PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115
  1. Nitrous Supply Line Question
  2. TR 224 cam with N2o
  3. Good Idea to spray or not
  4. rev limit
  5. pics of dual stage or single MAF nx kits
  6. Stepping up to a direct port!
  7. I need colors
  8. nos or no nos?
  9. is anyone running dry kit w/out jets
  10. cam for nitrous?
  11. NX on stock engine how much,,,?
  12. wanting to put TNT on the Z..help
  13. Nitrous works jet card
  14. NXL direct port kit
  15. Newbie needs some NOS help
  16. question on the NX kit
  17. Newbie needs help
  18. Is NX really a bad company?
  19. NOS EFI LS1 kit
  20. Dry Shots and Hidden Solenoids....
  21. is there a special jet for a dry kit to move u to 150?
  22. TNT or NX???
  23. Looking for info on direct port fuel system
  24. Question about new Maximizer
  25. install the NOS system&dont hit hard
  26. First run...What do i spray?
  27. Would it work *DELETED* *DELETED*
  28. Fuel Punp and Injectors
  29. anyone spraying a cam like this
  30. New NOS GM Truck Kit for 4.8, 5.3, 6.0
  31. How to setup large dry shot to pull timing when you use n20
  32. why mount 'noids in engine bay?
  33. do N20 bottles go bad?
  34. first post...nitrous ?
  35. NX bottle heater fuse?
  36. New Dyno Numbers Inside...Thanks East Side
  37. Quick purge wiring question
  38. What should i run with my sig set-up
  39. Which to buy....NX Maf kit or TNT F1?
  40. Iridium & N20
  41. when to stop using hpp3?
  42. Need Help! How to mount the WOT switch
  43. TnT power ring still have fitment problems?
  44. How big of a shot with my new H/C setup?
  45. Dual Stage button-M6
  46. how to adj timming after NOS
  47. MSD Window switch?
  48. Where to wire window switch in 5177 kit
  49. Where to put the NOS 2 spay nozzles with KIPK
  50. Where to buy teflon paste?
  51. Interest in a digital knock guage with memory recall?
  52. Adapter size on NX bottle
  53. Can I safely do this? (fuel requirements)
  54. What is the difference between TNT Pro purge and normal one?
  55. Any brave souls w/ bottle between seats?
  56. 396 Lunati Stroker.
  57. Has anyone mixed and matched TNT jets?
  58. confused??
  59. Anyone need a holley 255 in tank fuel pump..
  60. Thinking of hooking up a heater.
  61. TR5 spark plugs
  62. cam question
  63. Timing control on large shot via PCM
  64. N2O coupling problems
  65. Where do you guys hide your N2O bottle?
  66. PLUG GAP TR6 WITH 125 SHOT
  67. Whats the BIG deal with the NXL kit
  68. nitrous purge on ebay
  69. LT1 Nitrous Question
  70. Introducing The New Maximizer From NX
  71. Introducing The NXL Kit From Nitrous Express
  72. how many shots
  73. anoyone need a nx relay
  74. Digital nitrous pressure gauges available soon!
  75. Will I see a full 100shot with a TR 224/224 563. 112LS cam?
  76. Just got the NOS kit
  77. A TNT 150 Wet Kit with my current motor?
  78. I need help
  79. Are dry kits bad?
  80. School me on NOS!!
  81. TNT wet kit install pics
  82. F body-which air lid fits the best on tnt power ring?
  83. just got NOS
  84. Best nitrous cam for stock displacement
  85. Is installing NOS easy?
  86. Is the NXL on the summit web site a direct port kit?
  87. Stainless Steel tubing flare tool
  88. Direct port, Anyone used Nylon line to foggers ???
  89. Dual stage dry kit..I've got questions
  90. Wiring question....
  91. pro race fogger nos for sale new
  92. window switch
  93. New times on a 100 shot
  94. Timing Tuner retard function question
  95. picked up 6mph in 1/8 with 125 help.
  96. K&N FIPK and TNT Power Ring
  97. Changing my purge setup, have a question.
  98. Nitrous and tuning
  99. 100 shot dry kit suggestions
  100. Running extremely rich and already burnt plugs twice!
  101. explain NXL to me
  102. 4AN line
  103. What should I expect?
  104. nitrouswarehouse??????
  105. Custom direct port ls6 intake, 1 fuel & 1 n20 solenoid??
  106. discreet 100 shot in ls1
  107. Custom direct port, can copper tubing be used to each fogger *DELETED*
  108. My car is depressing me.
  109. pics of MAF
  110. wiring and activation of second stage nx
  111. NX MAF KIT Q's
  112. Want to Run a Wet System on 99 Camaro SS
  113. OK, its been a few weeks. N E new words on the NXL???
  114. Spraying your '03 Cobra...Priceless!
  115. Upgrading fuel system
  116. what shot
  117. Does NX make MAF KIT for 85mm MAF?
  118. NX Jet pack ?
  119. Free remote bottle opener with any nitrous kit purchase!
  120. slp mass air and a dry kit
  121. NX direct port kit for sale
  122. NX says dry kits arent safe,many blown motors,not recommend
  123. Nitrous wiring MELTDOWN!!!
  124. TNT Jet Sizes
  125. Need help with NX jet sizes....Anybody??
  126. Got the NX kit up and running! Couple ?'s
  127. Got Spray???
  128. New dyno #s :)
  129. How much NOS ????
  130. NOS5177 Kit - What's The Max It Can Spray?
  131. For the love of wiring
  132. Wondering if the NX Switch Panel will work with NOS Heater
  133. Anybody know where the horn relay is?
  134. Newbie Question? Dry Shot on C5?
  135. Big Shot 200plus
  136. So who else knew that you can't use valve covers as a ground
  137. Is this part worth the money?
  138. ATAP and Nitrous
  139. Window switch must be modified to work w/ LS1's?
  140. need help on n.o.s
  141. Compucar remote bottle opener, any good???
  142. Fuel Pressure Safety Switch
  143. MSD Wiring Diagram
  144. timing on big shot?
