PDA
View Full Version : Nitrous Oxide
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115
  1. WHAT DO I NEED TO CONVERT FROM DRY TO WET?
  2. nos in a 4 banger
  3. N2O & Programmers?
  4. For a Nitrous Works kit.....
  5. How to put TNT kit onto Baker hose??
  6. edelbrock noid flow vs TNT noid flow
  7. How far do the purge line(s) need to stick out???
  8. NGK TR6s and N/A driving
  9. Need advice on N2O
  10. Do i need gauges??
  11. How well will this cam perform with my juice?
  12. Coming off the fuel rail, how can I...........
  13. Check out the new purge setup
  14. Questions for people who run N20 and head/cam car
  15. nos or not?
  16. anyone got a NOS Super Hiflo Valve to sell?
  17. wet or dry kit?
  18. biggest and best nitrous cam for A4
  19. can i use nos safely
  20. Compucar Blowdown?
  21. First time to spray 150 and not reallllll happy?
  22. Stock Clutch? Will it last on the juice?
  23. thiughts on ngk iridium plugs
  24. Finally ran the DP setup last night
  25. NX kits...have some q's
  26. Auto timing retard on the Spray?
  27. Need a good intank fuel pump,opinions please
  28. o2 sims and nitrous tuneing??? help..............
  29. Anybody ever done anything like this???
  30. NXL direct port kit for LS1
  31. CAN I????
  32. about to install NOS. any tips or tricks
  33. how high in the rpm's can the ls1 be sprayed?
  34. Stupid question...
  35. Ok nitrous gods-Educate me.
  36. Help
  37. fpss problems
  38. how much can you spray with NX shark nozel set up
  39. TR 224/224 + nitrous Yah or Nah
  40. help with seting up seperate fuel system for NX
  41. Timing Retard Controller that is NOT MSD?
  42. anybody have nos jet/hp chart?
  43. **Big Mike & Cartek, can you say 9's**!!!!!!!!!!!!
  44. NX new Pro-Controller
  45. 11.1 cr and 150 wet shot???
  46. has anybody tried the gemini kit?
  47. From dry to wet???
  48. Engines built for nitrous use
  49. heads and cam what all do i need?
  50. Dry shot on an LS1?
  51. Adjusting pressure on NX bottle heater??????
  52. Car falls on its face on dry shot.
  53. Custom nitrous express NXL system (pics inside)
  54. ? about shot size
  55. predator custom tune w/nitrous
  56. Will AN F1 TNT KIT SPRAY 200 SHOT???
  57. What Companies have Direct Port N20 kit released?
  58. Whats the best remote opener for the money???
  59. nos bottle pressure gauges SUCK!!
  60. HELP WITH NX BOTTLE HEATER!!! Quick!!!
  61. Changing my nitrous system around...
  62. just installed kit . i have a few questions
  63. Some Pics of my Custom Fuel System... pics big
  64. head/cam car and a 100 shot + stock fuel system
  65. 35 gap hurts n/a performance
  66. Finally going to hit the bottle.
  67. 200 Shot Whats NEEDED???
  68. timing tuner questions...
  69. Better Delivery Systems, Any Out There?
  70. Nitrous sale!
  71. MAF translater on dry shot
  72. Need a little help
  73. NitroDave's Is Moving!!!
  74. How Much NOS is to much????
  75. Can you run this reliably
  76. NX Wet Kit
  77. Nitrous + boost?
  78. Can I run nitrous with my car without BOOM?
  79. NGKs Tr-55s
  80. Nitro Dave!
  81. Can I repair my nitrous line???
  82. What NOT to do with nitrous?
  83. Did anyone try
  84. nos dry kit please help
  85. Spraying?
  86. MSD window turnoff???
  87. mallory window switch please help on wiring
  88. Sprayed the 150 shot tonight for the first time!
  89. New NOS wet system
  90. Question after TNT install (power ring)
  91. NX MAF Ends
  92. anyone with NOS 5177 Kit come in
  93. Jacobs Nitrous Mastermind?
  94. 6000 MSD Window pill?
  95. question about a/f gauge connection
  96. Spraying a supercharged truck
  97. What rpm does your window switch go off?
  98. spark plug 100 shot
  99. Need Help ASAP with NOS Dry Kit
  100. Low mph with 150 wet shot
  101. Wiring a Harlan window switch w/ NX kit
  102. How hard will this be to drive?
  103. new system
  104. TNT bottle pressure?
  105. how safe is nitrous equipment in vehicle ?
  106. ?nitrous buttons hooked up threw steering wheel?
  107. Eastside New Stock location suspensoin record.9.14
  108. nitrous plug colder than TR6???
  109. fuel safety
  110. **New best with new setup - Oh So Close!!**
  111. how long will a stock motor last on the juice?
  112. Wolfe Roll cage & 15lb bottle/spare tire location
  113. EASY QUESTION ====== PURGE VALVE
  114. cheapest and easiest direct port
  115. how long should i purge??
  116. Where to power switches from???
  117. As promised..Pics of my setup
  118. Prototype Nitrous set up in the works!
  119. Remote openers...
  120. Looking for line
  121. Why retard timing?
  122. What size injectors for a 200 shot on a 422
  123. Fan nozzle placement
  124. Max direct port shot
  125. Car stalls when coming to a stop after NX install
  126. Nitrous / Propane Injection
  127. Anyone spraying on stock GM plugs?
  128. pic of how you mounted your WOT switch???
