View Full Version : Nitrous Oxide
- what
- i need some help with my timing tuner
- LSX block, L92 heads, and nitrous
- Which setup?
- Need jets numbers
- 408 ShortBlock is here, pics
- 150rwhp or 200rwhp shot?
- nitrous outlet plate or nx maf housing?
- FJO question
- timing tuner question
- stock intake
- 500 shot
- 1st gear lockout--Robert?
- NX Opener
- Advantage of Nitrous Outlet vs. NOS Plate conversions
- anyone make a "Stand Alone" fuel system for the LS2 GTO?
- FINALLY a full spray pass
- Looking for a tee fitting
- Nitrous and the FAST Intake
- Spray small dry off the line (turbo)
- Help with wiring
- Getting dynoed, what do I need to bring?
- relay question
- 15lb bottle + Spare tire well
- direct port on Ls6 intake
- solenoid brackets
- where to mount?
- Power to Nitrous and accs.
- Progressive controller and dry ZEX nitrous kit?
- N.O. Size ?
- Ultimate Wiring Diagram....EVER??
- MSD window switch help needed!
- TNT F1 kit
- Dynotune TPS switch help
- Air Fuel Ratio
- How Big Of A Dry Shot?
- Zex Rapid Fire?
- N2O timing
- will this work properly?
- Stock Internals, 3600 lb raceweight = 11.07 @ 121 on 150 shot
- Who sells the bottle braket?
- Need Help Just Installed Nxl Kit
- Dual Stage 2 MSD WS's 2 Activations Switches All Done!
- lt1 dry nitrous question
- Changing nozzles on my 5177 kit, which ones?
- Need Nitrous Tune For Hp Tuner's
- BMN Controller Question with LS6
- HSW Stand Alone Intalled
- Need n02 Help
- can i remove my bottle sticker?
- note to you nitrous newbies installers
- To run a progressive controller or not.
- Going for 8's !!!!
- Nitrous shut-off rpm?
- wet install question about schrader valve
- Dryshot in cone filter
- My 9.40 @ 145 pass
- Dry shot with SVO 30lb. injectors?
- how much will it handle (HELP)
- Maxed out coils need big nos users help!!!
- 10.51 @ 131 Cam Only, Full Weight, 150 Shot
- Need Help-Sponsor has a new forum
- my bottle size.
- Which Kit?
- injectors or fuel pump?
- 125 wet shot on ls1
- detailed C5 install?
- I need Manual for BMN window Switch !!
- who indexes there plugs?
- a moment of truth i need help
- Which NX kit?
- Which MAF to use
- Dyno Tune Wet Nozzle Question
- where can i buy just just the lines and valves to fill my own bottles
- What race gas to use with nitrous?
- what should i shoot for for compression ratio
- Hiding solenoids in the trunk?
- Nitrous Idea
- 190's AFR
- tpp window switch?
- Race gas???
- Purge Pics/Vids!
- what size jet do i need to run a 100 dry shot
- Wiring for Nitrous
- Does Anyone know the NHRA rules about having a bottle in the cabin
- 200-250 shot on a 418ci. motor...what N20 setup would you go with?
- Best place to install wet nozzle on a C5
- 125 dry shot on stock fuel system???
- Which Wet system should I go with??
- Where does the the Nitrous filter go, how to bottle heater, purge
- Inline Vs Valve Bottle Opener
- what makes a nitrous cam different from regular n/a cams?
- How much spray to beat a KB cobra?
- TA AC Vent Gauges
- hsw wet kit shot
- Will a nos bottle opener work on dynotune bottle
- lt1+dry kit = confused
- Direct Port or Nitro Dave's Plate??
- Please help me pick a kit
- Gauging interest in stand alone...
- Single Nozzel Question
- Bottle Opener, what all will i need with this
- Can a ScubaTank Hold N2O
- Can efilive perform nitrous window switch functionality?
- Shiz goes 9.10@149.5 on pump gas...
- Need help on a guage question
- Does Wet System Need retune?
- N20 solinoid did not open???
- Purge and bottle necessary?
- quick question about nitrous (bottle, filling, empty, etc)
- Second week spraying. Aftermath pics.
- TRex Cam only with spray?
- anyone with a yank py4000e
- Finally some shakedown passes.
- has ANY ONE HEARD
- what plate for me?
- NX Wet To Dry Conversion Help!!
- Custom FAST/Daves plate and grp rods!!
- How much faster will I go with a 100 shot?
- Edelbrock concealed kit
- Dry Dual Stage Wiring Check
- nitrous ?
- NX window switch ?
- hidden wiring?
- Finally Installed My TNT Kit
- Fuel pressure dropping issue.......need some help!!
- high mileage guys[100k+]how much you spraying??
- Need Help with picking a Nitrous Kit
- do the TR6s come gapped correctly?
