View Full Version : Suspension & Brakes
- Torque Arm question
- Did I luck out with my Koni install?
- Front brakes, issues, need advice..
- c5 rear brakes?
- FREE Suspension Part from BMR Fabrication
- qa1
- Drop it like its hot!
- Suspension Mods - Where to Start?
- Strano Front sway bar install
- clicking sound? what is it
- my BRAND new Koni BROKE during istall... WTF?! pics included
- Just got my UMI LCAs
- Will SA's suffice for car w/ moser 9"?
- Where to Buy Koni's
- Strano front sway problems
- c5 calipers with stock camaro rotors?
- Frozen caliper slide pins - where to get parts.
- 2-3 shift clunk
- Is This What a "Warped" Rotor Looks Like?
- I Guess I Need New Rotors...
- Panhard Bar
- Car sits 3/4 inch higher with dana 60 rear
- Trouble with changing
- Boxed weld in subframes or Tube Bolt ins?
- A Must for All Lowered Cars
- grinding booboo
- aerospace rear brakes weld wheels
- Koni installation woes.
- Raised rear end suspension question??
- Panhard bar
- EIBACH springs
- Manual rack with 275 tire size?
- Question on Lower Control Arm Relocation Brackets
- S&w Torque Arm Good Or Bad?
- Adj. pan hard bar q's.
- spohn adj phr
- Upgrading Steering in 93-97 LT1 T/A Questions
- Koni shocks, LS1 springs on LT1
- Pics of the prokit*
- stock shock replacement question
- cheap front drag shocks?
- Strano Springs.... not in stock yet, but getting closer
- No one has Bilsteins, on back order, what is a good shock to use
- Hotchkis front springs install
- Alston Torque Arm? any luck?
- Rear Spring Isolatore Removed
- Weld in SFC question
- Strano springs and stock shocks?
- Convertible K-members
- Hotchkis and 315's?? compatible ?
- What kind of suspension only gains have you guys seen?
- Does any one know what torque arm I have.
- Do i have to jack up the entire car.....
- Good setup?
- Dana 60 & Lowering Springs
- Spohn Tubular K-Member Questions
- Which shocks?
- Bleeding Brakes?
- Quick Suspension Question
- sway bars on or off
- Need help picking a torque arm!!!
- ABS issues
- How does this setup sound?
- 2002 Impala quick strut - How to suggestions?
- Strange Pro Steel front brake kit
- *Sneak Peek* TTP's New 4130 Subframe Connectors
- Spohn TA
- Strano Performance is open again--back from my trip
- making your own drag bar?
- Rear Brake Bias problem
- ok so heres my problem
- SSTB Front Force 10 4-Piston Aluminum Caliper? kit
- 2 c5 passenger side calipers, can i convert 1 to driver side? help
- Brakes:
- Pics of Strano Springs and Konis?
- first suspension parts
- Shock choices
- New rotor/pad install gone wrong. Help?
- Noisy suspension?
- What shocks?
- ok what trq arm?
- Which shocks for BMR springs?
- Which Drag Sway Bar have you all been successful with???
- torque arm angle????
- ls1 brake conversion
- C5 Rotor Question
- SJM Line-Lock Install Write-up?
- Stainless braided brake lines?????
- TRYING 2 ADJUST KONI's???
- wheel hop
- how to fix wheel hop?
- About to install my Koni's.. Just a couple questions
- Brake fluid?
- Post Pics Of Your Drop....
- midwest crossmember doesn't fit HELP!!!
- Pro Kit vs. Sportlines
- torque arm install questions.
- Questions RE: c5/c6 brake upgrade w/ LG brackets
- KYB front install question
- pinion angle
- 1LE springs
- Full Suspension
- '94-'99 1Le suspension - rear sway bar
- Need help with Bilstein springs!
- Strano sway bars = awesome
- Help with lower control arms please!!!
- Brake Noise
- Powerslot brakes?
- 60ft times
- Abs Delete
- 12 bolt or 9in for Autox?
- Opinions on this Ride Height/Stance
- What Shocks?
- Used Pro kit good?
- Springs with SLP long tubes
- Two different springs?
- c5 suspension?
- Need your opinions
- Summit racing springs
- Win a FREE Torque Arm from BMR Fabrication!!!!
