PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Good place to buy switches?
  2. Need a pic!!
  3. Cobalt Blue "Nitrous" gauges. Does anyone have these? Show me your fancy gauges.
  4. Newbie to Nitrous -- need help
  5. Whos got the best progressive controller??
  6. need the nitrous shark picture!!!
  7. Which octane should I use with a 150shot of nitrous???
  8. How much nitrous with heads?
  9. nx problem
  10. Dumbest nitrous install ever!!! I spilled on myself after reading this
  11. Possible Help for Newbies (PDF instructions)
  12. jet size
  13. NGK Part Number Please
  14. Nitrous on a stock crank
  15. Tnt Question
  16. Nitrous on a stock LS1...
  17. IAT Timing Retard Verified w/ ATAP ...
  18. Neat jet calculator
  19. 383 with dp 200-300, couple questions
  20. nitrous newbie question
  21. Anyone know how to get a hold of Nitrous Outlet or Nitro Dave?
  22. What Happened To TopGun?
  23. dp fuel system pics
  24. whats the fastest m6 with a 10bolt?
  25. Holley black pump ?
  26. Help with a Lean Problem!
  27. O-ring for nitrous, head or block? What Gasket?
  28. wire guage affecting voltage?
  29. Just a few questions from a NOS Newbee down under
  30. Swapping in N2O for a blower...
  31. What are the details of this NXL "fuel reservoir"?
  32. Need Ideas on where to mount tiny guage
  33. Tnt F2 ?????
  34. 409 w/ 200
  35. Need input
  36. 5.3 liter heads+n20
  37. NOS Jets
  38. What's the MOST Juice You Can Run
  39. t.n.t or nx? wet or dry? please help!
  40. Need Help!
  41. What fuel pump
  42. Stock Bellows?
  43. nx jets!!!
  44. Help, controler/retard questions
  45. Fed Up with Nitrous Express...
  46. Need wiring diagram for a TNT F1 kit!
  47. anyone have the direct port (nos) kit from speed inc?
  48. IAT Timing Retard Switch Works!!!
  49. Which Kit? Where can I get it?
  50. TNT F1 Kit
  51. gap on nitrous plugs
  52. Purge Kit :eyes:
  53. Can I run a 100 dry shot with my 150 wet shot and just need bigger injectors?
  54. Dry Kit Question
  55. Is the ZEX bottle warmer a good product?
  56. Nitrous experts inside please
  57. Walk me through a nitrous
  58. stock convertor quest
  59. I think I have a safe way to run 300-400hp single NX S.H.O single nozzle shot
  60. 250 shot, stroker or not
  61. buying jets?
  62. Best way to activate nitrous
  63. How far can a wet shot be sprayed before the fuel starts to drop out?
  64. nx f1 wiring diagram help
  65. Please don't send me to search
  66. Advice on fueling my dry kit now that I have new mods
  67. Switched Hot for N2O?
  68. 02 WS6 with TR224 cam going with 100 shot on nittos (what to expect)
  69. Digital gauge
  70. Direct Port, stand alone fuel writeup!
  71. Air Fuel Ratio on juice
  72. Anyone have pics of blowdown tube set up with bottle behind pass seat??
  73. Ok, school me in nitrous please?
  74. Jet size?
  75. NX Maximizer
  76. 100-150 Shot plug gap? TR6's
  77. HP low on the N20.
  78. Making my own kit-What do i need?
  79. What fuel pump for nitrous dp setup?
  80. Remote Bottle Opener Wiring
  81. after search/research, still confused
  82. which kit do yall think i should use.
  83. Seperate fuel cell or twin intanks for 200-250 shot on 408?
  84. Fuel Pressure Gauge
  85. N20 List
  86. 75 shot ok with NGK TR55s ?
  87. Testing Noids
  88. N20 A/f
  89. NXL Impressions....
  90. BMW M3 gets juice and needs your valuable experience
  91. proshot fogger or sportsman fogger
  92. TNT F2 Question
  93. NGK-6 part number
  94. dry kit or wet kit
  95. can i use a 150shot with my 4.11 gears?
  96. Best way to lower compression in motor
  97. Nitrous experts Inside please.......
  98. single nozzle dry shot info
  99. Nitrous F*cked up my motor today...
  100. Any guesses on what I'd run on a 250-300 shot?
  101. RPM window switch install
  102. Paging Derty, my tune info...
  103. two questions (tire pressure, and purge kit)
  104. damn fitament w/ power ring...
  105. RPM window switch with modules for sale.
  106. Is a dual stage 300 DP possible?????????????
  107. Fuel cell ??????
  108. What is this nos setup worth?
  109. Dry Kit Jets??
  110. n20 dyno pulls!
  111. How much ET should you pick up with...
  112. It is ok for me to run NOS with the setup I have?
  113. High CR, 382cid, and 500HP of nitrous ... Need a cam
  114. Harlan window switch question
  115. Was thinking supercharger but....???
  116. converting a carb plate kit to ls1 dry
  117. Botttle warmer
  118. gauges
  119. Custom Nitrous Install w/ Pictures!
  120. nos gauge
  121. Just got my new NOS 5177 today.
  122. Mounting TNT wet kit behind TB?
  123. NX Dry kit question.
  124. Price list for NX DP Project
  125. custom nitrous piston, check it out.
