PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Finally wanna have some fun done with N/A
  2. Nitrous Outlet install wiring questions
  3. Planning a LS1 Nitrous build
  4. [VR] C7 Z06 - Stage IV + Nitrous Outlet = 836rwhp/816rwtq on a 100 Shot!!
  5. nitrous plate and fast 102 intake ??
  6. Solenoid placement
  7. where are all the Nitrous outlet puck install picture at?
  8. Fuel pump issue
  9. Nitrous and 2 step
  10. Nitrous purge..
  11. Nozzle VS plate Which one do people like the most?
  12. Pulling timing
  13. Nitrous Pop out exhaust
  14. Looking for 78mm plate kit for Fbody LS1
  15. Any advice for my nitrous setup?
  16. Nitrous Newb-Advice wanted
  17. Max shot on VP 110 racing fuel???
  18. 250+ Hits Progression/Dual Stage Questions
  19. Ls6 intake or a fast for a wet system.
  20. Nitrous Outlet Direct Port Special- Limited Quantity!!
  21. Ashtray switch
  22. Problems with Non-Resistor NGK Plugs
  23. Washer jug for dedicated fuel cell?
  24. Is anyone running the new zex nitrous kit
  25. Dual bottle gauge options
  26. What plate kit?
  27. Questions about the lnc2000
  28. Direct Port Help
  29. Will I need a Nitrous tune to spray 175 shot?
  30. zex pro solenoid capability
  31. Nitrous Express hard line plate kit?
  32. Nitrous Progression ramp rate
  33. LNC 2000 Mounting
  34. Any sales on nitrous outlets kits?
  35. Fuel Feed from Gauge Adapter
  36. would a progressive controller help keep a engine together
  37. diy mods ?
  38. lets talk big nitrous 5.3/6.0
  39. Everything finally installed
  40. Fuel Pressure Safety Switch (FPSS)
  41. nos question
  42. Maggie plus Nitrous
  43. Would a nitrous controller help your 60ft?
  44. vic jr, stinger plate, accufab tb. stud question
  45. N2O refill stations
  46. Nitrous without a tune
  47. BIG THANKS to Nitrous Outlet l NEW PB 4/9/2016
  48. WTB Used nitrous system for 99 c5 m6 or just window switch.
  49. Should I use the Microedge I have
  50. head games
  51. Need advice on nitrous setup for c5
  52. Carb WOT switch
  53. Return for stand alone
  54. Progressive and 2 step?
  55. Low rpm nitrous stall spool
  56. Nitrous On A 2005 LS2 GTO
  57. Am I blowing through converter?
  58. Buying used solenoids.
  59. FPSS on a carb setup
  60. eta on nitrous outlet controller?
  61. Thinking about upping my shot
  62. Advise on setup and Help with plug reading please.
  63. Dual stage 92MM GM EFI Plate system. What can I spray with each stage?
  64. Scratch n Scuff Sale
  65. LNC 2000 launch control
  66. NGK Nitrous!
  67. What gears for nitrous car?
  68. Difference in lengths of siphon tubes
  69. Anyone you this ?Race gas race fuel concentrate
  70. 5.3 build advice
  71. Nitrous + Meth + Procharger = FTW!!
  72. Holley Hi-Ram Specific Nitrous System
  73. Fast 102 & Direct Port Pics???
  74. stock fuel pump question?
  75. Converting Dry Kit to Wet Kit
  76. Nitrous Plate W/ Zex Box???
  77. Fast 102 plate kit problems
  78. 150 shot (wet)and a backfire
  79. Spark Plug Gap
  80. Burst disc fitting size
  81. Throttle Cable Extension Bracket for 04 GTO
  82. TPS or Switch for activation
  83. Piston coating...thoughts
  84. Will the Stinger boomerang plate fit with a SV
  85. Bennefitsfrom running race gas
  86. Catch cans and nitrous, do I need a breather
  87. When did the second design Stinger Plates come out
  88. 220
  89. 300hp shot,use BR7EF or B8EFS
  90. Where is ideal place to tap into fuel system? (pics)
  91. head gasket for nitrous 370
  92. what to do
  93. Stinger plate on built ls6
  94. How much Nitrous?
  95. LS1/LS6 Wet Nitrous System 75-125hp
  96. Beginner Nitrous system
  97. NGK B8EFS on the street
  98. How is street life really like with nitrous?
  99. entry level
  100. FAST / NITROUS OUTLET question
  101. Nitrous for 02 Trans Am
  102. All new nitrous outlet product!!! Pro wiring harness!!
  103. Any way to keep bottle from getting too hot when left in car?
  104. Flow test 500 Shot Nitrous Express Direct Port
  105. 3.9 stroke and quench questions
  106. Dual stage 600hp shot....roll racer........
  107. How long can you spray nitrous......roll race....?
  108. Low voltage from NOS Window Switch
  109. 11.7?
  110. Direct Port Jetting Size
  111. Who sprays on a LS7 clutch?
  112. Which wire out of ECM is 5 volts at WOT ?
  113. Opinions on slight change
  114. dynotune nitrous products (reviews anyone)
  115. LNC2000 not hitting desired RPM
  116. how much fuel pump do I need if running a stand alone?
  117. keep burning same plug on testing?
