PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. length of nitrous line to spare?
  2. Trouble setting up FJO
  3. 2 step and n20 with window switch?
  4. Should i move the nitrous bottle?
  5. crackle sound when using nitrous
  6. Nitrous help - Im a noob.
  7. The Nozzle that goes under the Injector
  8. Do you spray through shifts?
  9. tuning dry
  10. Best Nitrous set up for 94 LT1
  11. Nitrous Kit.... anything missing?
  12. Y off of the shrader valve?
  13. One Switch for 2/3 stages?
  14. wtf-cos5 wiring?
  15. Forged 347+275 Shot off the line?
  16. Happy 4th all!!!!
  17. dynotune hp ratings
  18. Part 1 of the nitrous install!
  19. BMN Window Switch and FPSS
  20. can i hide it here?
  21. Purchasing a Nitrous Kit... need some opinions
  22. 4th Of July = FREE BOTTLE HEATER !!!!
  23. sprayed 4.8L LR4
  24. Check out what I got from Daves!
  25. My Nitrous Install
  26. Hook and Book…….with BMR FAB and NITROUS OUTLET!!!
  27. will my car hold a shot
  28. Fuel pressure dropped 10 psi, but still rich??
  29. High pressure nylon tubing?
  30. On a completely stock car????
  31. Adapter/t-fitting for checking fuel psi for wet kit
  32. wonder what everyone else thinks
  33. Stand Alone Fuel Cell
  34. A/F Lean safety system*
  35. Out of the Office
  36. Reading spark plugs, mine are rusty looken?
  37. Purchasing Nitrous Kit
  38. dry kit
  39. Full Throttle Timing Tuner: Good or Junk?
  40. under pressure
  41. Help with BMN window switch nitro control w/ first gear lock out
  42. Dynotune N20 pressure gauge..pictures?
  43. Need help figuring out wiring on older FJO 908 RPM WINDOW SWITCH
  44. Timing Tuner from HSW
  45. Can I connect my 860 heater directly to a battery for testing???
  46. Is there a kit available that will turn my Dynotune purge into a dual purge???
  47. How to make absolutely sure no backfires
  48. need help wiring efilive 2step with nitrous
  49. Killer 4th of July Deals Part 1
  50. Will test spraying just fuel hurt anything?
  51. N2O dyno vid
  52. what tps wire
  53. Msd Window switch
  54. NXL nitrous install HELP!!!!!!
  55. Electronic WOT Switch help!!!!!!!!!!!!
  56. N2O baackfire = exploding hood.
  57. NX flow meter help needed - (step inside Nitro Dave)
  58. New to Nitrous???
  59. Dynoed Today!
  60. Nozzle to plate switch?
  61. Do these plugs look lean?
  62. Hey Guys, somewhat of a good bye
  63. How much does a N.O. 15lb bottle weigh?
  64. 2007 Z06 n2o kit?
  65. How well do you think your valve springs hold up?
  66. NX EFI kit cheap
  67. A few nitrous parts forsale!
  68. Nitrous Outlet Parts for sale
  69. FS: 43.5 lb Delphi Injectors
  70. Solenoid question?
  71. new to n2o
  72. Stock injestors?
  73. Newbie Wet Kit installed, first details inside
  74. Bogg right at activation????????????????????
  75. Nitrous and E85
  76. NX Piranha nozzle question
  77. LT1 Guys...
  78. Track Time Estimate
  79. Justin's 97 GTS Viper Nitrous Install
  80. Pics of my Dual Nitrous bottle setup
  81. Who's sprayin 200+ on stock bottoms with a direct port setup??
  82. Nitrous Outlet Nitrous Powered Golf Cart!
  83. 78 mm plate problems
  84. Direct Port braided lines?
  85. guestimates on whp ! 347+ juice
  86. Need help with transbrake wiring on Edelbrock 71900 controller (I searched)
  87. To spray or not to spray???
  88. Troubleshooting a possible restriction
  89. Nitrous and spool
  90. guys with big shots do you chassis dyno???
  91. Whats the deal with the zex kit?
  92. help me pick my kit!!
  93. timing with a 250-300 shot?
  94. Intake gain?
  95. i need help
  96. My dual intank pumps for LT1
  97. Complete nitrous kits?
  98. dynotune lean cut off
  99. ideal NX shark nozzle location in a LT1 ws6..?
  100. 700-800rwhp Nitrous folks: Ever run your car on the street?
  101. Octane Booster
  102. She's back!!!!
  103. Stock Fuel Pump?
  104. NitroDaves / Trick WS wiring question....
  105. NANO pressure
  106. Jet sizes for 125 shot, help
  107. Need some Timing Tuner help
  108. Nitrous Outlet PLate Kit and nos mini controller ?
  109. can i spray a 150shot?
  110. cam help
  111. Launcher confusion???
  112. Making some progress on my Nitro Dave's LT1 plate install
  113. fuel pressure sending unit and heat
  114. Nitrious plate size ?
  115. Nos cross plate jet size/ conversion from low fuel PSI to high
  116. TPS Voltage?
  117. Possible bad nitrous fill?
  118. Nitrous Gage reading yellow......
  119. Rods/Pistons for 200-250 shot?
  120. Hesitation on Shot.
  121. Jet Question.....PLEASE HELP!!
  122. How To Take Apart Bottle??
  123. refill station for sale
  124. P0300 on dry
  125. MSD Digital Window Switch woes....
  126. Full bottle pressure
  127. Nitrous Express LS1 MAF kit installed on
  128. is 3000 rpm too low to spray a 125 dry shot
  129. From a spark plugs point of view
  130. vic jr. nitrous set ups
  131. dual stage question
  132. What N20 cars at the LSX Shoot out!
  133. i need a conversion chart from jet size to hp
  134. My Dynotune Nitrous install
  135. Why a FPSS alone will not help!!!! FREE LEAN SHUTDOWN SWITCH!!!!
  136. can anyone give word for word directions for setting up the timing tuner?
