View Full Version : Nitrous Oxide
- 1 of a kind custom bottle mount pic
- selling brand new zex heater and NX bottle blanket
- Finally got to try out the direct port 200....
- which jets
- Ready to Rumble...
- Introducing. BIG PAPA !!!
- HP Loss Through Prog. Controller.
- need help with dry n2o tune !!
- Poor small block didn't even see it comming
- FPSS - where to put
- What does spraying through converter feel like?
- Custom Paint & Airbrushing
- Purge guys come inside!
- How Fast?
- 14/16 or 18 gauge wire?
- How to keep a good bottle pressure!!
- So close to finally hitting the 200 shot(~700rwhp)...
- Can/Shoud I convert my 125 dry to 200 wet?
- TNT website?
- Nitrous Harley for sale
- nitrous newb question
- Nitrous being installed
- How many switches needed?
- sneaky pete?
- Finished my bottle mount area
- Going to run 2 kits, need some advice
- blow down tube extension
- NX NXL kit question.
- Big Power On The Way
- Just finished plumbing stage 3 (direct port) pics inside
- first time nitrous with LS6. questions
- Nitrous Fill Stations
- Before and after...
- Now this is a Vette Intake!!
- Spraying my Lt-1
- EVERYTHING Nitrous related!! stock bottom end, wiring, EVERYTHING!!!!
- Retune after nitrous?
- car doesn't like 100 shot
- Victor Jr. Dual Stage Carb Plate Setup
- Timing Tuner question....
- Possibly a leak???
- fpss ?
- In dyer need of wiring help!!! (picture inside)
- can i get a pic please?
- Is there 175 jets for TNT kit?
- 200 shot on a 346ci
- Bung for my fogger nozzle
- 200 Shot on stock bottom end
- tune for 100shot???
- Anyone spraying >200 on Z06 Cam?
- Hidden Juice?
- Goodbye MSD Digital W/S..Hello FJO Mini Controller
- Anybody spraying more than 150?
- Need Help on Nitrous Jet Size?
- finally got my car back
- Big shots anyone?
- nitrous problem!
- Quick question first nitrous install
- Halo nitrous ring
- SI/n20 1/8 mile times...
- Nitrous Pressure Gauge - Missing Parts?
- New fuel pump or boost a pump?
- Throttle cable not going to WOT
- Who's running the new Zex Traction Control Window Swich?
- Is it possible to put a gauge on NX bottle?
- Need Quick Help - Timing Tuner
- Are the bottle handles(The knob thats used to open the bottle valve)all universal?
- DP conversion kits.. sponsors come on in..
- TPS Switch
- best dual bottle holder
- 150 shot
- Carburetor Purge Question
- How much longer will a 15lber last over a 10lber???
- My headers for sale....
- Direct Port with stock LS1 long block
- Still Surging (Guru's inside Please)
- zex boost a pump
- Harness relay has too many wires..........WTF???
- One bottle vs two
- ZEX question
- Help
- Another, am i spraying?, thread
- Bottle angle. Why?
- Dyno Results on Zex dry kit.....NA and n2o
- HSW any new plate info?
- Nitrous Direct Special
- Has anyone ever shipped to Nitrous Outlet?
- What will I need for fuel upgrades?
- N2O guys with heaters please come inside!!!
- Nitrous horror stories?
- What will nos do for my track times?
- Need some help with a project.
- Quick plug ?....
- Dynotune Purge
- Anyone spray a hemi? wet or dry??
- Fuel Pump Help
- 100 shot to 125 wet, Will I notice a differance?
- sprayin on my s/c vette, with stock internals
- N2O or No?
- whats the highest shot you can run on a stock internal ls1?
- How to tell pos/neg wires on noid?
- fuel upgrades?
- Speed density and nitrous?
- hsw?
- any MS4 juicers yet?
- n2o2??
- is this a good plan?
- Thinking about Nitrious need some help
- What safety features for a 100hp shot?
- A/F gauge pic !!
- My cam is for sale...
- which plugs and gap
- Odd looking plug...
- Weird noise after spray, video inside!
- Problems after nitrous instal
- Solenoid rebuild question
- stupid question...
- Nitrous beginnings
- How much spray can you run on a stock motor
- nitrous switches
- spray on big cam and tune
- What needs to be replaced?
- Good spray story!
- How many total degrees of timing should we be running?