- Penske Update
- suspention ?
- spohn adjustable torque arm hitting tunnel
- 98 Trans am Spring question?
- Fbodies racing on speed TV
- shocks and struts question????
- Quesiton bout new rotors/pads..
- drag set up
- My SJM ABS Delete install pic
- alignment b4 or does not matter
- Question about air bags for rear suspension
- True duals with pro-kit??
- PEDDER's DAY MARCH 1st !!
- Which Caliper Repair Kit?
- replacing the stock power rack...where should I get one
- Suspension work
- KYB AGX Guys, question about stiffness.
- Car bending rotors?
- Electrical and Fire considerations welding SFC
- Manual Rack and Pinion
- Twiggy's up front!!!
- This, That, or Both?
- Trouble removing lower control arms(A-Arm)
- torque arm mount
- Need rotor advice
- Floor mount vs stock length vs cross bar mount
- Clunk
- Quicker steering?
- vibrating help
- Koni SA with stock '01 Z28 springs vs Strano springs
- Is This A Good Deal On Brake Rotors
- Ball joints and Control arm bushings??
- hawk pads?
- need end link part number energy suspention
- Will panhard bar fix this?
- Brake time
- LCA relocation brackets?
- G2 super springs with konis question
- I love my Strano/Koni suspension!
- Which LCA's??
- "AG" lowering springs???
- nbm hotchis drop
- What springs
- welding sub frame connectors
- Eibach Drag-Launch Springs
- stock springs with strange shocks???
- painting drag brakes?
- q about strano springs...
- bushing size
- rear brakes
- lightest rear race brakes? strange,wilwood,aerospace?
- time to replace advice please
- a little help
- 4-link vs tri 4-link
- Why my front end is wandering, suspension or tires?
- front koni install help
- Front sway bar removal
- Question about fitting wider tires
- Needing a brake upgrade, pads worn, rear rotors possibly warped
- salad shooter + LS1 brakes =?
- Closing from Feb 20-25
- Coil Over Kits
- Sway bar end link sets
- optimal settings 4 Qa1 shocks
- Time to Lower it
- my shock system is a little too hard for my liking. how do i get it to be smoother?
- Probably a dumb question...
- Hey is this company legit?
- Strano bar question
- Line Lock Switch install locations
- a strong 7.5 rear-end?
- Thread pitch and size from the master to the ABS unit
- Lost on rear shock replacement...
- Interest in 4130 "Chromemoly" SFC's??
- help right now please
- Anyone make there own harness bar?
- 1 1/2"
- roll bar/cage question
- 3 point subframe connectors
- IRS in an f-body
- Power steering frustrations..lol
- 1 bolt shy of removing my lower control arm...help!
- Gound control coil-over kit????
- pics of prokit
- Spring rate and ??
- Used front hubs ticking
- LCAs - Making them
- Can a Rear Caliper be Rebuilt???
- spring swap
- how much of an improvement would I see from upgrading Shocks?
- Brake Issue
- New Suspension Installed
- c5 brakes
- Brake Bleeder's Leaking Around Threads Help
- Is this a Problem? UMI PHB Rod End
- compensating for a 12-bolt
- Trany mount replacement causing vibrations.
- carwont hook..help
- koni 4/3 shocks strano springs and sway bars
- What are your around town driving impressions of the 02 WS6?
- which company to get suspension from...
- My car car may be lowered. How do I know?
- SJM I need some help here
- DeCarbon shocks?
- lowering my car?
- Torque Arm delete
- Emergency brake needs tightening?
- ABS block?
- i need to lower my car a little bit...
- front QA1 shock nut size?
- spring
- caster plate???????
- anyone have the black zinc palted ebc rotors?
- drum to disk brake conversion
- Qa1 shock leaking oil
- Ceramic Hawk pads ok on the street??
- ProKit, Sportlines, or Stranos, with tt2's? Please help
- Pro-kit front, Strano rear springs, PICS
- part numbers needed pls.
- stranos swaybar and 9"
- Brembo/Powerstop Slotted Rotors
- Drag suspension
- Brake Fluid Change?
- lost
- Koni 4/4
- aftermarket k member
- What is a knuckle???
- SLP springs
- Wholesale Direct
- Torque arm...which body mount is the best...
