PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. NX N-tercooler Questions & Pricing
  2. need sum mounting ideas for an nx solinoid and purge
  3. Where does the white wire go on msd window switch?
  4. Window Switch Help
  5. Is a FPSS really needed?
  6. Nitrous + My Cam = BOOM
  7. Problem with nitrous leaking
  8. where does the fuel pressure safty switch get installed?
  9. Stall and nitrous.
  10. No JETS 5177 NOS dry shot
  11. MAF Translator - Timing Controller - Necessary for Nitrous System on LT1?
  12. Looking for a good spray cam on stock heads
  13. Automatic cars without Window Switches ??
  14. New Bottle Bracket/heater
  15. Nitrous Refill?
  16. Window
  17. NX bottle PSI gauge seems to have liquid nitrous swimming inside. Is this normal?
  18. Anyone have their purge in the hoodscoop?
  19. No power coming from the relay
  20. Nitrous Jet on a LT1
  21. what do u guys think of the TR224 LSA114 for nitrous
  22. Would the Asa cam be good for N20
  23. Which MAF to run with 100shot nos
  24. Pics of my Dynotune Nitrous guage
  25. damnit, i cant make up my mind!
  26. A few quick questions for my A4
  27. Who makes the best bottle heater???
  28. window switch or not
  29. New help from Nitro Dave's
  30. NX Bottle heater. How long does it take to heat up your bottle?
  31. TNT: F1 or F2?
  32. direct port lines suck need help
  33. What would you do?
  34. NOS Noszle Kit...
  35. Gauge Install ???
  36. Why do LT1 dry kits come with fuel pumps?
  37. TNT's mail address
  38. DRY kit users, please help!
  39. NOS jet size ?
  40. What made you choose Nitrous ?
  41. 100 wet shot on stock tuning...how safe is it?
  42. More install pics... Finally done !
  43. Anyone ever have a problem with the TB sticking after spraying?
  44. how do you guys run the nitrous line to a mech. nitrous gauge?
  45. NGK TR6 plugs were to buy?
  46. Anyone spray with over 70k miles?
  47. NXL dyno clip
  48. how to hook up the rpm wire on nos rpm switch
  49. Is this a good deal?
  50. What are you heads/cam, nitrous guys running?
  51. how big a shot
  52. Any big shot sprayers use the timing tuner?
  53. Cam and Nitrous, will this work???
  54. Direct Port or NOSzle setup
  55. Those with Harlan Window switch & NX wet kit please chime in..
  56. Some nitrous theory.....
  57. New NOS NOSzle LS1 kit???
  58. Some questions
  59. Lifespan of TNT N20 Filter?
  60. Teflon paste in jets?
  61. 150-175 Wet Shot
  62. bottle mounting locations?
  63. new TNT kit help
  64. N.O.S. dry shot (100) + 382 stroker... how much timing?
  65. NOS Remote Opener Poll
  66. Newb getting NX wet kit this week. Any last suggestions or advice?
  67. WOT switch pics?
  68. Anybody added NO2 to their LSX yet?
  69. Here's a PDF with NX jet sizes...
  70. Congrats Tom Kempf and AP-enginnering
  71. Newb have questions on tnt kit
  72. Newb to nitrous. Have a few questions.
  73. Help me pick a cam....
  74. L-19 stud GP
  75. Question on return line for dp setup
  76. Where can I get a fuel cell for a Direct Port setup?
  77. nitrous line ?
  78. Need for Fuel Pump and Injectors?
  79. Wet kit for LS6?
  80. Mod Marker
  81. Gonna spray my a4, any do's/dont's??
  82. just installed a cam
  83. L19 head studs, who wants them???
  84. Need Help wiring NX/Mallory
  85. Sweet New Nitrous Kit
  86. torque differences between nxl/tnt
  87. Getting NXL installed at Speed next week, can I run 180 jets with my setup?
  88. nxl for lt1?
  89. How much torque increase with a TNT 150 shot on a N/A 436ci stroker putting down.....
  90. OMG NX is CRAZY
  91. Bosch 42 pound injectors with dry kit
  92. Best Gap Size when using Nitrous!
  93. Mixing Jets
  94. Where can i buy TNT???
  95. Heads/CAM cars, how much N2O to be sprayed?
  96. TRs new "T-ReX" camshaft and nitrous...
  97. TNT F1 150 shot Vidy & Chart
  98. Why no relay required for purge noid?
  99. Another - Progressive Controller Question
  100. who sells tnt wet kit for ls1
  101. Need help
  102. ordering nitrous TODAY where to buy from,what brand
  103. TNT question Please Help!
  104. NXL results/pics
  105. Dyno results (advice please)
  106. NOS Jet Size ??
  107. NXL guys. need install help
  108. NOS bottle brackets, the wide one, I need mounting hole measurements.
  109. Which activation switch do you have?
  110. High compression Nitrous question.
  111. any M6 guys spraying a 150 wet shot from the hole?
  112. ONE SWITCH; bottle opener, heat, arm??????
  113. Max shot on a 382
  114. Would I be pushing it???
  115. in middle of install, threaded holes in back of nxl rails?
  116. Great googly moogly.....
  117. N20 Push questions!
  118. Paging fireball...Experience about running a small nitrous shot
  119. Pics of NX wet kit install
  120. What gears would you run with a 409ci Nitrous setup?
  121. to those running nitrous main line down pass side of the car
  122. MSD Window Switch Install troubleshooting
  123. LSX intake and 90mm TB worth a damn????
  124. Can a FUEL CELL be used to feed a WET SHOT system????
  125. Front fuel cells for nitrous?
  126. Estimated times on 125 NX wet shot
  127. Nitrous backfires?
  128. schrader valve
  129. Are there any nos progressive controllers that work based on rpm's
  130. 98z28 A4 2.73 gears 100 wet shot 1/4 times?
