PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115
  1. Dyno with TNT 100wetshot, after 12bolt installed
  2. 30# or 36 # injectors ??
  3. fuel pressure cut off switch?
  4. changed my mind, i want some N20, but i need help
  5. Wet or Dry on a 1998 SS
  6. mounting bottle in spare tire area
  7. help wire window switch
  8. 9.21 @ 146 at ATCO.
  9. Do i need to use blow down tube???
  10. Please help this nitrous and ls1 newbie
  11. where did you run wiring???
  12. Xylene and Toluene
  13. TNT POWER RING
  14. Did I get ripped off?
  15. purge tubing/hose question
  16. Bottle size question
  17. how big of a shot with factory fuel sysytem?
  18. TNT or NX gauges
  19. TR6 @ .039 N/A
  20. MSD Window Switch Wiring
  21. Questions on 5177 100 shot kit?
  22. Problems with grommet?
  23. Safest Nitrous Setup
  24. DO i need to change timing??
  25. nos 5177 kit.. What purge? -4 or -6??
  26. Is anyone using -4an lines on there TNT wet kit?
  27. what's wrong with my second gear?
  28. low dyno numbers on spray...
  29. My nitrous filter is leaking??
  30. VENOM nitrous owners please
  31. Dry kit jets question
  32. Dry kit jets question
  33. TNT owners inside
  34. Where to get the cheapest accessories?
  35. Have question reguarding TNT kit?
  36. Question about NX nitrous relay
  37. Dual Purge Set Up Questions
  38. Tuned for N/A-But want to run a 100 shot?
  39. Where can I get ~8' of tubing for NOS purge
  40. Auto cars with 3.73s running nitrous
  41. Which dry kit??
  42. Bottle Heater Question
  43. all NOS and NX direct port users come inside
  44. Would you rather be blown or inhale the laughing gas....
  45. Anyone have vid of exploding dry dyno run
  46. Getting bottle filled in Pittsburgh Pa area
  47. Before/ After MAFS?
  48. Do i need fuel pressure gauge with juice??
  49. nx wet kit pill size
  50. is a dry kit easy to hide? Also.......
  51. NX Wiring Question
  52. NOS 5177 and Ramchargers Timing Tuner
  53. TNT F1 and 85 mm MAF
  54. Bottle Mount
  55. Iridium plugs
  56. Need Data on Spray
  57. Ever order from Ultimate F body??
  58. MSD window switch on 98 Trans AM
  59. Hidden Nitrous System (C5)
  60. anyone ever hear of xylene hurting a noid?
  61. Can u flat shift with juice??
  62. CompuCar bag kit?
  63. help, are the noids sensative to heat?
  64. STOCK WS6 wanting to spray
  65. Question about Timing and Nitrous..
  66. which cam for nitrous!?!?!
  67. TR6 plugs anyone have the part number??
  68. NOS main feed line size
  69. Who's running the NX Gemini twin MAF kit?
  70. Direct port dry kit...
  71. Can you run 150 TNT shot on a 99 ls1?
  72. TNT VS NX kit: Help me pick a kit.
  73. Nitrous Mastermind???
  74. what did i screw up?
  75. Optimum A/F ratio on spray???
  76. NX System
  77. who do you think makes best kit?
  78. Tough decision???
  79. Detonation on TNT 100 Shot-Help
  80. where the heck is the nxl???
  81. Any way to use 85 mm MAF and TNT power ring?
  82. MSD
  83. NX Direct Port Finished
  84. Wiring diagram??????
  85. Track Safety Requirements?
  86. What REALLY causes nitrous backfires
  87. 150 shot at 5800 feet?
  88. where to buy 100 shot jets??? and other products
  89. Do I need tuning with a WET kit before I spray?
  90. I think T.N.T ??
  91. A (not so) quick TNT wiring question
  92. Question about why purge isnt working right.
  93. NOZZLE DIRECTION QUES?
  94. Question about the TNT F1 Dry Kit
  95. What kit is best w/K&N FIPK?
  96. Bottle heater question...
  97. Pros/cons of NX Gemini (MAF) vs. NXL kits...
  98. How to acitvate 2nd stage???
  99. nos dry kit single nozzle?
  100. 03 cobra forced me to do it!!
  101. Where's the cheapest internet dealer for NGK TR6 plugs?
  102. 224/224 .563 114LSA Good for 100 shot?? and 3500 stall
  103. NOSzle Installed - Pics
  104. want NOS on 5.3 help
  105. TNT F1 kit...
  106. Wavy torque curve. Please help!!
  107. tried nx100 on a tp4400 3.23 geared car.
  108. Can you turn a dry kit into a wet&dry kit?
  109. 3600 Vig and NX wet kit?
  110. Read something maybe some of you might be interested in....
  111. Mallory 685 Ignition or just a window switch?
  112. which nitrous is better
  113. TNT wet shot users/ what's your maf? ends?
  114. HP limitations of stock 2002 Z06 fuel pump(s) nitrous related
  115. Trying to pick my next mod???
  116. C5 Nitrous problems
  117. Tony from TNT or anybody else????
  118. Any update on NXL's release?
  119. Window Switch RPM
  120. Baby nos
  121. Change from stg 1 to stg 2 dry setup?
  122. The safest kit?
  123. Times with a TNT 100 Kit and....
  124. F2 TNT anybody
  125. why N20?
  126. nos kit for a lt1 and ls1
  127. Nitrous Works Kit (WET)
  128. N2O questions
  129. Installing NOS
  130. Need to learn Everything about using GAS on a LS1 !!!!
  131. slp 85 maf work w/ tnt wet kit?
