View Full Version : Suspension & Brakes
- drag suspension setup?
- Weld on or bolt on lca relo. bracket?
- Question on Relocation brackets
- Help..Which Eibach springs do I have installed?
- Got adjustable LCA's, have questions..help
- Thrust Angle experts - I need Advice
- full poly or poly/rubber bushings for LCA's
- Best rotors for money?
- Looking for pics of Sportline springs installed
- 1" drop
- Replacing Tie Rods
- Rod Ends--these Are Nice!!!
- Help narrow down springs
- Alignment after Lowering (need help)
- madman torque arm-rr?
- best alignment
- F/R Weight Distribution
- Turning Drilled/Slotted Rotors?
- Anyone know if 93-97 brake hoses are the same as 98-up?
- Will a LT1 TQ arm fit a LS1 car?
- Question about lowering, probs with suspension
- please help with alignment
- Adjusting the parking brake?
- bolt-on Subframe connectors NOISY ??
- Where to buy Koni SA Struts
- Rear sway under breaking
- greasing poly bushings
- Part No. for QA1 front drag springs
- New rotors, pads and paint.
- Panhard??? What exactly are the benefits?
- QA1 shock that pulls spring down!
- KYB AGX Shocks?? How do they compare w/ QA1??
- When do you know when your stearing rack os no good?
- Are all subframes the same??
- aluminum sway bar mounts?
- GOOD instructions for install of Torque arm
- What Brakes Are The Best???
- A4 canyon carver???
- SS vs. Z28 struts
- How do I make my 2000 SS not ride like a truck?
- Clunking\Knocking Sound, Need Help Please!
- what dictates rear end location?
- Spohn Pro-Series Rear Drag Sway Bar
- Need a quick measurement
- Adj Panhard Bar Help Quick!! Bout to order
- adjustable E-brake
- Why is my drivers side rear 1/2" lower?
- Wheel Hop
- WTF happened to my friends e-brake?!
- Squeeky brakes
- KVR Performance rotors quality
- does ur car do this?
- Bmr boxed weld on sfc installed.
- SFC and auto x?
- Random Tech T-arm question
- weight of BMR LCA's vs stock LCA's
- 1le springs
- help from BMR kmember contorl arm Users
- Help with removing front rotors
- Front Sway Bar Install
- rotor direction
- lowering springs install
- Ride Quality?
- help choosing springs, 315's on back
- Help!! I'm an idiot..weird sound
- How do you test rear brakes?
- Strut tower brace problem....Opinions
- Popping sound from front passenger side
- How can I improve handling with 12 bolt
- Rear Discs.
- Airbag spool? fix Help
- UMI Performance SFC's??
- Is the Stance right?
- Need Help Quick
- 94 Camaro Z28 E-Brake
- adjustable coilovers or stock...????
- What needs to be removed for a full cage?
- Eibach Drag Springs???
- Front spring lower insulator
- spring question
- Lowered my car
- Raybestos pads ?
- Rear Brake Rotors
- Lowering spring clunks on the rebound
- Stock "tunnel" brace
- SFC's, Need advice on choosing.
- BMR Springs..
- I want to lower my car!!! What Springs/Shocks?
- torque specs for castle nuts on spindle?
- Do Sportlines go bad?
- Spohn torque arm problem!!!
- quick ? about alignment
- where to buy new stock caliper parts.
- major break problems, (lockin up)
- Need some help with a "clunking" noise please
- "Performance Friction" Brake pads
- Question about Rear Coilovers...
- Competitiom Engineering Adjustable Drag shocks?
- Rear or Suspension related problem under load
- Do Hal Shocks Need any Modifications??
- Question on 4-link suspension
- Caliper is locked up... ideas?
- Rotors
- Lightest strut tower brace?
- LCA install advice
- Pro kit and SLP Bilstein?
- High horsepower guys, what LCA's are you using?
- Noise from back end.
- Linelock Install?
- Need new brakes and rotors, suggestions...
- awesome info from LG about G-stop kit (sarcasm)
- hotchkis or eibach pro kit
- Fender gashing tire
- OPINIONS on MAC Springs ASAP
- Best susp. mods for 60FT WITH SLICKS (AUTO)
- BMR LCA's
- Homemade line lock
- rear height adjustment?
- Home made LCAs?
- Steering box?
- Koni SA's: Adjustable ride height?
- Whats the need for Dual Rod ends on LGs adjustabe?
- Suspension 101 -- school me :)
- Having problems with front brakes
- How much did you pay to have SFC's welded in?
- HAL Springs make car too low!
- Best Drag LCAs?
- E-Brake Problem
- whats needed?
