PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 [110] 111 112 113 114 115
  1. Pump #7 w/nitrous Yes/No ????
  2. bought Nitrous finally
  3. Gettin out of the n2o game
  4. Need help with Nitrous Install...
  5. How much is too much?
  6. Fuel Pressure?
  7. SECO seals to seal leaking fittings
  8. NEED HELP WITH SOMETHING FAST
  9. Anyone with Vig 3200 & 100 shot, what does it flash at?
  10. ordering tnt wet kit what all needed? purge/heater/msd
  11. What's a window switch???
  12. MAF Ends & Nitrous?
  13. anyone using the new NOS DP NOZZLETS?
  14. 15lb bottle in Convert. spare tire well
  15. NX MAF kit
  16. What fuel jet with a 55N pill?
  17. NX Heater on TNT Kit
  18. how much does a 10 lb. bottle weigh full?
  19. Interesting Idea..Yes..No?
  20. why so much torque w/nitrous, you ask?!
  21. Nitrous on an A4 is spray through shifts ok????
  22. H/C cars on the bottle?
  23. direct port
  24. HELP! new to nitrous. getting tnt 100 or 150 shot need fuel pump?
  25. Got a NX MAF kit, what could i sell it for?
  26. Window switch?
  27. Wow! The vig 3200 rocks with a 100 shot
  28. Everyone, please, it is called "nitrous", not "NOS"
  29. How much NOS for stock LS1¿?
  30. troubleshoot this dyno graph please...
  31. What will fix leaking nitrous fitting?
  32. Where do I install the in line fuel pump?
  33. st3500 and window switch help
  34. Fixed 1 problem, now another....Nitrous only works in 1st gear
  35. Anyone running Nitruos without ATAP??
  36. HOT FREE PORN.....okay, TNT question
  37. Water/Alcohol Injection
  38. Finally a way to control our timing!!
  39. NOS progressive controller diagram
  40. Nitrous sprays.............Car falls on it's face? WTF
  41. "Hand count" of where you guys have your bottle.
  42. would this work? its a pretty sick show off kida idea...
  43. Spraying on a Vigilante 3600 converter
  44. Anyone running Stock manifolds with Nitrous??
  45. Nozzle behind TB???
  46. Direct port?
  47. OK decided on 150 shot
  48. Is the NOS Cheater solenoid too big for a purge?
  49. Sprayed for first time tonight...
  50. Lets see those trunk bottle mount pics....
  51. HELP!!! TNT sprayed once and motor blew!!!!
  52. paging nitro dave's performance
  53. 15 lb NOS bottle + NX opener + in the tire well-> FIT?
  54. possible to order a kit with a small bottle?
  55. Denso Irridium Plugs with NOS?
  56. Nitro Dave's Performance!
  57. Best NOS kit
  58. Auto T/A would it hold a 125?
  59. Can 30lb svo's hurt a 375rwhp motor?
  60. Question for people with NX wet kit (150 shot)
  61. 125 wet shot? 2000 trans am
  62. Do I need a relay?
  63. Compucar Bottle Heater?
  64. I need the TNT solenoid mounting bracket for a C5
  65. Venom VNC-2000
  66. NX Switch panel wiring diagram?
  67. any place to put the bottle hidden besides the spare tire well?
  68. NX Solenoid Current Draw?
  69. Help! Tach/MSD/Jacob's--Cant' Get Tach to Work!
  70. For yall that spray big shots what oil do u use.
  71. best brand
  72. Nitrogen push instead of heaters(warning: big pics)
  73. TNT on an lt1
  74. Should i get new spark plugs with an NX wet kit??
  75. A few general install questions...
  76. NOS wet Shot
  77. Ignition... any real upgrades available?
  78. Progressive controller ?
  79. We will match or beat anyones prices on NITROUS EXPRESS
  80. want to convert to wet
  81. I just got back from the local dyno
  82. what do these do?
  83. How much Nitrous can you run on a Forged bottom end????/
  84. what rpms are you all seting up your window switch?
  85. Is the Venom kit really worth the money? (safest kit?)
  86. 375 RWHP N/A, safest shot for wet kit?
  87. Pictures of my TNT F1 installation inside........
  88. question @ 4.10s and nitrous
  89. NOS 5177 kit?
  90. Digital pressure gauge
  91. 2 Stage nitrous questions.
  92. NOS 5177 Kit CA. legality/performance questions
  93. Fuel pump inline or intank?
  94. NOS drykit to wetkit conversion question?
  95. Bottle Pressure & Affect On Nitrous Detonation
  96. GM EFI NX KIT 4SALE!
  97. Timing in nitrous, theoretical question??
  98. Car misfires with TR6'S
  99. i need some pics of peoples purge setup
  100. Mallory window switch?
  101. Which pill to use?
  102. Spraying Truck... Got Q's...
  103. Any comments on running some race fuel?
  104. Anyone know the status of the Racetronix in-tank pump kit for the 99-up cars?
  105. Supercharger/Nitrous sale
  106. TNT kit owners......What bellows did you use?
  107. What fuel pump to upgrade to for 100 shot, H&C?
  108. TB Plate or Nozzle
  109. My Ws6 Purgeing
  110. First impressions...I think I'm hooked already
  111. nitrous, blah
  112. 150 shot help.....
  113. Ati Blown C5 v TNT C5!!!
  114. This is for all you heavy n2o users
  115. Help! Needing Wiring Info for NOS Remote Opener
  116. SES light after third spray???
  117. What do u think of my set up?
  118. Going to spray for the first time soon....
  119. Had problem with heater transducer ???
  120. Nitrious Fittings - How Tight Is Too Tight??
  121. What ET's can I expect?
  122. descreen MAF with nitrous??
