View Full Version : General Maintenance & Repairs
  1. Need some body parts
  2. Speed Sensors
  3. Part number for TCS switch
  4. knocking noise
  5. Firebird turn signal replacement.
  6. ASR & comfort control lights out
  7. starting problem on lt1 formula
  8. Car won't fire?
  9. got an idle problem
  10. Windshield Replacement?
  11. replacing headlight motor, how to get it out of down position?
  12. Dealership to order parts from?
  13. Hydraulics on hatch
  14. Auto Window Issues.
  15. Headlight noise when closing?
  16. 85 firebird headlights help
  17. popping noise
  18. Funny noise
  19. 96 T/A turns on, then loses power, then turns off
  20. bucking/clunking from M6
  21. OMFG Has everyone forgotten how to lift these cars?
  22. Air Conditioner
  23. tough to turn the wheel when stopped
  24. AC orifice filter Help
  25. Rough Idle and Surging
  26. Bad O2 Sensor = horrible gas mileage?
  27. Slight grinding noise on turns??
  28. a/c problem
  29. SES Light?
  30. stuck @ WOT
  31. 1999 Civic Help!
  32. low rough idle, no power, running on 4 cylinders?
  33. A4 Idle Vibration
  34. Car doesn't start
  35. lights grinding
  36. power steering pump
  37. Tail Light Lenses Dented??
  38. engine knocking
  39. Anything wrong with this radiator flush method?
  40. M6 maintenance
  41. blinker flasher
  42. radiator air dam bolts
  43. Horrible pulley squeal!
  44. crazy headlight problem... help
  45. damged wells
  46. Installed P/P throttle body, coolant everywhere!!!
  47. Power Steering Problems
  48. Parking lights not working
  49. Knocking!?!
  50. need a part number for an AC line
  51. Replaced all cooling stuff and a 160, and still running 205*
  52. Water spitting out of exhaust
  53. window rattles
  54. problem with dealer telling me my a/c isn't leaking.
  55. Burning OIL like crazy!
  56. thanks for the help ls1tech!!!
  57. Weird electrical problem
  58. wheel squeak
  59. seat noise
  60. Head lamp motor arm
  61. one more headlight question
  62. LS1 Won't Start!
  63. Fog Lamps not working...
  64. power steering fluid flush
  65. When does one say 'I need a new AC condenser'?
  66. Dealer says nothing is wrong. (brake pulsing and engine cutting out)
  67. Belt Noise?
  68. Front Foglight Bulbs
  69. grinding/popping noise when turning??
  70. Change your own spark plugs or take it to get serviced??
  71. oil leak - cost of getting gaskets replaced?
  72. car won't start
  73. The F-Body window Curse...
  74. car doesn't start
  75. Overheating
  76. battery tray Part number please
  77. Synthetic Oil
  78. car doesn't start
  79. "applique", small black triangular piece behind window
  80. electrical problems
  81. window rolls up very slowly
  82. smoking LS1 - does oil weight make a difference?
  83. Autolite XP spark plugs?
  84. Low Oil Pressure or High Oil Pressure?
  85. 4.3 liter vortec hesitation problems
  86. Clicking Headlights
  87. Ticking?
  88. Ignition troubleshooting - Coil or Plug bad?
  89. what does this sound like??
  90. My Car Wont Start
  91. Turn signals don't flash
  92. low coolant warning?
  93. 98-02 trans am headlight motor
  94. Oil Filter Options?
  95. Wierd noise in rear end
  96. AC leakdown problem
  97. vibrations at highway speeds
  98. Random Tinking Sound
  99. Trying to track down a squeal under the hood...
  100. good spark plugs?
  101. Service Interval Question
  102. weird problem... i think it's the rear?
  103. Royal Purple Or Mobil 1
  104. Just killed My compressor
  105. What oil should I use?
  106. Cruise won't work over 65 mph after gear swap
  107. What the hell is this noise?
  108. Part number for EGR intake o-ring?
  109. Left Turn Signal not working, What's wrong?
  110. Shudder/jerking still here
  111. oil change light??
  112. Wrong oil?
  113. Advice or secret hints needed for dealer repair
  114. overheating
  115. Whistle from engine bay
  116. window motor and regulator change
  117. A/C Compressor Switch
  118. Security Light on! Why?
  119. AC compressor issue
  120. Headlights pop-up on first dial setting
  121. Head Liner
  122. window motor?
  123. Any info on these problems? (driver seat inflation; brights)
  124. Does anyone know an easy way to replace the daytime running light assembly?
  125. loss of idle and serious surging at about 3k on full throttle
  126. Hideous whining noise, changes with RPM
  127. Should I drain my radiator?
  128. What's the best oil??
  129. jacked in the wrong spot, bulged fenders, help
  130. Charging issue - help!!
  131. headlights pop up with fog lights? no running lights
  132. RPMs drop with A/C
  133. Helms Manual?
  134. flakey electrical problem?
