- Introducing Fiber-Tuned Intake Manifolds
- 11.49@120.34 @26 degrees of timing w/75hp jets.
- Remote Bottle opener Problem
- MicroEdge mounting in C6 cabin
- Pagin jmill96Z
- Looking for Pics and Video......
- Nick @ HSW pls help?
- Solenoid Manufactures???
- I hurt it on a 175 shot, got some questions.
- HSW quick reinstall
- MSD Window Switch Problem
- So i am into Nitrous
- wet nozzle with slp bellow suggestions.
- what do set ur TR6 plug gap to for nitrous
- wot switch failure
- Guys Spraying With N20 Big Stalls
- Big shot help
- lean after 6k
- Complete Nos Kit 500 shipped...OBO
- any sponsors make an aluminum dual bottle bracket?
- Misfire....Need Help...
- TR6 question??
- Looking for a how to make a "hardline" kit
- opinions on my plug readings
- what kit? LME 408
- biggest shot on a STOCK ls1 ?
- Hey is there a ZEX nitrous sponsor on here that is active??
- what plate should i run Hitman or Performer RPM
- How big of a shot would you guys recomend for my set up?
- colder plugs?
- do i need bigger injectors
- timing tuner help
- Testing my solenoids with my window switch hooked up?
- Quick Mallory 685 w/ls1 question
- Best cam for stock head 100-125 shot
- Dual Stage Progressive, using a single nozzle
- need a help for wet nitrous
- ok i need suggestions here go get desired hp numbers
- anyone running the ZEX window switch??
- Wideband Accurate
- FS 15lb NX Nitrous Bottle
- Budget build (advice needed)
- Nitrous Outlet Complete kit with extra's!!
- Nitrous build up TEASER pics
- Is it safe
- Red bottle blankets??
- head gaskets and push rods
- Let's See Some Dyno/Track Numbers from Bolt on Cars with Spray
- Ring Gap
- Is it OK to run 26deg timing on a 100shot
- *FS* Billet Nitrous Bottle Bracket
- Bucks badly on the spray
- ***Nitrous Gurus Advice Needed***200+Wet questions
- Mount Bottle Behind Driver Seat?
- purging question??
- Window switch and shift points
- multiple things to add to fuel rail
- Need Help..how To Make 2 "5lb" Bottle Work
- First time spraying today! Some quick questions
- Spraying the 440 again
- how are you guys launching...
- Thanks Nitrous Pro Flow for TOOO Much power
- drill tap TB for nitrous nozzle?
- nitrous fill??? where
- oil help..
- should i...now or later?
- cam Quse ?
- What oil do all you guys use?
- How much timing would you pull?
- so i got my new fuel pump...
- how long would a tank last on 150 shot
- keep blowing fuses.
- Lets all congradulate Beer for popping his 'N20 at the Track' cherry
- CHEAP Carbon Fiber Bottles
- DIY RPM Window Switch
- Spark plug question
- Nitrous On Mostly Street Car...Opinions
- NOS on sale//
- Nitrous set up pictures wanted
- need help with what items to run a 200 shot.
- Vengeance Racing/TrickFlow/Nitrous Outlet=145mph Traps in M6 C5!!!!
- HSW Matt where have the sales been
- Had a nitrous backfire, need suggestions on what to check out.
- New to the nitrious game Help with picking my system out
- Nitrous gone wrong!!!
- any MS4 + Nitrous junkies??
- whats everyones opinion
- Check this crap out!!
- should i spray or not?
- My new intake/nitrous kit w/ pics
- Cold fusion direct port pics?
- GAP on TR6 Plugs???
- Nx bottle question
- Does this diagram work?
- Spraying a dual plane intake?
- who makes the best nos kit out there/solenoid
- main feed line length
- New Kit pricing - Dry Kit $239 - Wet kit $299!
- H/C m6 guys with 200+ n20
- tnt
- NX System
- Will Tranny And Rear End Hold 175shot
- ls motors and nitrous
- 2 step and Nitrous
- Tracetronix wiring harness
- bmn window switch
- msd rpm module pills
- plugs
- Any 200+ shots on stock bottom ends out there??
- Wire Gauge from Battery
- Question for the NANO users.
- 95mm tnt halo or plate?
- Direct Port kits can they be jetted to under 150shot
- who has the nicest...
- Finally sprayed the car
- Bad @ss import domestic race in Nov @MIR
- dynotune nitrous promo code
- do i need a better fuel pump or a stand alone fueling system
- FAST 92MM with DIRECT PORT vendors come in
- Insulating a stand alone fuel cell
- getting back into the nitrous game
- Thanks for providing the tech!
