View Full Version : Suspension & Brakes
- TA in AK Baer brake help
- Brake Upgrade Recommendation.
- Went to clean rear wheel speed sensor and found this
- LCA relocation brackets install
- Pinion angle reassurance
- 1982 - 2002 GM Rear Control Arm Bolt Upgrade Kit: What is the thread callout...?
- What shocks/springs for a 97 SS bone stock car
- Upper control arm mounting bolts for 2nd Gen F-Body.
- stainless brake lines for lt1 car
- Front Koni str.t bushing replacement?
- Lower A Arm rear bushing question
- Front shock boot/bellow orientation
- Anyone run 315s and bump stops on a fourth gen?
- Another LT1 to LS1 brake upgrade question
- 2004 GTO suspension
- 10+Year Odd Front Tire Wear (WS6 Vert)
- my review of vikings, not good
- Moog lower balljoint question
- Installing Bolt-on SFCs..
- replacement ball joints for lower tubular control arms
- What's the next step up from Koni Sports for Road Race/AutoX?(4th gen Cam)
- opinions on necessary rear suspension upgrades
- Brake Capilar Blots
- Steering rack ratios, fe2, f41
- subframe connector
- Strano Performance Parts update as of 5/1/17, and a reminder of
- UMI Releases New Product: Delrin Steering Rack Bushings for the 93-02 GM F-Body
- ABS Delete
- Viking Coilover Install: My experience
- Need some rebound adjusting tips
- Front LT1 to LS1 Brake Swap Line Question
- 5th gen ZL1 brakes on a 4th gen Camaro
- C5 brakes with 17" Torque Thrust IIs?
- New one piece strut spring compressor rental tool at Az
- Project Log: Road Race Suspension & Brake Upgrade !LOTS OF PICS!
- rear end or not?
- rear end or not?
- Koni DA rebound(upper) adjustment issue and other shock/spring installation questions
- Very Sloppy Car
- Power rack hose location
- BMR Suspension's 4th Gen Camaro Handling Project - OFFICIAL BUILD THREAD
- Looking for someone whose installed a Wolfe racecraft 8.50 cage in a t top fbody
- Poly bushings
- 70SS nova ls1 suspension help - spinning problems
- Panhard relocation on a lowered car?
- Loose steering box on my nova
- Rear Caliper Bracket Bolts - Torque 'em!!
- Front UCA ball joint dust boot
- Brake Pedal Pushrod Removal from Booster.
- ABS Inop, Brake, and Service Vehicle
- Went a little "cheap" and it bit me hard! Need some advice.
- LS1 Springs
- Another abs issue after rear install, only different
- Rear ride height is different from each other after spring coil install
- how to remove lower control arm bolts?
- Power Steering Issues.
- Which springs if i remove Stranos?
- Replacing Front Lower Control Arm
- strange brake issue
- steering shaft problem
- BMR Suspension New Product-Billet Saddle & Delrin Bushing Kits for 1 3/8" Sway Bars
- Air Suspension - Pressure Gauges
- Budget Manual Rack ?
- Need help with rear brake upgrade
- Suspension Question
- AFCO rear coilover springs
- 02 Camaro SS Complete BMR Suspension Package???
- Paging Sam Strano!
- Shocks no decompressing after trip to drag strip
- Need suggestions for wheel spacers
- spring noise 98 camaro
- Rear pad selection
- Best Budget Suspension Upgrades?
- Strange brake failure caused accident??
- Can this be removed and reinstalled?
- 4th Gen Front Wheel Bearing Bolts
- C4 C5 C6 IFS weight vs f body stock and performance
- Part number for this?
- Actual performance results of brake conversions
- What bushing for stock torque arm & BMR relocation crossmember?
- My seal in the cap of my master cylinder is swollen?
- Are ATS 4 piston Brembros as strong as the GEN CTS-V/GEN5 Camaro Brembros
- Driver side splash shield
- Best Pinion angle to start with?
- Strano bars powder coated
- Question about Lubricating Poly Bushings during install in Control Arms
- 2000 SS Brake Rotor Recommendations
- Do 3-channel brakes have Ice Mode
- What rear brakes for champion rims please help
- Suspension for the road
- What torque arm and sway bar for twisties? Tire size?
- Help with new shock and spring install.
- Spring isolator to lower rear?
- Does Nut come with GM # 10164163 Camber Bolt for Front Lower Control Arm?
- The Best Replacement Shocks
- Preparing to go Autocrossing this summer. Suspension suggestions?
- Lowering/Wheel Clearance for '06-'09 Impala SS
- wanting to run the new Black Stripster With XV Beadlock
- Is this balljoint trashed?
- MWC Watts Link Installed
- Race Stars - Best brakes?
- Torque arm pivot link adjustment
- ABS to Master hardline replacement?
- car sounds like a barking seal when turning
- Adjusting Viking coilovers for drag
- anybody look into this? opinions for rear brake upgrade
- SAE solid rod ends with OEM metric bolts
- BMR Torque Arm
- Spohn K member 704-Akit for an 97 LTX
- Steering Shaft Question
- Front lower control arm bolt stuck in sleeve
- Putting together a build, would like some input
- UMI Product Update: 4th Gen Shock Tower Brace Now Available in Satin Black
- How to?? CTSV Brembo 4-piston REAR brake swap for fourth gen
- best street suspension with S60 axle
- Front Brake Lines
- Rear brake dust boot
- Ls1 steering column weld?
