PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. what do you think?
  2. Christmas Sale Starts Today!!!
  3. 1999 205k mile ls1+75shot bad idea??
  4. nitrous 408 lq4 on e85 real world experiences..........
  5. reverse polarity with relay?
  6. 228r prc 5.3 stage 2.5 + 100shot
  7. Question on timing for 100 shot.
  8. The NOYZEE camaro is for sale!! hate to do it but
  9. What to do? PLEASE HELP
  10. 13:1 150 hit and pump gas
  11. How often do you guys change spark plugs??
  12. 9's first time out..
  13. what should the plugs look like
  14. Carter01 Moved on up today... Video inside!
  15. Whats the most you can spray and be safe with a nitro daves 2 stage plate
  16. Best TB for nitrous.....Vendors please come in
  17. Ever wondered what a 3200 Horsepower Nitrous Shot looks like?
  18. 226/236 584/601 114 Keep it or swap before juice
  19. Pulling timing with Intune?
  20. LS3 Direct Port by NX
  21. N/A tune + spray guys, show me your setups
  22. My nitrous outlet direct port pics....
  23. hesitation when n20 activates
  24. Should I use nitrous
  25. Nawwzzz
  26. nitrous and fly cutting
  27. Nitrous and timing??
  28. What dou guys think?
  29. Nitrous 408 LS2 Build Thread
  30. how much timing for 100 shot ??? by tomorow ???
  31. NX Nitrous Kit install on 02 Camaro
  32. Fuel pump and injectors question?
  33. New Victor Jr intake with spray bars pre installed
  34. Pics of the wiper cowl with 4150
  35. Bolt ons and 150 shot NANO dyno numbers; Thoughts?
  36. New to nitrous. Advice please.
  37. New to nitrous..
  38. Pump Station Blowout!! $699.99
  39. AFR's go rich on bottle. Nitrous Experts, Chime in!
  40. Proton Nitrous and acc F/S
  41. Nitrous and Meth
  42. chris@n2o big props
  43. lnc-2000 and nos launcher wiring?
  44. Starting Now!!! Black Friday and Cyber Monday Sale!!!
  45. fogger plumbing?
  46. max effort intake
  47. Nitrous Outlet 102mm Plate System
  48. Alzilzil Racing - Direct port
  49. NXL system to mount on FAST 102
  50. Help Wanted: weird big power drop in the middle of powerband
  51. Does anyone run the MSD 2 step with nitrous?
  52. FAST 102 Direct Port.
  53. good cam to spray in my 5.3?
  54. ring gap and nitrous.. ls2
  55. BIG Thanks to Nitrous Outlet team
  56. What plug gap?
  57. Thoughts on HSW Sudden Impact plate
  58. Lets Play "Name That Cam!" And the Winner Gets A Free Camshaft!!
  59. Hittman's stock cube nitrous car
  60. Fogger on stock LT1 intake?
  61. New PB
  62. adjusted controler
  63. TBSS cam only + nitrous= 10.77 Record
  64. nos jets
  65. required jets! help please!
  66. Blower cam in a nitrous car???
  67. why is my nitrous not activating?
  68. Holly High Rise Under Manifold Direct Port
  69. plugs
  70. We are ready for the 8's!!!!!!
  71. Stand alone options
  72. Clean/Powdercoat Nos Fogger Nozzles? Noob/Maybe really stupid question
  73. NOS plate or twin nozzles what do you guys prefer
  74. Jetting for E1 single nozzle?
  75. Anyone had used a Delphi t/b with HSW interface or dry pre-maf ??
  76. Can i have an optimized n/a tune with HSW interface
  77. How long should lean spike last?
  78. We just Sprayed 200shot on C6 ZR1.....
  79. My SUV's in the 12's
  80. 1st time with nos that i didn't hav to be towed home
  81. Question about Timing Retard Box connected to Progressive Switch
  82. Adjusting ignition timing on MSD optispark?
  83. Nos filling
  84. Rings for nitrosus build
  85. Nitrous Outlet Hoodies and Fleeces!
  86. 370c.i. LSx Nitrous truck, NOS cross bar dyno results and track times
  87. What can I hit on a stock longblock without a tune?
  88. At what point is the stock cam a problem?
  89. Info
  90. need a hsw interface harness
  91. Piston Ring Recommendation for 175 shot max? Are Hellfires Overkill?
  92. Halloween Sale! 1 Day Only
  93. who can help me with wiring my window switch?
  94. aeromotive 340, nitrous outlet plate, and NANO, do i need to up my fuel jets?
  95. Wiring schematic? I checked the sticky.
  96. Worried bout spraying cool weather
  97. Mother bottle mount done
  98. NX bottle heater kit F/S
  99. A couple melted spark plugs
  100. Lq4 + n2o
  101. Is it 9's worthy? Nitrous setup
  102. 75 shot on Ecoboost Flex vs 09 CTS-V
  103. Which nitrous system to use
  104. NO2 fuel distribution
  105. 75 shot on a ls3
  106. 383 street car with nitrous
  107. Dumb Question on Nitrous Jets
  108. Installed and tuned packages!
  109. Bottle Valve
  110. Well my stock short block 8 second pass
  111. Come on in Cam, Shiz, ATV, and Martin, boostit5.3 says to tune w/ knock sensors
  112. heads cam + nitrous help
  113. some shake down dyno pulls
  114. Whose The Fastest Bolt On Nitrous GTO?
  115. 75 shot on normal plugs
  116. BMN Nitro Controller
  117. Where would this be on the 1/4 mile fast nitrous list
  118. 4.10's/4.11's in High Mileage '98 F-Body
  119. IAT resistor mod
  120. Talk me out of it guys...quick...
  121. Nitrous Experts Please Help
  122. 92 fast plate set up? give me your feed back guys
  123. Here are the HSW Interface instructions...
  124. Stock LS6 CTS-V 150 shot dyno.....
  125. Need info from a LS nitrous guru
  126. 228R Cam + Nitrous?
