View Full Version : Nitrous Oxide
- Nitro Dave and Staff
- nitrous on stock motor
- Nitrous/NHRA legality help needed
- pink plugs
- What happens when the window switch fails?
- What happens when solenoids go bad/weak????
- Multi stages, when are they needed?
- direct port question?? Can anyone help
- N20 Matinence
- Post some vids, nitrous compilations
- Where can i get flat dpdt switch to fit in my ash panel
- Multi stage engine bays
- C5 nitrous numbers
- nitorus
- Help, nitrous window swithchs
- injector duty pretty high...what to do?
- dry zex help
- Lt1 Nitrous PICS!!!
- help bank 1 lean
- Nitrous Pistons/Rods Suggestions...
- Hidden Nitrous Setup?
- New best 10.23
- TR7 spark plugs
- Tr6 or Tr7 on N20
- n2o rmp window switch guestion
- Who is running the NX PRO NXL direct port system??
- I Can't leave well enough alone.
- New Best!
- my next great idea
- how much timing to pull threw hsw interface
- What type of switch for nx opener?
- 408 nitrous
- install pics, Blacked out C5
- Home Nitrous Install
- Let's talk air fuel ratio.
- How do you adjust min rpm on timing tuner?
- any tips on fixing a heater? the element?
- Have a few Nitrous goodies some of you might want!
- what to do (Nitrous) stock motor
- Should I run my STS kit or nitrous???
- need injector advice
- New NOS power relay?
- need help spray on ms4 cam
- Dyno Tune N20 Gauge/ Sending Unit ?
- mixing fuels
- low pressure single nozzle?
- Nitrous Help Needed
- Still selling my tranny!!
- Gemini Plate w/ Standalone Installation pics.
- N2O VS FI discussion
- Stock A4 + 100shot questions
- plate jetting
- Anyone running a front and/or mid plate?
- Maybe someone here can help, LS2 TB Problems on nitrous car
- a Few pics of the new install!!
- Spare tire mounting bracket
- A/f question????
- How many of you run race gas when you're going to use the nitrous?
- Timing Tuner install question
- Nitrous Daves LT1 plate, any 200 shots?
- Urgent help needed with blow-down tube
- putting together a kit...anything im missing?
- Not Gettin enought fuel with plate kit.
- Blown Head Gasket 150 wet shot
- Install pics needed.
- Nitrous Tuning with Efilive
- Spark plugs
- Another JoeyG and Oaks N20 Install (pics)
- Nitrous plate question...
- Can you hear the noid "click" on w/ using a relay?
- Looking for the 2005 and 2006 N2o Fast Lists?
- NHRA legal nitrous bottle mounting location question
- TA Nostril Purges...Come On In!
- Wiring Idea help
- Need quick jetting help.
- Nitrous Install Complete
- Wiring
- Injector size for 200-250 shot???
- need a couple msd pills
- 200 Shot N20 = Same 60 as all Motor
- C-5 Purge Pic
- Do you know how to wire 2 HSW interfaces...
- Trick Performance/Nitro Dave window switch help
- burst disk
- Testing with old motor no water pushing.
- n20 v6?
- PLx wideband is gonna be off on my gauge/a/f shutoff
- Having traction issues, anyone care to step inside
- TnT F2 kit installed..
- Mounting the harness and window switch for NOS dry kit
- Who uses the interface w. a car tuned w. efi-Live?
- Pic of my Wet N2O setup
- cam only and 150 shot car needs new maf. help!
- Purge Leak... Should I take it apart?
- is anyone spraying with minor bolt ons??
- 9.37 @ 148
- Safest 100 shot for Z06, wet or dry?
- Bad O2 Sensors
- tr7 plug gap?
- what window switch with hsw interface
- OK its this true?
- Complex wiring question
- Low power - 100 shot only adds 30whp
- best cc relief for a n20 motor
- what plugs should i use
- What's needed to add a second stage?
- Is this kit any good?
- Multi function panel
- could somebody help me out here??
- my first attempt at hardlines..
- NANO and jet sizes
- Will heater hurt my paint from inside?
- My Nitrous Install!! Thanks Vengeance Racing and Nitrous Outlet
- 2 step, N20 and M6
- NGK TR6 vs. NGK BR6
- Debating on what progressive controller to use?
- pistons and N2O
- WTB Dry to wet conversion kit SPONSORS L@@K
- Nitrous Outlet = Free Nitrous System
- NANO KIT (NEW) FS $490 Shipped
- Vic Jr. Where should i put nitrous in?
- Purge is light and feathery
- rpm switch nitrous outlet wiring help
- Hook and Book.....with BMR FAB and NITROUS OUTLET!!!
