PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Does any sponsor on here have a LNC-002 controller?
  2. Nano and other ?s
  3. Christmas Sale
  4. Nitrous advice ls2
  5. 3800 L36 firebird nos?
  6. which cyl is most important when reading plugs
  7. stock LT1 and nitrous
  8. effects of cam selection with nitrous cars
  9. NANO Check Valve Question
  10. Some M6 Launching on nitrous questions
  11. Help with a plug reading please.
  12. nitrous ? for LT1
  13. BONE Stock 2000 Z28+Nitrous
  14. MSD Timing Twister
  15. what should i go with
  16. Nitrous specialist installer needed in the NY, NJ area
  17. Fuel Octane VS Shot Size?
  18. What kinda base timing should I run?
  19. Which HSW kit for L76 intake?
  20. 90mm plate on 92mm Fast
  21. Out with the TH400, In with the T56..
  22. how much do you think I can spray
  23. Purge in CAMAR"O" plate (and some install pics)
  24. cyber monday sales?
  25. New PB and 60'
  26. NX pills in NOS plate question
  27. HSW Microedge 6-Speed Settings??
  28. N2RacingLS1's Survives 260'+ Bumper Drag on Dry Nitrous
  29. What's my limit opinions?
  30. Looking to get in the Nitrous game
  31. pics of battery post connection
  32. anyone spraying with a ms4
  33. Nano nitrous black friday sale!!
  34. Dynotune 100HP wet shot jets
  35. Tuning my new set-up for spray.
  36. tap into the tps for activation?
  37. wet or dry
  38. Painting Nitrous Bottle
  39. Black Friday Sale
  40. Nitrous + Fast Toys Timing Tuner
  41. Different types of relays?
  42. **LMR Episode #6**
  43. Any shops doing the Black Friday Sales Again?
  44. new system keep my cold fusion or use mt nos noids
  45. 1 gallon fuel cell as stand alone...how long would fuel last?
  46. How much HP will i leave on the table?
  47. what is the standard pressure for running a low pressurr stand alone
  48. Which plugs for a 150 dry shot
  49. Running dead rich on the bottle after cam swap
  50. Dyno tune nitrous plate
  51. Buying some acc., what else do I need?
  52. Nitrous build, 388Lt1
  53. Convert 04 Cobra wet plate kit for LSx
  54. changes needed for a 50 shot?
  55. Nitrous Outlet Big Show Purge Kits
  56. nos or nx
  57. N20 freezing water/methanol mix?
  58. n2o?
  59. N20 / afr?
  60. New PB 10.51 @130
  61. Looking for "how to" for nitrous activation & timing pull led light
  62. fogger or direct port
  63. Mounting a wet nozzle
  64. Tony Sheppard= Owns LT1 N2O Record
  65. Suggestions for a new shortblock
  66. TNT nitrous solenoid locks up after 1000 psi
  67. Can I do the relay trick?
  68. NOS bottle heater relay
  69. i think my nitrous outlet solonoid is locked up
  70. Will this 45 degree fitting hurt flow?
  71. Ok need to know if this fuel setup will work?
  72. Are all AN fittings good enough for nitrous?
  73. Nitrous Outlet Direct Port: Art with an Attitude
  74. My take at a DIY stand alone low pressure fuel system
  75. Spray 75, 150 or 175? Cam only ls1
  76. AES FAST LSX-R fogger
  77. Why is fuel jetting for a plate richer than the jetting for a nozzle?
  78. How am I gonna hide this? Added a few more pics 12/19
  79. need help? Plumbing my own nitrous distribution block.
  80. What Plate Kit to use on LS6 Manifold???????
  81. How much timing to pull for 150-200?
  82. What is the max you can spray through a brand x nitrous solenoid?
  83. how much nitrous could I spray ?
  84. 100 shot ?
  85. Carb Plate with F.I. Fuel pressure
  86. Which nitrous setup with this setup (LQ9 w/full aeromotive fuel system)
  87. Nitrous Questions on a Gen 1 SBC.
  88. Putting together a kit need some help...
  89. best way to pull timing without using software?
  90. mph GAIN with 150 shot
  91. Got the bottle mounted
  92. Nitrous oxide Good And Bad
  93. wanting to do a fogger on my ls6 intake
  94. 112 or 116
  95. 150 to 200 shot? .16 mph??
  96. Spray or no Spray?
  97. Nitrous question
  98. New to Nitrous.....Check my list please
  99. New times with the 6.0!
  100. HSW Wet plate issues
  101. Are there any downsides of NANO?
  102. What ring gap ??? LS2 404ci
  103. 7.86 177
  104. New best ... 8.02 @ 154
  105. who runs a ms4 and spray
  106. NANO connected to the wrong port?
  107. Clearance Items @ The Outlet
  108. Planning on spraying, am I good to go?
  109. New to spray, help me out! HSW Dry plate!
  110. Anyone spraying through the gears?
  111. nitrous on a 408
  112. Anyone running nitrous with a roots?
  113. where to get a b10efs ngk plug
  114. nitrous just stopped working
  115. Wiring question?
  116. Think I lifted a ringland
  117. Need advice
  118. check my plug
  119. how big
  120. FJO Gen-1 Software install file needed.
  121. Is 150 shot to much for a SS4000
  122. do i need 116 in the tank for a 300 shot?
