PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. High Compression Engine..Should i spray it?
  2. ZEX MNU Insides Plus Rewire for MSD Window Switch
  3. Can I run the heater power wire next to wideband/guage wires?
  4. dry setup help. Stock C5
  5. Maybe I am missing something????
  6. Why you need the Nitrous Express Lightning 45 Bottle Valve
  7. how to connect this ????
  8. FAQ: How much can you spray your stock shortblock,+ some helpful nitrous info
  9. Nitrous Outlet is giving away a free nitrous system!
  10. Money Maker VS Plate System
  11. trans mount..can you see gage
  12. Link to Nitrous Tech Notes
  13. N.O. remote opener having trouble closing
  14. Stand alone? need to know now,lol
  15. NANO on a featured Corvette
  16. Cam+spray guys, if you were to do it again....
  17. HSW Solenoind Brackets for Fast 92
  18. What makes a cam better for Nitrous?
  19. what fuel jets for my setup?? (HSW 78mm plate,fuel pump etc)
  20. How many pulls do you guys get out of a 150 shot in a 15lb bottle?
  21. couple nitrous questions
  22. Bottle Issues
  23. Final parts needed, questions.
  24. Need info on timing trick
  25. Speed Inc./ Nitrous Outlet 10% off sale!!
  26. C5 Z06 NX 150 Wet kit Install begins.
  27. Gearing question for the solid roller guys
  28. Nitrous wont fire?
  29. Anyone with MS4 on the kit, come in
  30. Experts tell me about my plugs. 1st 200 shot.
  31. MSD DIS4, two step, and SLP line lock: 6 speed cars
  32. What can i spray safely?
  33. What makes one wideband better than another?
  34. Maf
  35. FJO vs NX Maximizer 3
  36. marshal pressure gage
  37. Nitrous "hiccup"??
  38. Dry setup
  39. Nitrous Outlet dual stage plate wiring
  40. So confused now about tuning nitrous. Help please.
  41. best tune
  42. Just curious will 2 step colder plugs make you lose power na?
  43. Should i get nitrous?
  44. Looking to add a little nitrous off the line
  45. 408 N20 Fogger Question
  46. 02 Sensor Question
  47. question about my guage
  48. HSW switch question.
  49. Nitrous, retard timing by torque increase?
  50. Using Teflon tape or paste on fittings
  51. What PSI should i expect form a 200 shot?
  52. first time with nitrous. m6 car
  53. Do you need to Purge?
  54. Nitrous Refills here at Speed Inc!!!!!!
  55. Nitrous Outlet fogger dyno results
  56. Stand alone fuel pressure setting????
  57. Dynotune install easy?
  58. 383 guys..
  59. nitrous on stock lq4 block. whats safe
  60. timing tuner or hsw interface which do you prefer
  61. Custom Diamond Nitrous Pistons arrive and you wont believe this!
  62. bottle opener?
  63. LT1 with direct port
  64. nitrous on a stock stall?
  65. Need some advise
  66. Looking for this fitting
  67. tnt pill sizes
  68. LS4 N2O Quick Questions.
  69. ltx intake with fogger
  70. AN Fittings
  71. New Best N/A and Nitrous Dyno Numbers
  72. how cool is this!!!!!!!
  73. Nitrous Wiring Question (Diagram Included)
  74. NITrous problem? need help
  75. Breaking in motor question
  76. Jet question.
  77. standalone fuel pump?
  78. Newbie nitrous questions
  79. stock pistons and a 200 shot?
  80. direct or MAF kit on Fast 90/90?
  81. N20 and lsx?
  82. direct port on standard manifold
  83. Gapping rings for nitrous? Why not for expected torque amount?
  84. Nitrous backfire ?'s
  85. Direct or Plate on FAST 92??
  86. best way to setup n2o on m6 car?
  87. Finally dyno'd w/150 shot. good or bad?
  88. HSW solinoid issue I think.
  89. Leaking out the purge
  90. Nitorus Outlet Progressive Controller
  91. 617HP all boost 4.8L..now running 75 dry shot
  92. hows this for a nitrous cam?
  93. Running wires through the front of the intake (see photo)
  94. need ingrediants for a fast cam and spray ls1
  95. Gears for H/C A4 with 150 shot
  96. $999 Direct Port Installed
  97. help with n2o
  98. High or low pressure for my standalone?
  99. whats the best kit for my setup??
  100. bet place to mount fuel pump??
  101. Thinking of upping the ante
  102. 383 h/c/i and over a 200 shot
  103. Removing NANO system, retune?
  104. A Time for Change, Nitrous Outlet No longer offers NX products.
  105. Corn and timing
  106. Question about low pressure fuel systems
  107. MicroEdge users come in side
  108. Resistor Mod (Yeah I know again)
  109. N/O Progesssive contoler wiring ??
  110. Mechanical gauge install and fitment sucks!
  111. okay whats a good all around plug foor my set up
  112. E85 and n20? Anybody here?
  113. Steps for spraying auto???
  114. nitrous out let ! i need your help
  115. nitrous rich WTF help
  116. rear mount or spray
  117. Little help here. Wet or dry? I'm new to this stuff.
  118. When tuning at the track, when is it better to spray the first 1/8 or the last 1/8
  119. Could I have gotten a bad batch/bottle?
  120. Lookin to upgrade to direct port
  121. MicroEdge & LC1 question/opinions
  122. New motor. How long before you can spray it.
  123. 150 shot real world jetting?
  124. finally i installed my N2O 2nd stage
  125. safest nitrous kit?