  132. Need Descriptions of two NOS Part Numbers
  133. ignition guys I could use help locating a couple of things
  134. Wet or Dry? ...That is the Qeustion!
  135. DRY KIT BOTTLE PRESSURE
  136. window switch?
  137. Can I do this
  138. Mounting a switch to the shifter
  139. bolt-on motor with a 200 shot dry
  140. Custom NOS dry kit, I need some things, where to get them?
  141. TNT Wet Kit
  142. Nitrous Setup
  143. Antone had problems like mine??
  144. stock times with 100 shot
  145. NX Wet Kit - Basic Install w/ Pics
  146. 382 and a 150 shot
  147. Interesting item for big shot dry guys
  148. 10-bolt + nitrous from a roll, safe??
  149. Having issues spraying 300!
  150. Am I missing anything?
  151. Can I run more nitrous with a progressive controller? move up to 300 rwhp
  152. TNT Purge Differences?
  153. Sprayin with a 4.56
  154. t.n.t or n.x system?
  155. TNT F2
  156. Please help me quick!
  157. How big to go on Injectors?
  158. What will I need to change the NOS Dry Kit to a wet kit???
  159. The long awaited NXL pic.....
  160. NX Fuel Pressure Safety Switch ?
  161. 500 RWHP..will my car be ok???? HELP HELP
  162. TNT Force 2 Kit or NOS Dry Kit witch is better
  163. SHOW ME YOUR SWITCHES !!! ! ! ! ! !! !!!! !
  164. is this too much?
  165. Would this work?
  166. zo6 slave and master fitting f-body
  167. WTF!! Nitrous Freeze!!
  168. Anyone hooked their bottle opener to their ASR?
  169. Safer than the Venom VCN2000
  170. NOS Brand jet sizes
  171. Can NX bottle warmer tap into defroster for power?
  172. help with timing tuner !!
  173. Looking for a GREAT Nitrous cam!
  174. Whats the difference in a TNT F1 kit and F2?? diff solenoids?
  175. intake?
  176. what do i need to run tnt kit?
  177. What is a good fuel pump for nitrous?
  178. Are TNT N20 jets different than NX jets?
  179. HP limit for a -4AN main feed line...
  180. MSD window. What wire do I cut into for TACH?
  181. MSD window. What wire do I cut into for TACH?
  182. Have direct port nitrous question?
  183. BOTTLE MOUNT QUES?
  184. Paging Diamond, and other N20 Internal Gurus!!!
  185. Got walked, ready to bottle feed ASAP, need help.
  186. the little v6 that could
  187. Best Nitrous kit for me? NXL or just the NX wet system
  188. Best Pistons and rods for N2O?
  189. Need help with fitting selection
  190. NEW CAM, WILL IT BE SAFE TO SQUEEZE ON IT?
  191. MSD RPM Window switch c5 corvette
  192. Should I replace my head gaskets for a 125 shot?
  193. Do i need to change anything with 100 shot "wet" ??
  194. Nitrous pressure gauge stopped working, where's the best place to get NX stuff?
  195. Wet Kit or Dry Kit??????
  196. QUESTION ON TNT POWER RING
  197. TNT F1/2 users 200 RWHP Shot questions.
  198. I NEED A 1.5" PRESSURE GAUGE!!
  199. Dual stage or progressive controller, which is better?
  200. Need Help with jets sizes
  201. LS6 Intake w/ TNT Wet Kit
  202. wondering where to get a bottle warmer for 15# bottle??
  203. PLZ post pics of ur purge
  204. Air Temp And MAF ???
  205. 50 shot wet?
  206. anyone ever run nos with 1 super powershot noid?
  207. Kenne Bell Boost-a-Pump?
  208. Q on when to hit NOS with stock rear?
  209. Q on when to hit NOS with stock rear?
  210. Plugs for big shot?
  211. Spraying over 200, need input...
  212. HOT: NX kit relay wiring... which wire is which???
  213. The life of my motor will depend on your responses!
  214. How much timing with 150-200 shot?
  215. Nitrous Works
  216. any of you NX guys wanna make some money?
  217. E.T. Questions ? ? ? ? ? ?
  218. 4.10 or 3.73 when spraying???
  219. Hey Guys....
  220. Conveting a TNT F1 kit for a LS1 to work on a LT1
  221. How have you hid your nitrous?
  222. Stock 2001 fuel system enough to support heads/cam and a 100 wet shot?
  223. what to expect?
  224. Max Compression for a 200-300 Shot
  225. Nitrous Express LS1 NXL w/Rail
  226. Spraying in 5th gear??
  227. Compilation of Nitrous Direct port photos within
  228. Paging TONY TNT
  229. Best Mixture Distribution Dry or Wet
  230. Safe to spray TNT 250 RWHP (310HP) shot on forged pistons, stock rods/crank??
  231. Track and NO2 questions
  232. HPP3 Tuning with N2O??
  233. At what RWHP level do you guys change the stock intank pump?
  234. Who had the NOSzel DP pics?
  235. Time for WB.
  236. Best dry kit setup?
  237. TNT Conversion kit & some questions
  238. TNT kit without the power ring
  239. 2 soleniod, 1 relay
  240. Spark Plug Question
  241. Progressive Controller
  242. can I spray this setup?
  243. NX remote openers back in stock!!!
  244. New 5177
  245. help w/ nitrous!
  246. Custom H-11 Head Stud Kits F/S
  247. can i use nitrous on a road race course?
  248. honda ?
  249. MSD vs Harlan window switch
  250. possible to convert carb system to FI?