  129. Building first switch panel
  130. Jets, to richen/lean
  131. Wet kit jet size question
  132. How much fuel do you go through??
  133. Dual Stage vs. DP on a programmable controller???
  134. NXL Where are you????
  135. Backfire takes out the crappy ls1 intake for me.
  136. Window Switches?
  137. a newbie and nitrous
  138. NX Gemini Kit
  139. Dual Stage 300 Shot...wet or dry..direct or MAF
  140. Direct Port DynoToday (544/540 on 150-shot)
  141. Seperate fuel cell
  142. Timing retard with nitrous?
  143. LS1 NX Gemini Kit
  144. Wet Kit Users Inside Please
  145. How much fatter?
  146. TEST forum 8
  147. Possible Timing Tuner Problem?
  148. Disassembling bottle for powder coating?
  149. NX Jet sizes?
  150. Timing setups for spray, I have a slight problem possibly
  151. wtb wet kit
  152. Do the NOS brand kits come with a WOT switch?
  153. anybody with a wet kit accidentally spray with an empty bottle
  154. What gears with Spray..
  155. i need help
  156. will race gas kill 02's if just used with the nitrous?
  157. For thoes of you that manually engage you N2O
  158. I need pics of your WHOLE Nitrous setup!!
  159. Need NX Maximizer wiring/install PDF
  160. 5177 problems
  161. Need Wiring Help please
  162. question sell price for an lt1 dry kit?
  163. 2002 ls6 cam w/....
  164. Direct Port for sale
  165. spray at low rpm w/ 2 stage
  166. need help installing NX wet kit w/ genx 2 upgrade
  167. Will a wet kit make more power than dry with same n20 jet?
  168. Nitrous question and backfiring problem!
  169. Where can I get individual NX jets?
  170. Nitrous efficiency problem?
  171. Can we post the NOS 5117 install pics.
  172. Pls post your contact user in AOL, ICQ, MSN...
  173. 100 dry shot, 4400 and TR55`s??
  174. LS6 Cam And Nitrous?
  175. Recomended Kit?
  176. Quick help us! Where to ground toggle switches.....
  177. WTF, my gauges won't be legal?
  178. LS 1 edit
  179. jet size question again?
  180. Nitrous kit almost complete
  181. Get on the list for the New NX NXL Kit.
  182. nos 100 dry kit please help
  183. NX MAF system questions....
  184. where do you got tnt?
  185. How long does 1 lb. of nitrous last?
  186. nitrous activation
  187. Will a dual stage 250 Dry shot work correctly?
  188. BOTTLE HEATER
  189. Converting a wet kit to direct port?
  190. mti clear lid
  191. New dyno #s Yay me :)
  192. Help?
  193. Fitting connections... teflon tape or paste?
  194. Glidden Nozzles
  195. window switch settings???
  196. Installation
  197. newbie to n20....tnt f1 or nx maf?
  198. Which head gaskets for H/C with 100-150 shot?
  199. Quick question on bottle pressure
  200. Installing EGT question?
  201. spraying supercharger
  202. Who has the best price on NX system
  203. Sprayed 1st Time!
  204. Last day at TNT
  205. More than a 150 shot?
  206. Cheap bottle blankets on ebay
  207. beat a 911 with stock ls1 and N20?
  208. Hard to wire a window switch???
  209. Quick question on mounting NOS on a K&N FIPK kit
  210. How much for N2O install???
  211. Automatics with window switches
  212. TNT bottle
  213. Is a 25 shot worth it?
  214. Best cam for NA AND N20?
  215. Rails vs. Distribution Blocks
  216. life span?
  217. dual stage 250 shot dry
  218. What went wrong... ???
  219. Has anyone had their purge refuse to close?
  220. purge kit & paint
  221. Wet Shot manifold pooling?
  222. can nos get bad?
  223. pic of new switch panel
  224. NOS Bottle Warmer Install Q
  225. Will this wiring schematic work for a nos 5177 kit?
  226. Who has the Nitrous Oxide Systems 05177 kit?
  227. TNT People...
  228. I won NX...Now what
  229. Air fuel and 100/125 hp Dry shots
  230. N20 Filter and Flow
  231. Can spraying a lot......
  232. NOS Pro Race Fogger DP Q's?
  233. Pics of TNT Direct Port on LT1?
  234. Spraying 4.10s
  235. ??? FOGGER SYSTEM FOR LS1?????
  236. Sprayed it for the first time
  237. Well, I did it.
  238. when to cut off MSD switch?
  239. HELP ME DECIDE WHEN TO CUT OFF NITROUS WITH WINDOW SWITCH!
  240. Well, its April . . . any word on the NXL system yet?
  241. NXL vs. "standard" DP
  242. Oil Dipstick pops up after nitrous run
  243. NITROUS QUESTIONS
  244. Anyone have their FPSS wired this way?
  245. harlan window switch wiring
  246. Bad day at the dyno with a 5177
  247. NOS vs NX Kits?
  248. Car is hard to start after nitrous run. Have ?
  249. Have great pictures of my new TNT kit installed!
  250. Direct port not necessary for only 100 shot?
