PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115
  1. Fast 370's?
  2. Progressive 300, Dual Stage Plate, or Plate + Direct Port
  3. Any vendors that can rebuild TNT solenoids?
  4. head gasket material??
  5. slp bellow and nozzle placement
  6. 347 n20 piston's. What's the best for 300 plus shot
  7. plate vs direct port intake rescriction
  8. Nitrous to cool intake charge?
  9. 7.100 at 97mph in the 1/8th. Your thoughts
  10. Cam suggestions for my 430cid?
  11. 07 4.8 Chevy Silverado new body.
  12. Questions about nitrous plate
  13. Steering wheel with built in nitrous button
  14. Noob to Nitrous
  15. NX solenoid bracket
  16. 10 micron, 40 micron 100 micron ??? filter
  17. Stock lq4 nitrous question
  18. Progressive Controllers
  19. safe nitrous limit with stock ls1 cam
  20. How fast have you been on a stock short block?
  21. Changing to a dry kit few questions
  22. First Time Spraying, Need Input
  23. nos mini progressive
  24. **UPDATED for cut-outs**Going from 250 to 350 shot gains 2 tenths?
  25. what fuel pressure to use 40 psi or 50 psi??
  26. How much does a .001 change in fuel jet change actual air fuel ratio?
  27. Nitrous/Texas Giant guys... what compression?
  28. Tuning fuel on a progressive dry dirrect port.
  29. 100 shot question
  30. What plugs for my setup?
  31. New PB (11.38 at 131.62) but have a HUGE problem...! HELP (150 shot)
  32. who do I conctact
  33. how to convert a dry kit to a wet/plate?
  34. Fuel Flow Pressure for setting nitrous Q.
  35. Anyone have an HSW Interface they would like to sell?
  36. Untouched 799 heads
  37. is a 250 shot too big for a 10lb bottle?
  38. How much spray can you run without pulling timing if using a c16 stand alone?
  39. Wat should i be looking at for stock engine
  40. blew the hell out of my motor!! 200 shot pics
  41. car bogs then hauls ass on a 200 shot
  42. Dual stage plate and wondering about fuel line on Mustang.
  43. Plugs from 350 shot on N.O. Plate
  44. lnc2000 question
  45. question about bottles
  46. 5.3 150-250... plugs?
  47. is this enough fuel for my new direct port setup??
  48. plug gap
  49. Nitrous oultet jets contradiction
  50. Nitrous Noob few questions
  51. help please!
  52. What should I set my Window Switch "on" Off" to?
  53. Juiced up
  54. 1998 PCM "OK" for a dual 350 shot...or do I need a later model PCM...?
  55. stupid newbie question
  56. can someone check my wiring diagram I drew up?
  57. Good Nitrous Setup???
  58. How long does the fuel in a standalone last...?
  59. 6.0 Bore Block....When will the heads lift on NOS?
  60. wiring diagram needed please
  61. Don't bash me but have a question?
  62. gto ls1 2004 on spray stock tranny and rear end
  63. My microedge is actually a microedge plus...need a manual...
  64. nitrous outlet kit anyone run them?
  65. Lingenfelter NCC-002 WOW!!!
  66. Is Edelbrock pro flo xt manifold ok for 90mm plate kit?
  67. Pcm nitrous tune
  68. hsw nozzle jets
  69. Nitrous Outlet License Plate Frames
  70. NOS Increase?
  71. Finishing up piecing a kit together.
  72. tvs2300 and nitrous
  73. Fastest stock blocked nitrous ls1 383?
  74. Any HSW interface users in here?
  75. Odd 150 shot problem.
  76. NX 102 plate
  77. dual stage thinking
  78. Shark nozzle vs dynotune plate
  79. Whats my best options
  80. Lnc-2000 or Msd 6010
  81. head bolts
  82. nitrous outlet ls2 w stinger plate round 2
  83. E85 in a separate fuel cell for my wet kit. 93 octane in the car?
  84. where to set progressive controller?
  85. What 2stage/prog. w/xtra features nitrous controller is everyone running now a days?
  86. Need help
  87. What NGK part# for non-projected tip -9 -10 -11 heat range plugs L92/LS3 Heads
  88. Nitrous combonation setup ?
  89. nano nitrous pressure issue
  90. Running out of pump??
  91. Zex's box failure?
  92. Troubleshooting Nitrous Activating Inconsistently
  93. 300 hit on a 12-1 motor, what plugs?
  94. What brand of solenoids to buy?
  95. HELP! problems with dry kit on LS2
  96. Nitrous plugs run like crap, please help!
  97. plate/jetting Q
  98. best wideband for HP Tuners?
  99. timing tuner question
  100. anyone using Leash progressive and LNC2000?
  101. Nitrous Outlet / NX 78mm plate jetting questions
  102. rebuild solenoids
  103. 390ci iron, fully forged: Dual Stage 300 (150/200).....is it too much...?
  104. iat nitrous trick
  105. Back firing after nitrous pass help
  106. Cubic inches and nitrous question
  107. nitrous outlet ls2 first nitrous pass
  108. nitrous issues
  109. NX MAF results
  110. Wet or dry kit??
  111. Tps and tach on 98
  112. Nitrous ZEX Dry kit plz help
  113. remote opener options
  114. Diagnose my "breaking up" nitrous pass?
  115. Nitrous around northeast Nebraska?
  116. Nitrous plugs
  117. New cam is working out quite well.
  118. Nitrous 5.3 junkyard build. Help!
  119. Fuel Pressure Safety Switch Question
  120. 100% engine protection from an N2O shot gone bad....does it exist...?
