PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115
  1. TNT F1 Kit-What guages do I need? guage pod?
  2. Curious about N20?
  3. Will one 255L inline pump kit be good ??
  4. How is a "wet" system considered safer than a "dry" system??
  5. CompuCar bottle heater??
  6. Jet Sizes
  7. MSD Window Switch Question
  8. Pulling timing for Nitrous... Someone explain please
  9. Help me choose a kit
  10. NGK plug info...colder than TR6??
  11. 600rwhp with n20. have questions.
  12. NX MAF discharge system
  13. I need help with my Fuel Pressure Safety Switch
  14. Temperature affects on n20
  15. Long Tube's?
  16. VERY disappointed with my 75 shot
  17. Just bought a TNT F1 kit...:)
  18. Thinking of getting Nitrous, all you guys come on in?
  19. MAF High Freq. SES code during spray
  20. Nitrous Setup Question
  21. NEED HELP.. just bought a F1 kit... did I get the wrong kit??
  22. Purge question
  23. install question...
  24. 593 RWHP from a stock CID LS1 H/C + custom DP.
  25. 1/4 mile n2o tips
  26. Paging Onyx LS1
  27. 100 or 150 HP shot
  28. How much NOS on 382?
  29. Nitrous Warehouse
  30. How many peps in the 10's on Dry
  31. 1st timeslips on the bottle
  32. NX Gemini Twin MAF install pictures!!!
  33. Spray wired into trans-brake...
  34. How do I tell what my FPSS is set to?
  35. How much for rebuild
  36. NOS purge
  37. stock converter with spray...
  38. A little warning about Nitrous Express
  39. WOT switches....YES/NO?
  40. NOS bottle opener problems
  41. Woud I be alright with a TNT F2 kit??
  42. what jets t use on wet kit, H/C car?
  43. Need recommendation on a fuel gauge.
  44. FPSS setting?
  45. Very little gain going from 150-shot to 250-shot
  46. NOS switches
  47. Fuel solenoid stuck?
  48. Window switch, and switched 12v source?
  49. Dual-Stage Set-Ups
  50. Adjusting the Clutch on a NX bottle opener
  51. New to NOS
  52. Nitrous on H/C car?
  53. Nitrous on H/C car?
  54. Carbon Fiber 12pd!!!!!!
  55. LS1 Responsiveness to Nitrous..
  56. I want to trade my NX opener
  57. MSD rpm window switch install
  58. Testing my NX wet kit w/MSD window switch installed?????
  59. Does the pace work well with nitrous??
  60. How much for 255twin walbros?
  61. Installing wet tnt or nx
  62. Texas Nitrous Laws II
  63. My purge of intimidation is weak!
  64. Fuel and other questions.............
  65. IAT sensor and timing w/Nitrous
  66. TNT dry kit ?'s
  67. Can I see some pics....
  68. First pass with Dry N20, is this good???
  69. What size is the TNT blow down tube fitting??
  70. Dyno results with 100 and 125 shot ,plus a few N/A runs
  71. Most nitrous agressive cam for stock heads?
  72. Bottle Mounting??
  73. What's the biggest shot this motor will take?
  74. What size Injectors for a 250 shot
  75. Has any1 ran 11.50's or better w/a stock motor and an A4 w/a 3500# race weight?
  76. NOS bottle leak
  77. S2 Heads/cam w/ 100 shot????
  78. Nitrous wiring problems, need help!
  79. My NX N2O pressure gauge leaked!
  80. PROGRESSIVE CONTROLER ????
  81. NOS Illegal to use? laws?
  82. Really new to N20 got a question
  83. F.R.E.D Has anyone used one????
  84. FPSS......Question
  85. MSD RPM Switch......Question
  86. Mounting the bottle on the drive shaft hump in the back seat?
  87. Which bottle warmer has the strongest heating capabilities??
  88. Window Switch hook up
  89. NOS Q: How can the dealer tell you have used N2O?
  90. Timing tricker????
  91. NX Progressive Con.
  92. Where is the tach wire feed on a vette?
  93. When is Autometer coming out with their elec. nitrous pressure gauge??
  94. Any thoughts about the NX-Iceman solenoid...
  95. MSD window switch guys... pill info for ya!
  96. Bottle pressure question
  97. Looking for a set of new NX nitrous/fuel solenoids
  98. Finally, I got all my guages in.
  99. question about nitrous kit
  100. Need replies about tnt kit
  101. HELP......NX wet kit install with MSD/FPSS...what wire goes where?
  102. Can we actually get some answers this time around?
  103. TNT DRY KIT NEVER USED $500
  104. Any NX bottle heaters for sell?
  105. Spraying through the FTRA???
  106. First time to spray today, it was cool.
  107. A4 and nitrous
  108. LOOKING FOR AN N20 NOID
  109. Anyone want to trade MSD pills?
  110. Pros and Cons of spraying with a TNT wet kit?
  111. Who has trapped 125 or better w/ a stock motor+Nitrous?
  112. NX kits or TNT kits
  113. Where to buy progressive controller for LS1?
  114. Fuel Solenoid Failed Today
  115. install of msd window switch
  116. How long can the hose from the solenoid to the jets be?
  117. nitrous kicks ass !
  118. Who here has tried propane injection?
  119. 112 lobe seperation ok for N20?
