PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Nitrous issues, lower hp, lots of tq but WAY RICH. Help please
  2. got my z06 to the track on spray
  3. nixtrous express purge ?
  4. Newbie, Need some nitrous and plug help.
  5. Labor rates to install NOS in 4th gen
  6. Will pulling a couple degrees timming improve spray results?
  7. Need to find Tach wire on 2005 GTO LS2
  8. Red Locktite or Teflon Tape?
  9. Remember to check your nitrous bottles fellas
  10. 250 plate shot and no HP????
  11. Is a NOS .020 Pill Ok to Use instead of a NX .020??
  12. 150 WET SHOT Dyno Results Inside with YankSS3600 Stall. QUESTIONS
  13. need help converting to wet kit
  14. Nano jetting question
  15. anyone running the torquer v.3 cam with spray
  16. Nitrous Outlet 90mm plate for 78mm switch
  17. Plate setup + 200 shot on stock LS1?
  18. how much power will a stock motor hold??
  19. If rain stays away......today I will SPRAY!!!
  20. How Much Spray On an Lq4???
  21. new guy at nitrous and i got some questions
  22. where can I buy br6ef plugs?
  23. Timing for 150 nitrous (table pic)
  24. need cam help
  25. Hit the lil red button and see smoke in the rear view
  26. Still confused n20 or no
  27. Purge
  28. 150 shot on TR55 plugs
  29. few nitrous questions for the 5th gen camaro's
  30. New Micro Edge never activated for sale
  31. 408s with spray post your time and set up
  32. newbie
  33. Is this a good deal??
  34. video of 383 acceleration with 100 wet shot
  35. Nitrous Cams
  36. Sponsers that sell nitrous come inside
  37. NX 11107 Bottle Opener?
  38. Question about zex nitrous kit??
  39. TSP MS4 cam, and spray?
  40. What to set my window switch at ?
  41. 12.69@109 now + 100 Dry Shot = ?
  42. Is a 10 sec. Slip possible?
  43. Help me read the plugs
  44. Nitrous wiring problems...keeps blowing fuses.
  45. stock bottom end
  46. Nitrous record comes to the midwest
  47. microedge users, which 02 wire do I tie into?
  48. Nitrous problems today during dyno tune
  49. How much can a Walbro 255 handle?
  50. Carb'd intake, spray bar guys! Solenoid mounting?
  51. Light on zex box wont turn on?
  52. Well Im hooking up my 1st. N20 kit. pics.
  53. trick flow 265 heads
  54. Question for the guys that have the bottle in the back seat.
  55. How do I program my Zex Fuel Pressure Safety Switch(FPSS)?
  56. Ready to hook this system up....need help!
  57. HSW interface users, I really need your advice. about timing retarding.
  58. Am I Overlooking Anything?
  59. Remote bottle opener fitment
  60. Where can you buy locally? NGK's br7ef (in Dallas)
  61. nitrous leak..need help asap
  62. What Plugs with Nitorus? Been a few years and have TR6's.
  63. HELP with C5 install mainline TPS switch
  64. water meth/ Nitrous spray bar
  65. Question about -an fittings.
  66. Driving an Automatic on Nitrous
  67. gauges inside cup holder
  68. NX Dual Nozzle Kit What Jets for 100 Shot?
  69. what plugs??
  70. figured id share some pics of my street beater
  71. how much torque does a 100 shot add?
  72. Help with n2o numbers
  73. Compucar Nitrous
  74. Pics of my Pro-Flo XT intake & direct port
  75. Wet plate on high mileage ls1
  76. Help When Dyno/Tune Nitorus. WHAT TO DO....?
  77. Install InstructionsNX Electric Peressure Gauge?
  78. My TNT NITROUS Power Ring Moves around. PICS Inside.
  79. N2O newbie, sell me on it.
  80. want to run a 150 shot...should i go with harris speedworks kit or nitrous outlet?
  81. Can't get Dynotune A/F switch to read correct AFR
  82. Am I asking too much from my tuner?
  83. Post some pics
  84. Nitrous outlet all in one solenoid brackets?
  85. Old Nitrous
  86. Who fills Nitorus bottles in Dallas area?
  87. Ls1 cranks, rods and pistons?
  88. 2 kits?
  89. best bellow to mount nozzle on underside?
  90. standalone need 58psi?
  91. Check out this 102MM Nitrous Throttle Body Being Machined! Video Inside!
  92. Finally installed the nitrous through the throttle body!
  93. Hsw phones out?
  94. nitorus install question
  95. No power with nos
  96. bottle?
  97. Step up to the plate Dave...
  98. filling the bottle?
  99. hidden dry or disguise wet
  100. how much can one dry nozzel flow
  101. biggest dry shot on stock internal ls1
  102. Nitrous Outlet Drag Radial Nitrous Car.
  103. 6.0 going spray
  104. no2 forge ?
  105. need a little help from the pros (sponsors)
  106. Tach input wire
  107. just made my first spin with spray. have some ?'s
  108. how often do you change your plugs?
  109. how many times can u purge a 10lb bottle
  110. Nitrous Outlet Vehicle Specific Kit 2005 LS6 CTS-V
  111. Look at my Plugs
  112. Never trust the gauge..Flow it!
  113. Can you hide a wet system?
  114. quick plug question
  115. NGK BCPR7ES...Are these good for 200 Shot
  116. Stupid Solenoid Coil Removal Question
  117. need help!!! got a ?
  118. which is safer?
  119. high and low pressure regulator off a single walbro 340 ?