  121. Dynotune N20 vs Nitrous express vs Nitrous Outlet reviews
  122. iat timing tricker
  123. Yet Another Spark Plug Thread
  124. Predictions on power and longivity?
  125. Anyone using the new Nitrous Express Solenoid Brackets?
  126. testing KB BAP
  127. Is it safe to spray on this setup?
  128. SBE cam and spray car goes 1.23 60' on radials with 4l60e.
  129. upgrading fuel system
  130. Progressive
  131. KB BAP wiring with relay
  132. Nitrous Newb working on a Drag Week Setup
  133. Adding vp instead of timing retard
  134. Help with Plugs/Wires
  135. Aeromotive Regulator w/Nitrous Outle Remote Tank problem.
  136. C5 with bottle in rear well.
  137. NOS newby
  138. Rotating Assemblies
  139. NX relay question
  140. Old TnT N2O Kit?
  141. so how lucky was i??
  142. Pre-plumbed Intakes From NX
  143. To run 6a box or not Lt1 75 wet shot stock timeing
  144. need Nitrous Outlet fittings for the plate
  145. 2 stage direct port w/plate kit questions
  146. Can I mount my stand alone cell next to my battery?
  147. nitrous dyno results
  148. Please help with LNC2000 launch control ONLY install on c5 z06
  149. Lingenfelter lcn-002 not working?
  150. yank ss3600 with nitrous
  151. Nitrous backfire
  152. Help reading plugs...
  153. crank case pressure
  154. Nitrous Outlet wet nozzle on FAST 102 intake
  155. Nitrous setup and numbers
  156. C5 Solenoid Mounting Question
  157. who's all running the nitrous outlet puck?
  158. First time n20 user help with timing tuner
  159. How does running lean cause Nitrous Backfire?
  160. Carbon fiber bottle...because baller...
  161. Thanks Nitrous Outlet !
  162. Voltage switch
  163. IAT Placement
  164. Gears and spray
  165. E85 and Nitous help
  166. New Stock Cube Best 9.6 @ 141 w/crappy 1.40 60'
  167. Hydraulic hose for filling station?
  168. Spark nitrous system help anyone?
  169. 5.3 nitrous help
  170. 2 stage setup
  171. Prepping a junk yard LQ4 for nitrous
  172. Will my fuel system be enough for my 2 stage H/C/I stroker?
  173. New to the club couple questions
  174. 75 shot, New track mph.
  175. Timing retard via Coolant Temp sensor?
  176. Nitrous Plate Fittings
  177. 12 :1 compression safe for 91octane?
  178. At what levels do backfires become a concern?
  179. where to pull tach signal?
  180. Nitrous Express Direct Port Install
  181. Question about nitrous.
  182. Another nitrous build
  183. Thoughts on My Nitrous Install
  184. BR7EF how are they N/A?
  185. carbed ls1 200 shot
  186. ls9 cam with nitrous????
  187. nozzle or plate
  188. question about msd 8956 window switch
  189. best place to pull fuel from for solenoid, aftermarket parts??
  190. My Nitrous Build
  191. Need help, ls3 intake on 02 Camaro and plate system-throttle cable bracket?
  192. nitrous and converter question
  193. (c5 z06)nitrous outlet plate system questions and DYNOTUNE fuel pressure gauge
  194. Nitrous Confusion...
  195. What Nitrous kit for Cam Only ls1?
  196. Which nozzle is the best.
  197. coverter help 300 shot
  198. Newb question about my N2O plate
  199. extending wires on a lnc2000
  200. used nitrous kit need helping telling whats , what PICS INSIDE
  201. Pusher system/NANO questions
  202. Spark plugs and gap
  203. What plug to start with on a high comp 347 & a 100 shot?
  204. comp 918's
  205. My nitrous install thread...!
  206. H/C/I Ls1 150 shot test/tune
  207. Routing Fuel system for nitrous help?
  208. How fast is a stock ls1 w/ bolt on nitrous kit
  209. Tach jumping around after RPM Window Switch install
  210. Nitrous XPress come on in...
  211. my new emblempros switch panel
  212. K447X3 Wiesco Nitrous Dome Pistons.. How much Spray
  213. TNT Power Ring Nitrous kit
  214. 3.905 nitrous ring part numbers
  215. Where to set timing.
  216. Help with plug reading.
  217. what do u think of my bottle setup?
  218. Big shot on a Carb LS1, Timing issue?
  219. Nitrous oxide build questions. Injectors,pump,shots
  220. 78mm Plate Kit Dyno Numbers???
  221. Nitrous back fire
  222. dynotune n20 pressure gauge and fuel pressure gauge
  223. Nitrous install issues :( Help!
  224. Nitrous Outlet 78mm Plate Kit on stock LS1?
  225. Nitrous wet plate???
  226. Were do I start?
  227. Wiseco GFX ring gap
  228. Bottle heater options
  229. Nitrous plate install! NEED HELP!
  230. Port Match Intake to Zex Plate???
  231. What's a fair price for a HSW Interface without the harness?
  232. Any nitrious users running a wideband A/F ratio gauge?
  233. Spark plug replacement intervals
  234. Wiring--Mini Progressive-Lnc-2000
  235. Nitrous tuning
  236. Anyone Using The Leash Single Stage Nitrous Board?
  237. Starter Motor problems
  238. Nitrous plug gap help
  239. Money maker/plate/halo dry????
  240. new nitrous install: would you tune again?
  241. Burnt my solenoids - can I fix?
  242. NOS fitting leak - what to use?
  243. Quick question about wiring
  244. who has pics of there nitrous express maf kit installed ?
  245. HSW Microedge wiring
  246. what RPM do you engage your nitrous?
  247. What Hp will a 100 shot gain me
  248. Where is the best place to put my bottle
  249. power for NOS RPM activated box
  250. 100-150 wet shot
