View Full Version : Nitrous Oxide
- Nice pic of main cap (hit with some serious nitrous)
- 550rwhp via n20 vs 550rwhp via supercharger ... which is quicker?
- Nx kit
- Cold Fusion Nitrous Kits...
- About to order a n2o kit
- Dry kit and LS1
- new to n2o
- NX Kit cutting out at higher RPM's!!!!
- zz-409 cam vs. nitrous
- Will a nx bottle opener fit on a .............
- Just finished my NX dual stage - Pics inside *56k warning*
- Question about TR6 spark plugs for nitrous
- any nitrous for newbies? Also want to buy a wet kit, anyone have one f/s?
- Nitrous Through the EGR?
- Air/Fuel Gauge
- Who makes remote bottle opener compatable with TNT?
- Couple more ?'s, Thanks!
- Spraying a 11.5:1 CR motor - is it safe for 93 octane?
- How much will a 4an
- help with gear selection
- Got in an Argument with machine shop guy
- quick wiring question
- N20 newb? How do you know when bottle is empty?
- Nitrous Parts for Sale
- Buying n2o... Making sure I have everything... Help/Advice Welcomed!
- Tank Dimensions and bottle pressure?????
- NX MAF kit with a 90mm tb/intake
- I'm pumped Halo kit gets here today
- nx question
- Nitrous Questions
- 125 shot what else do i need to be safe
- First time to spray the 5.3L was today!!!
- Low Compression engine and N2O questions..
- Nitrous on Carb Setup
- Maf vs Direct Port
- What nx or tnt kit to go with?
- How much HP will this fuel system support??
- Hey guys check this out...
- filling station ?'s
- NX MAF for C5.....when?
- Nitrous Pressure Gauge and 4AN to 6AN fitting
- NX 150 fuel pump?
- Question about chroming some nitrous parts, also a guage Q.
- Has anyone seen the new NOS plate for the c6's?
- bogging ?'s
- How big is the TNT F1 power ring in millimeters???
- NX 150 shot question
- what do you think of this et and mph
- hp gains on nx wet kit???
- LT1 ac delco plugs
- Do you have to pull timing if you have a stand alone fuel cell?
- Routing the Nitrous feed line
- Difference between Dynotune's time delay switches?
- Anybody running AR472's?
- Nitrous Properties & Data For you
- Automatic Timing Retard with N2O
- nitrous and high compression 11.1
- New to NOS
- Spraying T-rex Help!!!
- thunder 224/224 with my 125 shot
- Opinions please....
- running out of gear?
- getting there
- pics of nx fogger with showerhead dist blocks?
- If anyone needs a 37 degree flaring tool...
- 100+ N2O setup with no problems ... how long?
- Controls for nitrous
- This sound right?
- A/F METER Frozen, Boiled, AND Ran Over
- newbee to nitrous what do i need
- So who else makes a window switch OTHER than MSD?
- Alcohol Injection & Nitrous? Help
- What HP Can I get out of a Fogger Nozzle
- Throttle body nitrous plate
- what can i do with this.
- Tnt Users Help
- Well i need better than pump gas?
- Free beer/money
- What size jets for 100 shot wet?
- Need some advice. Extreme n00b
- Nitrous filters?
- NX full kit + extras for sale..
- 2 5/8 gauges
- Question about plugs with N2O
- simple question
- msd digital window switch wiring
- What is the proper way to test my n20 system?
- pictures of stand alone fuel systems?
- Where can I find nitrous jetting charts?
- Progressive Nitrous Units...
- Gen I SBC Nitrous Usage Question
- 75 shot ok w/o pulling timing?
- Spraying in 4th with an A4 and 3.23's?
- Nitrous for 87,000 mile motor? Etc.
- What kind of hose end should I buy for a nitrous hose?
- Looking for a specific video...
- Those running inline fuel pumps
- Spraying thru a powershift?
- nitrous jets?
- Where to mount the bottle?
- its almost time for..
- Venom VCN-10000
- FM13 + 100 wet shot?
- Nitrous Bottle Brackets?
- What does a NX Maximizer do?
- N X problem please help
- Which is safer 100 Shot Wet or Dry
- setting up a wet kit,need some help please
- Thinking Of Going To Nitrous
- Where can I find a 15" 4AN nitrous line?
- Tech Tip "Fuel Puddle Something to think about"
- fellas need your help!!
- Timing
- Direct ports better than a nozzle right?
- Nitro Dave's - Nitrous Outlet Gone??????
- Continued discussion: Injector size and MAF flow rate with dry shots.
- n2o in non other places
- 36-lb./hr. @ 3 BAR ok for 600 rwhp?
- upgrading nitrous system?
- Hello all, Please enlighten a future nitrous user.
- Using Nitrous for droping inlet air temps and added power gain.
- 100 + 100 WET...Questions!