- The Black Pearl !!!
- Custom touches
- 383 Stroker/TNT Kit
- Small update, but everything counts!
- Will TR55's cause detonation?
- questions for nitrous dave
- TNT Kit Problems
- Upgrading a NX 150 shot kit
- if i got the nx 20920 kit what all would i need to run it on m6?
- Track day but no cigar for n2o, PICS !!
- Nitrous Gauge
- track time with nitrous
- What do I need to make a safe 100shot dry kit?
- nitrous track help
- Some issues dyno'ing my car....
- Can you put the gauge on the HSW bottle if its full?
- cam and n20
- Dynotune window switch programming ?
- Gettin the 100 dry shot tuned, what should I look for?
- zex and msd digital window switch
- Empty bottle..low TQ??
- Factory plugs at a whopping .67 gap!
- Nitro daves plate!
- cold fusion jet numbers
- Nitrous pressure switch
- ok guys, don't flip but...
- Ready to see some new work?
- nj fill station
- NOS Wiring HELP
- how fast do you ramp up with the FJO controller
- 91 octane
- HSW dual-noid dry kit on and operational!
- why would an 01 TA detonate on a 50 shot?
- texas giant and spray??? .622/.614??
- any interest in a dual stage setup???
- Solinoids and heat
- Timing for 150 wet
- H/C and spray?
- LSx Top 10 Nitrous Cars
- Nitrous flow rate
- New setup>>>> Spy photos
- Will NXL work with aftermarket rails?
- Purge Vid
- Timing Tuner question?
- help with TBSS
- help me pick out a nitrous system
- problem/question ?
- C5 Nitrous Plate?
- Direct port question
- Money Maker = $$$$$$$$$$
- Few things
- NOS Newbie!
- How much and when should I spray the nitrous???
- whats the largest shot anyone has run through a single nozzle
- What should I sell my NOS kit for?
- Throttle body sticking after Kick
- Arm System and Shift Light Goes Off??
- MSD Window Switch Help
- Pre-IC nitrous injection?
- rings for a 200 shot
- Switched 12v source--how many accessories?
- single fogger nos jet sizes
- What size wire with TNT system?
- Window switch???
- Anyway to tell if I'm spraying or not?
- EFI Victor Jr. and 4150 Carb Kit?
- halo jetting
- timing
- Jet Sizes
- Race Gas and Nitrous
- Cold Fusion Nitrous Kits????
- 4200 convertor and 100hp
- street traction with n20
- How soon after I turn on the bottle....
- TR6 spark plugs
- AN conversion?
- New to N2O question...
- How do you get the HSW switch plate to fit?
- Where can I get O2 sensors for use with leaded fuel?
- lets see pics of everyones switch set up
- COLD intake with dryice...w/ pics!
- what ET improvemenst are yall getting on spray?
- backfire question?
- can I do this? need help
- OK im stupid. FJO help
- 06 gto nitrous?
- dryice cooling intake effect?
- N20 to spool up a turbo?
- RPM's jumping all over the place with the MSD Window Switch Installed, Why?
- Should I up the Shot???
- Wiring Question? please help
- long question about nitrous
- changing plugs
- dyno results: wow...running super rich through Dave's plate
- Cam/nitrous question
- NOS 5177 copper purge lines
- Newbie lookin to get juiced
- About to feel nitrous for the first time ever...
- Ran my 02 vette with 125shot tonight
- n2o grind for stock heads
- timing question
- Nasty Hawk's 2 Stage N2O System
- Quick window switch question
- Which plug do you read?
- Post Custom Painted NOS Bottles
- Tr6 iridiums or regular
- Nitrous Cam and Heads.
- Stupid question...sorry!
- Dont know much about nitrous, but I have a kit
- Problems n/a after nitro dave WS wiring
- NOS, ZEX or NX ??????!!!!!!
- Painted my nitrous bottle PICS
- thinking of n2o how low
- LS2 nos kit
- What the hell was I thinking...
- Nitrous Works Power wing. Has anybody...
- O-ring for Nitrous outlet plate system.
- any c6 Nitrous kits for 06 C6?
- Where to put my wideband O2
- To Port & Descreen or not to port & descreen?
- More wiring Q's, tach signal and TPS
- Wiring Nitro Daves digital dual window switch
- N20 with XER281HR?
- Remote bottle opener switch options?
- nozzle position ?
