View Full Version : Nitrous Oxide
- wet and dry together????
- Oxygenated Racing Fuels & nitrous
- NIB Nitrous Outlet Big Show Purge Kit
- nitrous line routing from spare tire area
- nitrous jet placement
- Quick questions here.
- need help
- Can I shorten this nitrous line?
- Using Cold Gas??
- rpms reading way off! related to msd timing controller, digital switch
- Quick bottle pressure question
- What Plugs do i need for n20?
- Nos 5168 wet kit
- video of the TTT5 car we have (true street)
- What is wrong. going lean.and wide band blanking out
- Nitrous Outlet Direct Port
- My Custom Purge
- Jon's Gettin on the JUICE! (Nitrous Install)
- Sprayed for the first time!!!!
- My stealthy setup
- Should I use a timing tuner or timing twister w/ my setup?
- where can i get this switch panel??
- NXL vs NOSzle
- Need wot switch + controller's tps switch?
- What to gap tr-6s, torquer v3 + 150 wet
- 2 stage set ups POST UP PICS
- Nitro Dave's Plate Kit Installed
- C-5 Nitrous fuse center
- Need help with nitrous plate.
- Wire Selection Chart
- Need to Settle This
- PIcked up a NOS GM EFI Nitrous System LS1 Nitrous System need hints for installing
- Wilson Billet Bank / Nitrous Outlet DP Pics!
- N2o Compression Limit?
- Dyno tune Nitrous Kit
- Any sponsors working with E-85?
- MSD digital window switch *for sale*
- Nano/pusher Jetting ?
- Hide bottle or not?
- plug swap now rough running
- Never heard of this.......
- Is a trailblazer SS window switch the same as an ls1 fbody?
- Dyno Numbers with 100 Shot (TFS 215's, Vindicator, 90/90, A4)
- What AFR to shoot for on 100 shot Stock Bottom End
- is -15cc piston to much for spray. for a 408
- LED wiring for 2stage setup
- what gear for 3a and spray
- Please assure me this won't blow up.
- Show me your DP and Stand Alone Systems
- Shout out to Nitro Dave's
- Track Numbers?
- Nitrous Outlet LT1 Plate System
- Which wire to use???
- H/C+150shot+10bolt on dyno=?
- Dummy Proof N20 Setup???
- Freezing Bottle
- Fuel system upgrade???
- Anyone running a NOS progressive controller on a 416 CI L92?
- what converter?
- Suggestions / comments wanted.
- P0103 MAF High Input
- Pics of my car with new wheelie bars etc.
- A/F ratio question
- Cutout Versus Headers
- No power gain with spray
- Vig 3600 and spray...
- Check out this stealthy setup !
- Nitrous Guys Please help need advise !!
- IAT Mod Reliability
- New setup almost done.
- What to Expect
- Just ordered injectors, almost nitrous time!
- Best Nitrous Cam?
- GMPP ASA CAM +Nitrous?
- Guys with 408s and spray please come in...
- Nitrous Outlet Complete 78mm plate package
- Is there a benifit to
- Wiring dynotune nitrous gauge
- Zex remote bottle opener w/ HSW bottle
- Check over wiring, p series, iat tricker, etc.
- dual bottle heater wiring and plumbing
- Options for cheap remote bottle open?
- Ashtray switch panel
- Masterblaster over regular, worth it?
- How to decrease my lean condition on the initial hit?
- Optimize Your Nitrous System With A Water Methanol Injection System
- Can I run Water Methanol Injection With My Nitrous Injection?
- F/S: Opener, switch center, guage, brackets
- Need jet sizes for dual nozzel wet shot
- NOS question
- FS-78mm NOS brand plate
- What Is Nano Pressure Set To?
- 100 shot nitrous?
- 78mm to 90mm
- 2 stage with hsw interface and a wet kit ?
- need a tranny?
- motor change, need help
- which kit is best
- got a question about nitrous plate
- Nitrous Outlet has the 92mm covered!!
- What guage wire ??
- 2 stages
- Plug gap?
- RICH Backfire?
- confused on the interface still (timing)
- I might have a nitrous problem need your help
- what jets
- Name that nitrous relay!
- 3.905 n20 pistons
- Lean switch for sale!
- window switch
- Need 90mm TB plate
- They're clicking...
- I swear if I hear another person say "nos"...
- Plate VS DP
- Debating a new setup....
- Window switch
- HSW Interface Controller
- Will the Plo-flow fit on a Victor jr????
- Would you spray?
- About to spray. Few questions
- Advanced Nitrous Knowledge?
- nitrous finally hit out of the hole
- Ms4 Q
- Freezing Vs Pumping
- question about how much the motor can hold
- Low compression boost motor question
- When I arm my system the fuel noid opens, Help.
