PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Fuel Pressure Guages
  2. Another newb question...
  3. 4cyl kit on ls1
  4. nitrous works??? is it any good
  5. Any good pages on how to plumb a direct port
  6. NX wet kit or TNT wetkit??
  7. nitrous for and lt1
  8. how much nitrous
  9. Please help guys! In the middle!
  10. What should air fuel ratios be when spraying.
  11. New TPS switch, The Trigger!
  12. NX Remote Bottle Opener
  13. Need help installing purge kit..
  14. What will a 26lb inj and stock pump support
  15. Trouble shooting a NOS dry kit.
  16. NX Dealers...
  17. NOS line getting new ends????
  18. spark plug gap
  19. msd digital window switch?
  20. 175hp TNT jets?
  21. Need help installing Nitrous Express Bottle Opener...
  22. Maximizer II issues
  23. Just ordered the LS1 125 Dry Kit,
  24. Question for DYNOTUNE or maybe someelse can help....
  25. 5177 kit still not working...
  26. Fittings clogged
  27. Problems...
  28. Can I use a single TNT nozzle for 100 shot?
  29. Dry users, a mech pressure regulator for consistant runs
  30. Switch questions
  31. nitrooo dave, 90/90 DP?
  32. 5177 kit jetting
  33. TNT kit = IMPRESSED
  34. Solenoid/line Selection (help)...
  35. Should I go with a bigger shot?
  36. Check out this knucklehead nitrous install
  37. paging 383LQ4SS
  38. what kit are you LS6 guys running ?
  39. Race challenge
  40. Sources of switched power
  41. NEW Nitrous Progressive.... MULTI-POINT RAMP
  42. Darton blocks and NO2
  43. Sneak peek at the LS1 plate.
  44. halo kit
  45. NX Jetting Chart Question
  46. How many runs?
  47. nitrous quality
  48. Testing new system
  49. 15lbs bottle between rear seats, ooo yes. Pics inside.
  50. max effort cam for nitrous
  51. stall
  52. denso iridium plugs
  53. Question about NX switch panel..
  54. TNT Nitrous Filter??
  55. The Mark! Digital nitrous bottle contents indicator!
  56. Twisted Sanity Nitrous Controllers
  57. cam + nitrous question
  58. What makes the best street car Nitrous, Supercharger, Turbo?
  59. Why not direct port?
  60. Wiring help
  61. Want to build a low 10/ high 9 street car
  62. C6 10.96@128 on spray
  63. window switch
  64. ANOTHER Bmn Window Switch Problem
  65. Quick question reguarding WOT switches.
  66. Need Help...wire came out during cam install.
  67. considering a nx setup need experienced users opinions
  68. pirhana nozzle?
  69. all motor on tr6's
  70. need help with nos system
  71. does my dyno with tnt kit sound ok?
  72. Bottle bracket
  73. 55 and 33 jets? and wierd start up today on test run
  74. Need help hooking up Maximizer 2
  75. finally
  76. First Time On
  77. Looking for C5 direct port pics
  78. 100 dry sot on 2000 injectors?
  79. solenoid mount ?
  80. zex direct port kit for fast intake
  81. NJ nitrous permit
  82. help
  83. Need help piecing together accessoreies for my tnt kit.
  84. Bmn Window Switch Problem
  85. New LS1/LT1 plate systems!!!
  86. better pics of my setup.
  87. Question About NX Electric Bottle Pressure Gauge
  88. help me choose... please
  89. Is a purge really neccessary?
  90. should I buy the TnT power ring
  91. Best Way to Touch Up a White NX Bottle
  92. need new nitrous set up
  93. 15lb NOS Bottle weight
  94. Another New Product! The Angle!!!
  95. Refill question
  96. NOS plate for LS1
  97. Who has the best price on....
  98. Anyone need a NOS fogger nozzle?
  99. WOT Mounting ?
  100. poll, what will hold more power????
  101. Gap on NGK TR6's for 100 to 150 shot?
  102. Who uses just a WOT switch? (no window switch)
  103. purge plume
  104. Custom Billet micro switches...
  105. h/c ls1 going to NO2
  106. Fuel Pressure Riser
  107. 175 Shot + SES
  108. Does a dry shot need to be before the MAF??
  109. nitrous problem need help asap
  110. 28 degrees and 75 shot?
  111. Tapping Fuel Rail Problem
  112. 125 shot
  113. How hard is it....
  114. First dyno on the spray?
  115. soleniod question
  116. What shot to run??
  117. BMN, Shift Light, Rev Limiter Settings
  118. ls6 spray?
  119. NOS Bottle Opener ?'s
  120. need help please!
  121. Newby in Nitrous, whats the safest setup
  122. fuel setup for dual stage...
  123. -4AN bottle nut
  124. New Product!!! Progressive Nitrous Controller
  125. TR6 affecting performance?
  126. Whats the point of two solenoids
  127. New To Nitrous: Help Me Choose A Wet Kit
  128. close to stock 100 shot times...