  137. How to set up my a/f shutoff?
  138. Another Nitrous Install! Pics!
  139. Zex kit ?
  140. fogger a/f prob
  141. Nitrous with 230/226 cam?
  142. HELP! Huge nitrous issue...
  143. heads or headers with big shot
  144. How many people are using Nitrous with over 100,000 miles on their car?
  145. wet kit single nozzle N2O h/c results
  146. Attn, Any Moderator>>>>>>>
  147. nitro dave's bottle ?
  148. Who has the best progressive timer????
  149. I will be out of the office.....
  150. best place to buy bottle brackets that bolt to cage???
  151. Dry System Jetting
  152. Nitrous on 2002 trans am
  153. can i install Nitrous with my setup
  154. tested my system
  155. Nitrous Fill Station
  156. Congrats Pete (sprydncamd ta) on making GM High Tech
  157. Homemade blowdown tube
  158. Anyone have a blowdown tube nearby?
  159. VGauge Problems? Help!!!!
  160. HOW TO: Stand alone nitrous fuel system
  161. Connector on feed line broke...
  162. interface addes fuel when not at wot?
  163. Cig lighter
  164. what ring set to go with?????????
  165. How do I read the exp date on my NX bottle
  166. is a window switch needed with a standard?
  167. What is the highest MAF frequency anyone has logged?
  168. Is it a must for a tune??
  169. big ups to NitroDaves & staff
  170. Shop for Tuning/Installation in Ventura County, CA
  171. How much spray on a dry shot
  172. NOS Nozzle system??
  173. Nitrous newbie in need of guidenece.
  174. opinions on best NOS kit
  175. How many miles is too many to spray?
  176. Number 6 plug melted?
  177. How does this look?
  178. nitrous outlet digital dual window switch?
  179. Guys with plate kits, how'd you mount your WOT switch?
  180. xfi and zex DPK wiring
  181. When a Chair taps out
  182. nitrous wet kit f/s, full kit for cheap. need money quick for prob.
  183. Diagram Question
  184. warmer plug or more timing?
  185. HSW StandAlone kit, Problems Help!.
  186. BUILDING Another 370 Had a cam spec.out
  187. Need some advice on a good nitrous kit.. goal = 500whp
  188. Anyone have any NOSZLE funnel jets laying around?
  189. Thinking about spraying, need opinions
  190. My Custom Nitrous Bottle- What Ya Think?
  191. Will this suffice?
  192. Nitrous shop in Orlando
  193. deleted somethings and spraying
  194. LS1 Carburetor Nitrous help Needed ?
  195. Meth injection
  196. Dry Shot- What size Nozzle/jet
  197. Who fills their own bottles?
  198. what am i looking at?..
  199. cryO2
  200. N2O motor build, callies compstar or Eagle rods?
  201. Nitrous Outlet Summer Time Specials!
  202. Thankx Beer!!
  203. started on my nitrous setup
  204. Kit Choice
  205. NX Gemini kit surging issues. HELP!
  206. TR7 Gapping info
  207. What Dry Nozzel for small stage?
  208. plug gap?
  209. n20 question
  210. guys who wired their os5..
  211. AF lean cut off
  212. Bottle heater pressure switch location
  213. Easy timing tuner question help me out please...
  214. Head Studs And Main Studs.
  215. Wet kit timing?
  216. Help wire up 860 bottle heater. Relay related.
  217. Custom nitrous tune on pcm?
  218. What nitrous controllers are you guys using ?
  219. getting closer....
  220. How much power...
  221. N2O doesnt work anymore!!! help pls!
  222. 860 spare tire mount doesn't fit
  223. nitrous refill station
  224. COOLING your Nitrous Bottles
  225. Got a question
  226. Nitrous Dave's single stage window switch F/S
  227. Should I Buy This Kit?
  228. solenoids sound like a sprinkler system
  229. MS4 + nitrous?
  230. Dry Shot Questions: Mass Air Flow...
  231. LS1 nitrous solenoid help
  232. Dry to wet question
  233. NOS brand 05151 TPI Wet kit to LS1 setup?
  234. NX Propower Plate Pluss Solenoids 4 Sale
  235. n2o tune at TTP coming..
  236. First experience with Nitrous
  237. mandatory items for a 300+ hit or more
  238. Dry kit....to wet kit...help
  239. Who has the highest mileage nitrous motor?
  240. Best N20 rings
  241. N2O setup ??????
  242. After 6 months the nitrous is in! (pics and vid inside)
  243. New Dyno tune from N/A to nitrous?
  244. New window switch?
  245. Hit the Limiter A Couple of Times. What To Look For?
  246. Anyone know what caused this backfire?
  247. "The Perfect (Dry) Hit"
  248. Custom LSX NX Direct Port
  249. Finally finished hooking up the Nitrous
  250. Another Nitro Daves Nitrous Outlet thread