  127. Big Thanks to Nitrous outlet & Brian Black
  128. Things to consider when adding 150 shot to cammed LS1?
  129. what gears make nitrous happy
  130. Check my plugs from track today.
  131. Slower on spray
  132. am changing to Direct Port and would be
  133. Reading plugs info needed **now w/ pics**
  134. Safe total timing 50-100 shot?
  135. A VID from last night w/ The TA.
  136. spray rpm
  137. Got the kit in!!!
  138. Nitrous install help
  139. Filling one bottle from another
  140. nitrous tank line question
  141. Need a refill rochester NY
  142. A lot riding on tonight for my SBE N2O car....
  143. Custom Intercooler Spray Bars.
  144. My mixed and matched Plate system
  145. Nitrious stuff is on the way. Thank you NX
  146. Way lean while spraying
  147. Low compression motor and spray
  148. My Lingenfelter Nitrous Controller experience
  149. How far do you roll out before you spray?
  150. plate gasket question
  151. direct port dry setup questions
  152. Bottle Heater Question
  153. I've searched...
  154. C5 nitrous install
  155. hsw jets
  156. First nitrous pass on 150 :)
  157. 2003 silverado
  158. A few questions. Opinions please.
  159. and the Stock Cube Record falls *vid added*
  160. Nitrous cam!
  161. What would be thebest nitrous plate for performer rpm lq4?
  162. Come get it!!
  163. Nitrous filter placement?
  164. i need ADVISE PLEASE!
  165. ALZILZIL RACING - Direct port on LS7 and LS1 fast 102
  166. Switching Setups.....
  167. advise
  168. Nitrous Veterans, please help...
  169. general nitrous questions on ls2 vette
  170. H/C LS1. New to nitrous, what can I do with it?
  171. New Nos setup questions
  172. Intake manifold and exhaust questions
  173. N20 and suspension question
  174. Trick Performance window switch....
  175. stock bottom end. how much cam i push it to??
  176. 01 z28 how much power will the stock fuel rails support?
  177. new best last nite.
  178. Zex perimeter plate
  179. Nitrous Backfire
  180. First pass on the new setup
  181. Time to build it up and join the fun...
  182. what are the drawbacks to adding n20 to a FI setup
  183. jetting help...nos brand nozzle
  184. Swollen nitrous plunger
  185. Hemi Direct Port
  186. Quick Bottle weight question
  187. Tuning Write Ups From Robert56?
  188. Jetting help
  189. dynotune performance simple WOT switch
  190. need a progressive controll 2010 camaro what one?
  191. window switch automatic, save transmission
  192. SBE M6 1st time out on the gas
  193. Msd timing twister 8625 on/off?
  194. 01 vette nos?
  195. Purge valve not opening with N2O valve open...Help
  196. Anyone Dyno test a progressive nitrous controller
  197. Finally got some plugs pulled - help with reading please!
  198. New best for me
  199. So I had a bit nitrous backfire at the track.. How bad do you guys think it's hurt?
  200. HSW Module and More...
  201. 99-06 and 08-up Switch panels now avaliable!
  202. pics of nitrous outlet plate kit install?
  203. NOS Nitrous bottle blow down fitting
  204. Spray and Pump Vs. Racing Gas
  205. Bought an intake with a Nitrous Outlet direct port, need to know about the jets in it
  206. 02 z28 factory fuel rail
  207. stupid question, brace yourself
  208. 2004 c5 80k miles safe for 75 dry shot?
  209. Last Week for End Of Summer Sale
  210. Pulling Timing Via the IAT, Problems?
  211. Any issue daily driving on nitrous tune?
  212. Dual-stage install finished.....
  213. lq4 popping at 7k on nitrous but fine on motor
  214. What rings and what gap
  215. 100 shot...these plugs and timing sound right?
  216. Need advise in ramping when Launching whith 300 shots (dual stage)
  217. Nitrous Tune Question
  218. Stupid wiring question, just need quick answer
  219. Nitrous build? or ....
  220. please delete
  221. Wet or dry kit
  222. Low Bottle Pressure and Can't See Nitrous.
  223. Help with cam choice.
  224. high or low pressure fpss
  225. First Timer
  226. Be looking for my TA in a up coming GM HIGH-TECH
  227. help on plug selection....
  228. msd window switch problems
  229. MSD dig window switch help
  230. Pics of Nozzle kit installs?
  231. Sneaky Viper Direct Port
  232. Stand alone fuel pressure?
  233. -4 or -6 main feed for 200hit
  234. Jetting up, any et estimates?
  235. Whiteltone stock cube beater V2.0
  236. C5Z N20 Pull
  237. anyone using a MAF kit?
  238. LS Swap Mustang in the 8's
  239. Finally got the car out....
  240. Stock bottom 5.3 best plate setup?
  241. 2010 camaro ls3 tach signal
  242. New best... hurt motor finally PICS ADDED
  243. Installing progressive controller and harrispeed interface controller
  244. window switch wiring
  245. Nitrous Outlet End Of Summer Sale
  246. who much spray
  247. the do's and donts of a nitrous setup?
  248. Difference between these Big Shot solenoids?
  249. Best flowing muffler for true duals with 408 ci and 250 shot nos
  250. nitrous solenoid fried...why??
