View Full Version : Nitrous Oxide
- 200 hit
- NX Maximizer 2 is worth every penny!
- Dynotune.. Omfg... Woohoo!!!!
- Any pics of 2 bottles mounted in a f-body?
- Im Back!!!
- direct port pics? (revisited)
- Installing a NX LT1, LS1 Pro Piranha Kit
- Link to Fuel Pressure Gauge If Interested in One.
- DynoTune Comments
- cts-v guys
- pics of install
- What's Your Experience with nitrous?
- can a NX 1pc maf work with there new fly by wire instead of the WOT?
- POST PICS OF custom painted bottles !!!
- how do i mount this TNT purge solenoid?????
- need wiring diagram
- Finally got on the dyno!
- need some help!!!
- problems with the engine compression .
- better option?
- Any suggestions..
- N20 filter, pressure sender, and heater trans location
- I want to run a 2 step, can I?
- help me with a kit.
- ls7 nitrous help
- Spray in 5th gear good or bad?
- #13655 NOS Nozzle flow?
- Spraying a mach1
- Bigger injectors for nitro?
- timing for 150 shot
- is taking fuel from the rail a good idea??
- HCI 03 z06 + how much shot
- Dynoed today. 427hp, 600ftlbs torque
- (I searched) Aggervated, lean on 50 dry shot!!???
- NX system
- before i make my payment, what comlete kit do you recomend?
- New pics of ARE Dry sump and NX Gemini Twin Plate system
- Pic of installation
- Possible to pull timing via resistor?
- How long can you run N2O, continuously?
- looking for good switch panel,
- How do I connect a Bottle heater sensor and gauge to one port???? Dynotune
- NEED nitrous question answered
- Dyno graph and nitrous...
- Stock v6 plus NOS
- How much can I spray
- keep cats with n20 or get ride of em?
- How bad would it be to...
- Pics of recent Wet Kit Backfire
- Carb intake direct port pics needed!!
- Got one last question on my setup.....
- nitrous backfire down the track?
- Dry Nozzle installation.. WHAT SIDE!! LS1
- Starting points
- is it save for me to use 150 shot?
- Msd Rpm Window Switch, Pill Style. Anyone Need It For Cheap?
- random question
- Will 1050psi + 150 Shot Be Fine On Totally Stock C5?
- videos of nitrous cars before/after
- Nitrous Cake
- anybody sprayin patriot heads??
- Opinions for new setup
- hi mileage Lt1.... questions
- Going for my first tune
- FJO Gauge Compatibility??
- solinoid placement on DP
- New best 5.51@128.5 with a 1.33 60ft on radials
- direct port question
- got my 8 second pass!!!!!!
- Plate question
- Another 8 second street car!
- Opinions needed....
- Adding another stage...??
- A/F Write Up, Very Insightfull
- Pics of your purge
- Hit with a 250 shot and BAM!
- Best Nitrous Kit For LT1?
- 2 Stage Pics?
- Finished Plumbing My FAST Manifold [PICS]
- 02 z28 Factory Injector size??
- NOS wet kit 5168 jet recommendation way off
- LMR LS7 Project with Pics!!!
- few new best last night.
- Nitrous Outlet system installed,,,, 6.0-LQ4 Caprice
- AIR fuel gauge
- a few ?'s guys plz help
- Nitrous Express Mistake or for real?
- nitrous kit reccomendations. please help!
- Got to make 1 pass tonite....
- few noob nitrous questions
- 75 dry shot and ms4/factory injectors?
- Bottle???
- What would be better 5.7" or 6" rod 383
- Bottle issues?
- Bottle Placement
- Which head liuke the NAWZ better?
- feed line question
- 2 stage plumbing question
- Few under hood pics of the new setup.
- Tips on NOS tuning w/150+ shot
- "Go Baby Go" button.. where to purchase?
- What Hp Will A 4 An Bottle Feed Line Support
- bottle brackets
- can you do this
- HSW Plate, best out there?
- NX Solenoid Frequency w/FJO Progressive Controller?
- Need Help with selecting a nitrous kit
- Ngk's Tr6
- Nitrous Ring Size
- With just nitrous?
- Think we fixed my issues ... FINALLY !!
- optimul a/f?
- Will an LS1 NOS DP kit fit an LT1
- 402 with the bottle... questions/help
- Ny Trex EFI wet kit
- Bottle Mounting Between Rear Seats
- Flycutting and Nitrous. Good Idea?
- MSD Timing Twister
- How to convert 5177 kit to wet?
- My new motor for spray, what do you think?
- GenX-2 fitting ... what is it?
- Whats The Best Converter To Run With Nos
- NX 125 jets???
- A couple of new bests on Sunday...
- Any thing you would have done differently?
- Bulk Head allowed? or blowdown tube only
- Need help with kit activation
- HSW Stand Alone GP Thread
- Almost ready to go, first time sprayer...
