PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. I will paypal $20 4 help! Edelbrock Controller and MSD window wiring diagram needed!!
  2. fuel press on dry shots
  3. Couple vids of my ss on the bottle
  4. anyone running this??
  5. Anybody ever hear of COMPUCAR?
  6. protecting a painted bottle?
  7. nitrous switch on the steering wheel??
  8. BMN W/S Nitro Control instructions
  9. dry kit option suggestions
  10. good place to get bulk jets (DP Setup)
  11. Fouled plug #7 cylinder 2 times, why????
  12. Braided BD line NHRA legal? (already ran a search)
  13. have some LS1 ?SSS
  14. Post Your Dry 100 Shot Scan 1/4
  15. Pressure dropping fast after runs..
  16. fill in the wiring blank (fpss)
  17. NOS wiring help!!!
  18. Wtb: Fpss
  19. need some advice
  20. Problems after spraying???
  21. Testin the nitrous
  22. Pics of Nitro Daves new LT1 noid mount
  23. 1/4 mi results
  24. Tips How To Make It Look Better
  25. questions on 2nd stage n2o noid and purge
  26. 1/4 Is my setup working right?
  27. 11-1 comprssion, 93 octane and spray
  28. Dry kit qustion
  29. need a quick answer about teflon paste
  30. Pics of New Beer Switch Panel Installed
  31. Tuning?
  32. Car is backfiring through the exhaust at WOT w/ dry kit when system is armed only.
  33. Lets see pics of setups!
  34. Jet size question?
  35. 200 Shot And Redline
  36. 01 question
  37. 4000stall + nitrous?
  38. Flycut and the Bottle?
  39. Who wants a 100 dollar gift certificate to Hooters?
  40. shot on stock bottom,
  41. cam adivce please!
  42. MS4+n20 question
  43. attn dynotune
  44. New guy needs Trouble Code help
  45. WTB NX single stage EFI kit
  46. bottle refill?
  47. 2 Solenoid or 4 Solenoid Please explain this to me
  48. step one, compleat!!! sneak peek at my new build!
  49. Which TPS wire on a C5 for WOT switch?
  50. Any street cars that moniter egt's? Aeroforce EGT Adapter?
  51. Stock short block + direct port how much ??
  52. Led panel for nitrous tank reading
  53. purge wiring question??
  54. pneumatic solenoids
  55. Progressive controller!Anybody have 1?
  56. Tach signal wire question
  57. Got my nitrous all done *pics*
  58. timing Q
  59. 98 ECU + No MAF + Dry Shot Howto
  60. ZEX vs NOS(holley)
  61. WOT via TPS not working?
  62. Testing solenoids - quick question
  63. Just Curious....
  64. Fuel Relay
  65. Traction control?
  66. bottle heater relay or fuse?
  67. what plugs
  68. First time spraying today, problems/questions?
  69. Want to cover my bases on this set up.. Dart heads F14 cam and 175 shot.
  70. need a diagram
  71. what is the driveshaft hump made of?
  72. Can I really start spraying for $349.99?
  73. Nitrous spraying before WOT
  74. what size shot
  75. better fuel pump or not?
  76. dual stage/dual window switch?
  77. A few pics of my Hardlined NX kit
  78. Who is running what Kit Poll
  79. schrader valve problem
  80. New Bottle Sticker?
  81. Nitro Dave question..........
  82. dry shot surging problem
  83. can you modify the dynotune bracket to fit the center hump?
  84. where to mount noid bracket on LT1?
  85. Direct Port LS2 GTO, 56K Death!
  86. Trick windowswitch users! tell me how to "lock out" 1st gear...
  87. install electrical problems =(
  88. Looking at the Stage 1 NX kit...
  89. power loss with colder plugs?
  90. Help a Girl with a 100shot of N2O on a stock T/A?
  91. 2 stages
  92. this everything?
  93. Im freakin stumped...need help
  94. Jet sizes (already looked in stickey at top)
  95. Zex box fitting leaking
  96. Guys, What do you think?
  97. autolite 103's gap?????
  98. paintball nitrous vs. automotive????
  99. What nos jets for single nozzle 200 shot just checking
  100. Zex purge problem...
  101. couple questions
  102. Is there a stand-alone fuel kit for vettes?
  103. Opinions based on my set up
  104. Nitrous Pressure Gauge
  105. Wideband Guages
  106. The juice & the boost...
  107. WBC users inside please!!!!
  108. Nitrous Install, Help
  109. Daves Plate jetting?
  110. Updated Wiring Diagram - for review/critique
  111. debating on 150 shot
  112. Fjo Users In Here
  113. Question ?
  114. NOYZEE SAY's you better----
  115. 150 shot + 44 degrees timing= octane
  116. Using the wrong spark plugs in my AFR heads?
  117. ngk TR-6's and fuel economy
  118. Please double check my wiring
  119. purge out of ss hood
  120. Any good websites to help a newb out on install?
  121. C6 LS2 Nitrous (newbie)
  122. Which window switch to use?? and a few more Q?'s
  123. backfire lean or rich?
