PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Ahh yes another noobie nitrous question
  2. dynotune plate kit questions?
  3. Nitrous Outlet 102mm Plate .. What solenoids bracket ??
  4. New motor...base timing to start with?
  5. Finally got some runs in on a small shot(408 LS3)
  6. help me with my cam choice
  7. Does anyone make a ls1 plate with lines that connect on pass side?
  8. what jetting are you NANO guys running
  9. Help with Unusual Spark Plug Issue
  10. A few questions about my n2o setup
  11. What if fuel selenoid fails??
  12. Next accessory??
  13. New to N2O...
  14. help placing nozzle
  15. Check my wiring idea plz
  16. Colder than a 9
  17. 100 shot
  18. Made In The USA?
  19. can br7ef plugs making my car shake?
  20. two different plugs for 100 and 150 shot??
  21. quick question
  22. Considering Nitrous, Please Help!!!
  23. Plug recommendation....
  24. fuel pump booster
  25. Went from single fogger to Nitrous outlet plate!
  26. HSW has been great.
  27. Got some sick times lastnight!
  28. 1200 vs 900psi
  29. Safe
  30. reading wideband questions
  31. jimmy jams ashtray switches
  32. Nitrous before a cam?
  33. How much can I spray. LS7 motor diamond pistons
  34. Need to know were this solenoid bracket mounts!! Help lol
  35. Need more
  36. nitrous outlet is out of window seitches, next best
  37. Just bought a kit
  38. Nitrous: a slew of questions
  39. Is an exhaust mod necessary?
  40. Nitrous problem
  41. Looking for bottle mount
  42. Stepping up Setup looking for advice from experienced users
  43. Do I need a fuel pump to spray 150?
  44. Timing controller options
  45. Nano..Worth it?
  46. LS1 Nitrous motor help
  47. Jet Chart for Low Pressure Stand Alone?
  48. MicroEdge+ issue?
  49. Blow down routing question
  50. nitrous supply line routing
  51. shift points on 200 shot?
  52. Nitrous and transbrake wiring system
  53. Spray for a DD
  54. New Best 4.93 @ 148 with video...
  55. 9.15@145 (swapped car) Big thanks to Nitrous Outlet
  56. Carb'd 5.3 on Spray
  57. Need help with injectors?
  58. nitrous refills
  59. progressive controller settings
  60. Sneak peek and test software - Lingenfelter nitrous controller
  61. Nitrous with fast Intake??
  62. Adding 2nd stage, Question....
  63. ls1 N20 cam info
  64. nos mini controller problem
  65. Injector Duty Cycle?
  66. Tune for nitrous ?
  67. Couple questions about nitrous PLEASE HELP
  68. 100shot on a bolton tune.
  69. My Carb & spray Setup....Help
  70. Removing line from rail. what "cap"
  71. How much nitrous with .022"/.024" ring gaps?
  72. would my valve springs take the abuse?
  73. x275 with nitrous.
  74. fuel pressure
  75. Does anybody ever answer the Phones at Harris Speed Works?
  76. nano
  77. Dry, How much is to much??
  78. How Much Can I spray on my N/A tune..
  79. stock (spray/cam only) lq4 in 1955 chevy
  80. Nano ?? for big hitters, sponsor's
  81. spark plugs
  82. Who makes the best Direct Port System for LS EFI cars ?
  83. Help Problem with dedicated fuel system
  84. 408 on Spray
  85. 100+ Shot is it safe?
  86. Solenoid Question
  87. Bottle mounted in the spare tire area with battery relo?
  88. New kit on 5.3 carbed s10 MSD 6010 help
  89. Resistor Trick question??
  90. Nano Questions
  91. harris speed works issues
  92. Help with nitrous plugs
  93. how much spray is safe on stock tune
  94. need advice about n02!!!
  95. FJO 1st Gear Lock Out Issues
  96. wet or dry?
  97. Is a 150 ok?
  98. MSD Digital 6 plus (msd 6520)
  99. Cam only F-BODY Nitrous Record
  100. how much spray could i use on a stock bottom end LS1
  101. nitrous popping
  102. whats the best nitrous pistons
  103. Which wideband sensor replacement?
  104. Huge thanks to brad@nano
  105. Place Jets at solenoid or plate?
  106. wiring woos
  107. Please varify plug reading 100 shot
  108. Hard top pillar Pod
  109. how to tell what valve
  110. One Fuel cell for NOS/pump gas ?????
  111. Which Pressue gauge for Pod?
  112. Shorter fuel line solenoid to nozzle
  113. Any one running a scavenge pump setup
  114. purge questions
  115. Nos 05169 90mm wet plate questions
  116. 3 LNC-002 left in stock..
  117. how much can you spray on pump gas?
  118. 250 shot, is direct port needed?
  119. 100 HP shot questions for a LS7
  120. Which fuel for standalone
  121. about to bite the bullet on a kit.
  122. Progressive controller question.
  123. How do I tell if I lifted the heads on the 200 shot ?
  124. what head gaskets are you favorite ?
  125. What plugs should I use?
  126. Lean spike at beginning followed by very rich....
  127. who runs br8s on the street?
