PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. NOS install shops?
  2. Combination window switch/WOT switch
  3. Need help with nozzle location !!!
  4. I need help with a custom cam profile for nitrous
  5. Bad tuning
  6. Happy Halloween
  7. Wiring a progressive controller
  8. Flare Jet Question
  9. good inexpensie dry shot
  10. Who sells carbon fiber bottles?
  11. new engine
  12. LS7 w/200 shot = 8.90 @ 153.51
  13. N2O and Fuddle Stalls
  14. Whats the best way to tell when you need to refill your bottle?
  15. 13's on Nitrous
  16. what would you go with??
  17. New with NOS??
  18. Bottle Heater question?
  19. Harris Speed Works Nitrous (good?????)
  20. Full bottle preasure?
  21. what should the a/f be on a wet kit
  22. Airbrushed Fbody Bottles
  23. Cold Fusion Nitrous Controllers Are In!!!
  24. Can't do this with an LS1....
  25. Anyone getting rid of Nitrous equip for LT1? (wet)
  26. Big spray guys inside please...
  27. I Need Nawz!
  28. When wiring does it matter if you go from a larger wire to a smaller one?
  29. Mental note: A 10lb bottle does NOT weigh 10lb's
  30. Nitrous Pressure regulator pics from ZEX. Anyone like it?
  31. advice on tnt kit
  32. Need help. Lean spike???
  33. Newbie needs HELP!! What system to run??
  34. NOS remote bottle opener...
  35. A/F and JET sizing
  36. What is the best bottle pressure?
  37. standalone cell mounting????
  38. What do you Think
  39. Heads, cam, speed density dry nitrous = 183mph in standing mile!
  40. Kit installed. Pics inside.
  41. Nitrous parts needed
  42. gear lockout wiring diagram need
  43. Anyone mount nozzles at the air intake of a vic jr?
  44. How to inspect solenoid?
  45. Installation question
  46. NOS Window Switch (15879NOS) question
  47. Thank You LS1 Tech!!!! FREE BOTTLE HEATER AND PURGE KIT!!!!!
  48. Need Introduction To Nitrous
  49. Whats the easiest way to set a fuel pressure safety switch?
  50. progresive controler
  51. WOT switch with tnt f2
  52. Is it ok to use ARP thread sealer on NPT fittings
  53. NOS mini controller problem
  54. 2 stage nitrous questions
  55. Stacking fuel noids?
  56. NOS Jets
  57. Wideband 02
  58. Best converter for n2o
  59. What dose everyone pay to have their bottle filled?
  60. Best RPM Window Switch for my Setup
  61. Got some testing done last night with the 90/90 finally!
  62. Critique my graph
  63. Progressive Set-up - Starting Suggestions?
  64. My experience with Nitrous Direct
  65. A little more juice, A little bit quicker
  66. Is a nitrous filter recomened?
  67. leaving pressure in line
  68. Need help with Window Switch!
  69. Recommendations
  70. tnt f2, slp lid ??????? sugestions!!!
  71. what is this part?
  72. Pics** Is this an NX automatic heater?
  73. Swapping from dry to wet !
  74. A few questions
  75. Sprayin a 402
  76. New Install Pics (dial-up beware)
  77. quick question
  78. New best on spray
  79. Cutout Switch to Opener Switch?
  80. Supercharger and Nitrous-who's done it?
  81. 120volt bottle heater
  82. Would I up my jet size using methanol in standalone fuel system?
  83. The importance of heating a bottle properly
  84. nitrous line connecting
  85. nos plate kit ?????
  86. Noob N2O question - how long can a bottle be left open???
  87. Nitrous Dave's Plate users inside please
  88. Who Has The Best Kit???
  89. Bottle Heater?
  90. Zex Dry Kit
  91. nitrous motor help!!!
  92. need help
  93. Digital window switch ??'s
  94. help on repainting bottle
  95. What progressive controllers are you using??
  96. TNT F1 wiring schematic
  97. ? about Progressive Controllers
  98. NOYZEE Mobile Back in the works!!!!!!!!!
  99. Speed Density dry nitrous question
  100. How much $$ for install??
  101. Whats the biggest shot someone is running?
  102. how big of a shot to go 400whp
  103. new trickflow heads dry 75 shot 582 rwp
  104. Highflow valve guage
  105. Ls2 + cam + full exhaust (stock heads)...
  106. dyno tune nos kit
  107. new switch panel
  108. Upgrading To 90mm
  109. I hate to ask but...
  110. 200 shot on tnt's f2 kit??
  111. Directport Gurus come on in!!!
  112. Need help with why my nitrous pressure gauge doesnt work:pics inside
  113. Timing tuner question
  114. Advice please: Amps drop bad at idle when 860 bottle heater is on is this normal?
  115. stock A4
  116. nitrous piston
  117. this jetting too rich??
  118. Alittle help please.
  119. where to hide a 15lb bottle in a c5
  120. analyze my graph please
  121. One of those, "How much" questions
  122. dyno tune switch gauge & nos pressure wiring diagram NEEDED!!!!!
