View Full Version : Nitrous Oxide
- Can you purge through the intake??
- no2 and 02 simms
- Location for nitrous bungs for direct port
- Electric nos pressure gauge
- show me some pic's of the 5177 nos dry kit
- whats the big deal with TR-6
- questions on nitrous
- NX DP 9PSI Jet Map and Flowing Fuel Pressure Check Jet Info
- g5x2 and nitrous?
- retarding the timing?
- dyno differences between 92 octane vs 114?
- nitrouse and a convertor ???
- Any update on NXL?
- Juice on a Carbed engine
- Help me please. Bottle brackets
- Life with a 35lbs bottle.
- What should timing be for a 150 wet shot.
- Do direct port nozzles block airflow in intake ports??
- How much HP can a 2ft 3AN Nitrous line flow?
- need to trade FIPK filters
- First time wet & dry kit together, Intake blew in half
- Very interesting link. (N20 Experts, please read).
- Window switch question????
- How much juice on 91 octane?
- Best lid for TNT kit
- i need help hiding my nos 5177 dry kit :)
- help a nitrous newbie
- nitrous jet question
- What do i need
- air fuel guage installatin
- Stock injectors (28.8) ok with this set up?
- DP tuning question
- Project SS sets new LS1 M6 record
- TNT says thier foggers are 10x better than NX??
- Getting KR when spraying ?
- need jetting sizes for nos kit #5177
- What do i need to do to my engine to make it rady for nos
- mounting nos Bottles? In Trucks.
- Will dry N2O sprayed before the IAT cause a probelem?
- How much does just the TNT power ring cost??
- A variety of N2O questions....kinda long!
- I sprayed the 200 shot last night.....
- Best Cubic inch engine for high nitrous application
- N20 filter
- LS1 NXL shipping as of now.
- Dyno graph/sheets for 100HP, 150HP (direct port)
- problem running propane through NXL injectors?
- General questions.
- TNT Dyno graph inside, need help...
- Finally got some track times
- NOSzle issues......
- 346 forged or 370 iron forged for 150-200 shot?
- Drivin to work daily on the bottle
- HELP QUICK: Lost timing tuner instructions
- any other way to wire?
- Solid Roller N20 friendly?
- Spraying 75 dry, car goes dead lean 15:1
- Nitrous distribution on LS6 intakes?
- Whats the latest on the NXL kit?
- new numbers on the reckless directport
- big shots of Propane and cylinder fillng??
- Plug gap? .035 .040. or.060? Which and why?
- Pics of N20 Install
- Zex, Venom or TNT what's better
- Latest on the new NX progressive controller???
- Stock set-up
- Propane and N2O. Im still a little fuzzy
- NX Console Switches Question
- Pictures of my new Direct Port setup
- How long does your nitrous last?
- NX install help!
- NX jet size info needed
- C2 Cam good for 100hp shot?
- NOZZLE PICS?
- New Best on the bottle.
- Cost per pound?
- Sparkplug question....
- Texas lid and NOS dry shot setup??
- Fogger nozzle limits???
- Nitrous Cams...????
- Can someone please tell me whats wrong with my car??
- 100 Shot Plug Question
- Will this bracket work for mounting the bottle in the spare?
- NX price increase and upcoming new products!
- Best nitrous setup for FI
- Any ideas on what it will run?
- Q's about the NXL kit...
- Uh oh, what did I break?
- Paging Big Mike....
- Timing Tuner
- Heads Cam Guys what Nitrous kit are you using?
- sheetmetal better than "plastic" intake for N20?
- Small Wet Shot on my car
- NX Noid Leak????
- Possible problems with Ram Chargers timing tuner
- Your opinions PLEASE!
- ? 100 shot what's better wet or dry?
- Nitrous Kit Question
- What is Nitrous?
- Any suggestions?
- Anyone have a good videos of LS1's spraying out of the hole
- rev limiter sprayn'
- Need a good cam?
- Nitrous switch panel for automatic ashtray?
- Jet sizes
- A direct port jetting technique question
- Wet Kit
- How much can you spray a stock '99 LS1 (NX wet)?
- Thoughts on TNT 250 shot for LT4
- 10.750 @ 128
- new noszle kit and fuel system f/s
- Nitrous List
- Will this work?
- Will this work?
- Propane and Nitrous?
- Where to tap into the fuel line?
- How long would my motor would last with a 175 shot?
- Dry to wet
- How much n20 per cylinder before TB would = 300 direct port?
- How big of shot?
- where can i buy 2 125 shot jets and 2 150 jets for 5177 dry
- Nitrous refills in South Bend, Indiana
- How much timing?
- Help deciding on a Nitrous System
- Nitrous experts inside please, need ideas..
- Purge Nozzle
- thicker oil for N20?
- Modified MSD Window Switches now available!
- Question on a purge system
- FS: 5177 kit & Purge kit & 2LB bottle.