  135. oil
  136. E-brake quit
  137. Manual Tranny Mount data for all
  138. Bogging Issue
  139. wtf? (starting problem)
  140. Howling Noise From Engine
  141. Spark Plug Install Problem
  142. Strange Noises coming from Under the car
  143. how do I get the maintenance done on the rubber
  144. how can I clean my engine?
  145. Key Fob will not unlock Passenger door
  146. Blinker Failure
  147. What parts should I be changing regularly?
  148. Car runs hot
  149. Help A/C went out
  150. Car Died!! No Start!! No Power Up!! Completely DEAD!!!, Fully Charged!
  151. permanent fix ta headlights
  152. Pinging is Gone
  153. How hard is it to replace window motor?
  154. problems in paradise
  155. can too much coolant cause your car to heat up?
  156. What would cause these lights to stay on?
  157. Need help hooking up oil pressure gauge
  158. front bumper
  159. Spark Plugs?
  160. light fixing
  161. Electrical drain from "H/L DR HORN" fuse, cause/fix?
  162. oil leak on C5 Corvette
  163. Another Power Window Thread
  164. white residue on rear bumper
  165. ls1 oil pump
  166. newbie oil change
  167. Weird Sound Under the hood
  168. Which Spark Plug wires?
  169. What other maintenance items are needed for a 72k LS1?
  170. Tach response is slow
  171. which cylinder is #2?
  172. Strange Noise & Vibration when turning
  173. ticking noise coming from the rear brakes
  174. Plugs/Wires install done - Pics
  175. AC not blowing
  176. breaking in an engine on synthetic?
  177. cooling problems
  178. MAF question
  179. AC cold then hot?
  180. How to check for vaccum leak
  181. Getting a Trans Am door panel off
  182. wiper problem
  183. Where can I buy the Mobil 1 Oil filler cap Online?
  184. humming noise?
  185. case of the shakes
  186. car won't start
  187. HVAC mode switch not working right
  188. passenger-side spark plugs
  189. Fuel Pump mishap?
  190. I'm Running too hot....
  191. Ignition Cylinder in steering column bad?
  192. Distributor (Not F-body)
  193. smelling gas again
  194. Anyone know how to siphon gas?
  195. how to check for bad mount -motor & tranny.
  196. Need to fix or replace popup headlight motor
  197. cost to replace two airbags and a windshield?
  198. Your experiences at the Dealership
  199. Electrical issues on an 02
  200. Improving Fuel Economy of your F-body
  201. Headlights turn on / pop up all the time - possible short
  202. Mixing 5w30 with 0w40?
  203. Help with a vibration part 876432
  204. Don't Laugh... (replacing spark plugs)
  205. oil leak rear of block
  206. K&N air filter - which side do I clean?
  207. What is this?
  208. Does anyone have a problem with driver mirror shaking?
  209. Change Oil Light?
  210. Vibration when AC is turned on
  211. New rear shocks ALREADY?!?!
  212. so uh.. my Sun Visor fell off. :(
  213. Which suspension/mounts are most likely to creak/groan?
  214. Help Diagnose vibration problem
  215. possible bad cat?
  216. Electrical problem
  217. ticking from valve cover? gas gauge acting up? car at dealer currently.
  218. Water damaged car - what now?
  219. Vibrations coming from hatch area!!!
  220. Headlights flip up when you lock the car?
  221. Chassis Lubrication?
  222. window motor covered by warranty?
  223. man, i just need to vent (scratched plastic)
  224. Vibrations at 1000-1400 rpm...what could be the culprit?
  225. Major sources of drive pulley belt squeal?
  226. gas smell
  227. BOOM!!! hole in engine block
  228. Flasher Question
  229. How difficult is it to change a window roller?
  230. how to change rear hatch struts?
  231. No rear defrost
  232. Bit of an electrical problem... Help!
  233. high battery voltage
  234. NGKTR55 or BOSCH platinum 4 spark plugs?
  235. Cracked plastic around mirror adjuster....
  236. What Oil and Filter are you guys using??
  237. Reading Lamp?
  238. Coolant leak causes car to run hot?
  239. weak parking brake
  240. royal purple? oil filters?
  241. quick question about front fenders
  242. Automatic Transmission Indicator Lamp
  243. headlights go up and down when i lock and unlock the car now
  244. Oil Gauge fluctuations
  245. starting issue
  246. 91 rs camaro has been running hot
  247. oil question
  248. which car battery?
  249. Disable headlight doors with "parking lights" on?
  250. Ticking sound from under valve cover