- Testing TNT f1 w/ window switch
- TNT F1/F2 users, any of you have a ported tb?
- opinions on compucar nitrous in a bag
- Power loss N/A with TR6?
- bottle between rear seats?
- Pressure regulated bottle heaters
- Tr6/Platinum plugs
- Nitrous and compression question
- Irridium plugs IT20
- NX Pressure Gauge Wont Work...Any Ideas?
- nitrous help
- Solenoid Power Ratings?
- cutting back the ground strap on tr6's.
- NX Bottle Heater Question
- Fogger Nozzle discussion.....
- Building custom dry kit need some help??
- Nitrous Works
- un-opened bottle strikes again.....
- How much PSI are you using?
- what gear ratio should i use?
- on a stock ls1
- Do it Yourself nitrous kit...
- License passes (video)
- DynoTune Nitrous Switch Center ?
- Two Stage DRY questions....
- Purge From Nostrils?
- FPSS why?
- Gauge and Filter Install Question. Pics...
- New best
- Nobody has ever had this much troble with a f**kn' window switch...HELP
- Hot Rod Pump gas drags
- 42 pound injectors for a dry shot and a cam?
- fuel solenoid instead of nitrous seloniod?
- N2O kit recommendation
- Best Off-Shelf Nitrous cam??
- Motor is getting closer **progress pics**
- Msd Window Switch On Ls1
- anyone ever use a slot car plate N20
- What am I missing, guys?
- Got Board UPDATE: Nitrous for your RC car.
- Anyone have pics of a TNT F4 kit intalled?
- Will this hurt the flow?
- Thoughts on Cold Fusion Bottle Opener(discussion)
- NGK TR-6s are not being discontinued.
- what do i need for my 5.3L Silvy
- What cam for big shot?
- 723 hp ls1 in Chevy High Performance Mag
- nx ricky or nitro dave or anybody else
- TECH TIP: Nitrous Soelnoids exploded view.
- Custom TNT F2 pics
- Just a little FYI
- new cam for the SPRAY...
- Nitrous Bottle Super Sale
- Dean at dynotune
- Sparying threw shifts Gains?
- Polished 10lb bottles.
- C6 Nitrous, June issue of Vette Magizine
- Corvette and installing a TNT kit ???
- How should I trigger my dual stage kit?
- TNT 100 shot only made 65 rwhp at 950psi?
- 860 bottle bracket FS
- NX Fill Station help
- stand alone fuel system but alky
- Looking for pics of nitrous bottle in spare tire well
- Question...
- How large of a wet shot do you think a stock bottom end ls1 will handle?
- Dynotune Bottle Warmer
- NGK-One or Two Steps Colder???
- Jimmy Jams
- N20 help needed (nitro dave)
- retarding for a 75 shot
- ok so, who's gone 8's on nitrous?
- snapped a few pics of my NX MAF kit today
- Do I need an inline fuse??
- What all do I need for a dry kit?
- Why does the dry kit have 2 solenoids?
- Whats the fasted 346 cam/n2o automatic LS1
- How to flare hard line
- where do you mount your N20..pics???
- 150 Shot!!!
- TNT question for an LT1
- TNT Nitrous kit?
- LS1 NX full kit for sale!
- F.A.S.T-nitrous
- NX Solenoid
- Taping fuel line
- nos 5150
- Nitrous Special..
- Wiring 2 FPSS to help lean spikes.
- ZEX kit
- injector bungs or fogger nozzle
- 10# vs. 15# Bottle Dimensions
- Cold Fusion Kit
- TNT Kit and Lid Fitment
- Whats the highest hp nitrous stock ls1
- Question about Nitrous & Purging
- **FOR SALE** NOS 125 Dry Shot Complete System
- nitrous pros and cons?
- Nitrous Pics????
- ???'s about jimmy-jams
- Those of you running dry kits...
- hypethetically, if a car made 525rwhp on a 11:1 comp. ratio,how would it do on a 9:1?
- Here's what I've got... How should I set it up?
- Retarding timing w/o ignition box?
- Tell me what clutch to run and why
- stealth nitrous
- bottle mounting IN A FIREBIRD!
- Finally got this thing installed....
- problems to steer clear of
- dave or ricky
- Electronic WOT switch for nitrous?
- New homemade NX avatar
- Stand alone fuel system but different
- NX MAF Kit for Z06
- Anyone make a "power-ring"
- Soleniod rebuild & custom bracket Q?
- nitrous additives
- best "kit" for a beginner??
- timing chain and n20
- 5177 conversion??
- Tech Tip:FPSS (how to adjust & "Y" Have).
- Bottle heater???
- is it safe to spray with over 100,000 miles
- quick bottle mounting question
- Brisk Plugs
- Diving bottle useable??
- 75 shot WET or DRY?
- will i be good with a 150 shot?
