- DRY or WET???
- my new custom bottle for the challenger
- Safest possible?
- Noobie install almost complete!
- Any nitrous specific forums?
- 1 coil and 2 valves???
- Omg I Love Nitrous :)
- Fuel pressure regulator.
- Effects of E85 on Solenoids. Beware
- For Sale: NEW NX 90mm TB
- [rant] MAX2 [/rant]
- new numbers on spray
- cage mounting brackets
- Congrats 227hawk!!!!
- My bottle heater relay ground is getting hot
- Switched 12V @ the Fuse Box in 2000 TA
- 5177 dry kit install question
- Tuning car before nitrous?
- Input on the true facts on a Nitrous purge.
- LS2 timing retard?
- Quick Jet question
- Dean and Dynotune KICK ASS
- Nytrex Jetting?
- NO Digital dual window switch
- how good will my car act on spray with this cam?
- will the 5177 nos kit work on a v6 camaro?
- The difference between HSW Edge Vs. FJO Digital Progressive Controller
- WOT Switch help
- My C-5 Ashtray Panel Update
- 75 wet shot
- scott N2O direct!!!
- Progress pics!! lots done!!!
- progressive controller 4sale
- Carb plate for Dry shot?
- HSW Custom Hoses
- GM valves...hp limits?
- just a Question
- msd window switch-mode selector?
- FJO Green light not coming on?
- bottle in the backseat
- PCM #10 wire splicing
- Installing jets backward ok? Sponsors?
- 200 shot was fun!
- purge material?
- Converter anti balooning Plate??
- purge switch wiring question
- N2O not working
- Hiding nitrous
- polish my own bottle?
- bottle heater help
- finally sprayed the z
- Nitro Dave's Plate
- Car surging with spray???
- DynoTune Fully Automatic Adjustable Nitrous Bottle Warmer Kit – $99!!!!
- Purge Line
- Dyno Tune nitrous
- Ok Guy's I ned some help/suggestions
- Just ordered the plate from Dave
- Switched 12v source for vette?
- Verifying the dry shot is working??
- florida juicers...
- safest wet kit
- New NX Sytem...Any Advice?
- Need some help on getting a few things.
- need help
- Paging Scott N2O direct????
- where should I mount my bottle?
- What plug gap for BR7EF plugs
- About replacing the fogger
- Help me....
- Timing Tuner...how much to retard?
- Any MAF sensors better than others for a 100 dry shot?
- need to know how to hook up my nx tps box
- TR6 gap? on a 100 shot
- Vipper Install.....
- Looking for NOS Nossle system feedback
- Rockers And Nitrous
- What carb nitrous plate??
- Spraying 100 shot on 110k engine?
- Z06 + 100 shot results!!!! good mph!!!
- Is it illegal on the street?
- ZEX kit???
- Bottle angle question?
- NX Max 2 is up and running
- NX MAF 225 Single Stage
- Right RPM for window switch with 3200 stall
- Just wondering
- Anyone mounted a 5lb here?
- Want to win a race and scare someone.
- Rearend extender wiring Transbrake/linelock
- 96 msd window switch
- Go direct port or wet??
- Firewalll hole??
- Power supply relays?
- Mount Relays????
- Install diagrams
- What's to stop the Maximizer II from "failing"?
- Which one is the safety blow off adapter thing?
- average PSI of a full 10lb. bottle at room temp?
- Adapter
- How Much Hp(single Nozzle)
- Converting dry kit to wet kit.
- 125 shot?
- NOS Wet Plate System Installed
- anyone else have a problem with their bottle rattling?
- bottle warmer doesnt work anymore?
- Advise on juicing an 4x4 S10 v6
- Ls6 intake distribution
- z06 wet shot
- Filters
- Pulsing noids, is there a mininum...
- cutting out while spraying
- fuel pump for TNT? other stuff
- Going with NX, what is everything I'll need to be safe?
- life span???
- Anyone running nitro dave's carb intake elbow?
- Window Switch ?
- moving bottle into reaching distance@
- Anyone have a Maximizer 2 config file
- ZO6 Vette Help Please
- FS:::TNT F1 Complete with accessories
- New car and nitrous
- Nitrous of Trans break release???