- Solenoid fitting help.
- timing LT1
- thermocouple and bottle heater
- Solenoids under lid holder thing
- any reason wire a bottle heater wire would melt
- zex ls1 kit
- How do you like my install?
- Using A Window Switch And Hpt For Wet\dry\ Or Direct Tuneing
- 110hp from 200 shot
- Knock in 3rd
- Best way to spray a 200 shot
- the good, the bad or the ugly?
- Wet Shot necessities
- n20
- NX Wet Kit Question
- Where does everyone mount their Nitrous Gauge?
- Timing Tuner question
- Where to mount nitrous gauge sender?
- kewal guide for jetting and results
- Ponch does 10's and conquers Sealy (125 dry shot)
- propane mixed with Nitrous
- How to test kit while parked?
- Paging ChopStix or any other wiring guru
- Timing tuner and WS hook up..
- 57/31 now what fuel jet to run for 150?
- Can I wire a opener with the normal swich on a ashtray panel?
- Nitrous Stutter??? Please Read
- Do I need a dyno tune...
- Going to the track this weekend; advice appreciated
- Where to buy NX shark nozzle JET KITS?
- Wideband accuracy on only 1 bank
- tech question
- Best bang for the buck nitrous kit?
- Attn TnT users: Power ring fitment concerns?
- anyone know the stories behind these?
- Thumbs up for HSW....great product...
- Nitrous miss?
- NX Gemini Plate w/ standalone...... good for both low and high pressure fuel?
- Show me your Noids
- how many people spray through their 4l60e?
- About to gap my rings. Look good?
- 860 spare tire mount guys come in
- nitrous express kit
- Motor Flooded to Hell
- Had My First Nitrous Bang
- Anyone Running Nano With Zex Kit?
- nitrous outlet warmer new . 150 obo
- Timing correct 19-23* @ wot 150wet + cam?
- Warming bottle w/o heater
- Has anyone had any luck with the l76 l92 plastic intakes for direct port
- Leaking bad
- Not sure if my nitrous worked
- Free Shiping On HEX TO WING Adapters.
- HSW interface install question
- Spraying An LS3 Based 427
- C-5 Bottle/NANO Photo's (updated for May08)
- 15# bottle hidden in the spare?
- HSW Dry Plate Kit - 07 C6 A6
- Getting a instant hit off the line
- Help with nitrous tune (timing)...
- Where to get proper wrenches for fittings
- How much nitrous am i using?
- dynotune nitrous pressure gauge?
- 383 on a 200-250 shot?
- Check list before I spray
- Has anyone ever tried Dyno Tune Nitrous?
- What's the labor on something like this? (direct port)
- Pics of the set up .....
- jet sizes
- What to use for nitrous bottle nut washer
- Need help with dry nozzle placement?
- How to Extend the Capacity of Injectors for Dry Hits
- Spraying 150- only getting 90
- timing tuner question
- whats it going to take to go 8s
- Nitrous shooting through purge non stop HELP!
- ? about speed density tune and dry nitrous
- bottle question
- Do you leave bottle in the car all the time?
- a couple dumb questions
- My nitrous install (pics inside)
- Installed new switch.
- Thank You Beer99C5
- Nitrous Pressure Question???
- Spark plug wires cause misfire:safe to spray?
- Nitrous Plate Bellows Problem LS1
- Safe shot
- New 2 Nitrous
- fogger mounting question
- Cold Filling Nitrous bottles
- Gauge won't stay powered when car on
- Want to spray my LE2 Bird...
- Cam question
- Help with solenoid location..
- Best setup
- Nitrous Life Question
- This might be a noob qustion
- Show your Purge location!
- nitrous outlet bottle warmer 150$
- will this hurt my engine
- Need Advice
- I have a NX Wet Direct Port. How BIG a shot should I run?
- what timing for stock ls1 lt's and 125 shot
- Need some help...
- 02 LS1 with MS3. What Nitrous setup?
- (2) 10lb nitrous bottles for sale
- what size line for tnt kit
- Need a particular bracket.. where to find??
- set up
- Toggle Power Source
- What to use instead of Teflon Tape??
- NANO Group Purchase
- need misc msd window sw pill
- Pics needed for outlet of dual windshiel purge
- Dangerous to run line inside?
- New to Nitrous, little help..
- n20 safe with my cam?
- Please help newbie wants to run nitrous!!!
- Wideband+Vgauge Help!!!
- got a preasure guage need help
- Get me into the 8s
- Dynotune Winners!
- paging a wiring guru
- any sponsors sell compucar products
- Need Advice On My Gauge Setup!
- Line leangth from noids to plate F16" N24"???
