View Full Version : Nitrous Oxide
- Need Help w/Cam Decision #3
- JETS SIZES
- Please Help! NX Remote Opener w/Venom
- don't everone chime in at once
- im confused, which kit? wet/dry?
- WILL MY MOTOR LIVE?!?!
- TNT Dealers in DFW
- TNT users
- With nitrous and a cam...
- What size injectors...
- Inline and Intake pump together - how much can it support?
- What lid fits the best for the TNT wet kit?
- What's needed to "freshen up" solenoids?
- bad to run dry 100 shot with tr 55s?
- nx fuel solenoids
- Can I tune 30 lb. Injectors with MAFT on 2000.
- how many w/stock rear & nitrous
- Heads + Cam + Nitrous + 10.8:1
- Hello Everyone
- Thinking about MAF for second stage
- 75hp pill and shifts
- MTI 422 tnt 100 shot safe?
- Drilling & tapping holes for a direct port system?
- Direct port, what kit? NOS, NX, TNT
- NX KIT Rating Questions...and some other stuff
- Weldon 2025 pump?
- To 100HP and to 125HP wich jet I Have to use if I'm using a DRY set up
- N2O is just plain evil. ('explosion' news article)
- purging the nitrous
- dry nitrous MAF spray questions?
- Best Fuel Pump
- extra high octane tank and pump
- What is the best gear for a a4 and nitrous?
- nitrous and converter question
- biggest shot for stock 5.3
- what is Dry or Wet set up? There is another...
- Dyno #'s with TNT wet kit 100jets on Bolt on M6
- how much would you charge for the install?
- Finally got friends N20 working....kinda....
- RPM modules
- Spark plugs?
- TNT F1 Power ring kit and TR6's...need some advice on Gaps..
- Anyone spraying a 200 shot on a TNT?
- Who's ran an LT1 NX kit on an LS1?
- Nitrous stuff for sale, TNT kit, and few other goodies...
- what gears with nos??
- One Solenoid Safe?
- Looking for N2O system... anybody selling one !!!
- will i lift my heads?
- Nitrous works purge with TNT noids??
- FPSS question?
- 9.50 first time out.
- New setup going in :)
- When would fuel puddling become a problem?
- another new best with a TNT
- NOS and INTERCOOLER ???
- have a question about my ses light going on???
- Paging anyone who has had nitrous blowback or explosion....
- dual stage?
- How much N20 will an LS1 engine really take?(SX2 pics inside)
- Drill and Carbon Fiber lid
- Window Switch install questions?
- Nitrous For Christmas
- Anyone have install instructions on NX kit?
- New Best with TNT :) :)
- Can I use the N20 Tuner with this setup?
- Fuel Pressure and Rev Limiter on Nitrous
- n.o.s ,what do i need to do?
- first kit on my car, stock 99z anything i need to worry about
- 2 stage through one nozzle?
- Direct Port NX kit 100-150 shot + heads/cam car all on stock fuel??
- Venom computers
- TNT F2 kit FS cheap
- help, window switch?
- How long will stock tranny last?
- When do you need bigger Injectors
- WOT switch on a vette
- Tell me what you would do.....
- whats the best direct port system out
- Does anyone just install the 5177 kit on an M6
- racetronix
- Intank and Inline pump
- Nitrous express "NXL" system pic?
- NX fans, read this...Fred ^10
- Spraying after 1st
- what shot are these jets?
- how can you tell if you have a leak?
- new nx direct port
- Nitrous kicks in and out w/ nothing changed from old setup...
- what do i need to know about spraying my car?
- Finished Nitrous Express DP kit (pics)
- How many have toasted their LS1 engine with just a 100 shot?
- Ignition timing
- To Run Wet or Not?
- Can I convert a NX WET EFI kit to a Carberated Kit??
- NITROUS QUESTIONS.......HELP
- Any interest in a N2O bottle mount for the spare tire well?
- help on 97 ex police camaro
- how many lbs do you have left before you cant build the pressure up?
- Fuel Pressure?
- TNT Lovers New Avatar!!!!!!!
- What two gauges should I get for spraying?
- Who here is running Heads/Cam & Spray on a stock bottom end?
- 200shot? Why not? LS1 turbo does it....
- What gear with a 100 shot
- Timming question with a NX 150
- Who's running what Fuel pumps?
- What electronics do I need with a NOS
- anyone with NOSzle
- NOS Sneeky Pete 4 Sale
- WINDOW SWITCH
- Surging Ahhhhhh!
- Fuel Pressure Switches
- Injectors, controllers and other questions...
- Here is how to make a bracket for your NOS in the spare tire location.
- Nitrous questions
- propane\nitrous?
- Nitrous and race gas dilema
- ? about octane when spraying
- Check out my 1/8 mile run
- N02 Level indicator?
- Venom Nitrous
- What shot on stock LS1?
- How to wire up nitrous with transbrake?