  123. Can NOS be ramped in in 1st gear
  124. Difference between 2nd gen and 3rd gen N.O.S. tanks?
  125. hsw interface
  126. first time out on spray (videos)
  127. new to nitrous.few q´s
  128. Should I Nawzz my Hawk? 4:56s and a 6 speed???
  129. IAT tricker + sd tune + nitrous = potential boom.
  130. making sure I got this right???Nitrous Outlet
  131. what fuel use ?
  132. new pb, video inside
  133. How it's made: 100% Synthetic Oil Filter [VIDEO]
  134. nitrous install help
  135. What type of Wiring do I need?
  136. Need size for TNT fogger nozzle
  137. what kinda window switch
  138. Plate or nozzle?
  139. Big Thanks for a Great Year!
  140. ? on reading plugs
  141. Finally getting this drag radial/suspension/nitrous thing figured out! Vid posted
  142. Nitrous gains seem a little lacking
  143. camshaft for my lsx 400+ shot
  144. Best way to accomplish my goal?
  145. Smith goes 4.99 !!!!!!!!
  146. 75% 93Gas 25%Toluene for nitorus fuel cell
  147. The safest nitrous setup?
  148. Can I use a performance mass air flow housing with nitrous
  149. How NOT, i repeat, NOT to install a nitrous kit!
  150. How much nos can a lt1 block take???
  151. input needed "inpressive or standard"
  152. Heating Solutions
  153. Quickest 150 LS-Powered Cars of All Time
  154. Motor purge wiring
  155. Spraying nitrous early in first gear with A4....
  156. Remote gauge/nitrous filter Q
  157. Tuning NOS LS1 Plate - Way lean!!
  158. whats the stock number for a ngk br7ef
  159. Looking for info on Activation switches
  160. found the limmet of the stock block
  161. Solenoid Problem
  162. 4l60 with n2o. Shifting
  163. Switch Mounting Suggestions
  164. New nitrous system
  165. Thinking about increasing my nitrous shot
  166. How does timing affect power levels.
  167. Another A/F plug reading question.
  168. New personal best!
  169. nitrous problem help.
  170. using ASR & foglight buttons for nitrous
  171. Fastest Stock Longblock?
  172. Proper Way To Purge W/O Purge Kit
  173. What hp shot needs aftermaket fuel pump?
  174. Fuel Rail Parts
  175. 9-1 compression with nitrous need feedback on my setup
  176. New to spray, just bought a kit, couple ?'s
  177. new trunk, 30 pound weight reduction
  178. Lingenfelter two step/retard
  179. Window Switch?
  180. Big thanks to nitrous outlet
  181. HSW plate users inside
  182. hiding nitrous intake line?
  183. Need some nitorus help.
  184. Spark Plugs For Nitrous
  185. Nitrous Feed Line
  186. FS: 25 LB Nitrous Oxide Bottle $160
  187. need some advice
  188. can i run a low pressure spring in my stand alone on my hsw plate
  189. got my 15lb bottle and 4500 nano in spare tire well under plastic
  190. got my 15lb bottle and 4500 nano in spare tire well under plastic
  191. nitrous LQ4 sonoma
  192. BR7EF with ~11.4 CR on heads/cam 100 shot car?
  193. Best Place to Enter Wires into Car
  194. Let's talk about nitrous filters...
  195. Where is the Cheapest Place to buy a timing Tuner?
  196. bbk ssi
  197. Spraybar in Super Vic + another plate
  198. How many seconds would it take to run out bottle on 50hp or 100hp jet
  199. problems once the nitrous is activated
  200. C5 fuel system
  201. What setup did you go with on your LS3 heads and intake?
  202. slower than i hoped, but still a new PB.
  203. Nitrous And Transbrake Wiring Hookup
  204. who says a 3000psi nano and 10lb tank wont fit
  205. Br7 Plugs
  206. New PB 10.34 @130
  207. New PB time on the bottle
  208. Will this Bott'el deaux ?
  209. 5.01 @ 140 !!
  210. Pistons out of the hole?? Bad for Nitrous?
  211. 2010 meet Nitrous Outlet
  212. Just Bought My Wet Kit.
  213. Whats the correct way to adjust the FPSS?
  214. Anyone use the NX stand alone fuel tank?
  215. anyone ever hooked up a ZEX kit on a LS car?
  216. Nitrous Gauge ?
  217. Any Problems with a PP intake and a wet plate?
  218. Anyone make their own stand alone?
  219. what mass air are you using
  220. Solenoid Maintenance How to
  221. Happy B-Day Chris!!
  222. Zex plate?
  223. Bottle placing spots in car?
  224. af
  225. Nitrous/RMVB TH400 guys...
  226. Is this bs.
  227. New to nitrous
  228. NX Nitrous Switch
  229. new to nitrous.few q´s
  230. MicroEDGE users, What are you setting your wideband lean cutout settings to?
  231. Popping in the exhaust....
  232. new to nitrous. what is this?
  233. 50 shot on stock plugs and stock timing?
  234. Air Fuel Ratio
  235. 02 z28 dry nozzle placement...need help
  236. NANO users attending LSX Shootout head count
  237. 6an nitrous line/ fuel line... is there a difference?
  238. help me pick a nitrous controller for my set up
  239. please help..
  240. personal best
  241. Looking for best ashtray switch plate
  242. Finally done and cleaned up
  243. how much heat can the HSW MicroEdge controller handle?
  244. How much can I spray and be safe on my new motor
  245. FAST 4150 TB with N2o guys step in please..
  246. what to do what to do
  247. 100 shot times from last night. Very happy.
  248. Will this kit work?
  249. Do I need fuel mods?
  250. 7 second pass