  126. How do these plugs look?
  127. anyone spraying 250 on a TNT
  128. nitrous question
  129. What bottle pressure for 150 hp shot?????
  130. How Much
  131. is there such a thing as...........
  132. Numbers don't add up
  133. Alternatives to TR-6 plugs?
  134. NX pills?
  135. RPM switch question
  136. N2O Setup
  137. Torque with N2O
  138. List your N20 stereotype.
  139. DP seperate fuel system
  140. Dyno numbers with 175?
  141. TNT question
  142. who to do my nitrous install
  143. post # of bottles your LS1 been through
  144. Spraying a TCI 4400?
  145. What bottle PSI should I use????
  146. window switch tach wire?
  147. LS1 timing retard switch diagram
  148. need MSD window switch
  149. Impact of headers and camshaft?
  150. which jets for 100-125 shot on a 5177 dry kit
  151. Incagnito Kit
  152. Your thoughts on Venom
  153. 112 vs 114 lsa on juice.
  154. Need info on the type of fuel connections you N2O guys use.
  155. good n/a and N20 cam
  156. How much is to much?
  157. Any A4 Guys Spraying On A Tsp 231/237 ?
  158. post your 75 shot run's
  159. Please evaluate this setup
  160. You think this will work?
  161. Tuning NOS 51077 kit
  162. Computech N2O
  163. Well used the 200 jets tonight and...
  164. direct port
  165. Question about placement of guage/filter
  166. Nos Gmaf ??
  167. Nx Tpas Install Question!!
  168. maf screen & NOS 5177
  169. Window Switch Problem
  170. Anyone have pics of the bottle mounted in the back seat area?
  171. anyone spraying the 238/240 comp XE-R cam
  172. Still surging!!
  173. custom kit
  174. Spray
  175. Share your horror stories--->
  176. wot switch
  177. Best nitrous kit and supplies
  178. Bottled Nitrous (Houston)?
  179. need sum info on nitrous
  180. Ordered custom N20 Pistons from Diamond, good for 300-400 shot??
  181. LS1 Timing Retard Switch...
  182. Need propane info
  183. Great N20 link!
  184. Harlan switch: Where's it at Y2KHAWK?
  185. Compression Ratios and Nitrous
  186. Homemade Kit
  187. Nossle setup rocks-Thanks to Ken at Eastside
  188. Anyone experienced on fixing Solenoids?
  189. why propane instead of nitrous?
  190. Basics on Solenoids please....
  191. Biggest shot on pump gas?
  192. broke my N20 line
  193. what are the dangers or problems with overfilling a bottle?
  194. Need Expert advice about 175 shot
  195. Forged 346 vs 408-iron for big nitrous (300+)
  196. NXL guys any more good results?
  197. Please help with buying N20 kit, suggestions.
  198. will a 5.0 nos kit work on my boys ls1??
  199. 75 shot?
  200. One solinoid not working/using just 1?
  201. trying to decide on a kit
  202. Anybody willing to tell about there hidden kit?
  203. 100 shot jet#
  204. Hella Stupid Question Dry vs Wet
  205. Nitrous Express wet 175 shot jetting... Anyone have them?
  206. Anyone ever use this bottle bracket?
  207. Switch Plates
  208. Anybody running a dedicated low pressure system?
  209. Harlan switch not working
  210. Power changes with new plugs
  211. How to wire warmer?
  212. where to connect white wire from harlan?
  213. Selling my NXL
  214. Made my 5177 kit a dual stage kit got a q
  215. pic of one of my better nitrous launches
  216. Dry question for a friend
  217. cams
  218. Any install tips for 5177?
  219. Thanksgiving day project...PITA
  220. thoughts on my combo?
  221. 383 with 10.5 compression and 125 wet shot. what kind of cam would suit best guys
  222. Bottle pressure questions
  223. Timing Tuner Help
  224. HP loss from switching to TR6's?
  225. It Fit... WOOT... NOSzels w/ Hardlines!
  226. running a Big dry hit?
  227. brand related questions - please help me decide
  228. 2 heater pads
  229. Need to pick a cam for 409", 300+ n20 setup
  230. Building n20 409" For the 8's, O-ring block or heads, which gaskets, good combo?
  231. Inline Fuel Pump Help...
  232. How to make 5177 kit into a dual stage
  233. How to make 5177 kit into a dual stage
  234. Here are some pics
  235. Soleniod Maintenance Advice
  236. Can I use N20 with my F1 cam (230/226 .591/.571 112)???
  237. converter for nitrous?
  238. Nx Tps Wot Switch-help
  239. Nitrous Guru's help!
  240. Hiding Nitrous
  241. MSD window switch wiring, pills-please help
  242. Max engine bore (to be safe) with a 200 shot?
  243. Nitrous + 4.10 gears
  244. Nitrous set up
  245. how many are running the stock t56?
  246. will 1 7/8 headers help?
  247. heads/cam/nitrous on stock bottom question
  248. Question...please read...
  249. NXL sucking the rails dry?
  250. Are all jets the same?