- GM TBI ALL (50-75-100-125HP) NX Wet Kit
- NX wet kit wiring diagram
- Can you spray through the shifts on an A4!
- Spraying concerns on resleeved block??
- Max dry shot w/Walbro in-tank & '99 injectors?
- Purge issues
- How much and how difficult to rebuild TNT N20 noid
- NOS Bottle heater problems
- O2 Sims and NX
- Does the NOSzle system interfer with the injector spray pattern??
- attention 383LQ4
- Bottle nipples questions inside!
- Gimme some input PLEASE!!!
- 200 shot or heads/cam and 150?
- does this part exist (for using bottle pressure gauge)?
- 200 shot, stock ls1 with nos nozzle?
- ?dual stage n2o 5o shot out of the hole?
- best way to launch with a 150 shot &M6
- zex heater w/ nx kit
- Z06 with NOSzle setup (pic)
- Do I need to retune?
- I have some nitrous questions!
- decent clutch for 100-150shot wet kit
- FS: Custom Dedicated Nitrous Fuel System
- What are the best ways to watch A/F in the car?
- What did I do wrong?
- Nos suggestions
- where can I get a direct port made?
- NO2 vs O2
- 5 tenths slower on the spray
- Building up 4 nitrous
- FS: Nitrous Controller
- Suggestions Please!!!
- third gen nitrous kit for a ls1
- dry setup. how big of a shot can i run with my setup?
- Spraying on top of heads and cam...
- RPM Progressive Controller Re-visited
- How to NOT blow up your motor w/ Nitrous
- Where can I find brackets to mount my TNT solenoids?
- 400 shot on stock motor
- NOS #'s
- Fuel System Upgrades
- Nitrous Rookie
- What Fuel pump are you running!!!!
- Pressure Switch
- Help Please ASAP! Nitrous Bracket.
- plugs question
- How to launch big nitrous with big stall? When to activate N20?
- I need NX installation intructions
- 1/4 mile #s on nitrous
- ANYONE USING IRIDIUM PLUGS W/ N2O???
- Nitrous research/books?
- Heads / Cam / Nitrous and stock fuel pump
- ? on No2 and tuners
- 490/630 on a 100 tnt shot..update-track times
- maf or nozzle kit which one is better
- maf kit or nozzle which one is better
- NX MAF ends question.
- NX dual stage pictures Needed!!!
- Will NGK TR5's work with N20
- nos question
- Need Help with MSD Window switch
- NX 100 shot Questions
- 75 hp shot
- installation and removal...
- NOS Shot
- stock pump with voltage boost?
- M6ers what RPM are you launching at with what gears/clutch
- New to nitrous world
- Finally Pics of my Direct Port Kit
- Need help on the chemical workings of n2o
- Dyno#s- 75shot w/ NX MAF Systeme.
- ? about 5177 plumbing
- Questions about FRED?
- NOS 5176 Lt1 kit on a Ls1 ????
- I need some ideas on purge outlets
- 4.10 OR 3.73 WITH 150 WET SHOT
- Venom & Window Switch
- NX bottle heater install ?
- abs inop
- fred problems
- Those that have installed a seperate fuel system
- tnt wet on head and cam car......
- VCN2000 experts please help.
- does anyone spray below 3000 rpm?
- need help
- edelbrock nitrous kits? ne 1 know anything about them?
- Nitrous Activation Setups pics
- Flashing SES... Help
- help!! nitrous,window switch question.
- Venom VCN-1000
- threw a code went i sprayed it, HELP
- spiratic idle turned off the N20 and it went away? what happened?
- WOW!!! Bottle pressure info worked
- TNT headaches continue
- new z28 nitrous
- A reason why dry kits are better...
- Need TNT F1 Wiring Diagram ASAP!!!
- What is a Window Switch
- bottle pressure (temp)?
- I want to see your NOS 5177 kit installs!(pics and details please)
- NOS DRY O2#S ARE SCARY
- Safe to spray a 75 shot???
- what do I need
- I want to be able to sell nitrous... What do I do????
- 1/8th-mile to 1/4-mile times question
- Need pics of nitrous w/ supercharger
- Guy tells me that if i use N2O i will go through rings like crazy
- i want to spray my truck
- What is F.R.E.D?
- Changing the intank Fuel Pump on 98 Z which pump and how difficult
- NOS newbie has questions.
- TNT F1 Install
- Need advice on a system....Wet or dry....
- TNT Conversion Question
- dry shot and purge?
- Pics of NOSzle on LS1
- Show me your NX install pictures!
- Who does freeze and fill method??? Might buy pump..
- Where can I find a guide or book on installing and wiring my first kit
- Give me the Be all-End all Nitrous system
- Micro switch mounting
- Newbie Nitrous Question
- What did you use to cut your lid?
- Check out my custom TNT nitrous ring replacement!
- Instructions in installing NOS Dry Kit
