View Full Version : Nitrous Oxide
- can not get my window switch to work! help!
- Stand alone fuel system questions?
- Harris 150 dry plate, fuel system questions.
- LT1 on juice
- wiring a nx kit
- Nitrous pass hit rev limiter
- NITROUS ? on Vic Jr.
- Why doesn't someone make....
- Dinitrogen Monoxide newbie :)
- interface users PLEASE COME IN
- Video from 275 race at VMP Sat.
- Need a little wiring help...Timing Tuner and Dynotune lean shut down switch
- nozzle fittings?
- lightweight nitrous piston for Lt1
- LS7 ZO6 NOS question please
- Standalone pressure?
- throttle sticking after spray
- 200 shot...do I need a dedicated fuel system?
- What is the best fuel pressure for nitrous
- 90MM HSW Plate Max wet shot?
- msd timming twister
- 150shot dry timing question
- nitrous/timing & octane questions
- Hell of a scare....
- what do you think of this setup heads cam...and what NOS system should i buy
- The baddest Nitrous Racers run Madman suspensions
- Need a bit of wiring help,read stickies twice
- converter/lockup on spray ?
- 3 years later finally sprayed at the track!
- Jet Sizes??
- Help with my setup?
- Stock bottem end nitrous build???
- flycutting with nitrous?
- #4 nitrous feed limits?
- Hsw interface
- 9.97 @ 140.8 n/a
- 200 shot on 10 bolt??
- converter/gas ?
- Breaks up when its cold but it fine after it is warmed up
- latest and greatest?
- Why is rich so dangerous?
- N20 progressive pros step in
- fuel pressure ?s befor a spray
- nitrous not hitting as hard
- Look what came in the mail today
- More Tech - What makes a plug "colder"
- one stage 300 shot hlp ?
- Dynotune RPM window switch question
- Nitrous on 7 cylinders; how bad it is?
- cam/stall/spray what gap?
- Zex nitrous question??
- TNT 90mm Power Ring. Where can I get one?
- Topping up your bottles...calling dealers inside!!
- Nitrous Race Checklist
- Plug brown/red after about 20 nitrous runs...
- Should I go with a blower cam or nitrous cam?
- Too much Advertising, Not enough Tech - Spark Plug Reference
- How much can i spray with TR5s?
- Spraying on the hit
- Nitrous Bottle and Battery in Spare Tire Well
- What's your race weight?
- ran br7ef's and they fowled out BAD street driving
- rewired my nitrous kit this past weekend
- 347ci nitrous motor questions
- Introducing The Nitrous Outlet TBSS Switch Panel
- Introducing The Nitrous Outlet 2010 Camaro Switch panel.
- Introducing The Nitrous Outlet LT1 Specific System
- Gota See this
- Beck intake with Nitrous Outlet 3 stage direct port for sale
- What is this Spark Plug trying to tell me?
- E3 SPARK PLUGS (Nitrous?)
- Dyno #s with 100shot
- gap for 100 shot
- bottle pressure?
- Looking into nitrous. Help me out!
- Tr6 or tr8???
- plug question for 150-200 hit
- How much nitrous can you flow through a -4AN line?
- Innovate WB/lean shut down switch question
- Best N2O motor for $10K-ish
- plugs QS chime in
- motor built for nitrous? what you do?
- E85 Solenoid Question...
- Forged internals, 42#, racetronics, HSW
- nitrous guys what does your cars run na
- Help choosing jets to lean out
- shift through nitrous?
- why is it acting up only on 150 hit?
- dyno-tune question?
- timing box
- nos controller for m6?
- NX MAF Kit/ Fuel pressure quetion??
- using wideband with microedge?
- nano bottle valve leaking
- truck nitrous system suggestions
- Stand Alone Reservoir in trunk...
- sprayable? 1st setup options?
- Can I spray a 75 Shot without pulling timing?
- wanna bottle feed my baby
- how much n20
- RPM resets the record again
- nitrous question
- WTB N.O.S LS1 plate
- Jetting at outlet of solenoids
- What oxygen sensors do you guys run?
- low profile plate for ls1 fbody?
- 05 gto, 100 shot results
- Nitro Daves F-Body Nitrous Kit.
- Honest opinion of 200hit on my car..read
- A Question to those with Dry nitrous experience
- N2O outlet LT1 plate guys, quick question.
- Run TR6's on motor vs. 8's?
- 600 rwhp? and the SAUCE?
- The Nitrous Outlet 98-02 F-body Nitrous System
- hsw help...
- Introducing the Nitrous Outlet 2010 Camaro Nitrous System!
- Air and fuel????
- 103's gapped at .40
- how to Gap the plugs ?
- One noid two nozzles???
- 6 speed and N20 questions.
- 2010 Camaro HSW Nitrous Plate
- Harris plate install pics on 05 gto
- Manual tranny/nitrous/launch controller guys-spraying thru ign cutout?
