PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Holley hi ram with a plate?
  2. What are my true limits?
  3. Spark plug reading help
  4. Need suggestions on nos
  5. how much spray on a goat?
  6. LNC2000 Questions
  7. 150 shot on 100% stock 2000 ls1?
  8. What should I buy ?
  9. Nitrous Outlet window switch? Pics inside
  10. Will cam work with nitrous?
  11. 150hp shot, When should I lock my triple disc converter?
  12. Nitrous breaking up PROBLEMS NEED HELP
  13. Holley High ram LS7 with Dual stages by Alzilzil Racing
  14. Pistons for spray??
  15. Nitrous System install with Pics
  16. hesitation
  17. First outing in 3800lb. 6 speed 408=6.50@107
  18. Going through my new car and found this...
  19. Question about Fuel Gauge on Remote Fuel Tank
  20. Anyone sprayed a stock ls1 w/ Trex
  21. brīs 8 plugs 200 shots what gap
  22. C5 dies on nitrous
  23. help please, why doesnt it spray?
  24. Dry kit reco. - C5 Vette
  25. need help wiring
  26. Opinions: Whats it gonna run on a 150 shot?
  27. Programmer and 2 step wiring. HELP
  28. Need help with HSW Interface
  29. Can I see your dedicated fuel systems
  30. E85 / n20
  31. LS7 2 stage intake
  32. Nitrous Outlet Billet Valve VS The Competition
  33. N.O.S 2stage TPS/Window switch?
  34. Opinions needed on a simple 125 kit.
  35. Assistance Reading Nitrous Spark Plugs (first timer)
  36. NANO Nitrous 3000 Universal Kit + extra
  37. Plate kits
  38. Need Help
  39. nitrous delay
  40. first gear lockout for nitrous
  41. Is my cam good for juice?
  42. hitting the track up tonight searching for new best. need quick input!!!!!!
  43. Nitrous Outlet Direct Port Sale!!!
  44. Average price for nitrous install..?
  45. Bottle pressure
  46. nitrous/fuel jet question
  47. HSW 90mm plate with stock throttle body?
  48. direct port nitrous with a Maggie? help
  49. Ditch timing tumer and go with Microedge???
  50. Spark Plug Indexing
  51. Nitrous help!
  52. Need some opinions on a cam
  53. GM High Tech cover next month
  54. dry to wet shot
  55. solonoid leak help
  56. Stand alone overkill??
  57. Speaking of stock shortblocks, Ls3 record?
  58. 6 speed guys whats your nitrous set up, new to spraying a m6
  59. Old school noids!!
  60. Nitrous Help/Opinions
  61. Cam Swap before and after results
  62. injectors advice
  63. Wet kit on top of dry shot....anyone tried this setup?
  64. Stock Bottom End record fell tonight!!!!!
  65. Inline/helper fuel pump?
  66. N2O / Microsquirt
  67. Introducing The New Nitrous Outlet Bottle Valve
  68. Nitrous Install advice
  69. nitrous oxide stand alone fuel cell
  70. Wiring help/tips
  71. spark plug ?
  72. 1993 Mustang, LY6, Nos Plate(Start up video added)
  73. Shark Nozzle question----which way does it mount in plenum or bellows??
  74. NX express Shark Nozzle line size
  75. Lingenfelter LNC2000 2 Step Wiring Help
  76. NX Good Customer Support Thumbs Up
  77. Help With Tuning Dyno Attachted Plug Pictures Soon
  78. LS1 Fast Direct Port by Alzilzil Racing Perf....
  79. Anyone running a Holley Hi Ram and plate set up?
  80. LS3 150 shot problems
  81. Need help with nitrous build....totally nitrous n00b here, so help me spec it out
  82. I need relay help (Ive read all the stickys)
  83. Introducing the Nitrous Outlet Puck System!!!
  84. Any negatives to running BR7EF plugs when....
  85. Only 3 pulls on bottle?
  86. In need of quick wiring info
  87. 8.87 @ 153
  88. Car won't idle with BR7EF's?
  89. Another lnc-2000 question..
  90. injectors
  91. Nitrous breaking up PROBLEMS NEED HELP
  92. 75-100 hp dry kit , info please
  93. lnc2000/twister/whatever placement
  94. 2 stage shots
  95. low hp #'s on 75 shot
  96. Ok... Lots of searching, no answer. Plugs...
  97. Cam and 75 shot
  98. Frost tune w/ nitrous
  99. Help with trick perfrormance controller
  100. Lingenfelter LNC2000 Diodes
  101. FS:L92 Victor Jr. With Spray Bars SOLD
  102. got bored, made a switch panel.
  103. Nitrous Plate Location
  104. Anyone running a n.o.s ls2 plate on a low pressure sand alone?
  105. Can u port out a n.o.s ls2 nitrous plate to fit 95mm intake combo
  106. Pushing Water
  107. about to spray
  108. Am I going to have a problem with the stock bellow?
  109. 300 shot on Stock Forged Block Question
  110. The Rebuild of the Nitrous Outlet Drag Radial Car
  111. Stock Cube ls2 build ideas
  112. NX fuel line ?'s
  113. HSW Nozzle with NOS jets?
  114. Help me read my plugs
  115. NA 402 c16 in the Fuel cell with no timing pulled Safe?
  116. Coil Pack Signal wire? for MSD Window Switch
  117. FJO Progressive NEED HELP
  118. Stock short block LS3 Goes 5.58 with a Puck System
  119. "the famous DynoTune high flow bottle valve"
  120. Plug reading debate. Who is right?
  121. few detail questions..