- Looking for a bracket to mount my noids
- Spray the TPI or just get a 350
- will the nitrous outlet 90mm plate work with the small dynotune solnoids?
- Real Fast Question!!help Me Out!!!
- what octane are you spraying on??
- Launching a M6 with nitrous off the line
- Finally Got it
- Question for you guys...
- tr6's for my 408 and 150 shot?
- a few quick n20 questions...
- whooohooo!
- upgrading head bolts?
- nitrous back in but..
- >>Need help Picking out Kit<< thanks
- question
- TNT Nitrous still open?
- Best plate system out there... square flange carb plate.
- LT1 two stage
- what realy to buy???
- Pics of Nitrous Outlet "Hidden" lid spray halo?
- finally finished!!
- nitrous filter?
- how often to rebuild noids?
- 5.3 or 6.0 heads for nitrous
- Why is my MPH so low?
- Single NX Shark Nozzle - 200 Jetting
- I'm now an addict
- Dave's Plate
- Tank Pressure Time ???
- best place to mount nozzle for wet kit????
- I need a 90mm plate for my NOS wet kit..
- Are these lines OK?
- Finally Nitrous!!!
- Air Fuel Ratio HELP?
- Anyone had problems w/MSD timing twister?
- Where to Set Timing for Max Power
- Question to F-body owners that keep their bottle between their back seats.
- HSW WOT Switch PIC ?
- 10.50s @ 137 on a 200shot
- newbie Question
- Performance Induction Intake Plumbed up !!!
- HELP! Timing tuner and progressive controller
- fuel press on spray?
- Parts list, is there anything else i need?
- wat will i need for the bigger shot?
- ? about ls1 noszle kit!!!
- OHIO Nitrous laws
- Progressive controller question.
- Best NOS 90 degree wet nozzle?
- Need Bottle Heater Installed Pictures
- who's pushing a 200 shot with a single nozzle?
- NOS Fogger nozzle killing me?
- 75shot
- Retarded question
- Solenoid ground help
- 150 shot??
- Who makes custom switch plate for dash??
- Cant understand why....
- Tempting Death - 125 shot on a 150K stock bottom end with H/C/I?
- plug swap now slower?
- Looking for a few pictures of plate systems on Corvettes
- are TR6 plugs really recommended?
- Lines for purge melted :(
- SPONSORS PLEASE...Looking to buy NOS set-up
- Switch from 75-150 shot picks up 2mph?
- NOS fogger nossle spray direction
- NOS plate kit wit a T56?
- New with nitrous PLEASE HELP!!!
- Does anyone think I have a chance?
- Nitrous noob....what caused this?
- How fast can you change plugs...
- Help with fuel pressure/n20 problem
- Coated combustion cambers?
- Hidden nitrous?
- hot wire kit?? is it worth the money?
- Power ring vs a plate kit.
- What kit to get ?
- Heard tuff went 8.28@150 on the brakes at T/S Event
- window switch not working
- Changing Plugs
- spark plug gap
- Small dry kit for turbo?
- beer switch panel for corvette
- pulled my motor and tore it down to find!!!
- How Much Timing Retard When Using Race Gas?
- cig lighter used for 12 volt?
- n2o pressure
- Dry kit Jetting at 45 psi fuel?
- Couple dry kit questions
- TPS wire
- New personal Best
- how much is it for a nitrous fill?
- Help reading AFR
- show your switch panel
- Just bought my 1st Kit!!
- Calling it a season, more damage then i thought
- 383 LT1 Pill sizes
- Where to set window switch?
- stupid question...
- Lets play "can you spot the MicroEdge" :)
- No results with dry 75?
- Anything about the 98 PCM/MAF that makes is not as good for Nitrous?
- Plenum Spray bars
- Need some advice/help
- microedge users, which o2 wire did you use?
- blown down tube
- Help me decide how to spray the gills off the new daily driver
- Solenoid Problem
- Fall Nitrous Specials!!
- Question about spraying on the rev limiter
- Wantng pics and info of nitrous gauges in the ac vents
- When nitrous goes wrong, Kabooom!!!
- MY FJO/ZEX 908 window switch went out.....
- NOS TPI to LS1
- Looking for fitting for a nx plate.
- Where to keep the bottle
- New to NO2... Is this a full kit, and can I use this on a basically stock LS1?
- NOS launcher
- what system gives better results tnt ring or plate?
- Colder plug = a rich tune?
- Purge?
- Zex TPS switch
- New Update for the 'INTERFACE'
- New Times - C6 w/HSW Dry Plate Kit
- Good plugs???
- Advice on settings for my Microedge.
- Car Is Smokin After Nos Run
- custom or N20 cam