  129. Dry shot. any suggestions?
  130. How many amps does a ZEX bottle heater pull?
  131. race gas and nitrous
  132. Can I really?
  133. TR6 problem?
  134. Fuel Tap Question
  135. thinkin about nitrous...
  136. Most Reliable RPM Window Switch?
  137. HPE Dual Nozzle Stock TB Ring for sale...
  138. Need a Part
  139. so at what point do i need to upgrade my fuel pump?
  140. My Custom Nitrous Bottle Pic.....Take a look
  141. Questions about tnt power ring..
  142. Which is betetr for NX?
  143. Who Runs an NX TPS Switch Right Now?
  144. Drag Strip Results From Today!
  145. Who needs a BMN window switch?
  146. New to Nitrous, here's my mods, how much can I spray safely?
  147. hurry nitrous prob...
  148. Want to purge only when system is armed - NX switch panel gurus step inside
  149. TNT F2 help please??
  150. timing tuner help
  151. 134k still SPRAYABLE
  152. is it safty
  153. can i spray a 100 shot on a tci4000?
  154. Solenoids not firing! Help, races tonite.
  155. I think im gunna need the spray....????
  156. how safe
  157. Dyno TR6 plugs and 05177 NOS kit
  158. My car leaks oil after I spray!!!
  159. Official Nitrous Pic Thread
  160. Ramchargers timing tuner/window switch. Has anyone used one?
  161. Anyone wired their heater w/o relay?
  162. Nitro Dave Comes Through Again!
  163. Not making all my power
  164. which jets?
  165. My new dyno numbers
  166. Nitro Dave
  167. C5 ground question.
  168. nitrous with a stock 4l60e
  169. need help wireing
  170. BMN = The DEFINITION Of Customer Service!
  171. quick questions b4 installing tonight
  172. Got Zex?
  173. Plug ?
  174. 10 LB Nitrous Bottle + 75 Shot =
  175. 05 GTO I need a little help. IF you have an osilascope.
  176. How much timing to pull???
  177. nitrous help please
  178. Gas vs N2O prices
  179. My TR6 plug???
  180. TNT nitrous jets?
  181. Window Switch Wiring
  182. FS:Autometer ultralite electric Nitrous gauge
  183. Nitrous with a Procharger???
  184. can I make a dry system to a wet system
  185. 100 shot on stock motor need advice
  186. Clash Race this weekend...
  187. The Rolling Nitrous Store!!!!
  188. A/F Ratio
  189. OK Todays Nitrous Quiz...
  190. supercharger with nitrous
  191. nitrous
  192. Detonation woes.
  193. 10% off all Nitrous Kits and Accessories!
  194. 101 + octane
  195. Window Switch setting
  196. 115 dry shot, extremely rich and slow!! Help
  197. nitrous dave kicks *ss
  198. NX Guys WET, WET, WET
  199. Holley Blue pump for stand alone single fogger
  200. Jet question on NOS dry kit
  201. 100 shot dyno run.
  202. need advice on a 5.3
  203. Dry 2 stage through Fogger Nozzel Help Please
  204. NW WOT switch FS
  205. Dry Kits - Nozzles
  206. is this a good "kit"
  207. can I spray a 100 or 125 shot on stock timing
  208. Bottle pressure gauge Q's
  209. First Nitrous Dyno Numbers!
  210. Installation 90% complete - need to test system - question
  211. Dynotune Nitrous Special of the Week! Remote Bottle Opener!!!!
  212. First N20 passes..Pics of plugs inside...
  213. Tnt ?
  214. anyone useing the nitrous works system?
  215. Need some opinions/information
  216. Need Dyno Tune instructions for TPS.
  217. Nitrous for towing
  218. Colder Plugs
  219. Another Dry Hit, Hits Pretty Good
  220. NOS question
  221. Is anyone running a Zex kit?
  222. Need pics of FAST 90 intake with TNT power ring
  223. Video-C6 on spray Vs kennebell cobra
  224. BMN Window Switch Install
  225. Nitro Daves Nitrous Outlet
  226. Alright guys I need your help.
  227. EFI Nozzels
  228. 150 shot, stock fuel pump?
  229. Best deal ?
  230. hey guys new member here
  231. Can someone look at my wiring and confirm?
  232. install help-PHX, AZ
  233. Nitrous issues need lots of help...
  234. Can i run a 200 shot on stock timing?
  235. The one week sale.....
  236. 200 shot for a Civic?
  237. 10% Off All Nitrous Kits!!!
  238. Bottle presure Q
  239. NX kit/system question
  240. Dry 100 Shot or Wet 100 shots?
  241. Wiring question, any ideas?
  242. mounting the bottle
  243. Is it possible to run a 200 shot (wet) on stock motor, and be safe?
  244. quick easy, probably dumb question
  245. Want To Spray The Car Badly... Look At This Graph!!
  246. Car running good now. 05177 kit
  247. Do I need to jet richer/leaner going to 100+ octane gas?
  248. dry nitrous idea
  249. Nozzle mount for hard tubing?
  250. Can you use hard line for nitrous bottle to solenoid?
