View Full Version : Nitrous Oxide
- 1/4 Times with 100 Shot
- tnt wireing diagram
- Noszle Pics
- Converting a 5177 kit to a "Wet" system?
- NOSzel DP Kit finished...
- Stock fuel pump, 30 lbs svo's, heads and cam,,, can i still spray?
- How to install nostril purge?
- a/f guage install ?
- Can I mount my dry fogger right before the MAF?
- New best!
- Does anyone use AV gas?
- Fuel Pump?
- Who else purges through the motor?
- Purge for NXL
- New NXL system with a slight blemish
- Times On 100 Shot
- bottle mounting question
- People with single nozzle dry setups...where is your nozzle mounted?
- Running lean on a 50 & 75shot. NX
- Which spark plugs?
- dry shot question for NOS nowhows.
- NX Maximizer
- UP to?
- New NX kit out of package
- NX TPS WOT switch issues....
- Strongest gaskets for N20
- most N20 on a stock crank...
- quick simple ??
- Modified MSD Window Switch Question
- 300 shot on stock bottom
- Help a beginner out
- what is missing from NXL kits?
- NOS Direct Port Questions?
- NXL kit problems?
- Need Bottle
- Jetting for Nitrous
- Recomended window switch?
- Thanksgiving Nitrous Kit Specials!!!
- Large (200+) shots and camshaft LSA....
- 5177 -- 75/100 shot?
- Another new best, the little 346 that could!
- Jetting Chart for NXL up to 300hp!!
- Am I missing something??
- Thinking of buying NXL?
- Nitrous friendly and NON-friendly cams
- Quick DP Fuel system question
- NXL Trobleshooting..Brains, or Anyone else..
- Need some n00b advice
- What's your take/experience with the ZEX system?
- anyone ever use their purge as a 2nd stage dry shot?
- What is the purpose of regapping spark plugs when on the bottle?
- Hey boys QUICK Question?
- Question for the N2O Gods
- im a beginner with nitrous, have some questions?
- What is the jet size NOS 5177
- More NXL problems
- AF gauge glove box install pics
- NOS 5177 dry question??
- NEone has pics of Dry kit and FIPK setup?
- Any More NXL results?
- Just Took First Test Ride TNT F1!
- Dry Kit pics
- What else do i need?
- What regulator for low pressure fuel system?
- NX fogger help
- DP fuel and nitrous distribution questions
- Timing and Spraying?
- Nitrous Solenoids?
- DP Jetting ?
- Pressure Gauge
- Looking for Picks of TNT F1 install!
- Paging Cammin Beast
- 382 with a nozzle system
- NOS Noszle kit product number??
- Anyone spray on LS6 cam?
- Which Nitrous tuning works..
- NXL Issues in here...
- Best direct port setup?
- NX direct port part#??
- No Instruction NXL help---Quick Please
- Just received my TNT F1 Kit!!!
- No Jets On 5177 Nos
- 150 shot?
- NXL and Nitro Daves
- Ngk Tr-6??
- Nitrous and TR230 cam?
- Wich Spark plug?
- What makes a cam a "good" nitrous cam?
- NXL install question
- fuel requirements to support a 200 shot of N20
- how big of a dry shot?
- Which kit do you have?
- Some excellent tech info about nitrous oxide
- Where to mount bottle?
- what happened to the good 'ol NOS DP
- NXL help...
- Maximizer of NX for the turbocharged 800 hp Euro BMW M3
- Whats the best direct port system out there??
- Zex through the filter?
- DP Dedicated FS Setup Pics
- FPSS? and surging problem
- ideal a/f ratio with nitrous?
- Nx Direct Port
- help with window switch
- anyone do their own refills?
- Nitrous Cam Advance
- How big is safe for nitrous on a Iron Block??
- TNT Experts Inside.
- Finally found missing horsepower !!
- anyone spraying on flycut pistons?
- not an LS1 but if you want the best go NX
- NOS brand jet sizes
- Nitrous Express is TERRIBLE!!
- Can I dyno like this? N2O shot on a h/c car...10 bolt..
- NOS dry
- I want to see pics of your NX set up
- NXL and LS1 edit question
- Never used nitrous before...
- Purgin out the hood...
- Nos question
- TNT Guide
- question about "v power" NGK's
- TNT 100 shot plug gap
- NXL kit and a FPSS
- What could be wrong with my bottle?
- TNT Help...New to "Install"
- TPS switch and Mallory window???
- Bottle Filling in VA??? who does it ???
- How many have ran the 100/150jets together?
