PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115
  1. 200 shot questions
  2. NX MAF install PICS ...
  3. 100 shot hurting my tranny?
  4. NX remote opener?
  5. Fuel Volume to Support Direct Port System
  6. N20 slowing me down?
  7. anyone spray witha 3600 converter
  8. ? about timing tuner
  9. Simple NOS 5177 Question
  10. Any word on when the NX NXL system will be available for the LS1?
  11. QUICK QUESTION ASAP >>
  12. New Dyno with a 382 and 100 Shot!
  13. 150 pills 62,33 or 62,35
  14. For those of you that spray through the shifts........
  15. need help with window switch
  16. H/C and spraying fuel pump question?
  17. Purge problem...
  18. I WANT NITROUS....but
  19. Any of you N20 users check your compression before and after?
  20. Tapping the LS6 intake for Direct port?
  21. Is anyone spraying the C2 cam?
  22. wiring diagram for wet kit with purge needed
  23. Difference between wet and dry shot???
  24. where to buy mounting brackets for 15lb bottle
  25. dry nos with slp meter
  26. bosch inline pump part #s
  27. TNT F1 jet question
  28. dry shot parts
  29. FINALLY doing it...??What parts for wet kit...???
  30. Bottle and fuel pressure gauge
  31. Timing Tuner
  32. Where To Put The Nozzle?
  33. Plug ?'s w/ 5.3L heads and nitrous
  34. seperate fuel system for nitrous.
  35. Can stock fuel pump and injectors support a 100 shot?
  36. Where to install my purge?
  37. NX Direct Port Install Update
  38. who makes the best DP kit?
  39. Where to run bottle line?
  40. NX maf kit question.
  41. hot cam and a kit
  42. NX Window Switch
  43. Need help from you BIG shot dry users
  44. Has anyone run multiple window switches?
  45. Dry kit tuning issues....
  46. WTB NX shark nozzle
  47. NOS website?
  48. where did you mount your bottle in your vette
  49. Nx wet kit jetting chart
  50. Newbie install Q.
  51. Considering dual stage setup
  52. Mounting in a spare tire compartment
  53. Would a 4400 stall + nitrous be okay w/ a progressive controller?
  54. Timing and fuel question??
  55. Can I use Granatelli maf with NX maf kit?
  56. Difference in solenoid sizes and nozzles?
  57. 175+ shot...
  58. Spraying a 4.56 bolt-on LS1 :)
  59. Does anyone have a 224/230, .550 lift, 114 grind for nitrous?
  60. safe to spray NEW 422?
  61. Dry to wet conversion?
  62. Question about NOS jets...
  63. How did you mount your gauges?
  64. speedshop nitrous gauge
  65. DETENATION ON SPRAY
  66. building nitrous system
  67. Digital Fuel Preasure Gauge, Can i get this one?
  68. Direct Port Fuel System Write-Up Moving Along
  69. Help im SCARED
  70. N2O controller question
  71. Running hose and install Q
  72. Nitrous Express NXL kit at MMT on Saturday
  73. Safety of using nitrous
  74. Biggest shot safely on a built Aluminum LS1 Vs Iron?
  75. Where do I get a wot switch?!?!?!?! please reply asap
  76. What's a window switch?
  77. Only picking up 150 rwhp on a 200 NX wet kit, problems?
  78. LS1edit N2O tuning questions
  79. nitrous accessories ( which ones needed)
  80. Dynoed 02 Vette /w 700 miles on 150 shot
  81. anyone running a Venom VCN-2000 kit?
  82. Wet safer than Venom Dry ??
  83. New TNT F1 on 2002 M6 Z
  84. NX window switch question. Need reply ASAP please.
  85. Racetronics intank fuel pump who has them and how diff to instal?
  86. 383LQ4SS need some help
  87. How to not to spray over the shifts in A4?
  88. Bottle times
  89. sprayin with a jet chip?
  90. any of you m6 guys spraying 4.10 gears?(nos)
  91. MSD RPM Activated Switch question
  92. Would these two gauges be adequate for spray?
  93. just bought tnt f1 kit, what all do I need?
  94. Whats the most I can spray on an upgraded fuel pump (Direct Port)?
  95. Direct port, what kit? NOS, NX, TNT? Is there any difference?
  96. What size injectors to get with stage II H/C and 150shot?
  97. Is it possible to wire the nitrous heater so that it only works when the car is runni
  98. Holley Intake/Direct Port Install How-To (with pics as always)
  99. injector sizing
  100. Tapping NX Shark Nozzle on TR MAF End
  101. Thanx Annil8r
  102. TNT F-1 kit or HEADS/CAM package
  103. Holley intake with fogger setup questions
  104. Mallory Hyfire VI... any good?
  105. nitrous or heads/cam package?
  106. Thank you all @ LS1 Tech
  107. WIll TNT dry 100 shot give me 100 RWHP?
  108. No headers/stock engine...125 shot ok?
  109. Dry and Wet set up use the same Jet# for 100Hp?
  110. Nos and Supercharger Applications
  111. Single Nos fogger. What jets?
  112. Project SS now has the gas...
  113. How come 35 PSI is safe?
  114. Stand alone fuel setup, or in the tank?
  115. Think I am gonna juice up!but....
  116. who has wired up fred with a window switch?
  117. Need some Brackets for my Bottle
  118. Wiring for 99 C5 MSD rpm window switch
  119. Need 3000 and 5800 pills!!!
  120. newbie question. simple and straight forward.
