View Full Version : Nitrous Oxide
- Broken Pressure Switch, have to replace whole bottle?
- is this normal??
- Preserving piston rings.
- nitrous nozzle
- Dry shot, cam-only, Tuning, stock pump questions.
- Nitours fuel system
- 100 shot wet! Nitrous questions,Experts inside please
- Nitrous Express Octane Booster
- 100 shot
- nozzle or plate
- TR6's in cold weather
- Nitrous times
- Is HSW closed for today?
- Dynotune or MSD window switch? WHY???
- Whats the most rwhp anyones made on just spray?
- unistall nitrous?
- First Dyno run
- hidden dry nozzle placement????
- Nitrous strain vs. boost on engine?
- Hows my setup look guys.Am i missing anything
- ls6 plate
- zex kit installed $600??
- stock fuel pump? Need an inline/intank?
- Nitrous Cleans Engine?
- Is fuel going to be a problem nitrous + cam?
- Custom fuel cell and 2 stage PICS!
- 348+the jug...???
- Nitrous results on my 07 TBSS
- ******TNT F1 Kit******Kind of new to the idea of nitrous
- Sonny's first ride in a nitrous car
- Adding a second stage ?
- To spray or not to Spray
- how much can tis 383 hold?
- programer and nitrous?
- **Nitrous Install Pics**
- Finally got my Nitrous kit installed on my TBSS. Thanks guys at nitrous oultet
- crap! did a dummy move now nos wont work?
- Hurt #6 with 175 shot why???
- is this a decent nitrous cam?
- 90mm ring
- Nitrous Control w/ EFI Live
- need help with motor planning
- What nitrous system can be hidden from the eyes the most???
- Noob to N20
- where to fill bottle
- 'Vert Spare Tire Well Mount
- Wiring Guru's Please Enter!!!!
- Help Critique my New DRY Timing Pull Write-Up
- What is the injector spacing on ls1 fuel rails?
- Couple of quick questions.
- How's the LSX iron block holding up to N2O?
- Ses Light Problem Under Spray...
- Might switch sides, Help me!
- how much timing
- compression for nitrous
- help chosing wet kit
- Bottle mounting
- How much timing should I pull?
- Nitrous switch Question
- Trailblazer ss guy needs help. ASAP
- 1st gear lock out
- Should I take a baby step up?
- Whats the easiest way to wire n2o for launching off of the trans brake?
- Does MSD Window Switch send 12v or ground signal?
- Speedtech
- DynoTune Fully Automatic Adjustable Nitrous Bottle Warmer Kit – $99!!!!
- The New HSW Interface Air to Fuel & Timing Controller
- Nitrous Safety from Dynotune at $99!!!!!! IN STOCK!!!!!
- Nitrous 383 shortblock
- Nitrous Outlet Christmas Specials
- L92 HEADS vs OTHER 6.0 HEADS
- What size injector??
- Best cam out there for a 408 300 shot
- window swith-progressive controller!
- nitrous parts.....list needed!
- nx jets diff. than nos??
- 100 shot
- n20 cam
- Wideband Help
- Got the Nitrous Trophy-Dyno Shootout
- main feed line
- money maker on typhoon?
- Engine Trouble, Help Please!!
- Complete Nitrous plate system for sale. Used once on dyno
- Stupid question (hidden nitrous)
- This might be a stupid question.........
- Introducing 860 Performance Products
- Trying to setup for big numbers low ets have ???
- Introducing Brand X Nitrous Systems
- direct port users inside please
- Paging Robert56
- Dirtect Port-Plastic lines
- does colder plugs take away a couple horses for nitrous
- Nitrous is flooding my car!!!!
- How much can stock Lt1 handle?
- throttle body plate required to spray a wet shot on an LS1?
- NX Stage 6 plate...
- fuel rail test port question
- dry to wet
- Discussion is nitrous for me?
- How much can i handle?
- Will It Take It?
- Solid Roller with Nitrous?
- FPSS/window switch
- New NOS controller
- Nitrous and Cam?
- HSW kit questions
- Dry tuning
- what gears with nitrous
- for those who spray and have a catch can
- E85 and nitrous?
- safe to spray?
- Happy Thanksgiving!!!
- Fuel solenoid question.
- I need help selecting Nitrous Kit
- Pain's new dual stage setup (pics)
- help a n2o noob out
- tnt f1 wiring instructions
- Am I blowing through the converter or does this dyno look normal?
- Possible Nitrous Leak?
- venom nitrous bottle
- Noob with a 402 to spray
- n.o.s. mini controller please help!!!!!
- 10.46@139.59 First time out......
- and the 10 o'clock post whore award goes to Nitro Dave's Nitrous Outlet!