- Direct port of MAF...
- can i run nitrous with my current setup?
- Will a Sneaky pete system work for a LS1
- Blowdown tube for bottle above fuel tank
- TR6's gapped at .060"
- Dir Port Fast 90/90 For Sale
- timing retard or not
- nx tpas switch having problem anyone else
- If you've installed an NXL kit with a Maximizer 2 maybe you can help.
- LS1 zex install
- Any one using the nitrous express maf kit on a lt1?
- NOS 05177 jetting question...
- How to tap into fuel line on wet kits?
- Heater sensor ?
- put NGK TR6's and now my car is misfiring
- Nitrous parts list insanity check
- Will i loose HP on Motor?
- Few new bests!! need sissy sticks now
- leaking bottle
- Need time delay relay anyone!!!
- TB Plate vs Soft Plume Nozzle Questions?
- 100 hp dry system, what fuel injector size?
- Need help/suggestions breaking-up bad
- LT1-Nitrous or not?
- for shits and giggles....200 shot?
- NX manifold part# ... anybody know?
- temp drop through use?
- Jet DST Tuning software
- low compression and spray
- harris speed works nitrous kit
- Tim Slovert? (orlando,fl Dyntotuner
- zex plugs?
- How do I retard Timing with a two stage?
- Zex Direct Port- Any installed pics?
- NX Quick Thank You Shout Out...
- Dave,Chris From Nitro Daves?? pics please!
- Lid for N2O?????
- Job of a relay?
- Biggest shot without tuning
- melted tr6 plugs running n/a
- Weird: Nx 73n, 33f jets = 11.3 a/f wot
- ls1 carb to kuwait
- activation switch problem
- Opinions of advantages of a 10lb bottle over a 15lb bottle?
- What do you guys think??
- Cleaned up the nitrous in the engine bay! (pics)
- Two (2) Nitrous bottles ?
- Losing a little antifreeze...
- Biggest shot ever?
- Anyone using Victor, Jr, Wilson 4500 and Pro-Flow Plate?
- NOS Tuner in No. California???
- hows this look? :D
- NOS plate kit test question.
- Some HSW Brute Force Plate Pictures
- AN-6 line or AN-4 line for a 100 shot
- Help, Zex, Trying To Spray 150 Shot But Cant Find Correct Jet. Will This Work?
- 2 Stage Dry Shot 90 Elbow
- Need help with NX DP pill sizes
- NOS throttle body plate kit question
- fake nitrous
- Direct Port and Standalone
- What kinda fogger are you running?
- driving with the_____________ nitrous bottle open_____________is it safe for noids???
- Maximizer 2 wiring question
- Anybody have clearance problems with Nitro Dave's new LT1 plate?
- NX single hole rail users
- First test of the nitrous and I ran into a problem..
- Universal Wot Switch Mounting Bracket
- Simple Question
- Where to get anodized bottles?
- Sniper
- New 60ft video ...
- What's wrong with this plug?
- NX-NXL Kit hose quesion
- who else uses the nx mass air flow system
- Wire guaging
- need a similar plug to TR6!
- What makes what size shot....
- My new setup
- What nitrous kit for this engine ?
- Who has sprayed 350
- Direct Port Vs. Plate System
- Supply for fuel noid...in a different location. Thoughts?
- ZEX kit question.
- NX Fuel Solenoid Leaking?
- Nozzle Location
- How much will it take?
- HSW -vs- Nitrous Outlet
- Who makes the best nitrous piston? (300 SHOT OR MORE)
- Car hesitating when wet kit hits????
- Why is the FPSS connection to ground on the NO and C sides both????
- Problems 1st time out with new combo
- What is the difference between 100 & 150?
- W/S setting for RPM
- Wiring in the NX kit > solenoid wires ?
- New Zo-6; (New to me) with Nitrous ???
- how much can I spray on 28degrees timing?
- How hot is too hot?
- Backfire and now TPS stuck @ 15% open-help
- Dragstrip bound..lock out first or spray..
- Plugs for NOS...
- 100 shot is about ready...
- got question about nitrous
- Spraying at 2000 RPM's
- track results for the big motor dry kit
- Please don't laugh...quad nozzle setup...
- Dave's Nitrous Outlet Plate Kit installed w/pics...
- Buying an NX kit?
- tested halo
- Fuel pump for standalone question
- How much to spray on 04 Z06
- ngk tr555 safe for nitrous _______________________________
- need some advice on whats next...
- going TNT kit, need help with supporting mods
- which tps wire for nd window switch?
- need help with nos kit
- Question: Dry kit is going lean
- where can i find this bottle bracket???
- Any sponsors have new NX bottle stickers?
- does anyone sell a customizable kit? HSW? Nitro Dave?
- Plate Questions..
