View Full Version : Nitrous Oxide
- nitrous plugs
- WTF 15 lbs. Bottle in NOS 5177 kit
- MSD Window Switch question
- stand alone ?
- n20 ????
- is n2o my best option
- Drew Up a Switch Panel Design - Yay or Nay?
- 75 shot
- To stand alone, or to not stand alone...
- What clutch???
- #1 A/F safety product back in stock!!!!!
- decided on my new system
- Trying to Run Nitrous safe as possible
- ATT: All N2O Sponsors, please read.
- Am i missing something..
- kit is here
- pics of nitrous outlet body mount solenoid bracket?
- 150 Shot Timeing
- 15835 nos controller wiring help??
- weakest link?
- N/x Maf Kit.... Come on in
- N2O Set-up question
- New user with questions
- Whats your exhaust setup?
- Standalone Fuel Cell
- single realy diagram with mds pilled rpm switch
- Nitrous AFR and EFI Live A0015 Calculator
- low n20 numbers, is my noid bad
- Fastest T56 or Tremec LS based engine?
- Trick Flow heads and plugs?
- Best Nitrous setup for me?
- hi or low pressure fuel system on your directport using a dedicated fuel system
- Does anyone make a progressive controller that pulls timing?
- Secret recipie at 65MPH =
- 6.0 iron block
- how long doesnt it take for your bottle heater to bring your bottle up to pressure
- Got a Buddy Wonting to Sell me Nitrous
- Jetting for 125 on Dave's LS1 Plate?
- hsw nitrous braided line
- Couple of wiring questions!
- thinking nitrous again
- direct port pics?
- whitch jets to use for plate???
- What would it take to make a ls based z28 trap mid 140's?
- 3 Questions - Amp draw, Injectors, Stall
- Bulk nitrous cost? How much for a 100lb cylinder
- Zex LT1 Kit Questions?
- Relay Problem?
- Nitrous Outlet TAPS
- Dual or single nozzle for dry???
- Trying to get rid of some nitrous stuff.
- what do you think good to go?
- Guys running NGK plugs that are purchased from Oriely come and save money$$$
- Trying to piece my shortblock together for 250 shot. Check it out.
- N2O Nozzle change... big difference
- 3-stage 300 shot and MS4
- Am I good to go???
- How Too Spray
- 08 project is in the works!!!
- Standard Answers we'd all LOVE to give.. but don't.
- In need of TLC
- a1000 pump
- MSD window switch
- Who makes a good nitrous cam?
- fuel solenoid as purge?
- Tons of Nitrous stuff for sale
- 150 shot will it last on my stock motor
- looking for pics of nitrous-outlet all in one brkt
- New Sw Panel
- anyone in houston or san antonio want to do this?
- hard line tool question
- 232/232 110 for a 150 dry need more exhaust durration
- Fm13 a good nitrous cam?
- nitrous solenoid hook up
- DP manifold bungs?
- Using Nitrous with Boosted Applications..
- Anyone using Nitrous/Methanol combo?
- Need some info on Nitro Daves Dual window switch...
- fuel ? on a 200 shot
- First spray Help
- Can Nitrous Go Bad/Stale? If so How long does it take?
- Bottom firing purge?
- HSW Plate kit in action!
- Happy New Year
- What else do I need?
- 99block/crank-how much nitrous..forged pistons/stock rods with arp bolts..
- 225 shot! Is this safe?
- quick question: VP C12 fuel ok?
- dynotune a/f lean shut down switch
- What Should I Run??
- To TPS or to Micro Switch
- Help Double Check my Wiring (N2O Outlet & Dynotune Please Read)
- LT1 and NOS
- Help with Injectors/Fuel Pump
- Nitrous Hesitation Between Shifts
- 200 shot, how much tuning will need to be done
- Which way does the jet go??
- Spray with smoking motor ?
- N2O/Stall question...
- dynotune tpas/window switch & a/f kill switch wiring help
- For anyone Pming Dave!!
- Attn Dynotune & Nitrous Outlet
- Good Deal? new to nitrous
- fjo NITROUS CONTROLLER problems
- Fastest stock cube M6 car?
- Where to get a 90mm plate for my NOS plate kit?
- The money maker
- what system for 300 shot L92? carb intake.
- N2O is here!!
- FPSS questions
- 300 shot and bottle life?
- Tach signal Input, Camaro z28 98?
- reverse split vs spray
- Relay Wiring Questions
- Which sponsors build dirct port systems?
- Purge Solenoid
- Help me outsmart the welding shop!
- 99FRC vette
- Where to buy gas and how much to pay?
- hsw nitrous kit
- Pics of my new setup...
- Nitrous and increasing stall rating
- How to make ur single purge dual???
- How often do your change your plugs when running N2O
- What spark plugs do I need to buy?