- Keep Losing Spring Isolator
- help me find the brake fitting I need
- 7 Mods to Make the 4th Generation Camaro/Firebird Handle Better
- ABS inop safety question.
- Opinions needed
- KW Variant 3 coil-over kit rebate, $150.00 3/1-4/30/2017
- Koni Shocks, spring 2017 version. 3/1-5/31
- UMI Releases New Product: Front Sway Bar Reinforcements for the 1993-2002 GM F-Body
- 98 camaro , benefits of upper and lower adj A-arms
- 2000 Trans Am Wheel Hop
- Looking for 4th gen fbody coilover setup. Help please?
- Stock SS wheels. Best brakes?
- LT1 Fbody Rear Brake Diagram
- Rear Viking coil over install time ?
- Installing TA relocation bracket
- Tracktion Trouble
- Pressing out bushings
- Abs light after ctsv brake install?
- Vikings settings for Street and Strip. What has worked best for you?
- So who makes the highest stb?
- Front hub assemblies without abs sensor?
- Rear sway bar upgrade
- Hard pedal and locking up brakes
- Pulling to the right when braking
- Back to stock ride height
- 2000 firebird brake problem
- What height are you guys running your Viking DA Coilovers
- New Item: Strano Performance Parts Master Cylinder Brace for all 93-02 cars
- Anybody just do suspension ?
- Whose A Arms are these?
- Will I need the torque arm relocation kit ?
- Strano spring question
- A brief review of LCA relocation brackets on a lowered car
- BMR Suspension New Product - Third Gen F-Body Lowering Springs - SP096
- Need help just bought some adj.strange shocks
- New Midwest Chassis TQ arm and vibration issue
- Springs for spohn double adjustable rear shock
- single or double adjustable rear shocks?
- C6 z06 calipers
- C6 calipers
- Koni Double Adjustable Shocks Spring Perch Question
- Strano or UMI lowering springs
- Newbie trying to do rear end
- Springs or coil overs ?
- 3.89 or 4.11 gears ?
- Suspension before engine mods
- How to tell if car is lowered
- Alignment issues possibly
- Torque arm ?
- Alignment question after 9 inch
- Help installing umi boxed lower a-arms
- A little help for a newbie buying parts.
- New & Better Price to our Road Race Package
- What's my shocks/ springs worth
- Brake ducts
- UMI Release New Product: Upgraded Adj. Front Upper A-arms for the 93-02 GM F-Body
- torque arm mod?
- Is this the stock sway bar?
- Size of Caliper Bracket Mounting Bolt?
- Need Steering Rack Advice
- 2000 TransAm EBCM only?
- Lowering Car and Kmember
- adding spacers on front wheels require new alignment?
- Need Rear Brake Help on a 95Z28
- differntial torque arm clamshell mount
- Rear Brake Pads
- Torque arm clunk
- 1000hp street car what front brakes.
- 10307912
- Gabriel ReadyMount
- Which suspension will best fit my goals? Budget friendly!
- looking for ABS delete info after 9 inch install
- Daily Driver Suspension Help????
- Bmr lowering springs
- Is 28.5 inches roughly stock ride height
- TRZ anti roll bar
- Hawk HPS 5.0 Pads Compared to HPS or HP+
- need new brakes, let me learn from your mistakes!
- New Control Arms, Panhard Bar & Relocation Brackets installed on our 2002 Z28
- subframe connectors
- Need help, 4 channel brake line routing
- Help! routing of brake lines for Hust lineLock
- 1994 LT1 FSM Brake Pressure Bleeding Procedure & Questions
- Whats a good rear lca angle for a 4th gen thats geared towards handling
- alignment questiona
- Coil Overs vs. Upgraded Stock Setup
- Steering linkage too short after steering column installation
- 2000 T/A Wanders
- Wheel moves when applying brakes.
- quick question
- pedal goes soft when braking
- RideTech v/s Viking
- 96 Sonoma ABS
- What are symptoms of a bad abs pump/block, not module
- Koni Str.t shocks lower bushing issues
- BMR turbo K-member install issue
- 68 chevelle with 14 inch C6 front brakes
- 97 trans am ws6 rear brakes
- New alignment tracking around on road, what settings?
- '70 Camaro - Reman Steering Box vs Aftermarket?
- What size fittings for brake lines?
- Power Steering Fluid
- Rack and pinion
- Rack and pinion
- Calling BMR or anybody else who has this
- Upper Control Arm Replacement
- Info on DIY ABS
- New tie rod ends dont have castle nuts
- My Condensed Brembo Upgrade Cheat Sheet
- Bilstein step by step installation
- Merry Christmas from all of us at UMI Performance!
- Brake System Mods and Upgrade FAQ
- Which part keeps the transmission from lifting during acceleration?
- UMI Christmas Sale- 10% Off, Free Shipping & Free Apparel
- Side winder
- BMR Suspension Christmas Sale!
- Calipers: buy them bare and install the rubber myself...is it hard?
- DIY f-body hydroboost on the cheap
- Suspension Problem: Hard KaBANG! Over Dips
- Review of the CTS-V Brembos video inside!
- Feels like a tank. Time for a refresh
- What spring for strange s5271
- Watt's Link question
- Code U1040 Loss of Comm with ABS/TCS - 2000 Z/28, any solutions?
- Rear Drag bar
- Lack of Vacuum for Brakes
- LS swapped 03 GT Having powersteering and hydroboost issues
- Emergency Brake Light
- Drag Suspension Tuning Questions – Very Long
- Trans Am Shock Tower Brace....