  122. Hotcam with nitrous?
  123. Help in Plug Reading please!
  124. Will the nitrous outlet window switch reset
  125. plesae help me out!! need diagram!!
  126. For the guys wanting to plumb a LS1 Fast 102
  127. place to fill near OCMD
  128. Air flow
  129. maf screen, remove for n20??
  130. nozzle location pics..
  131. How often need to swap br7's on a shot?
  132. biggest shot on my motor
  133. how many mph do you pick up on a 100shot?
  134. Bottle heaters
  135. New to Nitrous
  136. Looking to get wet plate kit... Quick question!
  137. MSD 8969 Issue, question for the nitrous guys
  138. 120 Volt Heater In Car
  139. FPSS Users
  140. Done with nitrous
  141. joining the nitrous world
  142. Diamond Dome Nitrous Pistons...
  143. nitrous and n/a timing 110 octane
  144. Fastest Stock Bottom Nitrous LS?
  145. Is 18 deg timing low for a H/C 130 shot?
  146. First time out with nitrous on new combo 5.73@122
  147. Installing FPSS on 2 Fuel Solenoids
  148. Slew based timing controller.
  149. help with nitrous!
  150. nitrous power loss on dyno
  151. Nitrous Help!
  152. Crazy question....
  153. nitrous question
  154. Spark Plugs Help
  155. victor jr intake nitrous setup help
  156. Would you need to change fuel pump ???
  157. Nos Cheater1600 noid good for 150plus shot?
  158. Should I rebuild solenoids?
  159. Does anybody make a timing and progressive controller in one?
  160. converted from NX single nozzle to 92mm plate
  161. What parts to replace on 8 year old NX kit?
  162. How much extra timing to pull for every 10 degrees temperature increase
  163. Digital Nitrous Gauge
  164. Announcement from Nitrous Outlet
  165. what progressive, window switch ect....
  166. can different solenoids effect horsepower?
  167. tuning and spraying a dry shot using an IAT resistor and momentary switch
  168. Bottle mount
  169. Information On Nano Kit Dealers
  170. Need nano kits
  171. DO i need more timing adjustment?
  172. Mounting the Nitrous Bottle Side ways???
  173. Another Launching M6 Question
  174. nitrous filter
  175. 4.8L e85+150 wet shot...Questions
  176. 93 octane and nitrous
  177. NX and NOS jet compatability
  178. fast 95/95 with 92mm plate
  179. best nitrous setup for 408 stroker????
  180. Wet or Dry? H/C/I Stroker 100 shot
  181. My NitrousXpress install so far
  182. Small shot with my set up?
  183. H/C/I LS1 going N2O- Pic heavy/install/ DYNO RESULTS
  184. low hp gain on a 150 shot at the dyno
  185. Z06 cam and springs with spray?
  186. show me your nozzle and smooth bellow install
  187. NX Lightning Valve Not Happy
  188. What can i change?
  189. Lingenfelter RPM-002 window switch blowout deal!
  190. Project JUICE 2
  191. So I'm not sure if I'm hitting or not...
  192. help with mounting 15# bottle
  193. Spraying a dry shot through a "Wet" plate
  194. 300 shot what gears?
  195. Need advice on a 200 shot?
  196. timing retarder
  197. WhiteLTone update
  198. TPS switch or WOT switch?
  199. Chevyhardcore.com, check this out!
  200. Newbie to nitrous
  201. Surging, low voltage, weird N/F reading? Check this out.
  202. who has sprayed a stock bottom LQ4?
  203. Looking for some help with my nitrous wiring.
  204. Check my 2 step/Line Lock Wiring
  205. Need fuel regulator?
  206. timing twister users come in
  207. NX Maximizer 4 + Lingenfelter Launch Control (LNC-003) Wiring Diagram
  208. Noobie to Nitrous, need some reccomendations
  209. G8 Switch Panel
  210. Nitrous Outlet Direct Port pics
  211. plug readings
  212. Too much gas off the line?
  213. Please help with nitrous question!!!
  214. Want to reinstall nitrous.
  215. Since HSW is gone, does anyone make something like "The Interface"?
  216. Nitrous System Help *Popping my Cherry*
  217. First time at the track on spray, now bad misfire
  218. what shot noid are hsw , asap
  219. Pick my kit! Suggetions please!
  220. Using nos as a intercooler on turbo charged ls1
  221. Fuel pressure guage with nitrous outlet kit
  222. nitrous tune, Need Help!!
  223. SBE 5.3L 4l80e 3.73 gear Mild cam, how much nitrous for 9 sec slip?
  224. Deck Clearance
  225. Stand Alone setup
  226. Launching on Nitrous with Manual Transmission
  227. Help with nitrous setup
  228. Another intake with dual stages by Alzilzil Racing
  229. Nitrous Outlet 102 Plate - Picture request
  230. NOS Sniper Wet Plate Kit
  231. First Stock Cubic Inch Nitrous in the 8's!!!
  232. Dedicated fuel systems for nitrous using race fuel
  233. need wiring help!!
  234. push button vs window switch
  235. How NOT to empty a NOS bottle!!!!-Video
  236. plug gap for 125 shot
  237. n2o outlet feedback
  238. 1st gear lockout
  239. Ramping Up Production @ Nitrous Outlet!
  240. Lsx ls3
  241. New Guy at Nitrous Outlet!!!
  242. NANO questions
  243. Mounting microswitch for nw tb
  244. Carb plate
  245. ADM built/ LPE powered CTS-V runs 192.4 mph at the Texas Mile!
  246. nitrous noob, advice please
  247. NX custom wiring harness for c5
  248. few nano kit questions
  249. Nitrous on my 98 Trans am
  250. nitrous illegal!