- nhra rules
- nitrous question
- Those with tirewell bottle location, how to run feed?
- Look what I got for X-mas!
- Dynotune switch install
- edelbrock nitrous bottle
- what nitrous kit 4 a 98 v6 fbody...
- Stock Heads
- Will I run out of injector?
- anyone wanna trade dynotune wideband gauge
- Dry Plate
- Nitrous Gauge And Line For Sale
- i need help.(nitrous outlet)
- 860 sparetire area mount
- Stock Cube Nitrous List
- which bottles will a zex remote bottle opener work with?
- Best place to hide bottles?
- N20 newbie?
- Spray through the fliter?
- how much do u think I could get
- how to tell when the bottle is empty?
- Custom PCM mods to support nitrous
- Best 3.905'' Rings for nitrous?
- HSW Black Mamba Nozzle?
- What kit to get for my vette
- Nitrous with mainly stock LS1?
- Top ten stock cube N20 LS1's
- Easy to hide nitrous on an ls1?
- MSD window switch
- Nitrous with Meth injection
- independant fuel system for spray
- question about hsw kits
- anyone running ngk tr-7's?
- #7 cylinder in a LTx and nitrous?
- would it hold up
- Blew the head gasket on my 5.0 mustang today
- ms3 cam and nitrous?
- Nitrous without tune
- Fuel feed other than fuel rail?
- testing an MSD window switch
- I've been thinking about 250...
- LS2 + Cam + Nitrous
- What brand of Nitrous kit are you guys running?
- HUGE Savings! HSW Super Holiday SALE!!!
- Merry Christmas Everyone!!
- Selling my Nitro dave 90mm dual plate system
- What do you think of the specs on my 370/nitrous cam....
- hp level
- Ls2
- thinking of running n2o and meth now???
- help with dynotune wideband
- Thinking About Putting Nitrous In My Car.. Need Help.
- New Toy! NX Boost Referenced Controller Thanks Chris@Nitrousoutlet
- Getting ready for install what gauge wire to use? and nitrous filter questions?
- running a 2 stage nx kit witch window switch
- O2 Sensor bung help
- Blow down tube question.
- Best pistons for 250 shot?
- Started my wet kit Install
- My switch Set up
- another daves plate thread...i wanted my own
- nozzle placement
- 3 Stages-Why?
- Should i? (dont jump down my throat)
- PICS.. Harris speedworks dry kit/ Dynotunes new lean shut off switch
- nitrous nozzle?
- Is it realistic?
- Looking into Nitrous, Please help!
- first time user help
- Fuel?
- dry nitrous question
- Zex wet kit.
- ???'s about FPS and Gauge
- Who runs a dry kit or a wet kit, what are your thoughts on both????
- Need help with 2 stage LT1 kit..
- Texas Nitrous Tech, Any Experience?
- Can you heat a bottle with the valve closed?
- which dry kit?
- Window Switch
- Hidden nitrous on new Magnachargers
- Nitro Dave's plate!
- Can I have vette frcs w/ HSW wet plate?
- Safe amount of N20 for my Z06...
- I want to run hard lines for my N2O install. WTB?
- Biggest Shot Recomended On A Stock Bottom End With A Dedicated Fuel System
- AFR Safety Switch discussion
- 2 Stage, Dry-Wet Kit?
- Plate BBK 80MM
- Anybody running HSW dry plate kit?
- Whats the biggest nitrous shot to run without a tune
- CTS V plate
- nitrous lines leakproof?
- Ls7 Plate Nitrous Kit
- Can paintball CO2 bottles be used for nitrous?
- Help-Lean shutdown switch,were to splice in the 02 wire.?
- So you want to go with a plate huh? Check this out!
- cheep dynotune
- What is the biggest rcommended shot?
- help me plz to run 10's
- Please critque my Injector scaling & Sizing Write up
- Using HPtuners to control 2 stage. Please review Diagram
- did anyone save the timing tricker wiring diagram
- Pics of PAIN's new setup!!
- Timing/ring end gap question.
- FPSS Mounting
- What Is The Best Heads And Cam For A Nitrous Set Up Please Help!!!
- What controller to get?
- Need info. how to figure out what jets I have...
- Is 26.5* of timing too much for 75 shot?
- MSD Digital Window Switch Setting??
- Whats it going to take to hit 7's....
- Remote Opening
- wiring help pleaseee
- 50 shot?
- Lt1 Dry Setup
- NANO question
- The goods...Opinions...
- Nitrous hit and stall rating
- Why are all the wiring diagrams been deleted?
- All this talk of hidden nitrous lately...
- 38 supercharged + boost???
- is a nitrous cam that much better??
- 2 step, progressive and wide band to use
- SX2 nozzle experience
- what gears with a 125 shot