  118. Nitrous Outlet Direct Port Conversion
  119. Which Stiger Plate Bracket w/ Super Victor
  120. Does nitrous add rpm's to your powerband?
  121. Safe to spray from rail?
  122. Pulling off the rail (How big can I go)
  123. ideal location for wet nozzle on intake piping
  124. Dual stage vs progressive
  125. pics of solenoids
  126. Jetting and spark plug reading help!
  127. Nos brand plate
  128. Lingenfelter NCC Andoird APP - beta testing
  129. Msd digital window switch question
  130. What all would I have to change on my setup for a 150 shot
  131. Methanol injection with nitrous?
  132. LS376/525 + 150 Shot
  133. testing my x series kit
  134. Normal to have 25-50psi drop?
  135. Custom Blowdown tubes
  136. For nitrous gurus
  137. PCV/breather setups for large shots
  138. am i going to have to butcher my cowl? *stinger kit
  139. Fueling for a 100 hp wet shot
  140. Just a heads up! BLACK FRIDAY!!
  141. New personal best 6:26 @ 112
  142. How much timing are you guys needing to pull for a 150 shot? Ways to alleviate KR?
  143. Lighting the candles??
  144. nitrous guru's LS1 block
  145. What's it take to go From 10.00 to 9.50s 1/4
  146. Retorque heads after lots of spray
  147. nitrous lifted head
  148. How often to rebuild solenoid
  149. E85 and plate jet questions efi
  150. Timing Tuner Poll
  151. 250 shot on stinger (PLUGS???)
  152. Severe KR after putting in BR7EF plugs and LNC-2000 for nitrous
  153. Nitrous experts and tuners timing ? Please help
  154. FJO on Windows 7
  155. Nitrous outlet 78mm plate
  156. Bottle psi
  157. stinger kit
  158. Round Two
  159. Bottle heater damaged is it done?
  160. how does this set up sound?
  161. Which system? 150 shot w/ super victor & 4150
  162. Stock head bolts
  163. do i need a new tune?
  164. using nitrous like a turbo?
  165. Direct port progressive
  166. Nitrous kit help!!!!!!!!
  167. Compucar nitrous in a bag
  168. Residual fuel in intake, normal?
  169. First Nitrous Setup
  170. 243 heads on a 6.0 how much will it flow ?
  171. Nitrous Kit
  172. 150 Shot, how much ET
  173. Super noob questions, new to the ls family...
  174. First gear lock out options
  175. Nozzle placement on dual nozzle kit, suggestions needed
  176. Having trouble with my lingenfelter lnc2000
  177. safe hit on a ls1 without pulling timing
  178. FPSS Issues, help adjusting.
  179. Which Size Plate Kit To Use?
  180. Nitrous Line Size Question
  181. Fjo nitrous controller and windows 8
  182. Questions about my setup need advice
  183. Fuel system requirements for N2O and E85
  184. 05 Cts-v with nx window switch
  185. Programming Nitrous Controller
  186. When is a fuel cell needed?
  187. Want to put nitrouse on my 1993
  188. 100 shot only making 50hp?
  189. Help me piece my nitrous kit.
  190. Using Holley HP or Dominator for Carb Nitrous Motor?
  191. Few N20 Questions 300 plus hit
  192. Bottle heater wiring
  193. 15 lb bottle tunnel mount
  194. N2O newb?building fuel system for future n2o
  195. 4n line how much nos
  196. what style intake is better for nitrous build
  197. HSW MicroEdge plus
  198. Sbe 5.3 nitrous outlet Stinger plate on 250 hit surging on top end
  199. Fast 92mm plate kit
  200. nitrous bogg
  201. Sbe 5.3 300 shot
  202. Nitrous port positions
  203. NOS Mini settings for dyno..
  204. How much timing to pull (250 single stage)
  205. progressive explained help
  206. Any alternatives to the NX Octane Gauge / Progressive Controller?
  207. Where to get a cam speced
  208. What fuel to use?
  209. Normal for purging ?
  210. FJO Nitrous Controller Help
  211. 370 nitrous build
  212. 427 ls3
  213. How Hard Can You Spray A Stock Crank.
  214. spark plug recommendation
  215. Issue with NOS Mini 15974
  216. Smart Spark on EFI Nitrous Car
  217. More nitrous , same et, less mph? !?!
  218. Nano assisted or 15 lb Bottle w warmer??
  219. Nitrous and turbo
  220. Nitrous Outlet 2 stage plate install
  221. Nitrous on a Stock C5
  222. MSD Atomic Air Force with Nitrous Express
  223. Nitrous outlet 4500 flage ls3 super vic direct port dry shot
  224. 416 ls3, cathedral heads, fast 90. Plate kit ?
  225. Nitrous Express Plate Install
  226. VCM Scanner to pull timing?
  227. ls1 mustang coupe help
  228. Direct Port Nitrous Conversion
  229. nitrous shelf life?
  230. nitrous refill bowling Green kentucky ?
  231. Adding a second stage
  232. 853 or 317 on lq4
  233. Swapping to e85
  234. **Another New Personal Best! 9.66 at 140.79!
  235. Some NO2 Questions
  236. Help!! Car won't make power on the juice?
  237. What way to go?
  238. NX Proton mini-review
  239. Nitrous or meth?
  240. Need help trouble shooting. Noids are pulsing...
  241. spray and boost
  242. how much do i need to spray my 427
  243. Stinger plate ruins another rear bumper!
  244. 125 pills on 100 shot tune
  245. E85 dry or wet setup
  246. 6.099 @ 116.65MPH 5.3 On PumpGas!
  247. E85_Plate = 9.24 @ 145.2 with a soft 1.424 60'
  248. Nitrous outlet halo
  249. NOS Mini Progressive wiring, LS2 GTO
  250. Whose Got The Fastest Stock Bottom End 5.3?