- Making a battle plan with nitrous
- would i be safe to run 150shot if i only have 55FP w/100shot
- NXL came today... a few Questions
- Car stalled after 150 shot!!!!!
- LSX, Holley, or LS6 does it matter for N20
- nitrous vs boost(blower) for max hp on stock bottom end
- Who is running a 100+/- shot on a stock bottom end H/C motor
- Window switch question
- 10 sec m6 guys in here<<<<<
- Bottle Mounting Question
- Iceman solenoid didn't help!!! GURUS HELP ME!!!!!!
- Anybody know where I can get a 3an-3an fitting
- Wheel hop on dyno?
- purging through ram air nostrils
- Second Nitrous Solenoid??
- whats the best brand solenoids?
- What happened on the dyno?
- NXL install questions
- nitrous jetting question
- What set-up would you recommend for my H/C car??
- any NXL results yet other than cool pictures?
- how long are your lines?
- taken care of
- Price Matching From Nitrous Outlet!!!
- what fogger or nozzle do u use?
- CA law question (heard a weird rumor)
- how high of a mileage have you squeezed on
- Knock question
- California law question and question about use on engine
- would it be illegal?
- deleted
- We have NXL systems in stock
- Good deal?
- What could be wrong with my car?
- New Nitrous Product
- jets for 125 shot NX?
- Using fog light switch for 5177 activation
- Anyone runing a 1-2 Ga fuel cell in front for their wet kit.
- Need opinions, 418ci +300shot.....Already have NXL.....
- nx bottle opener on a TNT???
- anyone with a NX remote bottle opener ? need help !!!
- Stock bottom end, 600 rwhp on NX single fogger
- How do i get a purge like this? (pic)
- Cam only and spray guys, in here?
- Best kit for 100RWHP shot on stck motor
- The lucky guys with the NXL kits!!!
- 150 shot = 3HP
- Got the rest of the NX kit installed
- Whats the in'line fuses amp rating on the NOS LS1 kit
- Why not spray a 4000+ stall with a big shot?'s
- wet and dry
- NXL Pics
- VCN1000-what's it worh used???
- TC and nitrous
- NXL Update???
- Help with TNT kit...please!
- Track times with 5177?
- N20 DRY SYSTEM QUESTION?
- in between 1&2 step colder. which and why?
- Any pics of WOT switch behind the gas pedal?
- How much will using N20 affect my NA performance? If any.
- What tool to flare stainless direct port lines??
- AutoLite plugs suck!
- PICS of Direct Ports, "POST THEM HERE" NOS,NX,TNT
- NXL install tips
- What plug and gap should I run for 250 shot?
- sprayin nitrous at high speeds/sprayin with traction control
- First spray TNT 150...
- Nitrous filter?
- Need to know what shot my Z28 can take
- Dyno Results......
- What size shot is this???????
- I played it safe.(50wetshot) What should I increase to?
- New Best here in Texas
- 250 DP shot on my ARE 436 stroker...........................
- new best at the mir efa shootout
- fuel pumps questions
- New best NA and N20 11.2 at 125MPH
- tapin the revlimiter
- People w/TNT kit come in....
- first time at the track on nitrous :)
- half-forged 347, H/C LS1, thinkin about N2O
- N20 woooos 1st run on a 100 shot
- We Have NXL kits!!!!!
- Question about TNT F-1 kit
- How do you guys feel about Edelbrock's Nitrous system?
- what is the n2o max on stock ls1
- what do you guy think about using co2 insted of n02
- 150 Wet Shot ok?
- Which Direct Port for LSX?
- Nitrous on 84k motor?
- What is the......
- Nitrous Express NXL got some ???
- Hidden switches
- Retard timing for N20 through IAT sensor?
- HELP!!! I cant get my nitrous to work!
- window switch question
- Biggest Dry Shot w/ Upgraded Fuel Pump and Injectors??
- buying a used kit question
- What's the ball park price for a TNT F2 kit install?
- Which nitros kit to buy
- what dp kit to get?
- conflicting info on NX jet sizing
- How much gap?
- Bottle heater on.......pressure not rising
- NXL work with a Nasty or Speed Inc. fuel rail?????
- Has anyone painted their TNT power ring?
- NOS
- I need help choosing the right gear for my future setup.
- TNT Help (532.3 RWHP 649.2 RWTQ)
- newbie
- can i hide this n2o?
- You guy's should know
- Piston Ring Gap
- How much hp can I run on the stock fuel system?
- Fuel Requirement of Huge Shots!!
- NOS valve opener fit NX bottle???
- Where to get nylon line like noszle has??
- NOS dry kit advise please
- New Maximizer?
- Taking a poll..