  123. Anyone looked at the new NOSzle system?
  124. holley's aluminum intake and nos
  125. Nozzles?
  126. What's a good price to pay for a nitrous solenoid?
  127. A little nawsss action on video
  128. I just ordered my nitrous kit...
  129. TNT question???
  130. How much nitrous can you safely spray on a BUILT 382/383 motor?
  131. Anyone elses Harlen Shift light blink when you hit the juice?
  132. 150 shot question............
  133. maf & hpp3
  134. spraying an old motor
  135. NGK Iridium or TR6 for N2O??
  136. HELP, NX wet kit install ... only one noid will work at a time.
  137. All of you running a big fuel pump... NA are you running rich?
  138. Bolt on 75hp
  139. Remember my problem with my N20 at SLP Day
  140. Moment of truth is coming
  141. Custom ARP Head Studs- Who's interested
  142. Cartek H/C and I want nitrous
  143. Serious Bout Nitrous Oxide(need all the help i can get)
  144. Word of advice on blow offs on nitrous bottles
  145. Looking for nitrous bottle valve with a built in pressure cap
  146. Newbie needs help...
  147. Mounting Location for NOS Progressive Unit?
  148. WTB used NX Kit
  149. fuel pump?
  150. plug?
  151. will tnt ring fit an 80mm TB??
  152. best wet kit?
  153. does tnt have a remote bottle opener?
  154. what fuel pump with tnt f2?
  155. TNT power ring for sale..
  156. where to get just the NX maf ..
  157. Fuel Pump
  158. My Fuel Solenoid Failed
  159. Is it difficult to install a 340 Walboro in tank pump?
  160. Bottle... what size is the fitting for the pressure gauge ?
  161. ok how about a serious TnT F1 vs NX wet kit debate
  162. Nozzle placement??
  163. I need nitrous help?
  164. need help with nx tps switch
  165. Nitrous with a window switch? Question inside.
  166. Thinking bout NOS
  167. Will a NX purge kit fit on a TNT dry kit?
  168. Is it ok you think? TNT dryshot with (100jets) with my Mods
  169. New to nitrous and have a few questions..
  170. NOS 5177
  171. Nitrous newbie has a question !
  172. 75 shot, NOS 5177 on a T1 Cammed A4, upgrade fuel system?
  173. Where to find nitrous hose and adapters?
  174. First Impression,,
  175. Has anyone sprayed a 75 shot w/ Yank 4200?
  176. Finally built the bottle holder for the spare tire well :)
  177. need help from you nitrous guys
  178. nitrous wiring pics
  179. Where to buy WeatherPack connectors?
  180. Problems with 5177..... please help!
  181. TNT Kit accessories
  182. Please post pics of your setup!!!
  183. Nos 5177 kit or NX maff kit or the standard LS1 NX wet kit
  184. For the Nitrous Experts ONLY....
  185. Blown, stroked and sprayed...
  186. msd window switch!!help,asap.
  187. NX Pressure Guage!!!!
  188. NX electric nitrous pressure gauge
  189. Need to learn a little about NOS, got a couple questions....
  190. TNT vs. NX vs. NOS Your thoughts on each ???
  191. Who Runs a 100 Dry Kit with the Stock Fuel Pump?
  192. open line shot
  193. Newbie to NOS just ordered a kit and have questions
  194. Custom Fuel & Nitrous Lines
  195. I found it!!!
  196. Should I try spraying the car???
  197. Small shot dual stage for traction...will it work?
  198. msd window switch?
  199. Ew-wee this is a Nasty set up!!!!
  200. nx kits
  201. Anybody running a seperate fuel system for nitrous?
  202. NX vs. NOS
  203. Does VERY high heat and humidity kill you N20 shot?
  204. Nozzle Location Question
  205. Knocking 1.8 seconds off ET with
  206. Do I really need a window switch???
  207. NX MAF system
  208. Has anyone replaced just pistons, rods & bolts with spray?
  209. nos install,can i leave my tr55's in?
  210. Best bottle pressure to run w/a 10lb bottle....
  211. check out my new switch plate :)
  212. Nitrous questions
  213. hooking up nos (window switch)???????
  214. TNT 100 WET Shot times suck
  215. Does anyone know....
  216. Fuel system question for a big shot
  217. Nitrous
  218. Calling ASR OFF...
  219. buying lt1 wet kit/ ZEX good?
  220. rev liimiter and tnt
  221. Nitrous Install help?
  222. How 'bout a home made bottle heater?
  223. Is this a good price for a complete NOS 5177 setup?
  224. Pictures of the NX MAF kit
  225. Dry Kit Question
  226. WTF? I hit the speed limiter at the track!
  227. My fuel pump
  228. Full throttle switch, and MSD window switch....PEOPLE WHO HAVE THESE INSIDE.....
  229. Need some advise!
  230. sell ati charger and get 150 shot?
  231. Whats the biggest dry setup youve sprayed thru one nozzle?
  232. How do you wire these things??? PLEASE HELP!!
  233. Need Instructions for F.R.E.D.
  234. TNT F1 problems anybody who has one please help inside
  235. How much pressure til my bottle 'splodes?
  236. nitrous?
  237. WTB - NX EFI Kit
  238. NOS5177 info please...
  239. SS owners with TNT kits, come inside.....
  240. NX switch panel and NX bottle heater problem....
  241. Must read on nitrous.
  242. Thinking of changing N20 systems.. Need some advise.
  243. VenomSS please come in...
  244. What do N20 kits for LS1 Camaros go for...
  245. Honest question...
  246. BFG Drag Radial Air Pressure?
  247. Specific cylinder risk from nitrous...is there a difference?
  248. Custom NOS on LS1Truck questions?
  249. biggest shot i can sprayon my 382
  250. which cylinder is the........