  124. Solenoids and current/amperage draw???
  125. Purge Solenoid's Compression Fitting Question
  126. Best Ci Motor For Spray?
  127. soft line for direct port
  128. well i'm glad i tore her down
  129. What is a good kit
  130. TNT window switch????
  131. ??? for people that fill thier own bottles
  132. dynotune rep????
  133. Nitrous newbie ?
  134. Newbie Question
  135. Need help finding what I need
  136. Shops?
  137. dry tune
  138. window switch bypass question?????
  139. dedicated fuel cell pumps...
  140. 85mm Throttle Body guys in here....
  141. wideband install
  142. Too much too fast
  143. what should i feel??
  144. loosing power on spray
  145. Installation of a Window Switch HELP!!!
  146. WET or DRY????
  147. cold fusion vs. HSW
  148. Are the fuel and nitrous solenoid motors the same?
  149. 820rwhp on 1st stage
  150. BMN window switch wiring diagram question
  151. what rings on forged motor?
  152. Silonoid rebuild
  153. Built Iron 408 Limit
  154. where can I get JUST the TB PLATE FOR LS1
  155. info on refill stations
  156. I need help fast...I'm late for the track!
  157. What size are the screws for the noids?
  158. how do you hook up n20 and fuel psi gauges
  159. 4L60E 1st Gear Lockout ?
  160. duel nozzle setup problem?
  161. Dyno # HSW kit
  162. Noyzee= new Moderator!!!
  163. power ring
  164. 2 degree timing pull.
  165. harris speed works
  166. anyone thinking about DYNOTUNE do it
  167. DYNOTUNE Gauge-Heater and NX Bottle Opener FUSES
  168. Nitrous Newbie
  169. Best Nitrous controller out there?
  170. My tuner says you cant tune for dry
  171. Nitro Daves FTW!!!!
  172. Should I switch to a plate system?
  173. Where to get parts for a NOS soliniod?
  174. nitrous direct halo bar
  175. HSW window switch problems
  176. Those N2o Questions/Answers you've all been waiting for.
  177. Need help with TNT F1 kit
  178. Corvette C6 Window Switch
  179. Pls critique my wiring diagram - NOS dry system
  180. Bottle siphon tube orientation?
  181. Some questions about setting up Spray.
  182. im going to put spray wet or dry
  183. Switched 12v power
  184. My results from tonight!
  185. le package welcome
  186. Gauge Question
  187. 99 SS 24k miles HSW SIWK
  188. why relays for nitrous
  189. NOS remote opener on dynotune kit?
  190. autolite 104's
  191. which nitro dave kit?
  192. Need Pics Nitro Dave plate installs
  193. ported fast from ron @Vengence A++
  194. Spring Specials!
  195. 500HP shot !!!
  196. Where to tap?
  197. just got noids back, now one of the pro shot n2o noids leaks like a sieve!
  198. Bypass window/wot switch?
  199. Need options. Have dual kit want to change
  200. Is this the smallest AFR display?
  201. Dyno Tune for 125 shot?
  202. 300 shot ?
  203. Need some help with selecting parts!!!!!
  204. is nitrous cheating?
  205. 15 lb nos bottle
  206. autometer gauges? Are they half decent?
  207. Fuel pump ?
  208. Fuel Injectors
  209. how much mph for 100 shot
  210. Nitro Daves Dual stage plate system running way lean
  211. DRY IAT AND MAF hz
  212. What Rpm To Spray
  213. Who sprays with flycut pistons and how much
  214. YO, Nitro Dave...Got a ? for you
  215. Spraying on stock timing
  216. NGK TR-6's, AutoLite 103's or AR103's
  217. DIY wet kit
  218. Digital Dual Window Switch (operation questions)
  219. Few Nitrous ???'s regarding HSW kit, Jet sizes + accessories... please help
  220. PINKS ALL OUT @ Rockingham
  221. TNT TPS switch instructions
  222. Nozzle/Plate help needed
  223. purge valve problem need help
  224. Pics of the new 2 stage SX2 kit on a sheetmedal intake
  225. Stock Engine question
  226. fast idle after n2o install
  227. Jet sizes?
  228. Stock bottom end car making close to 500rwhp h/c, spray?
  229. Oil???
  230. Can I use SS Brake line for nitrous lines?
  231. IAT wiring clarification..
  232. Solenoids wire size
  233. how much nitrous can hypereutectic pistons handle?
  234. Does this really work with stock O2?
  235. Purge push-button rating?
  236. Bottle guage port block or T?
  237. HSW Dry Kit???
  238. M6 Nitrous people
  239. Timing tuner help needed.
  240. going to the track on fri
  241. No Purge, Hard on Solenoids?
  242. has anyone used the dyno tune wet kit???
  243. 2 stage kit
  244. custom N2O hoses ?
  245. Video link -
  246. injector size for a 150 shot
  247. C6 Bottle location pics
  248. Nitrous or Turbo
  249. Who grinds a Nasty LT1 gas cam?
  250. dynotune remote bottle opener