  121. Anyone running the NX Gemini Twin kit??
  122. Who has best deal on TNT F-1?
  123. Pros and Cons TNT F-1 kit?
  124. Direct Port nozzle orientation question
  125. Window Switch
  126. O2
  127. Will NOS hurt my car???
  128. why so rich on NX wet ket???? Help
  129. i'm sure this has been asked a million times
  130. SES Light - HELP!!!
  131. biggest dry shot on a 2002 camaro z28
  132. Dry kit ?
  133. Stock internals with YPT4200 - Question for the N20 pros->
  134. Ricer NOS kit questions?
  135. A4 guys...where do you????
  136. Best way to hide a nitrous kit
  137. Optimal A/F ratio and timing for a 100Hp shot?
  138. MSD rpm window switch 99 C5
  139. What converter for a 150 shot with my combo?
  140. I tried it out all the way tonight!
  141. 150 shot jets for Nitrous Works Wet Kit for 02 Camaro please....
  142. A/F #'s On nitrous??????? Anyone
  143. Which size nitro jet for 75Hp; Wich for 100Hp Dry system
  144. 250+ nitrous plugs
  145. service engine soon
  146. Remote opener,just convienience??
  147. spraying the verter?
  148. Dry 60-75 shot w/ Yank 4200, will it work?
  149. UH OH!!! I got an SES light this morning!!!
  150. Anyone using methanol nitrous injection?
  151. I sprayed it tonight!!!!!!
  152. help w/ nitrous
  153. ?s for Harlan 2-step users
  154. NOS RPM Activation switch diagrams.
  155. how to convert my nos dry to wet?
  156. Anyone using
  157. window switch question, does nitrous engauge before the tranny gets into next gear?
  158. anyone heat their bottle with the valve closed?
  159. Nitrous Oxide on Fiat
  160. 94 vette cutting out
  161. Mr. Colonel......
  162. Fuel Solenoid....
  163. Info on new (NX) NXL-DP and progressive controller
  164. easiest no brainer kit for a newbie?
  165. Where can I get an inline pump?
  166. Can I use the TNT F1 Wet kit as a dry kit?
  167. wet or dry ????????
  168. New 2003 N2O laws...
  169. NOS NOZZLES
  170. Thinking of going with a TNT kit
  171. Lifted Head/Heads?
  172. Need Help w/ NX Wet Kit Install **Update**
  173. New NX system?
  174. Banner Information
  175. Banner Information
  176. What intank fuel pump is the easiest to install and quality
  177. Solenoids from Speedshop.ORG + TNT
  178. LS1 direct port nitrous ???
  179. Opinions on fuel pumps for Spraying
  180. dry nitrous kit ?
  181. Which is better NX or TNT?
  182. FAQ 4 new Nirous User
  183. Do you have to purge after you're done spraying?
  184. TNT ?
  185. nitrous fuel pressure shut off
  186. Nitrous ?'s
  187. NOS sniper kit???
  188. Raised shift points and nitrous( i have never heard this topic before)
  189. ls1 with sneaky pete?can it be done?
  190. whats the diff??
  191. Advice on Heads for Nitrous
  192. anyone using the sneeky pete?
  193. well I got a NX wet kit for X-mas.... I need safety!!!
  194. NX 100-125-150 shot Jetting #'s
  195. safety precautions
  196. venom? tnt?
  197. What causes this??
  198. Mounting bottle in spare tire area.
  199. sneaky pete nitrous?
  200. HELP NEEDED......
  201. progressive controller?? whats this?
  202. did the dealer bust u 4 using nitrous?
  203. 9.33 @ 143 with new converter.
  204. Pics of Fogger systems offered by all manf. Please!
  205. NX MAF plate system, any experience with it??
  206. Thinking of going with the new NOS fogger
  207. NX Express states their basic wet GM kit does not need tuning
  208. 10.61 @ 127.73 with TNT - Stock Trans and 10 bolt!!!
  209. dry vs. wet nitrous systems
  210. Best wet N2O wet kit for stock motor?
  211. TNT 150 shot, H & C >10.5:1 CR....
  212. heads, cam and nitrous.....look at my set up....
  213. Where to get bottle warmer in Houston?
  214. TNT Power Ring and the baker hose?
  215. Which Injector
  216. Who's spraying the SS3800?
  217. NX 150 Shot HP and ET guestimate??
  218. edelbrock juice
  219. TNT F1 kit questions
  220. Tnt fuel solenoid
  221. how much is too much
  222. Hidden help
  223. Best Prices on TNT
  224. Whats the max shot you'd run on this?
  225. MSD Window Switch or Mallory Window Switch
  226. Sneaky Peak??? nitrous ?
  227. Would a progressive controller help save my trans?
  228. Check out this new kit!
  229. slower with dry kit
  230. VCN2000 and GENX2 Kit
  231. SAFE NO2 KIT.... heh,,,
  232. Progressive kits
  233. Fuel Pressure Regulator for Stand-alone fuel system
  234. plug question
  235. Dyno# MTI S2/X1 100 Wet Shot!
  236. Spraying a warranty car?
  237. 1 day sale - Free bottle warmer with NX kit purchase!
  238. which kit and how much?
  239. What kit should I go with? TNT, NOS, NX?100-150-175?
  240. NOS on Silverado
  241. is the TNT dry kit underrated like the wet kit?
  242. LS1 Fuel System Pressure Control Question
  243. Venom VCN2000 users
  244. TR224/112 and 150 shot HMMMM.
  245. H/C and TR227
  246. switch panel?
  247. Installin NOS 5177 with FIPK
  248. Another set of "?" on DP kits...
  249. 125 Shot on Stock 2000 TA
  250. Help me choose a new cam