- Rear springs for drag racing...
- C5 Front Brake Upgrade Question
- SLP Line-Lock Question?
- C5 calipers a direct bolt on for f-bodies?
- rear sway bar hitting 12 bolt?
- AERODYNAMICS and GOLF ?
- quick brake question
- brakes WILL not bleed!!!!!
- will bmr extreme TORQ-ARM work w/ bmr 'vert sub frames?
- best fitting sfc's
- newbie drop questions, please help..
- Anyone ever installed a line lock to block fluid to rear brakes?
- New Suspension and still getting wheel hop!!
- LCA install Question
- who has the new spohn torque arm that mounts to tranny?
- inner wheel lip ground off on one side??
- Sfc?
- Usefull links-DIY alignment, torque specs, etc
- V6 springs for racing
- HELP! How to adjust HAL springs?
- What SFC to use?
- Hotchkis TVS system
- Have Revalved Bilsteins, What springs?
- Edelbroke Torque Arm...
- Anyone ever have a HAL shock blow out?
- Torque Arm replacement...pros & cons
- Installed Bilstien HD's and stock springs?
- Looking to lower it
- Eibach Prokit VS Suspension Techniques?
- Traction Package
- ABS kicks in at low speeds
- C5 Brakes on Trans AM
- How much do 17" wheels help handling?
- Trouble with SLP bolt on SFC's Rusting?
- New Suspension Done, Finally...
- New rotors
- Clearance question
- Speedbump+Rear End=SQUEAK!!
- what to pick for rear rotors?
- About to buy SLP SFC's..Last min. HELP!
- Can I switch subframe connectors?
- New Sponsor Cross Drilled Slotted Rotors 98-02 Camaro/firebird 289.00 Complete Set
- Front bushings stock, 1LE, or poly
- Problem with G2 Torque Arm
- broken studs ... heh
- when do i need sfc's??
- spohn's new torque arm (stock mounting location) won't fit with my headers
- Z28 and SS Springs?
- Special Deal On 93-97 Camaro V8 Rotors Drilled And Slotted Zinc Plated
- HELP, Tire Place Messed Up My Car!!!
- Rear Shock Tower Brace?
- suspension help
- New Suspension
- Springs and shocks
- new rotors and pads
- Advice on rotors and pads
- Any one with a 1.60 or better 60ft.please help
- Swaybar Fasteners
- Next Focus is on handling, help please
- Help installing front springs/shocks!
- what next....
- Line Lock Switch in Ashtray
- Cracks on/in a rotor?
- Do you bolt in "weld on" LCA brackets first?
- just got my lg motorsports g2 sfcs welded in
- ANyone using...
- brake and abs inop light on!!
- problem installing the BMR tubular SFC's...
- Raybestos Quietstops for the rear at Pep boys
- SFC's?
- Does eibach make drag launch kit
- 2 types of fluid on master cylinder
- Parking Brake Woes...
- Wicked bad wheel hop
- ABS INOP, LOW TRAC, Brake light come on over bumps, harsh accelleration
- Those with Heater Hose on rears
- I feel like buying SFCs today
- lowered car with wide tires....
- can BMR TA handle 10 second passes?
- Help On Abs!!
- Energy suspension Poly Tranny Mount
- OEM Calipers
- Good Company for 82-92 SFC's??
- Global West SFC help!!!
- will the carpet get burnt......??
- What are the best springs...
- What size are our rotors?
- SLP Bilsteins or Bilstein HDs (to go with 1LE springs?)
- BMR ta great mod
- Wilwood Pad change?
- people with hal shocks and springs??
- help me upgrade my suspension
- Cracked, Broken, or warped new rotors?
- Metal brake pad clips rubbing on rotor!
- E-Brake Problem I Think
- Spohn Torque Arm
- suspension noises?
- brake trouble
- Need BMR k-member install help.
- What shocks will complement my Sportlines.
- Need some help choosing alinment specs.(?)
- Swaybar Question, Which One?
- Remove rear parking brake pads
- lower ca dif????
- Help Lowtrac light comes on all time with stock wheels on!
- Which LCA's should I get? My 60ft times suck!
- help with bmr k-member
- Front wheels caked in brake dust...always.
- LCA's and NON-wheel hop traction problems
- BMR vs. SLP torque arm??
- What shocks with Hyperco's?
- Tire pull? (alignment specs in check)
- Stupid question....
- New brakes squeal when not under pressure
- 99-2002 rear disc brakes on older 8.5 10 bolt?
- wheel hop?
- rear drum to disc question
- bmr torq arm trac pac the way to go?
- What rotors to get?
- Suspension setup?
- WTF is goin on with my car??
