View Full Version : Drag Racing Tech
  1. francis johnsons 4.66 run
  2. Problem with slick, cord seperation?
  3. what tire pressure for et drags?
  4. Running no air filter at track?
  5. Clutch Recommendation
  6. Race brakes?
  7. Help wiring aftermarket th400 shifter to P/N saftey switch
  8. weight reduction help for a DD 02 trans am
  9. Shelf life on Mickey Thompson Drag radails?
  10. Crack in Windshield=no racing?
  11. UMI upper control arms
  12. New DMH Carbon Product: Mirror block off plates
  13. Damn suspension!!!!
  14. zr1 17x11 vs. weld 15x10
  15. LS1 throttle stop??
  16. video of my car launching
  17. Which drag radial?
  18. lsi conversion to carb and dist
  19. Help me keep my Car Cool!!!!!
  20. tach signal
  21. Rear Coil Springs Help
  22. How should I launch my M6 car tomorrow?
  23. Those of you with an Accufab 4-barrell TB
  24. My Stock Internal M6 buid thread...10's???
  25. 325-50/r15 drag radial what front tires
  26. Wheel Spacer Suggestions
  27. Cost effective dry sump setup
  28. Too much gear for an A4?
  29. What brand gear should I go with?
  30. Building a race car? Document it here!
  31. Anybody know the stock block record??
  32. Mounting BCM after hvac delete?
  33. Newbie LT1 guy Needs some advice
  34. How true is Density Altitude and drag racing?
  35. Fuel Cell Placement
  36. Wireing thoughts. Lots of stuff to wire up. Need Ideas
  37. Burkhart bumper support questions
  38. Physics behind increasing hp but lowering tq?
  39. Lug Question
  40. how to keep poer windows with aluminum/ carbon fiber door panels
  41. Top Times for All Stock Motor
  42. Lt1 fans bolt up to ls1?
  43. good data logger.
  44. Drag/Street suspension ????'s
  45. Am I losing THAT much with my converter?
  46. K-Members..Worth it?
  47. MT 325/50/15 Drag Radials what PSI
  48. Do I have to use a window switch with 12 bolt
  49. show pics of drag exhaust setup
  50. stock wiring harness
  51. ANOTHER Tire/wheel question. Sorry guys haha
  52. Which Torque Arm?
  53. Cloyes ?
  54. Convo Pro wheel question......
  55. Screw in Bias Ply
  56. Lets see pics of who has 5 point harnesses in car with NO cage
  57. Who ACTUALLY does this???
  58. 4:10's or 3:90's
  59. What have you done to your car that other people over look?
  60. who's torque arm is this? pic inside
  61. what dipstick are you guys running with TH400 in fbody
  62. deleting BCM?
  63. skinny tires
  64. Hoosier QTP Vs MT Drag Radial?
  65. Camscam's 10 point cage install thread
  66. how much does a D.A panhard chromoly bar weigh?
  67. UMI stage 6
  68. does anyone have a write up on removing the complete ac system in a camaro ?
  69. New Set-Up and Paint Job!
  70. Crank Weight
  71. Holley LS Fest, September 10-12, Bowling Green!!!
  72. Turbo 350 or 400 which one and why?
  73. UGHH! TH400 Safety Debate!
  74. rear sway bar
  75. More important PHB/Axle centering setup for launch...?
  76. what's my pinion angle?
  77. Anyone running a 28 x 10.5 radial on a 15" wheel?
  78. Aftermarket LT1 T-56 crossmember?
  79. Vidicator VS Magic Sticks
  80. HVAC delete and water pump fittings???
  81. one piece front end?
  82. K Member - Slots vs. Holes
  83. Change the cars not the track?
  84. strange 12 bolt and bumpstops?
  85. Cam only guys....
  86. New guy going to the track next week, 6 speed help.
  87. Are mt et streets considered a slick?
  88. For the OK and surrounding area bracket racers
  89. manual brake conversion with super hard pedal
  90. i need your help guys
  91. Ls1 for 300 buck!!! What to do?
  92. What tire to run in True Radial?
  93. Putting in harness?????
  94. Belt/Harness Question
  95. aftermarket coil brackets. Who makes them?
  96. cometic head gaskiet
  97. Those With Removed Bump Stops?
  98. How do I set up my front qa1s?
  99. Trying to hook on the street...
  100. What size mts would you use?
  101. Converter slip problem?
  102. A little info on racing tires please?
  103. Rear bulkhead
  104. Racecraft Inc. complete front suspension ?
  105. What Tire???
  106. Setting 3 way rear shocks for strip only
  107. HELP!!! Oiling issue
  108. How much spray?
  109. Anyone heading to numidia tonight in NEPA?
  110. How many passes do you think are left on these mts?
  111. Racecraft seat brackets?
  112. battery drain problem and hopeful fix
  113. Anybody running these at the track?
  114. No Holden Back - 2005 GTO build
  115. How do you guys race your 4l60e autos?
  116. SuperPro SD tune (IAT's etc.)
  117. guys I need some help on making a couple decisions...
  118. More tire or less gear?
  119. dropping weight changing suspension settings?
  120. how important is this?
  121. Who has fit an Accufab on a Super Victor???
  122. Looking for 11's on street tires M6
  123. hoosier 315/35 17s on the street
  124. Help me decide tires for the front
  125. Who's manual rack for stock k-member mounts
  126. race pack
  127. 14's normal?
