- What color wire is postive on coil?
- long time forum reader, first time poster
- cam swap?
- install pricing?
- how do posts count?
- Engine noise! Crank Pulley?
- Please Help
- Need Some Quick Help
- LS6 Intake or FAST?
- Tire size question
- ARH Headers!!!
- Can't get full throttle
- dyno tune with a catback???
- Vals Auto Highly Recommended dyno numbers
- Advice Needed.......
- how much hp can a stock LS1 handle
- Car pulling under hard braking
- LS1 oil pan off - recommendations?
- Underdrive Pulleys?
- LS2 heads - center or perimeter bolt covers?
- 160* thermo
- Dyno Lottery
- new exhaust questions
- Need help with oil pan sealant
- Nbm???
- different maf question
- descreening my maf?????
- temp guage
- 02 T/a Ws6
- pushrod length
- 2000 Camaro SS blinker issue
- ok newbie has 2 questions...
- Problems with shifting
- Can a warped rotor throw a tire out of balance?
- Just bought WS6 and have a question on the heads
- how much power can u get from blower?
- Stall / shift kit / traction questions
- question on 02 ta #s
- Are these stock heads?
- adding freon in LS1
- Bicycle Rack?
- Do I need the windage tray?
- Just got a 01 with a catback...
- Bad GTO Drag Times
- Oil Pressure Question
- looking for 450-475rwhp
- need bolts for a/c compressor,lines...
- Having to shift to much
- anyone want to help me???
- I have set my Goal!
- What BILSTEIN'S and Labor
- window motor help
- MTI lid wont fit!!??
- Fresh LS1 for the modding
- Maf
- oil possessed camaro
- Advise me on heads
- LS1 clutch-intake-oil pan question.
- 6.0 Tow Motor
- misfiring at WOT, changed plugs
- Opinions and Install?`
- Can someone help me out with the spec of these motors
- Putting Car into Park Problem
- Y-pipe Question
- how important is it to get a dyno tune?
- 2 wire temp gauge troubles, surging idle
- amp gauge
- xtreme vision hid knock offs..
- suspension mods...
- fuel pump relay
- Ls1 Swap
- New to the board and the GM community...
- Stock dyno numbers
- anywhere in virginia to get a dyno tune
- Dumb Question... I apologize...please help
- Fans
- Lid opinions vs. Newbie FAQ
- A couple of 98-02 F-body questions
- Oil leak
- 4,500 RPM sputter....
- Question about headers(yea i know....)
- poly motor mounts
- 1/4 mile question!!!!
- Spark Plugs!!!
- air pump
- Check Gauges light
- A/C leaking? inside on floorboard
- Just bought WS6/Questions
- stock ls2 gto 1/4's
- mufflex y pipe
- Is there any difference between WS6 springs, and regular springs from a T/A or Z28?
- Extreme Performance In Okc
- spun a bearing!!!!
- slp loud mouth and header help
- Noise from rear ...
- want to know the diffrant btween
- ORY probs...
- RPMS Hanging while Shifting
- What mod first
- weiand mainfold done blown up?
- help with cam
- 42k miles, can i switch to synthetic oil NOW?
- loud rubbing noise when i push gas pedal..?02 a4 ta
- Order of mods on a limited budget (sort of long, need advice)
- Engine Stumble
- Replacing the steering wheel
- O2 sims
- What are the belts on the LS1
- Air Noise at High Speeds?
- ls1 quarter mile time
- LT1 Headers on an LS1?
- rear end opinion 3.73 or 4.11?
- What Is The Weakest Link In A F Body?
- What kind of car, engine??
- Mod Marker
- pushrod job complete?? Running sluggish?
- Tune
- How can I distinguish LS1 block
- weird noise
- Low coolant light ??? new to ls1's
- how much shud this cost?
- LCA relocation Brackets???
- exhaust?
- Ttop shades
- LS1 lifting question
- Concers with SLP line lock
- best combination of cams & heads
- battery problem (i hope)
- Help!! Choppy idle/service engine light after ported maf end install!
- changing gears on a4 trans am
- Lower Control Arms WTF?
- Newbie ???
- Lo Input To Maf Code 102
- AIR gasket
- Security light
- What causes a car to backfire?
- Any "How to" on removing all pulleys and accessories?
- I am retarded. (broke antenna)
- About to install Pro 5.0
- Window Fun!
- Complete Head Gasket Kit
- Limp mode with SES light?
- pop in reverse
- Vibration after LT Header Install
- Can a tune do this?
- what'll this run?
- difference when installing ls7 lifters over stock?
- pacesetter vs flowtech longtube headers
- Will this work????a/c compressor off of a 5.3
- Have you ever had to have your lifters and pushros replaced?
- Hey!
- HELP!!!! Cats on TD's????
- anyone have images of how to remove a fuel line at manifold
- Well need a little help
- help?
- How to post up pictures in threads???
- estimated time with this...
- Grinding noise from the rear - 99 SS
- 160F Thermostat!!!
- 2002 stock gear ratio
- Z28 and Z28 SS. What's the difference.
- give me your TD input
- TCS wont turn on?
- Another Question!?
- Need Help...Codes
- what would you do?
- What to Expect from a Cam?
- Please Carfax Needed Very Urgent!!!!
- exhaust for corvette
- Headers@tune
- $80 /hour labor?
- car shakes after WOT (especially when cold)
- What should I expect with this setup.
- just startin on my 99 Z
- Skip shift nonsense
- fluids and maintenance, any other suggestions?
- Axle Shifting?
- hey guys need a quick answer
- Drag Racing Basics(A4)?
- is it a 4.8 or 5.3?
- parts we can use from a junkyard
- header question
- Sub-frame connectors question.
- oil pressure question
- Should I get a tune?
- identifying ls7 lifters
- Oil change light comes on then goes off Need help
- stock block HP
- Help with shift knob
- hp added...
- T/A magazine?
- What free mods can u do to a C5 coupe
- drag tires. which is best?
- Floor mats
- 4,500 rpm sputter...
- What!?!?!
- A question about engines???
- tires out of round???
- valve lift/power with rpm
- Where to get a parts numbers/catalog?
- Bad Fuel Injectors Causing Failed Inspection?
- Gauges
- what engine should i use?
- squeaking in back...
- finally got my lt headers on
- fuel pressure bouncing
- noise in engine
- Quick intro and first question
- new lifters what kind?
- Starting a LS1 build. Need advice please.
- MAF wiring
- Help disconnecting slave cylinder
- C5 Corvette
- Ticking From Lifters?
- ??? about 3rd brake light 98ss
- Weird noise in car?
- tune vs. shocks/swaybars
- gauge cluster background
- How does this setup sound
- crackling sound
- What ignition is this?
- ls6 engine
- how do you know if its a4 or m6
- Straight coolant?
- Got A SS!
- spark plug ques.
- AIR system question
- Shortblock Rebuilt!?
- Exhaust help for a newb...
- Intermittant wont start
- Dyno'd my car. Very disappointed.....
- how to blackout the front and back side markers?
- Need headers any suggestions
- swap a4 to m6 on a trans am ..is it possibble?
- Will kook's Y-pipe work with Pacesetters?
- Lights Flickering
- Completed LT install, funny noise
- What would make a more reliable 450-500whp set-up?
- Who Wants to guess!!!
- car check
- A.I.R. removal
- True duals..
- ram air question
- C6 Z06 rear end?
- Drag tires
- Need Help Calculating Final Gear Ratio
- need advice about installing headers.
- Sluggish motor
- 02 Camaro Z28 wont start, need help!
- Help needed BADLY
