???
  169. Valley cover
  170. CNC ported L92 much better than stock L92 heads
  171. stock weight
  172. Intake porn.
  173. 2005 GTO engine ?
  174. Ignition Box or Front Drive Distributor?
  175. How many CFM does a 90mm versus a 102mm TB flow?
  176. Header studs for LS3
  177. Cylinder exhaust port shape???
  178. LS2 for '68 Camaro
  179. ls2 intake on GM900 truck
  180. 4255 - Edelbrock 2-Piece LS Timing Cover....will it fit the LS7?
  181. LS2 Drysump capacity
  182. headers on a 2010 z
  183. Did I get a good deal on l92 and l76
  184. Thread-locker needed on GM Flexplate to Crankshaft bolts?
  185. Does the LS3 use rear steam vent bockoffs too
  186. acceleronics Injectors to small for l76 intake...do i need diff orings?
  187. LSX 427 NA Build Opinion needed
  188. No tune with headers..how bad it is?
  189. LS6 intake on 2006 4.8L?????
  190. 243 Heads
  191. LS2 thermostat and cooling questions/issues
  192. RAM air with FRA?
  193. L92 vic jr intake
  194. cam suggestions???
  195. $~lsx-r 102mm questions~$
  196. cheaper /6-71 8-71/ blower.intake manifold..
  197. Ls3 vs ls9
  198. LS2 thermostat, highest flowing model?
  199. 100 MM Mass Air ?
  200. Ported Intake / Throttle Body and Tuning Special
  201. ET Performance Head Castings
  202. Any differences between LY6 and L92 stock injectors?
  203. Ported stock heads, what gains, and which route to go?
  204. 06 or 07 6.0
  205. difference other than sodium filled valves?
  206. about to buy headers....I need help
  207. Connector ID?
  208. Blown out spark plug
  209. Black Coated Stainless Braided Hoses
  210. Looking for a new catback setup.
  211. Melting motor mounts!!!
  212. LS2 stumbles/hesitates only when COLD.
  213. Truck harness ?
  214. L92 intake-how bad can it really be?
  215. Making CNC Ported Ls3 Heads flow past 650' lift?
  216. 6.0+ liter 600HP+ before the jug????
  217. DIY: LS3 Bosch to Delphi MAP sensor conversion w/o harness
  218. 1968 Chevelle 6.2 L92 Vortec Engine Conversion
  219. How to install LS3 Corvette MAF
  220. 200 miles on new exhaust, smoke?
  221. Anyone running a carb and a 6ls box
  222. Help with LS3 Motor
  223. ID my block?
  224. Clutch Compatibility
  225. 87mm tb, what did they come in?
  226. best longtubes for the buck.......
  227. LS3 oil pan on a C5. Fit?
  228. Throttle Body coolant tubes?
  229. Throttle Cable Bracket
  230. Lq9
  231. Where can I buy an I pipe?
  232. 6.0L Gen IV iron block, part number?
  233. 4 barrel efi w ETC
  234. How much power am i missing out on???
  235. lq9 into a 98 z28
  236. Exhaust port location question
  237. What else do i need to install long tube headers
  238. head and cam package?
  239. 90mm MAF Options?
  240. Cary's Intake + Elbow + 115mm TB
  241. Best electric cut out????
  242. Where' the LS2 Fuel Pressure Regulator
  243. ARP Head Studs question
  244. Gauge questions...
  245. borla catbacks with "multicore" mufflers??
  246. when is a 100maf needed?
  247. LSX block Knock sensor pictures please
  248. Thermostatic Oil Cooler Adapter
  249. F.A.S.T. LSXR 102mm inake for cathedral port now available
  250. ARP head bolts need tourq specs