  123. I got gas!
  124. Are all Dry shot NOS jets the same
  125. Spraying on top of 400RWHP, how big can I go?
  126. Nitrous ring end gap, 2nd ring??
  127. Injector duty cycle?
  128. Is it safe????
  129. Rich no matter what.
  130. whats the trick to wiring msd window switch?
  131. N2O issues - detonation
  132. Duramax Deisel n2o kit in my ws6
  133. Fuel Pressure Switch Installation
  134. Timing tuner configuration ?
  135. best clutch for nitrous
  136. Dyno numbers on my C6 vette with A6 transmission
  137. just a couple questions...
  138. The Black Widow #2 !!!
  139. jets 4 175 on nos plate asap!!!
  140. Thinking of N2O
  141. WOT switch with 80mm TB
  142. Cleaning jets
  143. Dyno Tune Dual Stage Install
  144. Dry shot and 26# to 42# injectors
  145. 1998 SS: MS3 Cam Only + FAST 90/90 + TNT F1 = 555RWHP, 576RWTQ
  146. Heater & Purge 5177 kit and MORE POWER!
  147. NX Throttle Body - Any users?
  148. How much timing should I be pulling
  149. My dynotune nitrous pressure gauge came today
  150. rpm window switch question
  151. Where to mount a dry nozzle on a vette?
  152. Blow down tube
  153. Any one using an old school style plate kit?
  154. when you street race do people get mad that you use nitrous??
  155. big stall, n2o, stock tranny
  156. Finally got a tune and dyno #s
  157. Nitrous Works LS1 kit? Opinions?
  158. LS7 in a Mustang
  159. Do I need bigger injectors/higher flowing fuel pump?
  160. When one just isn't enough
  161. Speed Hut Custom Gauges!!! Anyone use these???
  162. Vette FJO wiring
  163. Nitrous problems......
  164. smooth bellow and tnt ring
  165. tnt f1 or f2 pics?
  166. pics of my Harris speed works stand alone
  167. Check out my Helmet
  168. Do I need to change the plug gap?
  169. Jetting a plate kit w/ standalone(low psi)
  170. Restrictions of a kit....
  171. Nos valve opener
  172. Tuning AFR
  173. fuel upgrade or not ???
  174. where to mount a WOT switch
  175. window switch question??
  176. Trex and 200 shot?
  177. what bottle opener
  178. For the Truck Guys..
  179. 10-Sec Daily Driven N2O Recipe
  180. Tuning a 400 shot
  181. is it the tune, the plugs or both?
  182. 75 dry plus cam
  183. bottle gauge question
  184. All questions about nitrous oxide
  185. wiring help
  186. Car won't shift
  187. What do you think..
  188. nos nitrous jetting
  189. Stand Alone Fuel Requirements
  190. ***help With Nitrous And Fuel Pump!!***
  191. Aluminum Tubing
  192. Done for the season!!!
  193. Which Set-up/Brand For 383 Stroker?
  194. 109hp gain on a 150 shot?????
  195. Tested System For 1st Time
  196. Spark plug Gurus inside please
  197. Progressive Controller
  198. Tpas
  199. BMN Wiring
  200. adjusting n2o and fuel pressure?
  201. NX MAF kit
  202. -6an is it worth it!!
  203. Where Can I Get My Nitrous Bottle Filled?
  204. 5 LBS of N20 Enough to Dyno 2-3 runs??
  205. A4 window switch or not
  206. 175 shot
  207. NX filling station FS. NEW!!!!!
  208. quick question
  209. would something happen
  210. Spark plug changes?
  211. FREE Dry Kit Upgrade!
  212. what gauges
  213. How long does nitrous last?
  214. Plate question...please help.
  215. Nitrous Plate System + FJO Controller No gains :(
  216. Best way to monitor A/F on a budget?
  217. Gauge on pillar
  218. Would you spray a car your making payment on?
  219. What heads for spray??
  220. what else do i need???
  221. -------Wideband commander logging question---------
  222. Nylon tubing good or bad?
  223. Pressure Pro Nitrous Regulator
  224. Nitrous System In Michigan - Legal Or Not???
  225. TnT nitrous system for sale complete cheap!
  226. Nitrous Express Price Increase!
  227. 1/4 mile estimate
  228. Lets see your custom bottles
  229. NX Price Increase Across the Board
  230. How much can I spray?
  231. Who is using the TNT F1
  232. dynotune window switch (single stage)
  233. dynotune window switch
  234. piston melting problem with
  235. nx import efi wet kit?
  236. hypertech w/nitrous
  237. Dual Stage For sale CHEEP!!!!!!!
  238. T-rex and spray
  239. popping at high rpms
  240. Nitrous activation light
  241. Should you heat shrink all connections?
  242. Poly Line Purge
  243. Autometer Nitrous Gauge Reading Off
  244. A4 wont shift fast when N2O is on
  245. nitrous effects on tranny
  246. difference between a 250-300 shot.
  247. Saw a dave Posser!!! Vinny saw to!!
  248. Direct Port Victor Jr. For sale
  249. A few basic questions
  250. Found my wot issue finally!!!!