  126. If you know how to hook up a STAND ALONE COME IN HERE PLEASE
  127. Quick question about wiring (using Timing Tuner & Trick Performance V gauge)
  128. Nitrous for Dummys, got the purge kit mounted, now what?
  129. Pics of where you guys mounted your bottles!
  130. Speed pro-Hypereutectic aluminum pistons?
  131. check out my plugs 250 shot...
  132. Quick question
  133. It has begun!!!!!!!!!!!!!!
  134. how much can i spray
  135. Tuning based off plugs.....
  136. What caused my plug to look like this?
  137. Ls3 Camaro Plate System
  138. How about 150 shot and done?
  139. Fast intake burst panels
  140. fjo question
  141. Lean spike when spray hits
  142. TNT F2 plate kit, what are your opinions?
  143. ml 2000 efi kit work on lt1
  144. Small video of my purge kit!
  145. Nano leaking
  146. Have NX Dual Nozzle Kit, want to go to a Plate. Help! Pics inside
  147. If you know how to hook up a STAND ALONE COME IN HERE PLEASE
  148. Can a ls based nitrous motor go over 140 in the 1/8?
  149. Trick Performance "trick box" window switch. NEED HELP ASAP!!!
  150. Nitrous??? need details please
  151. aftermarket fuel pump after what size fuel jet??
  152. Nitrous Oxide and tuning?
  153. New to N02
  154. weird HSW n20 gauge
  155. here's a silly question...
  156. Just sprayed for first time.
  157. can it be done 10 's with bolt ons and spray
  158. 2-step with progressive controlled nitrous
  159. hsw micro edge controller?
  160. What yea think bout my standalone set up?..
  161. hey
  162. Just how uneven is the airflow on the Vic. Jr? pics inside to illustrate
  163. NOS Plate question
  164. Blow Down tube?
  165. Fuel Supply Qs
  166. nitrous kit help
  167. Another cool video we made..
  168. Nitro Dave's Halo results inside
  169. Damn.. Bottle went empty?
  170. TNT F2 vs plate systems
  171. Best way to control difrent functions of a NO2 kit.
  172. Thinking About Spraying.. Need some help please!
  173. which nos kit?
  174. HSW kit soon...is this all I'll need?
  175. What's best to seal gauge to bottle?
  176. Can my setup drink 150 - 200 shot of nitrous ?
  177. Nitro Daves plate compatable with a Zex kit?
  178. Device to Display Timing Being Pulled??
  179. Would My System Work On An LT1 Or Other Car?
  180. Lowering window switch, gain et and mph?
  181. ideas on Installing nitrous on a Procharged engine
  182. Hit nitrous, only fuel selenoid kicked on, now car goes lean at wot.
  183. I might have to switch my kit to a different car lol
  184. n20 noob, help plz
  185. Speedtech Nitrous
  186. Looking for some Nitrous footage
  187. For the guys looking for the ultimate in nitrous control...
  188. window switch/ timing retard contoller
  189. best wet kit a/f?
  190. HSW MicroEdge+ Does it have a pressure sensor? Any installed pics?
  191. TNT Nitrous Install
  192. Will I be safe running 100-150 shot?
  193. Can I just run a fogger nozzle or is a plate needed?
  194. Spark plug tuning video
  195. Join us on Facebook, Receive a Shirt!
  196. What do you guys think of my setup?
  197. damn damn DAMN
  198. seem lean 13.1 A/f
  199. single noid dual nozzle quesiton
  200. What size shot would it take to empty out a 10lb bottle in a pass.
  201. nitrous and altitude
  202. Nitrous Problem
  203. Pulling to many volts from the tach wire?
  204. Nitrous Outlet 78mm plate jetting
  205. 26 degrees, still pull timing?
  206. Wideband cutoff switch.
  207. NX bottle opener/ Nitrous Outlet bottle?
  208. Plugs and tune HELP
  209. Solenoid nut missing pic inside..
  210. does a 15lb bottle take alot longer to heat up than a 10lb
  211. who can i get to do me a wiring diagram for my set up?
  212. Tuning methodology questions
  213. What direct port kit should i go with??
  214. NOOB Questions???
  215. another nitrous purge ?
  216. sponsers step in
  217. Nitrous purge kit advice?
  218. hey nitrous express can i order some new stickers for my solenoids
  219. how many 1/4 runs can you get witha 100 wet shot with a 15 lb bottle
  220. Anyone tried Zex nitrous plugs?
  221. At what HP levels do lean rear cylinders start showing up at?
  222. Can I still get a tune?
  223. How to tell if a solenoid needs rebuilt?
  224. Cool video we made.
  225. nx proton plus or other cheap kit?
  226. what does nitrous do for you?
  227. 91 octane vs 50/50
  228. BR7EF's...ok for a DD?
  229. question about warping the decks...
  230. Vertical Bottle?
  231. window switch in M6 car
  232. C5 zo6 tach signal wire location
  233. nitrous switches
  234. need some help with surging issue
  235. New Engine build 408 W NITROUS OUTLET D.P
  236. Re-tune for a 100 shot or not ????
  237. need a wiring diagram
  238. Good cam?
  239. how to destroy a stock bottom end
  240. Nitro dave 2010 camaro kit.
  241. calling anyone from HSW, please let me know what you think?
  242. Rookie standalone ?'s
  243. timing tuner controller
  244. Ls powered 69 on the bottle
  245. How hard is it to change a bottle valve?
  246. Just had my bottle filled.
  247. Okay got my n20 going, but now Im loading up on fuel?
  248. 125 wet shot on a stock a4 torque conerter!
  249. plate question
  250. HSW 90mm plate jetting?