  120. What do you all think?
  121. need some help with compression
  122. Nitrous Questions..
  123. New track record with the RPM-Motorsports sponsored 07 Z06
  124. Need jetting help for e85
  125. nitrous purge?
  126. Nitrous on LS2 RX7
  127. recert. a bottle and self filling?
  128. Some opinions on this plug.
  129. quick wiring question.
  130. Fuel recommendations for a 13:1 motor on a plate kit.
  131. What to expect from a 100 shot?
  132. Edelbrock Pro flow LSx manifold
  133. Starting point
  134. Speed Density tune and nitrous guys come in....
  135. Just got a fuel pump, what else do I need?
  136. Update on junk yard dawg!!!!
  137. Nitrous Plate
  138. Run daul Bottle in One stage
  139. Timing twister?
  140. CTS-V Purge Location...Opinions?
  141. Timing Tuner Wiring Question
  142. Nitrous and relocating battery?
  143. Options for Pulling Timing With Nitrous
  144. Always check your cam!!!!!!!!!!!!
  145. T-fitting for fuel rail?
  146. Microedge/Transbrake?
  147. How much timing for 100 -125 shot ?
  148. NX and NOS jets
  149. Timing Controller Spark Translator
  150. Timing retard contoller with MicroEdge+
  151. Was this detonation or just an engine failure on a good nitrous hit?
  152. Refilling nitrous
  153. fogger nozzle install question
  154. msd digital window switch diagram question
  155. finally installed Dual bottles and V spray
  156. an ls1 stocker with n20 jetting question
  157. N20 Outlet NO-61001 N20 controller?
  158. Stock flycut pistons & N20?
  159. Is cyl 1+2 leaning a serious concern?
  160. Removing nitrous kit... have a question about fuel rail
  161. nitrous Express question
  162. T into fuel supply fuel line
  163. Dry plate set up
  164. Microedge help
  165. harris speedworks nitrous kit
  166. Is a electric bottle opener pointless with NANO???
  167. fuel solonids feed
  168. Anyone have a LNC-002 or 003 for sale cheap?
  169. rpm signal
  170. Is texas nitrous technology(T.N.T) still around
  171. MSD timing twister or LNC
  172. NOS Tank Re-Certification
  173. Gauge in drivers vent
  174. wiring
  175. MicroEDGE Help/?'s
  176. Best head Gasket out there for spray?????
  177. Mixing E85 and C16... how to tune?
  178. Lets discuss your oriface
  179. WOT switch on LT1 pics needed
  180. Looking for a job in the high performance industry with banker’s hours?
  181. testing solonoids with HSW Microedge
  182. how much nitrious can you put on a stock ls1?
  183. nitrous on a carburetor
  184. Rings for street/strip 200 shot
  185. Nitrous Plate question 102mm Fast 92mm TB
  186. Trying to match a nitrous setup to my heads and cam...
  187. Anyone spray a Torquer V2?
  188. Stock Block Nitrous Guys Come In...Suggestions/Opinions Needed
  189. ATVRacer, and ShiznittyZ28 please step inside.
  190. Can't get the air/fuel right...
  191. The GMHTP Shut Your Face Race | Holley LS Fest | Sept. 10-12th
  192. Lnc-002
  193. Hidden Bottles in the C6??
  194. Nitrous AN line size, quick question.
  195. Bolt ons, E85 and 150/200 shot !
  196. Silicone Hose Help.
  197. swapping plugs
  198. Another budget set-up
  199. jet size
  200. NOS Outlet setup
  201. got my bottle mounted
  202. Some pics of my Nitrous Outlet install
  203. Help pick a kit
  204. some nitrous input/tips needed
  205. post some pics
  206. ls1 intake record with nitrous
  207. Smaller cube glide cars
  208. nitrous ring gap 300 shot?
  209. bottle pressure guage question
  210. Nitrous help
  211. Who has the best heads for nitrous applications
  212. 100 shot safe on stock LS1? HELP
  213. LQ9 317s good for spray??
  214. Bolt on A4, stock trans, will it take a 100 shot?
  215. Got My Brand X Nitrous Installed
  216. Need Some Nitrous Kit Suggestions...
  217. help needed on selling nitrous kit.. offers??
  218. bottle heater and pressure gauge help needed
  219. need some advice
  220. how. about some pics of where your mounting the HSW microedge
  221. Information on Plug Reading?
  222. 3800 vig stall and 100 shot zex kit nitrous good idea or bad?
  223. Nozzle Modification
  224. Anyone have any old parts?
  225. Air /fuel for a 100 hp dry shot.
  226. Good read about projected tip plugs ....
  227. jets....
  228. Race Gas Question
  229. What to do?
  230. selling all nitrous express stuff
  231. Bottle heater
  232. Is Timing Twister pulling timing?
  233. NOS brand bottle blow down
  234. Nitrous Laws In Ohio Or anywhere else.........
  235. Race gas and timing
  236. 200 shot off the rail???
  237. best placement spot for wideband
  238. Nitrous Outlet digital progressive controller???
  239. new beck intake with one stage
  240. What gauges are needed?
  241. 170 torque from a 100 shot?
  242. Nano
  243. spraying on 6l80E
  244. Spraying in 4th gear 4L60E
  245. Big thanks to Nitrous Outlet!!!
  246. Only gsined .156 on a 100 shot?
  247. 125 dry shot????
  248. High idol issue after HSW 78mm palate install...HELP
  249. Hard Line Questions
  250. Thinking about a little 150 shot