  128. Switching from pump 94 to VP ms109, timing question
  129. Spark plug recomendation 100hp wet kit
  130. Should I be using two Widebands?
  131. What kit should I use?
  132. Ready to say F#$k it......
  133. Spraying 150 wet plate kit.. passenger bank goes lean
  134. Nano goes above and beyond
  135. Nitrous Outlet switch panel question
  136. Single plane with spray bars? Who has it?
  137. Anybody ever run a progressive on a M6 car ?
  138. Video Walk around of my nitrous 408 street build
  139. Where are the Baddest LS Nitrous cars?
  140. In search of suggestions for Nitrous tuning
  141. TNT Fuel solenoid repair kit?
  142. Am i ready for 200?
  143. dynotune digital gauge not working
  144. NOS Sniper kit jets??? Confusion
  145. getting tuned for nitrous, run not as good on motor?
  146. Plugs after 1st nitrous pull
  147. another msd window switch thread
  148. A few strange nitrous questions
  149. Fuel Pump and nitrous ?
  150. Looking for suggestions
  151. LNC-2000 Vs. Interface
  152. Nozzle Placement in Lid
  153. My Nitro Daves/Nano Nitrous 09 V
  154. Must have's for any serious Nitrous Racer.
  155. plate kit video
  156. Aem wideband wiring
  157. can anybody give me the actual math to figure out HP from Jet size or Jet from HP
  158. High Mileage LS N20 Question
  159. 98 camaro LS1 motor max for nitrous
  160. Please read my Plugs
  161. A few beginner nitrous questions
  162. Nitrous question
  163. 654 RWHP and 677 RWTQ on 250 Shot....appreciate help reading plugs
  164. LQ4 MS3 ls6 - 75 shot. Timing??
  165. question about wiring the purge solinoid
  166. Turning on Nitrous in mid run?
  167. N2O confussion
  168. NOS mini controller wiring ?
  169. who sprays a 200 on #7 plugs
  170. to squeeze or not to squeeze
  171. Nitrous with transbrake schematic, overview
  172. Spraying through the shifts Pros and Cons
  173. Went a little faster, now think high 60s are possible...
  174. Plug temp for E85
  175. gas and plugs
  176. wiring up
  177. Anybody like hi pressure better
  178. The most interesting person in the world..
  179. how big a shot b4 lifting heads?
  180. msd?
  181. TNT kit owners come inside
  182. Nitrous isn't activating...
  183. from 100 to 150
  184. Which window switch is best?
  185. 102 plates? Anyone used different ones?? Running into fitment issues, PITA...
  186. best setup for me?
  187. microswitch
  188. Free Shipping!
  189. Justin K"s NANO Assisted/Nitro Daves Camaro
  190. microswitch
  191. Will MSD rev-limiter chips work for the MSD window switch?
  192. Mallory 685 doesn't work with LT1 pcm
  193. nozzle vs plate, which is for me
  194. Line size for shot amounts.
  195. HSW No Longer a Vendor??
  196. Nozzle placement, Dynotune or NX kit (pics)
  197. NOS window switch won't program!!?
  198. nitrous wiring
  199. Best NOS Setup for Stock LS!
  200. Nitrous Express 20915-10 Universal EFI kit and 102 plate
  201. TNT kit worth it?
  202. Question about bumping to 125 shot and PSI presure..
  203. tr-11 on 250
  204. Wiring schematic help
  205. 75shot track results
  206. fuel pressure regulator ?
  207. Nos 2 stage or fjo controller
  208. Direct port nozzle?
  209. Who carries chrome or polished noids?
  210. NON-projected Tip Spark Plugs??
  211. Look what Brown did for me!
  212. Harris plate-anyone running >150?
  213. Heads!
  214. Nitrous question
  215. Dual stage options w/ Nitrous outlet plate & NOS nozzle?
  216. Nitrous question
  217. NGK 11's part number
  218. another nitrous question
  219. Tuning for nitrous.
  220. Need some help on a plug recommendation (non-ls but nitrous fed)
  221. Reassurance on nitrous lol
  222. single nozzle placement?
  223. Just some 200 shot questions?????
  224. 3 New Personal Bests..all in a row!
  225. Lashway Motorsports tests new 102mm Plate System!
  226. Mallory 685 help please
  227. First hit of da juice on new motor.
  228. where to tie in fpss on lt1 camaro
  229. Nitrous Express NXL hose inner diameter?
  230. nos bracket.
  231. Nitrous Outlet- Dual Stage 102mm Plate
  232. NX Intake Plumbing Special! 50% OFF!
  233. fuel for 200 shot
  234. Will a 255 be enough for me
  235. Less timing, less fuel = more power?
  236. Vortech G-trim + n2o?
  237. 102 mm dual stage?
  238. Fuel for a 150 shot?
  239. I've picked my poison...
  240. Newb trading for a kit. Help
  241. Need a custom length hose...
  242. Any Interest in a Group Buy for a Refill Pump??
  243. Microedge + with LNC-002
  244. 100 shot on a bolt on tune.
  245. Plate vs Fogger Nozzle?
  246. 200 Shot ok on LQ9
  247. Resistor Mod Write Up?
  248. gauges needed for nitrous set up ?
  249. Nitrous Plug Reading(Pics)
  250. Easy question...
