View Full Version : Nitrous Oxide
- Another Directport for a Vette...
- Viton is holding up.
- Blow down tube for bottle between rear seats
- Safe to run 28* timing on 50 shot
- Odd electrical problem raised idel when armed
- LT1 plate system?
- Paging Nitrous Dave
- Dyno Tune Nitrous
- Z06 with Nitrous guys come in (and C5's)
- ? about halo kit
- Nitrous Outlet Track Truck
- Spark Plug Question
- Brand new dry kit
- NX Max 2: bare mininum to turn on
- purge not working
- solenoid fittings
- Nitrous today!
- check out my A/F on 200 shot.
- pulling timing-how much power loss?
- The white Z is alive!!!!!!! ls2 fired up!
- Just left the dyno. No more nitrous for me
- Lots of 250 wet shot questions.
- stick with the NX nozzle or get a Nitro Dave's plate
- Need help with jet size!!!
- How much spray for a LT1
- Master Blaster purge kit from dynotune
- NOS Bottle Heater question - Wiring
- Wiring on bottle heater getting hot
- Anyone have a wiring Diagram for NOS Brand BTL Heater?
- Pitiful times on 90shot
- sprayed the 200 shot lastnight
- finally installed and first spray
- Cold Fusion Jetting for 150
- Jimmy Jams wiring question (or any switch panel for that matter)
- Spray/Cam
- how much spray?
- fuel injector cleaner?
- new time with daves plate.
- wtf......
- WARNING: stupid newb question :WARNING
- Solenoid Testing / Rebuild
- i need a keyed 12 volt source asap
- Need Help Please?????
- Progressive controller
- Bored at Work / Part Two
- Nitrous Help
- Descreen for dry shot?
- how much n02
- Big News From Nitrous Direct!
- Electrical problem need some help
- most nitrouson on ....
- Timing tuner and NX TPS?
- Safe A/F ratio for 75 shot?
- Another N20 video...
- How much can i handle
- NX Injection Rail ?
- Newbie's first time TNT install pics
- New to nitrous!!
- TNT micro switch
- Pics of Daves Plate Installed!
- zex jets with nos kit?
- 150 shot and 91octane?
- Knocking with new wet install.
- How much timing do YOU pull?
- didnt want to do this, getting crap about dry, help with an argument
- Modified LT1 /TPI throttle body
- Whats needed to fill your own bottle w/o a pump?
- Change from BMN to Timing tuner?
- no purge cloud when purging
- lots of nitrous ? please help
- Best Set Up For Ms3 6spd???????
- ESP's 99 Hardtop Hoss 25.5
- Going to track
- Is my cam safe for nitrous?
- Fuel Trim Bank 1 and 2 too rich?
- Need dry setup pics please
- Nitrous bottles, opener, and nozzles for sale
- LS1 newcomer
- Possible to spray a 125 shot with TNT?
- Im hooked
- TNT owners
- Opinions on MSD's digital window switch MSD-8969
- HP/Weight calculations?
- My A/F ratio went to 12.28 to12.94 on one run for like three seconds on nitrous!?WTF!
- Picture of my nitrous setup
- wideband sensor location???
- Here's my (stealthy) install.
- My old C5.. numbers to support the theory
- Another Dry kit hits hard video...
- dry or wet?
- Pics Of Bottle Mounts
- regular efi for ls1 car?
- Moving from "Dry" to "Wet"
- Sweet Deal here!!!!
- Advance and 250 shot (LT1 engine)
- new times on the juice
- Window switch
- Looking for an nitrous A/F ratio cut off switch to use with my wideband.
- 97 SS Nitrous Kit??
- Sponsor/Vendors of Nitrous Solenoids..E85 chat...
- Friend's Install Pics
- What do you guys think about this deal?
- For those using timing tuner
- dual shot? or not
- Thinking about running a system on my T/A
- How long does it take your 15lb bottle to heat up? Is my heater weak?
- What's the temp to pressure ratio?
- Wanted nitrous
- Like the guage instal??(a/c vent)
- Injector Size for dry shot
- Spark Blowout symptoms
- update pics! getting close!
- dual stage results
- what gap for TR7's
- How many runs with 10lbs bottle and 150jets
- Timing tuner issues when Spraying above 5500, who understands there TT instructions?