- Dumb Question
- Stupid question.
- Help with Jet sizes please
- Will the TR230 on a 111 lsa work with juice
- I'm a rookie, but I have a question about juice?????????????
- Running 75-100 wet without retarding timing?
- nx switch pannel
- wet kit on heads and cam cars........
- Upper and lower RPM's?
- what timing should i run
- nitrious ?
- nitrous kit wiring help
- How do I post up pictures
- NOS 5177 Single Fogger
- Air Fuel
- do i need new fuel system
- Finally got some N20 Dyno's :(
- Big Mike and Cartek do it again!!!!!!
- 100hp "dry" and TR6... What gap??
- Need install pics of NX GM-MAF kits on F-bodies please....
- newbe
- WOT switch and BBK throttle body where do i mount it?
- questions about direct port
- What Spark Plug Is 1 Step Cooler Than Stock-- TR55IX?
- making a NOS 150 shot.....?'s
- fuel question ????
- NOS 5177 setup
- any reason you cant run a BIG shot dry?
- Wideband guage
- TNT kit comin on late
- New Dyno Numbers with 100 shot
- NX Twin Gemini Kit
- Lookin to get spray (newbie), got some ?'s
- Question for guys running over a 300 shot...
- QUESTION ON THE MSD WINDOW SWITCH INSTALL
- IS ANY ONE RUNING A 200HP SHOT ON A STOCK LS1 ???????
- huge shot limit??
- Need help. Injectors hitting direct port nozzle
- newbie!
- Anybody runnig NOS with Procharger
- Brand new TNT kit for sale
- Any update on NXL progress?
- Hitting a barrier Spraying, need help...
- pics of setups and switches
- Anyone using Iridium plugs with nitrous?
- headers and 150 shot ...123 mph
- TR-6 GAP WITH MY MODS
- what size jets for 125 shot { nitrous express}
- NOS Switch
- Flycutt pistons and N2O???
- Wiring Schematic Question! *4wd switch for Nitrous*
- anybody use the timing tuner?
- Direct Ports and smaller HP shots
- GMS MAFS + 100 shot= ??????????
- Experimental Nitrous, Timing controller
- Need help on building a 10 sec SS
- How long can a motor be sprayed?????
- good stall for auto and nitrous off the line?
- NOS 5177 bottle heater thermostat
- tnt jet sizes
- tr6's good for my setup
- anyone sell pills so that i dont have to buy 2 sets
- need 100 shot on top of my powerdyne *DELETED*
- Does TNT have a 5# or 6# Bottle?
- 4 SALE: Nos 05177 Kit with Bottle Warmer & Whisper Lid
- How much RWHP on a bolton ls1 with NOS 5177 and 125 jets?
- What is the biggest shot i can run on a dry kit???
- NEW NOS NOZZLE SYSTEM FOR SALE (CHEAP)
- Reading Spark Plugs..need some help
- Backfire ?
- Does anyone answer at TNT anymore??
- Selling NX Wet Kit
- ls6 or lingefelter intake for DP nitrous
- running a T off the fuel rail for a dual stage?
- Spark Plugs
- TNT F4 Kit
- i need assistance with nos
- Noszle kit
- Well explain these dyno #'s with the TR 224/.563/112LS runs
- What should the Air Fuel ratio be?
- Late nitrous
- What plug to go with for a dry 100 shot?
- newbie nitrous ??
- The making of a low 10 second street car.
- NX anyone with a pill chart???
- Selling brand new noszle kit
- N2O install basic questions
- Nitrous Express NXL system delayed until the end of August
- Went to the track last night :)
- Who sells the Noszle system? (Direct port)
- How to run a gauge inside cabin?
- Whats needed for Dry shot?
- 11.41 at 124MPH w/TNT 100shot and TR 224/112LS cam!
- Think I'll have enough power?
- Mallory VS. MSD?
- RPM based Progressive Controller ... Who makes them?
- MAF plate NOS VS Lid injection
- TNT Direct Port
- Big cubic inch guys! What are you spraying?
- NX Twin Nozzle System- Need help!!
- Could my bottle have a leak??
- Need opinion--What is best Nos for 02 Z06?
- dont guess anyone can answer my question
- Can a Stock Clutch Hold Nitrous From a Roll
- NAWS
- ?? on a dry shot
- ForSale: 2LB NOS brand nitrous bottle
- Need to cover this darned bottle!
- How many of you have been running N20 for 2 years +
- Attn:WS6 Owners W/Power Ring
- Never had nitrous before... want it now!!
- Spraying through shifts?
- NOS Programmable Nitrous Controller
- Will NX automatic bottle heater work w/ the TNT bottle?
- What converter for a TH400
- Aluminum Nitrous Feed Line
- hpp3 ok for gears and nos
- new to ls1's
- Any updates on NXL kit ?
- can i safely spray with these mods?