  131. Anyone running a direct port on a LS1?
  132. LT1 nitrous kit
  133. thinking about spraying...
  134. Do they make these awesome switches for trans ams? Pics inside.
  135. whats so go about this "wet" stuff
  136. finnaly got running and cant wait for the spray.
  137. Newb Question About Nitrous...
  138. Please Help: List ALL of the Nitrous Companies that provide kits for the LS1 F-Body
  139. what parts do you need to convert a 5177 to a wet kit?
  140. Whats the biggest shot I can run with NX wet kit single nossle...150 or 200?
  141. A few newer pics of the system and car
  142. If you run a wet kit do you need to upgrade injectors?
  143. window switches
  144. Just got a refill station
  145. NOS 5177 on a Cold Air Intake
  146. methanol
  147. Nitrous torque converter experts question
  148. Using SMC alcohol injection as fuel for nitrous?????
  149. New TNT Kit
  150. How to hook up WOT switch?
  151. TNT?F1orF2??
  152. Going to juice up my SS, need some advice!
  153. Sort of a newbie question...
  154. Nos killing O2s!
  155. Solenoid mounting w/guage and purge
  156. Attn: Nitrodave or anyone else that can get NX parts
  157. My 150 shot NX dyno numbers and track times
  158. Adjusting fuel pressure safety switch without adjustable fuel pressure regulator...
  159. timing with the 5177
  160. Going lean... Help!
  161. 500rwhp M6 DR guys, got some questions.
  162. window switch question
  163. does the ls6 cam like the spray?
  164. Fried 3 o2's so far on 150 wet shot...
  165. n20 controller
  166. people with new pro shot foggers be carefull
  167. Question on installing direct port kit
  168. Plugs and N2O
  169. tnt f1 kit
  170. Low dyno numbers
  171. Satisfied with nitrous?
  172. Need Nitrous Pill Size Please
  173. TNT F2 vs NX Maf kit
  174. new to nitrous
  175. NX Maf Kit + Fuel Cell
  176. alchy on a dry setup
  177. pic request......
  178. New TNT Install
  179. New BMNracetech window switch
  180. Will lowering the window switch to 2500 rpm hurt?
  181. TNT F4 queston
  182. Who has a window switch for their nitrous set-up? Got a few questions.
  183. When should I spray?
  184. which jets to run
  185. Dry shot question
  186. will it work????
  187. i need advice on injectors?
  188. DP TNT F4 users
  189. 9 psi or 14 psi for stand alone fuel system?
  190. Jet ? with Edelbrock Kit
  191. 11.25:1
  192. pics of NX switch console?
  193. NXL smallest shot
  194. Need Advice on Nitrous Cam
  195. NX opener clutch - how tight?
  196. nitrous and newbie
  197. nx pressure heater switch?
  198. MSD Window Switch Modification ??
  199. stock with tr6's?
  200. How do I install the Nitrous Express Gauge on the bottle?
  201. Why not use pure oxygen?
  202. Is a nitrous gage legal in the car
  203. What do you think of this kit?
  204. Any progressive controller that will work by different gears and by rpm???
  205. Nossle kit stand alone fuel system for sale
  206. New to NOS
  207. What to buy?
  208. Is the timing tricker worth it ?
  209. 175 nitrous jets?
  210. Help a poor guy out
  211. Where can I buy individual pieces of the nos 5177 kit?
  212. Anyone have a direct port on a LSX intake?
  213. MSD window switch experts inside
  214. all motor
  215. Whoopass nitrogen push and new intake
  216. TNT F2 Smallest shot
  217. anybody use hydraulic hose for nitrous line?
  218. pic of my 5177 install
  219. Opinions on ring gap for big shots
  220. Will progessively holding 600 rwtq keep motor together on huge shot??
  221. What kind of pump do N20 refill stations use?
  222. Hotcam owners what are you spraying?
  223. NOS Question..
  224. Placing the nozzle in the throttle body?
  225. 85mm MAF and N2O (dry)?
  226. N20 guru's inside..What to do with this kit?
  227. fuel question
  228. 140+ traps without o-rings?
  229. i need plugs for nitrous (NOW)
  230. Best Place to buy misc NX parts
  231. Invented a new nitrogen push nitrous system
  232. Any pics of a NXL system installed?
  233. Mallory window switch wiring ??
  234. Silverado SS need suggestions....
  235. Nxl Users In Here
  236. Spraying but nothing is happening????
  237. Any good books to learn about the juice?
  238. Maximizer Settings
  239. trap speeds (100 shot dry)
  240. TNT jets and NX the same?
  241. Cut the stock time 13,5 with 150 shots.
  242. 10.089 @ 137.61 mph on ~600 rwhp
  243. Nitro Dave's Dyno Day Winner !!!
  244. nitrous newb question - how big of a shot on stock motor 100rwhp or 100fwhp?
  245. New systems for LS1`s on the horizon??
  246. Vote on where to place N20 purge (photoshop pics inside!)
  247. Guys with refill stations - where do you get your supply from?
  248. NX gauge
  249. Quick nitrous? 20* of timing and 5.3l heads ok?
  250. Brand New NX Direct Port kit For Sale!
