- Project JUICED stock LS1 99 CAMARO
- My Nitrous Outlet VIC Jr spray bar intake came today
- How much are you spraying through your Nitrous Outlet plate?
- LT1 nitrous plugs
- Issues at the track yesterday
- Solenoid and spare tire bottle brackets?? Where to get?
- Nitrous for LT1 - which controller/fuel pump?
- 'Bout to set this car ON FIRE! Help!
- plug? ??
- A New Tech here for you guys
- Newbie Questions
- nitrous set up on a cam/bolt-ons WS6
- spark plug gap ? i read the sticky
- Nitrous outlet custom dedicated cell mount with PICs
- having a new tune without NOS
- Black Widow System on Fast 102
- NOS high-flow valve vs. old style
- Biggest Shot On Stock Long Block
- Plug change, nitrous soon....
- Fastest Stock Long/Short Block?
- Effects from NGK loose plug tips???
- help
- First Pass 1/8 mile 150 shot
- Homemade switch panel
- pulling timing choices
- Where is the leak?
- which direction going lean
- Critique my build
- LT1 Intake Max Shot
- trying to finish up my kit...
- Full nitrous build questions
- Did a Little Wiring on a buddy's G8..
- Nitrous Express direct port services
- Nitrous Outlet Switch Panel
- solenoid Maintence???
- Speed density tune with nitrous??
- how can I get 30 amp connect to au bat?
- spark plug heat range?
- Blown Intake and have some Plug Reading Question.......
- Help me build my engine
- 150 shot questions
- what head gaskets and CR for nitrous 4.8?
- Calling N2O Vendors
- nitrous question
- Will I hurt anything?
- Super Vic question
- added 100 shot
- Some GoPro fun from SGMSP
- Help please
- New 408. How much nos?
- how much gas will L92 pistons hold??
- NOS against RC
- 90mm 2 stage plate... dyno #'s
- cam/spray-nano/boltons 581rwhp 582rwtq
- Rookie question.. with purging
- too much???????
- 92mm tb bracket question
- Beck Sheet Metal 3 stage
- What fuel setup for 2 stages
- Did some testing on our DF-5 valve.
- Vic Junior guys, where are you mounting solenoids. Pics would be appreciated.
- Shooting for the 5,s
- Noob thank you
- Low compression and nitrous
- new to nitrous. quick question?
- Anyone want to try a DF-5 valve for free?
- how much can a 5.3 handle
- so I'm doing my head gaskets and...
- Difference between150 and 175 shot?
- stock ls1 nitrous record time and who has it?
- Fuel setups
- Zex wet kit
- Nozzle vs spray bar
- Watch out all Stock Cubic inch players... Were ready
- Anyone know what brand this is?
- Wiring diagram for LNC-002 and NOS mini controller
- Harris plate with nx jets?
- Talked to old school racer about n2o & timing,do u think he is right? Need exp. guys
- 5.3l vs 6.0l nitrous mustang build
- Stroked LT1 Ignition and Plug help...
- How much have you hit your MS4 with?
- NOS style jets whith a nitrous outlet plate ???
- Nitrous on carbed LS3
- VP113 and plug gap
- Window switch help? Much needed
- HSW solenoid replacement parts?
- diablosport and nitrous?
- Safe Shot for an LS-7 bottom end
- hsw interface
- G-FORCE N20 C6 runs 9.36@146 Video
- How to tap fuel for wet kit with stock style FAST rails?
- Nitrous pressure regulator?
- Need help wiring NOS WOT
- Question
- Who can spec me a cam??
- Critique My Setup - 150 wet shot
- Engine done..Need a converter who should I go to to spec something?
- good nitrous H/C/I combo
- 150 dry shot realistic
- Nitrous & Cam
- nitrous problem
- do i need bigger injectors?
- Another spark plug??
- Looking for sponsor?!?!?!?!?!?!?!?!
- Looking for a Sponsor
- i need a sponsor.
- Nitrous Outlet
- Is it worth changing from a ms4 to a ms3??
- Nitrous accessory ports
- Yank PT4000...how much spray?
- Nitrous set up?
- 3 passes on 150 shot and spin rob bearing i think
- LT1 Plate Kit Pics
- new- b nitrous question
- i need help, HOW TO INSTALL A WET NITROUS SYSTEM??
- track time predictions?
- WTB Nitrous kit
- Fuel Pump Booster Casper
- what kind of fuel pump to get with nitrous
- 102mm plate kit feed line?
- Locations of your microswitch
- Harris plate
- spark plug?
- Quick LT1 plate kit question
- Thinking of a dry kit.