- Suggestions on toggle switches...
- Need TNT Bottle Pic
- 98 stock bottom end
- should i 2 stage it
- any pics on installs?
- Where can i get a regulator
- would nitrous be a good idea?
- Changing out injectors?
- So I think I have too many switches...
- alternative to race gas?
- Nitrous Question?
- What does empty bottle feel like on Ls1 wet kit?
- Dual Nozzle
- Fjo
- nitrous effects on widebands...
- NOS mini progressive controler TPS signal?
- New time on our 05 gto
- Biggest shot on stock motor
- How much can you spray on...
- Bottle Bracket
- Building a Nitrous turbo car(DSM)
- GAUGEs
- GAUGEs
- GAUGEs
- Can I spray to 565 on a stock bottom?
- new to nitrous
- Indexed bottle, Filling it up tomorrow!
- 100 shot sotp feel
- How much would you spray????
- I had a nitrous backfire....
- Tuning Question
- Like my hiding spot?
- Dyno tune N2O
- How many of you have a stall and spray w/ 7.5?
- Nitro Dave's Dedicated Fuel Cell, NX Wet Nitrous Kit, and MORE
- WOT switch mounting
- Will it work?
- Nice add on for the vette...
- FPSS issues
- direct port fuel only shot
- Fuel Questions
- Hole in nitrous line!
- Injector question ?
- Plate vs Nozzle (LT1)
- A little something to smile at.
- 200 shot and Clutch.
- Nitrous & compression ??
- FPSS install?
- Dual Nitrous setup...Which Noid first???
- Track Nitrous Rules. What do I need
- Thanks Nitrous Dave
- Idle time video
- Cost of a good setup
- nos on ls2
- Nitrous Problem
- What battery?
- Harris Speed Works installation manual site no workie
- Flow testing.
- timing tuner wiring question?
- NOS fill station for sale
- Z06 pics!! N2O installed. not great pics tho
- Hooking up the NX WOT sensor to the TPS...
- Few questions concerning a vette, and need pics.
- bottle bracket question...
- TNT Nitrous Owners
- basic quick question
- Nx Direct port kit in For sale page
- Fired up my W2W/TEA 402 Nitrous Motor
- mwahahahaha let the fun begin
- nos mini progressive controller problems.......
- NX didgital window switch?
- ? for wet kit users
- Is 150 shot safe on stock shortblock
- N20?
- Another MSD window switch thread.....
- Mixing jets on F1 kit
- Save.. Save.. Save
- Recommend a change to the sponsors products...
- Simple Ramcharger Question
- All this new technology...
- ? about harris speedworks dry kit
- cheapest place for steel braided hoses?
- maf system vs twin fogger
- NX MAF system?
- TRex / big shot, progressive ramp..
- ran worse after nitrous at the track
- oo t/a what is the best way to retard timing for a 150 shot
- Ready for nitrous-which kit
- Throttle stuck open at track (Glad motor is in one piece)
- TNT F1 Jets
- mother bottle ?
- noid help pls
- Where to connect low oil pressure cutoff switch
- CF opener ?
- -3 to -4 8" N2O hose ?
- Want to convert my nitrous kit, have a few ?
- Need Fjo Help!
- Dry Shot Question
- Finally got my kit installed
- wire size for bottle heater Battery connect
- what wet kit for my ls1?
- install N2O ????
- Best MSD window switch and location
- whats the best jit for dry
- Nitrous doesn't activate from a launch
- nice setup for sale
- timing tuner question
- Dumb Question: Nitrous Wiring
- New Mechanical Remote Bottle Opener
- Iridium plugs?
- Fuel psi safty??
- dyno tune jet setting
- msd digital window switch(CYCLES)
- Dyno tune dry kit
- Window Switch Help
- seems slower on the FJO..........
- Tach wire for MSD Window Switch?
- window switch settings at the track???
- nx ricky question
- Angle of bottle question?
- Installing NX Wet
- Almost finished nitrous pics...
- Anyone have fouled TR6 often?
- Wiring diagram anyone??
- Wiring Help..
- Changing Spark Plugs w Nitrous
- nitrous set up i am thinking about
