PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. nitrous outlet solenoid power/ground
  2. Nitrous Wiring Schematic
  3. Nitrous Cam Selection
  4. wiring help!!!
  5. hsw plate???
  6. bottle/solenoid leaked overnight
  7. vote time- dry vs. wet!
  8. How much to spray w/ poll????
  9. maximum nos hp
  10. NOS Launcher whith NGK Wideband sensor ????
  11. Anybody used the EPP spec'd cam and juice?
  12. Having engine built - ring gap ?'s
  13. money maker kit
  14. What Size Pitch and Thread Is A Nitrous Nozzle
  15. Justin smith just ran 4.89 on 275s at 145mph at SGMP
  16. Decisions pros cons nitrous
  17. C5 vette nitrous??
  18. A few questions
  19. RON 106oct fuel. How big shot ??
  20. Plate / MAF questions
  21. 300 Shot, o-ring block or not?
  22. My problem with NitrousExpress solved
  23. Best spark plugs for nitrous???
  24. Purging nitrous through engine!
  25. Ring Gap shot capabillities
  26. My HSW Brute Force 78mm Plate Kit Install w/Pics!!!!
  27. FREE Nitrous Express!!
  28. Difference in Nitrous outlet and Hsw jets
  29. Win a Free Shirt and beanie with Nitrous Outlet
  30. Wanting to run a plate setup: How much to spray/Check my setup
  31. 6 Speed What Gear?
  32. Safest way to do a 100 shot?
  33. Need replacement wet nozzle
  34. How much timing should i pull??
  35. gearing+n2o question
  36. cam and spray??
  37. Trick Performance V & P Gauges !
  38. Where can i hide my nitrous bottle in my 2008 corvette
  39. Intake and plate question
  40. Controllers
  41. Can i have speed limmit when spraying
  42. zex 75-125 nitrous on a stock bottom good idea?
  43. Take a look at this!
  44. Review my wiring diagram
  45. window switch question
  46. 3.90's or 4.10's m6 75-100 wet shot
  47. fuel pump trap door
  48. few q´s on wet shot
  49. wet 150 shot on a stock fuel pump?
  50. Refuse2buy a electric bottle opener so i custom rig a tunnel bracket2open it my self
  51. N2O nozzle adapter in silicone...anyone?
  52. How much can I pull off the rail?
  53. H/C with flycut pistons + 125shot? Hmm...
  54. BIG PROBLEMS installing LT1 N/O plate!!
  55. LS7 ZO6 N2O Vette
  56. please help ... FJO Controller wiring
  57. Wet shot and duty cycle
  58. Looking for installed pictures of 102MM plate on FAST installed...
  59. How to hook up fuel solenoid to FAST rails?
  60. What to check on used kit? (Pics)
  61. Ordering new complete N2O set up Direct Port 300shot+ guys please come in
  62. nitrous oulet timing tuner??
  63. nitrous outlet 98-02 console switch panel pics
  64. Fuel system for E85 and 200+ shot
  65. What pills for a 200 shot?
  66. Interface Wiring
  67. Safe to run an N/A tune on a 75 wet shot?
  68. Bottle Opener
  69. Best plate for a Vic EFI manifold?
  70. Relay for purge????
  71. Stand Alone - question on different burn rates
  72. NMCA/LSX Events this year, are you attending?
  73. HSW intake bracket too short???
  74. High Fuel Psi VS Low fuel Psi
  75. zex box placement
  76. Stand Alone Fuel Question
  77. 200 shot, plugs?
  78. Nx experts??
  79. Will stock injectors work.....
  80. Question???
  81. Plugs ...
  82. stand alone install ?s
  83. Thermostat/fan settings for spray
  84. 100 shot and timing ??
  85. Need input on this nitrous kit pronto before i buy
  86. my solenoids big enough for a 200hit?
  87. Update...Nitrous Outlet
  88. Building a Daily driver 347 with occasional spray, what pistons?!
  89. FS: N.O. C5 90 mm plate system complete w/ extras
  90. LS1 Victor Jr...Which 4150 plate
  91. need help on a nitrous kit
  92. Window switch RPM signal E38 PCM
  93. anyone running the hsw 92 plate kit?
  94. Bottle Valve ?s
  95. 04 c5 zo6 C/E nitrous next wich kit?
  96. Upgrades Needed for 150 shot?
  97. NOs bottle high flow valve--cant open it
  98. HSW kit - Need Diagrams
  99. MicroEdge question - separate stages for fuel / nitrous + progressive
  100. Moving difficulties
  101. timing retard, window switch, 2-step all in one?
  102. "old nitrous"?
  103. Experience nitrous and HSW users and experts please open...need help
  104. Cons of nitrous
  105. thinking of selling my lsx parts???
  106. Tuning for higher elevations-C6Z06 ?
  107. new to nitrous
  108. Anyone use the Brisk Racing Plug GR12S
  109. What pistons and rings are you running?
  110. Shopping list
  111. Cold Weather Special!!
  112. 1/28/11
  113. E85 nitrous jetting
  114. best spark plugs?
  115. Stock ls1 needs a good n20 cam!
  116. How much NOS can my car take?
  117. 10.46@133
  118. Proper pression?
  119. only using 1lb if nitrous per run..
  120. High Mileage H/C Car
  121. installing a spray bar in a 4500 to 4150 adapter?