- need new feed line
- Enough Fuel?
- sprayed 100 shot for the 1st time!
- anyone in here running flycuts?
- Your thoughts on my dyno...
- track results
- Do you think this is resonable?
- How Much
- how much is too much
- What head gasket and bolts with spray?
- Should I use Nitrious?
- Presuring Coolant on the spray
- Severe detonation on 383 LT1???
- Nitrous guys with standalone fuel system
- Gages for A-pillar
- Buying TNT
- NOS NOSzle Poll
- Purge ?
- Diagrams
- on TPS which is output wire?
- NX jet size????
- nitrous valve thread size
- Why more power with FI vs. Nitrous
- May Nitrous Specials..
- Need pics, Switches, Bottle mounts, systems...
- 2002 WS6 with TNT 150
- Quick Wiring Question - NOS Opener
- Switches
- How much nitrous on heads and cam stock block ls1
- Green straps
- Need info on nitrous
- TR55 to TR6 plug question!!
- What System to buy?
- what to buy?
- Fuel Noids and Ethanol Fuel?
- Fuel Lines from Test Port to PS Head?
- FJO install question!
- New Anodized Bottle
- Where's everyrone mounting their TT's
- USed TNT Kit
- safe to spray
- How much space required for 10lb bottle?
- Help: Need some input on location to install a Nitrous Gauge in my 02 Camaro.
- How much is enough
- Window switch setting
- nitro dave/860 f-body bottle mount....
- Pics of 2 bottles?
- cam?
- affraid of bog
- ZEX Purge kit = GAY
- Spray on 408/Procharger Setup...
- FPSS and FJO wiring question
- Using larger Jets
- How to use Nitros ??
- Harlan Window & FPSS
- Taking time to smell the roses!
- When do you know when you motor is ready for NOS?
- Nitrous Horror Stories
- My new setup...
- Rebuilding NX Solenoids
- Harlan window help
- How Lean Can I Go ?????
- Thinking about some spray
- Pics of my TNT Setup
- Best way to test nitrous
- Right RPM for window switch with 3000 stall
- Stalling When Nitrous Is Engaged!
- NX Wet kit problem.
- where to put nozzle
- Nitro Dave Rocks!!!!
- plug gap and timing
- Need your help.....
- Monting a bottle between the rear seats
- Hotcam Kit good with Nitrous?
- Um, stupid question.
- need some guidance and info on a Dual system
- what jets can i use?
- Dartron Sleeves, How much can you spray?
- Please describe how n2o feels on activation.
- Bottle has nitrous in it BUT!
- FJO Progressive Controller Settings
- air/fuel on n20
- Vinny does yet another Dave Plate (Beers Install)
- Need someone to look over this Diagram...
- HSW... help on jetting (a question..)
- Questions about Setup
- n20 ?s
- Purge Line Question
- where did you mount your Timing Tuner?
- Question for thoes who monitor EGT's
- Dyno tune nitrous kit
- Newbie on Nitrous, input.
- Too much timing?
- BEER Switch Panel - Now for the F-Bodies
- solenoid wiring question....
- Direct port ?'s
- Nitrous Related Wiring
- Ethonal gas and Nitrous question?
- Different fuel system for Direct Port?
- Brainstorming nitrous bottle mount...
- Hybrid on N2O fuel system?
- nos dry kit
- Jetting too rich or slightly lean?
- Bottle Heater Wiring
- Blow down tube adapter
- Well decided to.....
- I found the car... how much should i put on it? ( spray)
- Someone explain analog n20 gauges
- blow down tube
- Dry kit questions?
- Is Low DCR Good For Nitrous?
- Spray on a boat????? Crazy Idea!!!
- injectors?
- stock nitrous shot size???
- Do we need a sticky with all the wiring diagrams?
- got my purge hooked up =)
- Wiring help
- important nitrous question... tuned motor = diffrent jetting??
- Jimmy jams switch
- Nitrous Flow Problem
- what would i need
- Help...fuel solenoid keeps running
- Why is my nitrous gauge still lit up?
- digital window wiring ???
- Switched power source
- May Sales
- need wire diagram for.....
- Am I asking for it???
- Bad idea?
- Trick two stage wiring question
- May Sales
- bottle mounting bracket ??
- plug choice
- rpm - tach wierd issue 7 k bounce!?@