  128. What should I Trap?
  129. Track times!
  130. ls build
  131. Need some Kirkey's help!
  132. 9" Housing Questions
  133. 3.73s or 4.10s for H/C A4
  134. competition engineering cage?
  135. Torque / Tolerence Theory on Damper
  136. What did you paint your cage with?
  137. home made Kirkey seat brackets?
  138. best stall for a h/c/i 383 4.10 gear
  139. Best place to mount fuel pump?
  140. Madman torque arm
  141. HELP wolfe 8 pt.
  142. Need some help with diagnosing my 60ft problem
  143. Can i get into 12.999s ? :)
  144. Relocating your PCM
  145. Look at this cage....
  146. What else do I need.
  147. Change gears or change shift points?
  148. Tubular CM A-Arm, Panhard, LCA SPECIALS
  149. rim spining inside tire...maybe need rim screws?
  150. how advantageous is gearing? please share your results
  151. Battery Relocate...hooking up the shut off switch
  152. is this a good deal on this car? fully built camaro
  153. Leak in newish QTP`s
  154. mufflers off the header collectors...
  155. How picky are they about weather at drag strips?
  156. Battery Cutoff Switch
  157. Need pics asap of SJM abs delete only
  158. Can my SPOHN tq arm fit my 12 bolt
  159. which route to take for tires?
  160. Burkhart or MW chassis torque arm ??
  161. Help with breaking into 12s on street tires
  162. The low-down on Drag Wheels - SFI vs. non-SFI
  163. Pics of where everyone has their gauges mounted
  164. Will this shock/spring combo work for my setup?
  165. block front grill with sheet metal on 64 nova?
  166. Shock Settings? Cam Only 6 Speed Cars..
  167. C5 brakes and 15" skinnies
  168. QA1 12 way adjustables Question
  169. Gains form drag brakes?
  170. What else would you reccomend for my build?
  171. 11.7 @120mph???? Mods listed inside, Am I leaving some ET behind, INPUT PLEASE!!!!!
  172. How many of you guys drive your cars to the track?
  173. Pinion angle?
  174. Th400 vs 6sp Hp#s, very interesting outcome
  175. Next suspension mod, ordering next week.
  176. NPB with my Firehawk!
  177. Which Drag bar?
  178. Is it worth taking the car to the track with street tires?
  179. Drag only torque arm
  180. Bolt In 6 point
  181. best rmp to launch from?
  182. lowering a dragcar
  183. Suspension gurus! need setup assistance
  184. Will this work?
  185. New Joe Van hood style? maybe somebody w/ pics?
  186. i need cam choice help
  187. why are more people not trashing power brakes?
  188. 430s or 456s?
  189. Rear Sway Bar
  190. Jegs or Summit offbrand Prostars?
  191. Strange rear drag problem help!!
  192. So apparently I can't launch worth a $#!*
  193. Finally got a Sway Bar..Need Help!
  194. how much will a launch controller help?
  195. 6spd guys, what shifter knob are you using?
  196. 540+CI- 14:1 - 1 Kit - progressive - 275, help
  197. Exhaust idea, X pipe and no mufflers
  198. ls1 pistons
  199. To tube or not to tube.
  200. Launch vid included, could use constructive critisism
  201. How much did my 60 ft kill my time?
  202. Post pics of your 8 point cages
  203. not happy with new times
  204. Official Introduction / July 4th Sale
  205. 1/8th mile gear help
  206. Why is mini tubs more popular over a big tire car?
  207. School me on Subframe Connectors
  208. Shift kits in Drag Racing...
  209. Anyone want Ozite carpet?
  210. RaceCraft front suspension
  211. staging temp
  212. Removing Front Sway Bar?
  213. New Intake!!!
  214. Anyone make a new panhard bracket?
  215. What thread pattern for DS loop mounting bolts?
  216. Time for a Sway Bar
  217. Car won't hook after ALCA's. Why???
  218. setting up anti roll bar
  219. Hoosier dr vs mt dr
  220. Relocating drivers side fuse boxes under the dash.
  221. whos manual steering rack are you guys using?
  222. Any updates on the MWC front suspension setup?
  223. Next mod to reduce 60ft times
  224. Stripping down PCM/Body Harness of unneeded crap. Alot of info, but help needed!
  225. What tire pressure with 19in c6 wheels
  226. what low budget drag shocks should i get?
  227. Front SA shocks and springs or slicks?
  228. Fuel Cooler?
  229. Question about slicks
  230. '06 Silverado cage/4-link build
  231. Super Victor LS1 intake bolt torque???
  232. ideas on trimming bumper for 28x10.50
  233. ABS delete
  234. Spool Question,
  235. average wiring cost
  236. Whats it take to run 7.5 or less in the 1/8th?
  237. What size front runner are you guys using?
  238. Picked up my new car hauler today!!!
  239. wtb external fuel pump system
  240. Rim styles
  241. billet specialties fronts ??
  242. Anyone buy the ebay roll cage?
  243. Braking issues
  244. Help with picking a tire for turbo M6 car!!
  245. What do you guys think of my launches?
  246. Lets see you ported super vic
  247. T-tops...on or off for Drag strip
  248. Best PSI for drag radials and launch RPM
  249. Mocking up
  250. What does 1/10th lead look like on the track?