  120. 2nd stage is on...time to really have fun
  121. Need a TPS swithc, Schematics? anybody.
  122. Running dual nitrous solenoids on a wet kit
  123. Injector Question
  124. WHICH N2O SYSTEM WOULD U BUY ?
  125. Who knows someone who has blown thier motor when using nitrous???
  126. Re installing NX bottle opened after filling the bottle
  127. How to prevent system leak down?
  128. fogger location
  129. Digital bottle pressure guage?
  130. Racetronix vs Walbro for Nitrous
  131. Hypertech and NX wet kit?
  132. Want to convert 5177 to wet. Opinions?
  133. AIT resistor with N20.. Why not??
  134. nitrous
  135. Has anyone used a mustang NOS dry kit on their ls1????
  136. What is the PSI of your bottle with NOS or ZEX bottle heater?
  137. wet kit with dry kit mafs
  138. spraying into maf....
  139. N2O $2.75 a # (San Diego)
  140. What will happen if i run out of Nitrous and spray just Fuel?
  141. What jets?
  142. Who is using a Harlan window switch? Question on install
  143. ZEX bottle heater - yay/nay?
  144. What is your fastest times while on Nitrous?
  145. Pictures of your Purge Install
  146. tnt wet kit jets...
  147. Results from retarding timing with LS1 Edit
  148. Nitrous Trade
  149. LS1 kit on a pick-up.
  150. dry kit: tnt or nos.....
  151. Just redynoed after mods...LS6 MAF didnt work well
  152. NOS noszle systems now available
  153. Question about n2o and mods.......
  154. How much RWHP can a Walbro 255L pump handle??
  155. Just bought TNT dry kit!
  156. Retard timing verses high octane fuel
  157. can i use a fuel pressure guage with a TNT wet kit?
  158. Aftermarket fuel pump will hurt NA performance??
  159. NX TPS switch
  160. Toque Converter & Lower Springs
  161. Dyno results for NOS 5177 on .032 jets; A/F 11:1, max HP 386, max torque 470.
  162. Should I retard the timing tables for 250 Wet Shot?
  163. Is a 100HP shot the same even with different cams?
  164. Nitrous Warehouse- what will happen?
  165. Detonation and nitrous
  166. How much fuel used w/150-HP shot?
  167. NOS pills
  168. Wideband sensor?
  169. What A/F ratio to shoot for?
  170. injectors question
  171. I gave into temptation........I smell 10's.........
  172. Spark Plugs
  173. picture of TNT Direct Port?
  174. Best oil weight for running N20?????
  175. Help: NX jets 50-100??
  176. ? about fpss on 5177 kit
  177. TNT system on top of S2 heads
  178. Is the NX MAF Plate out yet???
  179. 2000 Grand Am SE 3.4 v6 Nos?
  180. how much is to much???
  181. Saw the Noszle kit up close today
  182. Got my TNT dry kit on the dyno toady...
  183. MISfire????
  184. inline pump
  185. Paging Onyx LS1....
  186. Newbie wants help to start
  187. John Stewart of Nitrous Warehouse passed away today
  188. Anyone using an NX remote bottle opener ???
  189. I'm not a Nitrous Virgin anymore.....
  190. TNT LS1 Wet kit ( why are pills rated for 50psi)?
  191. Question about making a switch panel!!!
  192. Inline fuel pump from fuel cell to wet kit...
  193. fuel pressure idea good or bad?
  194. Digital air/fuel ratio gauage......
  195. TNT questions.....
  196. Nitrous Handling
  197. Please welcome the new moderators!
  198. Autotap Results
  199. ? abotu nitrous probs
  200. Who all is running a direct port setup?
  201. Who has the best deal on a NX bottle heater
  202. Surging???
  203. Wet or Dry; which do you find to be the better system and WHY??
  204. tnt kit question....
  205. two stage nx wet kit
  206. Wanting to run a 200 fogger, Give me my best bottom end
  207. What's needed to run nos wet kit?
  208. NEVER USED TNT DRY KIT $530
  209. NX 150 wet and A4
  210. NAAAWWWSSSSS!!!!
  211. TNT big daddy setup?
  212. MAF Question when running N.O.S. dry kit
  213. Don’t Disconnect your Inline pump!!
  214. maf compared w/ wet-dry kits
  215. How many feet of nitrous line needed for running from the spare tire well?
  216. NOS vs. Edelbrock bottle heaters...
  217. what injectors????
  218. New guys - My in car video of me spraying on a 02' Z06
  219. walbro 340 in tank: am i going to be too rich????
  220. Copper head gaskets or not?
  221. Newbie to Nitrous, have lotsa questions!
  222. Who makes a shifter knob that has a button I can use to arm nitrous system
  223. FLP results on N2O
  224. Who wants to buy a Carbon fiber bottle?
  225. So i am thinking about juicing.....
  226. How to make N2O as safe as possible?
  227. Which is what?????? (link)
  228. What happens if you run out of N20 during a run using a 100 wet kit?
  229. If using an EGT gauge What TEMP = LEAN at WOT on 100 wet shot?
  230. Which nitrous progressive controller??
  231. Window AND WOT switch?
  232. What's the fifference between the TNT F1 and F2?
  233. NX bottle heater install?
  234. ARP headbolts for nitrous use?
  235. Inline pump.........Will it be enough?
  236. Anybody figured out how to hide a wet kit yet?
  237. Blowdown tube question...
  238. Using a 100 NX wet kit and M6 trans in what gear should I spray?
  239. NHRA blowdown tube rules???
  240. IN-LINE PUMP ??
  241. If using a wet kit IS rich/lean even an issue?
  242. Need help with a Nitrous system
  243. Does the outside air temp make a difference?
  244. Guys with 5177 dry kit , come inside !!!
  245. FTRA and N20??
  246. TNT DRY KIT FOR SALE!!!!!!!!!
  247. NX Bottle Opener and NOS Bottle
  248. more fuel system ?'s
  249. Need fuel system help
  250. ANSWER THIS?