  145. Where Do I Start...?
  146. Nitrous parts for sell.
  147. Jet Sizes?
  148. What happens if the bottle is closed on a wet kit?
  149. What inline fuel pump for TNT 125 shot?
  150. 98 pcm tach wire help
  151. Is anyone purging out of the two holes in the Camaro grill?
  152. My new Nitrous Bottle Bracket
  153. read that this meltdown was nitrous related ?
  154. Limit of NOS 5177 noids for hp/flow?
  155. A/F when spraying??
  156. Any problems running 200 dry shots?
  157. What to spend $1500 on?
  158. Who Needs a Spare Bottle!!!
  159. Legalness of NOS
  160. 112 Lobe seperation or 114 LS cam and why?
  161. MSD Window Switch
  162. Talked to an NX rep today at the Nopi Nationals...
  163. Nitrous and timing retard - would this work?
  164. High compression and N20, Help.
  165. How resistant are solenoids to under hood temps?
  166. New to Nitrous Need help!
  167. VENOM Computerized NOS System (any good)
  168. What Are the Limitations of a Dry Kit?
  169. Nitrous and Trans
  170. whats so great about NXL?
  171. TNT users *DELETED*
  172. What seems to be the limit for nitrous on a resleeved block?
  173. TNT Fuel noid not firing, trouble shooting tips?
  174. Whats the biggest DRY SHOT i can run on 26#ers and a cam?
  175. Help making a kit decision...
  176. need help..Just got off the dyno... Not good.
  177. Question on testing nitrous wiring
  178. I heard a bad rumor about the NXL kit not coming out because
  179. Why am I scared?
  180. Wireing NX relay to Timing Tuner question...
  181. Nitrous Works kit for $300, good deal?????
  182. Best place to mount solenoids?
  183. Where do the jets go on a NX MAF kit?
  184. Going from TNT ring to MAF, need help?
  185. From TNT ring to MAF, need help?
  186. using my lt1 wet compucar as dry on ls1
  187. Is it common for NX to send you the wrong parts in their kit
  188. East Side Performance goes 8'S!!!
  189. Running Lean while Spraying?
  190. How to do away with full throttle switch
  191. NXL KIT ON SUMMIT WEBSITE
  192. Descreen MAF
  193. Bottle location? Can it be done?
  194. Switching from wet to dry?
  195. How many of you spray out of the hole??
  196. Hot Cam and Nitrous
  197. I need some help
  198. Anybody here spraying big on a all bore?Need help with motor
  199. NX style switch panels for sale
  200. Anybody run an EGT gague?
  201. Nitrous sale!
  202. spray a stock LS1
  203. Running a bigger Jet on a 5177 Kit.
  204. Safest setup to spray with my 224 cam?
  205. What Nitrous Kit to get??
  206. anyone make an all in one nitrous controller?
  207. anyone got basic schematics or diagrams ?
  208. brand new nx wet kit for sale
  209. what does your tnt kit make to the wheels?
  210. bottle blew up
  211. should I spray 150 or 175 TNT
  212. Window switch install, how hard is it?
  213. Everyone with an MSD window switch come in
  214. Do I need bigger injectors?
  215. N2O price roll call
  216. bottle refill
  217. NX wet kit...?....jet sizes
  218. Blew the engine on a 137 shot
  219. Is twin gemmeni kit the one with the replacement
  220. Jacobs Nitrous Mastermind???
  221. TNT Power Ring
  222. Installing Direct Port on Stock Motor :)
  223. Why is Nitrous considered cheating by so many?
  224. Thinkin I may want to spray....wet or dry??
  225. should I add or just get new kit????
  226. 150 shot heads cam
  227. Hooking up N2O???
  228. I want to go a second or more quicker in 1/8
  229. Nitrous and ASA cam
  230. How to hook up Window Switch ???
  231. please answer this question on n.o.s?
  232. Resistor for IAT sensor????
  233. Help:Testing N2O solenoid with MSD window switch
  234. How much timing to pull when spraying 125-150 shot
  235. Very lowest but still safe RPM to spray on an A4?
  236. I am looking for Fuel pump Sugestions
  237. Is this an NHRA legal place to mount Nitrous?
  238. Warning! Nitrous Air Fuel Ratio
  239. 200 shot
  240. Occasional 100 dry w/ TR55`s & 100 octane o.k.??
  241. I NEED A SUPER POWERSHOT FUEL SLOINOID.
  242. F1 kit
  243. who's interested in a custom NX style switch panel
  244. wet to dry
  245. what will break if i do a 100 shot
  246. MSD Timing Controller
  247. Progress on the NXL and Progressive from NX
  248. Need help ASAP!!!!!!
  249. Another option for a Blow Down Tube
  250. I need a Manual for a wet Nos or NX system For LS1