  122. need advice on the safest way to administer the N2O
  123. Carter01 goes 9.97 @ 133.26 today!!!!!
  124. Need a reputable Shop in Dallas TX for 632 fulton carb'd, fogger?
  125. TSP 440ci LSX + Nitrous Outlet Lumina SS Dyno
  126. Need help in fixing my N2O system
  127. looking for advice for my setup.
  128. Nitrous Outlet!!!!!!
  129. Cool 4150 plate I designed...
  130. Direct port im working on...
  131. Best FBody Headers for Plug Access (inspection on juice)?
  132. Harris Speed Works Microedge?????
  133. Rings for stock LQ9 pistons?
  134. Hidden Setup on a 6 speed
  135. Quick question
  136. So today...
  137. Are these the right plugs for me?
  138. what else do i need with my kit? fuel pump? wat kind??
  139. Into the 10s Finally
  140. IAT Connectors/Extension
  141. New issue
  142. anybody use this weiand air gap, better than ls6 intake?
  143. Nitrous Outlet= THE FLU
  144. New lq9 build nitrous advice please
  145. 1" Nitrous Plate?
  146. 4150 n2o plate questions
  147. Timing question?
  148. NX Gemini Twin plate install pics
  149. Window Switch
  150. stand alone question
  151. F Jo controller or nitrous outlet
  152. 8.50s or better with a 250 shot?
  153. anyone running nitrous on a 98 block?
  154. SDPC Short Block Limitations?
  155. Any dry fogger guys??
  156. Is it time to say goodbye to nitrous?
  157. N.O.S. Single Stage Fogger what jets are needed
  158. Switching to PatG nitrous cam worth it???
  159. nitrous motor
  160. new to non carbureted no2
  161. So close!!! 10.00 at 133.41
  162. Separate fuel cell photos
  163. How hot is too hot?
  164. I figured out how to hide my nitrous...
  165. Another N2O outlet Bad Ass Job!!!
  166. Help me rebuild for N2O
  167. Need advice for 2 bottles w/ heaters?
  168. Nitrous After Cam Install!
  169. Stand alone fuel or off the rail?
  170. LT1 Problem
  171. dyno tune nitrous kit
  172. car for sale!!!! great deal!!!
  173. March 2011 issue of Gm High Tech Performance
  174. high compression with nitrous. what plugs?
  175. Asking for trouble to run Nitrous on top of my current setup?
  176. What rods and pistions
  177. Would you buy this for your bolt on LS1???
  178. I think i made a boo boo....tell me what you think
  179. head gaskets?
  180. Zex wet kit parts
  181. Tunerpro Timing table
  182. nitrous controlers
  183. Happy New Yr's
  184. Cold Fusion----anyone ?
  185. best location for activation button and purge switch
  186. What are you guys running with a Cam only car and 100-150 shots?
  187. SlowTruck
  188. Video of the 7.86 @ 177mph pass ....
  189. nano port
  190. Br7ef or br6ef
  191. auto trans guys come in
  192. Nitrous disc
  193. finished up my nitrous outlet nitrous install...pics, UPDATED 2/26
  194. Best way to hook up multiple grounds
  195. Nitrous problems..cutting out!!
  196. New Times on 7 cylinders
  197. 100 wet shot
  198. used 12 bolt rear axle kit & gears purchase guidance
  199. Dry shot tuning on 2002 Camaro
  200. HSW have any new years specials?
  201. what cam should i buy help
  202. TNT F2 kit with NX jets, what sizes to use?
  203. Track times for my carb'd SBC 4th gen
  204. Gain from larger headers?
  205. big thanks to nitrous outlet for a badass job
  206. Need to wire my nitrous kit
  207. Using N20 to roadrace?
  208. Merry Christmas!
  209. will a nozzle stop flowing after 150 shot?
  210. plugs for new engine
  211. 4.125 stroke and nitrous
  212. want to go to 100 wet shot
  213. best kit for 2005 GTO
  214. how much for a good nitrous kit?
  215. lt1 nos kit?
  216. direct port nitrous on LS1 question/?!?!
  217. Direct port on a Vic Jr?
  218. NX Christmas Sale!
  219. 98 ls1/t56 nitrous
  220. Is it safe to spray with notched pistons????
  221. Problem installing nitrous outlet LT1 plate!
  222. how much have you got in your nitrous system?
  223. dynotune nitrous systems
  224. spraying through shifts
  225. How reliable is a timing controller?
  226. This months GM Hightech
  227. blow down tube..re routed
  228. Opinions on this setup please.
  229. christmas sales...
  230. Got some new lines made!
  231. Will these solenoids work for N2O?
  232. Spraying in 5th .. BOOOOM ??? ..
  233. Help! Nitrous leak.
  234. Anyone have any experience with the 860 performance intake elbows?
  235. How can I run my purge out the vents on my Firehawk hood?
  236. stock 346 new motor
  237. Carbon fiber nitrous bottle anyone?
  238. Have dark spot on plug, opposite ground strap
  239. L92 heads
  240. Anyone know the overall height of a nitrous outlet 15 lb bottle?
  241. New PB 10.10 at 131 with 1.37 60ft
  242. Found pics of a 15lb bottle in GTO...how does bottle angle look?
  243. Post pics up your burnt up stuff!
  244. Ordered a Bullet Racing Cam
  245. 200-250 shot on 11.5:1 stock bottom end?
  246. anybody running the nos launcher?
  247. Nitrous Bottle Recertification
  248. Leaky NANO Valve?
  249. what mph gain 150 shot
  250. Max spray with 243/247 116 lsa cam