- who makes a dual stage plate for an ls6 intake?
- pulling timing
- N/A Tune w/ spray?
- does anyone agree with me?????
- AFR goes crazy..Any ideas?
- little rough idle in gear. now backfire with tr6's
- Need advice please, trouble @ the track.
- Another fuel pump question
- 10.92@122.53 NA vs. 10.00@133.9 N20
- Robert or any Mod - Wiring Sticky needs attention
- FS: Nitrous Outlet Dual Stage Direct Port 90mm FAST intake
- bottle fill woes
- dry to wet?
- audible noise from bottom end of nitrous motor
- Nano ROCKS - 9.1 @150- x2
- Need help with Dynotune Bottle Warmer
- A little closer but no 8 second pass ...
- Looking for pics of the Red T/A with a plate kit.
- How much can I spray in a 255 hLP Pump?
- noob w/a surge problem
- Dry:can I?
- New 60 ft video...
- Post your stories/results from Detonating/Pre-Igniting on a big shot!
- IAT mod to pull timing? what ohm resistor does what?
- Question about a 300 shot on forged bottom end??
- How Much
- Nitrous Backfire I Need Help Figuring Out Why???
- help with wiring
- nitrous vs stock stall
- Factory Radio switches used for nitrous???
- CheaTR and 150 Wet
- Ring gap for 300 NAWS
- taking timing out for big shots
- nice nitrous kit f/s with all the goodies
- 402 questions??
- What do you think I will run?
- NGK B8EFS-non resistor plug question
- LSx to LTx kit
- Ngk Tr-6s
- Normal For Car to Backfire after Spray?
- 9.08 @ 148.... 3700lbs! ... Video.
- lets see pics of mistakes you made with N20
- How Many People Spray Their Daily Drivers?
- New Gauge/Panel Setup
- Pump Gas or RACE Gas???
- How hard is it to change a bottle valve.. ?
- My Freezer...
- qustion about my nitrous
- checked the fact, this wasn't in there
- What will it take to go 10's?
- does this sound right?
- A/F ratio (Colorado)
- Another new best Thanks to Kooks 2" race headers!!...and another broken oil pan
- nitrous guage question
- Recommendations for noids (300hp and up)
- Should I change to a Direct Port Fogger??
- Is Something Wrong With My Car?
- checking a wet kit
- Robert Inquiring Minds want to know?
- RaceTested nitrous bottle/valve
- cleaning nitrious out
- Hard start?
- Any thoughts on a dedicated fuel system?
- nos single dry kit nozzle pill
- Nitrous with BAP ?
- help with installation
- homemade backseat mount??
- TNT - Cant get it to lean out
- Zex Direct Port & Fast Intake
- Nitrous likes compression...
- does anyone get their bottle inspected periodically?
- spark knock
- Scratch, Dent and Used Sale!!
- Sorry Guys, im leaving the NITROUS world!
- 8 second nitrous guys
- purge smoke effect question
- 150hp jets = 80rwhp?
- Recommended Dual Stage Shots
- 125 dry shot
- spraying thru the throttle body
- TR55's or TR6's; C6 cam only + 100shot
- Does anyone have this combination???????
- Entire set up, price
- LS1 Ignition Timing and Nitrous Controller
- nitrous wiring question
- Is my converter killing my 150 shot?
- How much will it take?
- tapping for RPM/Tach input with a DT window switch. Need WS HELP
- Help Quick Please, BMN Wiring...
- ? For C6 Guys
- PLUGS.. TR6.. Rusted looking color on em.
- Changed nozzle position on dry kit
- Single-Plane MPFI Plate System
- mahle pistons,scat rods,how much nitrous will it hold
- Need Wiring diagram.....
- HSW plate?
- Got Traction?
- how big of a shot??
- Basic N20 Question
- Is there a ring kit for typhoon intake?
- Dyno Graph - ?????
- Gear lockout options
- Nitrous Newbie!
- Introducing the NOS Launcher
- legit dry shot questions
- Ngk Tr6
- Eastside doing some testing this weekend (pics)
- Flowing fuel pressures???????
- Timing Tuner and a few nitrous gadgets
- Why are Nitrous Stalls different?
- Wet OR Dry???
- Anyone out there have a custom bottle bracket?
- Wiring Diagrams
- new to the LS1 & NOS
- Can you spray a 100 shot off idle?
- Testing Solenoids
- 175 Rwhp Shot + 346
- 402 (ls2), 427 (ls3), Or 408 And Big Shot
- nitro dave's window switch
- mounting screws.
- Timing Tuner ?
- fastest roll to spray
- Ring Gap for 150-200 shot
- Steering wheel buttons
- Anyone run a dynotune FP gauge??