- Dribble feed tiny dry shots??
- my Zex kit install vid from lsxtv
- 125 jet size?
- Fort Worth Nitrous Fill
- Let's see your setup!
- Biggest dry hit on 93 octane
- tnt nozzle - nx jets?
- More than complete DRY kit for sale
- Selectable Dual Bottle Setup
- purge
- New Best with VIDEO
- Anyone looking for a nos cam
- Marshall electric nitrous gauge not working?
- cold fusion plate with nitro dave noids quick question
- where to mount TNT soulenoids
- Nitrous OutLet direct port system
- New best for LT1 car 9.28 @ 144.21
- Carb style wet kit to efi?
- Need input on finishing Zex piremeter plate setup!
- micro edge questions
- micro edge causing rpms to flux
- Microedge/Interface Issues....Scans Inside
- HSW Warranty
- Questions about timing and what device for changing timing
- Kickin @SS on 275's !!!!!!!!
- TNT hose length
- About to step up to bigger nitrous system, need advice.
- What would you think of this setup? Cam & Nitrous; Brand X
- need some help on what should i do
- carb nitrous plates?
- Is this kit any good?
- How many passes do you get out of a 200 shot?
- 150 wet shot on stock fuel system?
- Torque Converter for NAWS
- My Nitrous setup topped out?
- Who has Dynotune nitrous setup?
- Will these pistons work?
- Ok to run solenoid grounds through FPSS?
- Anybody in here happen to have a crossmember for a glide laying around?
- widebandn and microedge
- IGN switched 12+ powersource in engine bay?
- Stand alone lines?
- Free hsw stuff!!
- need help nitrous plate
- Nitrous mount between seats pic please
- Set up question? Class rules setup
- NANO NHRA Celebration SALE!! NEW AND USED!! NITROUS BOTTLES!!
- how to install nitrous pressure gauge on 14LBS bottle
- wet nozzle questions
- help me choose a set of heads
- Sticky? For NANO Refill stations???
- Stuck silnoid
- 860 Spare tire mount
- dart headed motor with big shot plug change?
- how much timing
- Bottle Pressure Explained...
- Setup Almost Complete
- please need help ( nitrous solenoid )
- Nitrous Confusion (pros come help)
- nitrous solenoid problem!
- quick ? TNT F2 kits noids
- My new dyno pulls LS2 with all the fixins and a 2 stage
- Direct port or single plane?
- Plug gap for a 200 shot
- Setting up system, should I go ahead and just use the FJO vs TT?
- Jet sizes!!!!
- Which stall converter for spray?
- Fuel pressure problem????
- Acts like it has a 2000 rpm rev limiter and dies at idle
- Jet sizing
- Anyone looking for a NX Maximizer.
- Anyone have ever used a cold fusion plate
- Which is better?
- DYNO TUNEn NITROUS
- What do you think about my setup?
- Where to fill in GA or AL?
- 2 stage dry kit using 1 nozzle and one bottle PICS and write up
- Stand Alone Fuel System for Vette C6
- Wiring Issues
- HSWs Micro Edge controler and LS2s ONLY!
- 4.10's and a 100 shot?
- how many people would be interested?
- HSW Microedge Gear Lockout/RPM Issues
- updated master faq
- Went out to run Real Street (275 radial class) this weekend and got a new best.....
- Nitrous
- what ngk plugs to run?
- nitrous times
- Zex nozzle location
- Selling my kit
- BIG backfire through exhaust when nitrous activates
- What size shot are you running on your stock bottom end?
- NANO Approved by NHRA
- Dry Shot Size...
- pic inside , is that the correct setup for purge ?
- Nitrous bottle lose pressure over time
- Wide band o2 sensors for C16???
- installed wet kit, now p0118 code...wtf?
- FAQS RELAYS; how they work etc ....
- what plugs for 250HP ? and for 200hp ?
- how much to fill a 10 lb bottle where you are?
- What is the mileage cut off for Nitrous???
- pix of my finished NOS setup.
- Congrats
- 90mm tnt power ring?
- Im too lazy to search...what jets are compatible with Nitrous Outlet nozzles?
- HSW Plate/Cruse...
- Remote Bottle Operner - reliable?
- How old is to old?
- mallory 685 help
- Car dies at idle after using N20
- water in n20 bottle?
- Sold broken "Timing Tuner"
- The best nitrous jets ???????
- Dumb question about staging nitrous....
- What plug and gap to start with?
- ballpark price for this setup?
- HSW Plate Kit on my 2005 CTS-V...Dyno Numbers Inside!
- HSWs micro edge controller issue? anyone else have issues???
- Adapting my N2O setup from my old LT1 to new LS1?
- New best .....
- Nitrous issues on dyno...please help.
- how to hook up fuel line for wet kit
- Possible last season with nitrous.
- lt1 nitrous install question, need help.
- Where are you noids located?