- Where to mount WB sensor?
- Rich or Lean can you tell by these Pics?
- Noyzee in a hold up
- What bellow with Dave's Plate?
- I got a nasty Spider bite!
- Weber Racing Equipment Short Block Specials!!
- new numbers in
- Help with remote bottle opener!!!!
- What can I run in the 1/4? Possibly a wheelie?
- Lean Codes After I Spray
- help with purge!
- Nitro Dave - Any 90mm Plate Conversions In Stock?
- Mechanical vs Electrical N20 Pressure Gauge - Which Is Right?
- New Best 11's at 4200 FEET!
- Nitro daves/860 spray results stock car!!
- What the hell
- Looking for line and system recommendations
- what to torque bottle nut to HSW bottle and 4an nut
- propane injected Does anyone have a set up
- NX Kit....Should I?
- 75 to a 100 0r 150 shot question?
- Pics of HSW universal Dual Nozzle setup + Heater
- Need Pics of TNT LS2 plate
- th400 dyno results?
- 10mph per 1.3 seconds? Is this about right?
- empty or full bottle?
- timing tuner instructions
- some ones bored in the morning
- pictures of daves ls1 plate system installed
- WOT switch bracket install help needed!!
- stranf a/f situation, nitrous gurus, please come in...
- dual stage options.
- Solenoid mounting question
- Single or Dual nozzle
- lt1 timing
- dry shot nozzle position??? ---pics---- help me out
- Too soon to spray????
- piks of nitro daves kit
- How Accurate are electric fuel pressure gauges? (Nitrous related)
- What kind of nitrous setup would you use?
- Tune + 150 shot?
- Did I make the right decision by going with Dynotune????
- n2o gauge disassembly
- What Guages?
- Thanks Dave and NX
- LC-1 standalone gauge kit or LM-1
- Which blow down tube?
- New toy in the family!!!!
- WOW 1.33 60ft on a 100 shot.....
- Zex LT1 dry kit opinions needed
- New best first pass of the year
- hi or low pressure
- Autometer C2 Nitrous Gauge Install - Help Please
- How big should i go? Dry shot
- need nitrous help
- HELP!! Piston Ring Gaps for nitrous
- For the guys that want to Know Why!!
- why can't you use splice/tap clip on the TPS or Tach signal?
- Bottle Locations on 98+ F-body...
- good article on plug reading
- Is it worth it to go with a plate vs a single nozzle
- Nice pics -
- what did i just do??? (electrical problem)
- which gauge wire?
- For The LT1 guys....
- Building A 408 What Cam?
- im retarded and have a stupid question
- track tonight
- What wide band works best with the hp tuner?
- ls1 dry nitrous install QUESTIONS -piccc-
- stand alone fuel cell
- a couple of questions...
- went to the dyno today, 150 shot =85hp????
- how much does it cost really
- Please help with Jetting....Please help!!!
- mail order tune???
- converting a dry kit to a wet Feed line size????
- do any of the Forum Vendors carry autometer
- Nitrous question..
- How do you connect a FPSS
- HSW Plate
- Timing with stand-alone
- Picked up .7 and 6 mph Tonight! thanks Nitrous Outlet
- another hsw stand alone fuel pressure question
- here are some pics of my new HSW stand alone system and solenoid brackets
- Nozzle help needed
- NX bottle opener w/ Nos bottle?
- Spraying in first gear
- What Is A Lean Spike
- What am I lookin' at
- Going N2O today I need help from you big guns. Beer, Noyzee, hsw, DT, etc...
- What do you know about the Dynotune Autometer WB kit????
- Yo 860 Vinny????? need more stuff!!
- Pics of my new toys!! with a good camera. hehe
- just got the nitrous, curious to see if i have everything right
- Fuel pressure and nitrous pressure gauges
- I'm in :)
- sneaky pete?
- New Nx System?
- OK.... am i retarded ?
- thinking of n2o
- What covering is that?
- Hey dave where's this months specials????
- H/C Nitrous and fuel question...
- So it starts!!! N2O in the family!!
- Dynotune help?
- NX Lightning amp draw
- Four Free Dynotune Nitrous Line Wing Nuts!!!!
- And the winners this month are!!!!!!!!!!!
- I am taking off my NX and going with TNT
- WOT swtch related question
- Best Nitrous Solenoid?
- HELP!? Car running lean on 100shot!
- Harris Speedworks (Edge)
- Bigger injectors?
- 9.59 @ 138.71 first time out on 346 w/150 shot
- What Single Controller Available with These Features??
- Need a new full throtle switch.
- My race day today, new best, but a lot left!!!
- Recomendations on upgrading Fuel Injectors with NOS NOZZLE system!
- NXL direct port + NX fuel accum is for sale