- Having trouble keeping my connections from leaking gas.
- What size shot am i acutually running?
- help, FJO nitrous mini controller
- Shorten nitrous lines???
- got to race my car today
- Bottle heater
- help with electric gauge
- Please help I think I have a short.
- should I spray the 200 shot
- F.S. Built Street/Strip Low 9 sec Camaro SS
- any stealth kits on here??
- NX 200 shot 10.5:1 A/F
- Window switch wiring NEED HELP ASAP
- So I'm N2O Stupid...
- nitrous track updates 4-16-08 on the 94 ls1 mustang
- Fitting size
- Timing Tuner issues...bad stuff
- In Car Vid: MY 99 z28
- got my car running.
- Help Fast!! Noids Not Clicking!
- Can Any Sponsers Make me a custom nitrous hose?
- Nitrous newbie
- Will this Window switch do?
- Just Hooked up my HSW kit :)
- Window switch question...
- Braided Fuel Hose??
- NOOB with nitrous safty questions
- 860 heater wiring Q
- Help on wiring a Digital MSD w/ HSW Interface
- Yep wiring, BMN and NX MAF kit
- Nitrous Outlet- Closed Friday-18th
- Nitrous tune?
- full throttle switch on lsx intake
- Where To Get Bottle Filled Near Los Angeles Area
- Just ordered Nitrous, Please tutor me, DO'S AND DONT'S
- Questions about nitrous fill station/pump.
- Where the heck to put bottle?
- Zex Dry kit
- NOOB Installing HSW wet kit now..
- I'm back to the other dark side! Couple Q's.
- Dynotune Banner Poll
- Cost of Nitrous??
- Can a nitrous line be shortened?
- Wiring Dual Stage Nitro Dave's Window Switch (need help ASAP)
- what size fittings for my purge, bottle heater and fpss?
- Im new to nitrous, can someone fill me in?
- How much nitros if any?
- Dave @ Nitrous Outlet
- What timing for 175+ shot
- How long does a nitrous install take?
- Nitrous Outlets Digital Dual Window Switch??
- A/F Lean Switch from Dynotune
- Brand New In Box! NOS 05168 Nitrous Plate System
- Just a quick question
- cam/nitrous
- victor jr
- Well It looks like I may finally need a new SB.
- HSW what jets
- HSW Guys- Question
- Pics - NitroDave's panel & Trick Window Switch
- Nitrous Help
- HSW new n2o interface users
- nothing to do with nitrous, but nice story to share.
- spray auto stall question
- anywhere else?
- Oil darkening after spraying
- Nitrous ?
- which of these pistons for nitrous---ross or wiseco
- bottle heater affecting fuel press. guage
- dual stage problems
- Whats The Best Spark Plugs For Nos??
- best billet bottle setup
- Need pics of cage/floor mounted bottles.
- Little advice please
- Tcs While Srpaying
- What happened?
- Stock headed big shot guys, what plugs?
- Will this cam be decent for spray?
- My Weekend of Fun (pre-LTX Shootout)
- Final dry kit nitrous questions
- Brand New-Biggest and Baddest only need to apply
- Single Nozzle Kit.
- Nitrous Feed Line Flattened...Reusable?
- TA verses SRT Charger
- New Dyno #'s and a story
- Got my flow Numbers from TEA!!!!
- Where to run a nitrous line????
- Timing ?
- Some questions for Dual Fogger veterans
- Timing Tuner Problem NEED HELP !!
- Need some help with nitrous?
- Ok...lets have some discussion on head lifting, water pushing and studs etc etc
- Is it normal to run rich for a second or 2 after you spray ?
- System won't stop purging!!
- Bottle Fill Locations In Los Angeles Area???
- which nitrous plate for my Vic Jr?
- ugh...issues, help inside
- help with nos plate jetting
- HSW S-I-Kit Window options
- How much N20 w this setup? and lean hit?
- Nitrous Panel and TCS
- What piston rings are everyone using?
- F/S: opener, switch panel
- Head gasket question?
- Is the NOS soft plume nozzle good?
- New Track Times "Insite" plz
- what size shot is my kit putting out
- Dual Stage wiring help
- n20 ls1
- Carb nitrous question
- Will a 98 Computer keep up with a dry shot?
- What intake for nos? metal, composite, what brand?
- Nitrous Bottle Placement
- cam and nitrous
- Fake Nitrous/CO2 Purge System
- Dynotune Lean Shutdown Display...
- Pressure relief valve?
- 45* Dual Nozzles
- BONE STOCK motor + n20 #s?????????????
- Nos mini wiring programing a 2 stage
- Schrader valve question
- nitrogen pressurization