- Stand alone fuel and Tuning questions
- 175 Wet Shot?
- for those spraying out thehole
- Zex Nozzle.... Who uses / has used one???
- How to retard timing on my new set-up?
- Im Going from dry to wet.
- N20 Users Beware!
- Msd window switch
- Numbers ok??
- nitrous side fuel pump for E85?
- Remote Bottle Opener ?
- nx kit contents?
- need some advice from the experts
- Direct Port Question
- Dual Bottle pictures
- What TPS Activation switch is this?
- considering nitrous
- Timing & Nitrous
- Nos mini dumb question
- Stand alone washer jug
- BR7EF's TOO COLD ?
- Nitrous window switchs
- A couple of intakes we've done
- 100 vs 150 shot
- Bare Minimum Nitrous System... How much am I looking at $$?
- Bottle Fed SUV
- RPM switch install LT1
- Any reason I can't do this....
- Direct Port question on Fast Intake
- NOS plate kit question?
- Solenoid bracket help
- Going from high fuel pressure to low fuel pressure on nitrous
- "Sticky" is gone
- Winning some money to fill our bottles :) street vids inside
- Nitrous?
- Looking for SKILLED nitrous installer in Pacific Northwest
- Solenoids to plate line
- How much timing should i pull
- Fuel System
- What should i expect with my combo?
- what should i run on 150 shot
- Smoking?
- Lean at the hit
- Someone ID these nitrous (electronic) parts for me.
- Switchplate help
- The inevitable finally happened
- Nitrous Outlet Reps->Need your help
- Needing a little directions
- Anyone Done This? Stage 1 MAF Stage 2 Direct Port...
- What you guys think of my purge
- Nitrous outlet 102 plate question
- Stock pull vs 100 shot 50-130 vids! 3 second gains?
- what selenoids for 300 shoot???
- 4an feed line for 300+ shot
- spraying my 150k mile SS PICS
- How often should plugs be changed if theyve been sprayed on?
- to nitrous or not to nitrous?
- whats a good cam for nitrous?
- Keep my motor or build a lq9?
- Help me pick Nitrous for my G8
- Sprayed first 100 shot today. Not impressed :(
- Nitrous running lean??? suggestions??
- Thank you nitrous outlet! Pics inside!
- window switches
- TNT F2 Jetting Question
- how much you can spray ?
- What Head Gaskets are You Using?
- Nitrous noob.
- Dynoed the Bolt on c5 with some N20!!
- How would this combo respond?
- 102 Burst Panel
- Keeping bottle pressure
- one or two
- Microedge Price...
- Tnt nitrous kit....
- Nitrous noob...help from a sponsor would be nice or anyone.
- Couple questions for wiring bottle heater? Size wire and fuse?
- tnt power ring gasket
- nitrous question on a certain brand
- What kind of system to go with
- Best 12v source for bottle heater?
- Need everyones help!!!
- Best kit for 78mm DBW? Nozzle or Plate
- need help with nitrous oxide
- Can you see it.... Oh Wait... YES.. YOU CAN!!!
- Question for nitrous Dave?
- Help with Nitrous 4.8 build
- Heads cam ls1. What's the a good nitrous kit to get?
- Clearence Sale 90mm Plate with Solenoids attached.
- What resistor do I need to pull 6 degrees of timming?
- Stuttering Fix
- 150 shot dry OK
- Lingenfelter lnc-2000 launch control wiring?
- Champion lsx454 all pro pics.
- NOS 78MM Plate ?
- Best n20 stand alone fuel pump?
- Fuel system help with carb application
- Can you see it?
- Max shot on LSXR 102mm intake manifold ?
- Nos mini progressive controller?? (wiring)
- Bottle Fed!(:
- Nitrous plumbing on LS-6 Intake
- FLT Level 4 4L60E 300 shot?
- How to make solenoid bracket hole bigger?
- My 2 stage lt1 impala ss pics
- direct port question
- Newb to nitrous... How much can i spray.
- TNT F2 question
- gap on a 100 shot??
- KY-Turbo Inc and Nitrous Cars....
- Should i descreen the MAF for nitrous.
- Post pics of where you mounted your nitrous/fuel solenoids!
- Bottle presure question
- Leaving the line on a 150 shot
- Wiring.. Progressive controller+LNC-2000+FPSS
- 5.3 setup to the 9's
- Our Latest Contribution to the 2010 + Camaro
- Controller Purchase Questions.
- ...its almost dialed.
- Heater element...where can I get wiring?
- Backfire after spraying
- Basic nitrous wiring questions
- window switch
- Hiding a nitrous bottle
